Parasound Owners Thread - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 709Likes
post #6301 of 6405 Old 03-12-2019, 09:35 PM
jima4a's Avatar
Quoted: 430 Post(s)
Liked: 210
Originally Posted by mzs22 View Post
The A52+ seems to be a very nice amp, after adding two more atmos speakers two my system I was thinking about adding the 52+ to my system to take some of the load off my receiver but not sure if I can configure the amp with my receiver.
What receiver? Assuming it has preamp outs.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is online now
post #6302 of 6405 Old 03-13-2019, 05:25 PM
mzs22's Avatar
Quoted: 225 Post(s)
Liked: 91
I have a Yamaha 3060 but the manual isn't very clear when it comes to adding external amps. I have a two channel amp running my towers.I know you can use a two channel amp for the front towers or rear presence. I would like to ad a five channel amp if possible.
mzs22 is offline
post #6303 of 6405 Old 03-13-2019, 09:40 PM
jima4a's Avatar
Quoted: 430 Post(s)
Liked: 210
I don’t see any issues. See page 40 of the manual. Just be sure not to hook up speakers to any channels that use the pre outs.
post #6304 of 6405 Old 03-14-2019, 05:13 PM
mzs22's Avatar
Quoted: 225 Post(s)
Liked: 91
I wasn't sure if I would have to change the amp assign or just hook the amp up to the pre outs.
mzs22 is offline
post #6305 of 6405 Old 03-21-2019, 02:20 PM
Jarrod2750's Avatar
Quoted: 40 Post(s)
Liked: 29
Sensitivity Switch question
I have the a21. To make the audio turn on feature work at lower audio levels, should I be turning the dial counter clockwise towards the 12 value?
Marantz AV8805, Parasound Halo a21, (2)Parasound 2250, Parasound 275, Panamax 5400PM
Klipsch Epic CF3 V1, KV 4, (4) RP250S,(2)RP140S (2)CDT5650
LG Oled 65C8,Oppo 205, Pro-ject 2xperience Classic w/Music Hall speed Control
Cambridge Audio Azur 851N, Harmony Ultimate
Jarrod2750 is online now
post #6306 of 6405 Old 03-22-2019, 01:13 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 78
The dial is a sensitivity dial. full counter clockwise is at its most sensitive position. This will trigger the amp on with a lower signal. Sometimes if there are spikes in the AC from other appliances turning on or off it can false trigger the amp to turn itself on when no audio signal is present. If this is the case then using the 12V trigger is recommended. In most scenarios 12V triggers are more dependable then any type of audio sensing triggers.
Chris
Parasound Products Inc.
2250 Mckinnon Ave.
San Francisco CA 94124
415-397-7100
WAFWarrior is offline
post #6307 of 6405 Old 03-24-2019, 11:02 AM
084runnerltd's Avatar
Quoted: 76 Post(s)
Liked: 43
I am running a Denon but recently bought the A21.
Yes, crank the dials on the back to the maximum position. (It should actually say, “THX level” or something like that.
When I first bought the A21 and hooked it up, I was very disappointed as I didn’t notice anything and figured that I did something wrong.
Once I cranked the dials up, things changed for the better.
Jive Turkey likes this.
084runnerltd is offline
post #6308 of 6405 Old 03-24-2019, 11:05 AM
Delija's Avatar
Quoted: 394 Post(s)
Liked: 266
He's not talking about the gain - he's talking about auto turn on sensitivity.
WAFWarrior likes this.
Anthem MRX 720 | Parasound Halo A21
Dynaudio Contour 60 | Dynaudio Excite X28 | Dynaudio Emit M20 | 2x SVS SB16-Ultra
LG OLED65C7V
Delija is offline
post #6309 of 6405 Old 03-25-2019, 03:49 AM
Quoted: 712 Post(s)
Liked: 280
For audio trigger, the A 21 manual recommends starting at 12 o'clock, making sure the switch is in the up position. I suspect counter clockwise may be less sensitive, clockwise more sensitive, but I've never tried moving from top dead center on my previous A 21 or current JC 1s.
dbphd is offline
post #6310 of 6405 Old 03-25-2019, 12:47 PM
Quoted: 386 Post(s)
Hi
I am wondering what amp is considered better the a23 or the 2250v2? They are similarly priced and am not sure. Thanks
Raiders4life12 is offline
post #6311 of 6405 Old 03-25-2019, 12:48 PM
WAFWarrior's Avatar
Quoted: 140 Post(s)
Liked: 78
Just to clarify, there have been postings that are talking about 2 different topics.
