Pioneer SC-25 and SC-27 Receiver Thread - Page 181 - AVS Forum | Home Theater Discussions And Reviews
 44Likes
post #5401 of 5432 Old 11-14-2018, 11:33 AM
meburdick's Avatar
Quoted: 1088 Post(s)
Liked: 443
Originally Posted by Hagar View Post
Thanks for the feedback.
Still can't seem to see why this cd input/ouput aren't active. Going from output to input on JVC CD record and viola, it should work, but doesn't.
Where's the tape monitor when you want it?
https://www.pioneerelectronics.com/S...ctions0421.pdf
Page 92, right-hand side.
meburdick is offline
post #5402 of 5432 Old 11-14-2018, 01:15 PM
Hagar's Avatar
Quoted: 12 Post(s)
You have no idea how many times I read that and feel somehow, I'm missing what I'm supposed to be doing.
I'm not sure if this part is what's screwing me up. Since I am trying to record from my PC home theater via HDMI into the SC27.
Keep in mind you can’t make a digital recording from an analog source or vice-versa, so make sure the components you are recording to/from are hooked up in the same way (see Connecting your equipment on page 20 for more on connections). Since the video converter is not available when making recordings (from the video OUT jacks) make sure to use the same type of video cable for connecting your recorder as you used to connect your video source (the one you want to record) to this receiver. For example, you must connect your recorder using Component video if your source has also been connected using Component video.
I have a 1018 VSX, think I'll try it.
Hagar is offline
post #5403 of 5432 Old 11-14-2018, 01:49 PM
meburdick's Avatar
Liked: 443
I believe that you have found the core of the problem... These AVR's do not provide signal conversion between analog and digital, although it MAY provide that conversion for whatever you send in to be output via the HDMI connection.
Try recording something off of the radio. If that works, you've found the issue.
post #5404 of 5432 Old 11-14-2018, 01:57 PM
Hagar's Avatar
Quoted: 12 Post(s)
Radio worked! WTD
Hagar is offline
post #5405 of 5432 Old 11-14-2018, 02:07 PM
meburdick's Avatar
Liked: 443
Radio worked! WTD
The "lack of DAC" is your problem, then.
post #5406 of 5432 Old 11-14-2018, 09:51 PM
Hagar's Avatar
Quoted: 12 Post(s)
Thanks, but what I did to complecate things was I have a ASUS XONAR HDAV DLX in the home theater PC and that going to my receiver. Wouldnt that constitue a dac?
Don't know why I keep the ASUS and just go direct HDMI video card but I don't.
Hagar is offline
post #5407 of 5432 Old 11-15-2018, 06:24 AM
meburdick's Avatar
Liked: 443
What I was referring to was the lack of a Digital to Analog Converter within the AVR for converting the incoming digital source signal to an analog signal so that you can record it with your tape deck.
post #5408 of 5432 Old 12-21-2018, 11:48 AM
Hagar's Avatar
Quoted: 12 Post(s)
I gave up on recording cassetts. Can't get their from here.
But I wanted to know does this receiver support ARC (Audio Return Channel)?
Reading pg 29 of the manual, I suspect it does not.
The sound of the TV cannot be heard over the receiver
if the TV is connected using an HDMI cable.
If you want to listen to the sound of the TV over the
receiver, connect the receiver and TV with audio
cables.
Hagar is offline
post #5409 of 5432 Old 12-21-2018, 12:17 PM
DonH50's Avatar
Quoted: 3449 Post(s)
Liked: 3646
I gave mine to my son but I am pretty sure the SC-25/27 pre-dates ARC, at least in the Pioneer line-up. That came in a later version of the HDMI spec than these support.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #5410 of 5432 Old 12-21-2018, 12:22 PM
Hagar's Avatar
Quoted: 12 Post(s)
You know, I just watched a video on SACD's. How you had to buy a new capable CD/DVD player to play them and then also had to buy or have a capable receiver and so on.
And then's Stereo to 5.1, 7.1 and so on. Atmos, new player and new receiver plus more speakers, want 3d, new tv (projector) plus the glasses and other.
Now its 4k! New receiver, new tv (projector) 3d died I guess.
I want off...
Hagar is offline
post #5411 of 5432 Old 12-21-2018, 12:25 PM
meburdick's Avatar
Liked: 443
SC-25/27 is HDMI 1.3 compliant. ARC requires HDMI 1.4
Phantom Stranger likes this.
post #5412 of 5432 Old 12-22-2018, 07:44 AM
Dale124's Avatar
Quoted: 62 Post(s)
Liked: 75
Hi guys. It’s been quite a while since I have checked this thread, but hopped on this morning with a question. I have the SC25, and it has been great, but with the advance in technology, I feel I may be suffering from FOMO (fear of missing out). I had jumped into the 4 k world last year with my tv, blu Ray player and 4k Apple TV. My blu Ray player is the Oppo 203, which has 2 hdmi outputs, one for audio to the receiver, and one to the tv. The problem is that my Apple TV has to go up to my tv first, and I use an optical cable to come back to the receiver for audio, which of course, limits the audio options I have. I was thinking about getting a new receiver that passes 4k signals, unless you all have a different suggestion. I was looking at the Marantz