1.Auto turn on by audio sensing and the sensitivity control.
1. The auto turn on by audio sensing. The sensitivity control is at its most sensitive position when turned fully counter clockwise. This means a lower volume (or mV) signal will trigger the amp to turn on.
2. Input attenuation controls labeled "gain" on the rear panel.
2. The rear panel channel input attenuators. or gain controls on the Halo A21 are labeled THX Reference at the max or fully clockwise position.
Let me know if you have any specific questions about this or anything else Parasound related. When in doubt call your local authorized dealer or Parasound's tech department. 415-397-7100
Chris
2250 Mckinnon Ave.
415-397-7100
post #6312 of 6405 Old 03-25-2019, 05:59 PM
BharatH's Avatar
Need some advice on amp upgrade advice for my dolby atmos heights. Setup is in my signature
I am currently using an old Krell KAV-500 and i am not sure how long it is going to last. My issue with the Krell is that it runs extremely hot, more than my A21 even when not in use. I am not sure i want to invest another $600 in sending it for servicing.
Here are my options
1) Get an A51 and migrate the A52+ to handle the heights (Will need to add additional cooling as i have heard the A51 does run warm).
2) Get another A52+
3) Get 2 x A23+
4) Do nothing until something happens to the Krell
I am looking for the best option in terms on value and at the moment leaning towards #2 or #3 though i don't want to look away from #1 .
Please let me know if it would be best to create a separate thread for this.
Paradigm 100v5, cc690, Prestige 25s, Studio 10v5, Prestige B, Rythmik 2x FV15HP
Anthem AVM60, Parasound A21 (LR), A52+, Krell KAV-500 (Heights)
Sony Hw50ES, Oppo BDP-105D, Apple Tv 4K, Tivo Mini, Panasonic UB820
Ac Infinity rackmount cooling, Stewart 120"
BharatH is offline
post #6313 of 6405 Old 03-28-2019, 05:08 AM
Kothoga's Avatar
Quoted: 76 Post(s)
Liked: 131
Looking for advice; Hint6 or P6/A23+ combo for a 2 channel La Scala II setup? I've read some reviews where people think the separates preformed better even though the two are essentially the same.
Kothoga is offline
post #6314 of 6405 Old 03-28-2019, 10:07 PM
TheMadMilkman's Avatar
Quoted: 20 Post(s)
The A-23+ will have adjustable gain which, with the high sensitivity of the La Scalas, might be worthwhile.
I went with the separates myself, largely to have future flexibility if I ever chose to upgrade. I got the amp 2 days ago, and so far the combo has been wonderful.
TheMadMilkman is offline
post #6315 of 6405 Old 03-29-2019, 09:22 AM
Quoted: 386 Post(s)
Can anyone tell me the differences between the a23 and the 2250v2 new classic?
WLGeter likes this.
post #6316 of 6405 Old 04-01-2019, 03:35 PM
glennQNYC's Avatar
Quoted: 44 Post(s)
Liked: 51
The A23 is part of Parasound’s higher-end Halo line; where the 2250v2 is part of their more reasonably priced New Classic series. The A23 has around half as much power as the 2250... that’s why you are seeing them priced approximately the same.
dream in algorithms
twitter
glennQNYC is offline
post #6317 of 6405 Old 04-02-2019, 06:35 AM
asere's Avatar
Quoted: 1912 Post(s)
Liked: 589
I recently bought a Parasound HCA 1500A 2 Ch amp that is paired with my Denon x4200 receiver (Front L,R towers are connected to the Parasound).Yesterday I did A/B testing with movies and music and I could not hear a difference. Is there something I am missing or could it be that both amps are about the same?
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #6318 of 6405 Old 04-02-2019, 09:25 AM
Quoted: 386 Post(s)
Ok thanks
post #6319 of 6405 Old 04-02-2019, 11:35 AM
jima4a's Avatar
Quoted: 430 Post(s)
Liked: 210
I am not familiar with the HCA1500A but IMO preamp or processor has a bigger impact than amps on reasonable to drive speakers. In both cases, your Denon is acting as prepro ahead of either the Parasound amp or internal Denon amps. The other unknown is the preout section of the Denon.
What are your speakers and configuration? Off loading your Denon’s power supply might help on multichannel music. Have you tried that?
post #6320 of 6405 Old 04-02-2019, 11:41 AM
asere's Avatar
Liked: 589
I have SVS Prime towers crossed at 80hz. Also how do I off load the Denon power supply?
asere is offline
post #6321 of 6405 Old 04-02-2019, 03:24 PM
stash64's Avatar
Quoted: 591 Post(s)
Liked: 219
Using the outbd power amp takes burden off the AVR's power supply. I agree with Jim... It really depends a lot on the capability of your Denon AVR's pre-out section. You should be able to hear better dynamics, particularly with multi-channel sources and with difficult to drive speakers. And if it is a significant upgrade in amplification, you should also hear better resolution/detail.
Sean
stash64 is offline
post #6322 of 6405 Old 04-02-2019, 03:26 PM
Quoted: 386 Post(s)
Would the a23 still sound better even though it has higher thd and less wpc?
post #6323 of 6405 Old 04-02-2019, 05:04 PM
asere's Avatar
Liked: 589
I'll listen in multch between amps and see if I can tell.
Sent from my SM-G935P using Tapatalk
asere is offline
post #6324 of 6405 Old 04-02-2019, 08:36 PM
asere's Avatar
Liked: 589
Well I think I know why I dont hear a difference from my parasound hca 1500a 2ch amp and x4200. The LR do not come on while connected to the x4200. I'm not sure how long it's been like this but a week ago it was working. I know this because my kids watched Spongebob in stereo with the x4200.
This explains why I don't hear the difference. All this time while watching in atmos and going back and forth between amps it disguised the LR. The high levels created a phantom.
asere is offline
post #6325 of 6405 Old 04-02-2019, 09:28 PM
jima4a's Avatar
Quoted: 430 Post(s)
Liked: 210
Just to be certain you connect your left and right mains to either the Denon or Parasound and when connected to the Denon speaker terminals the RCAs to the 1500 are removed. And all power is off during switch outs. Assume the Parasound is set to manual on/off and not 12V trigger (or audio sensing if it has that). My A31 is set for 12 V trigger.
Edit: This was assuming you were doing AB comparisons with Denon alone vs with Parasound added.
post #6326 of 6405 Old 04-03-2019, 05:33 AM
asere's Avatar
Liked: 589
Yes the comparison was with Denon alone. With all units off I disconnected the speakers from the Parasound and connected them to the LR of the Denon and played Stereo and no sound. I even tried this with different inputs like BD, TV and such.
I then turned the Denon off and reconnected the speakers to the Parasound and turned on the Denon then the Parasound came on with the 12v trigger and I got sound in Stereo this time.
How often can a speaker terminal go bad?
asere is offline
post #6327 of 6405 Old 04-03-2019, 07:44 AM
jima4a's Avatar
Quoted: 430 Post(s)
Liked: 210
Assume there is a Denon thread for the X4200 - it may include multiple models. Try posting there. Batpig is the Forum’s expert on Denon receivers and likely will see it. I don’t know if this is an amp assign issue or your L&R internal amps are bad.
post #6328 of 6405 Old 04-03-2019, 12:52 PM
asere's Avatar
Liked: 589
I'll do that. I'll check again without the rca connected to the parasound. I'm not sure if I did that but either way I don't see why the rca would keep the denon from having audio because the parasound was off and the speakers were connected to the denon.
asere is offline
post #6329 of 6405 Old 04-03-2019, 06:41 PM
asere's Avatar
Liked: 589
I just found out the amp assign was off. Changed it and receiver has sound in stereo. Having said that.
Does anyone know how come I'm getting more bass in stereo mode from my denon receiver vs the parasound hca 1500a? The crossovers are the same and subs are off.
Edit: got the bass back. -/+ cables were crossed.
asere is offline
post #6330 of 6405 Old 04-10-2019, 11:27 AM
neulee's Avatar
Hi,
I just purchased a 2250 v2 and I have some questions maybe someone here can answer.
What, in electrical terms, does the speaker load switch actually do?
Does it limit current somehow in the 2 ohm position?
Does it change bias in some way?
Why does this switch even exist? I have never owned a piece of equipment with such a switch.
Warren
neulee is offline
Parasound , Parasound Products Inc , Parasound Classic 2100 Stereo Pre Amp
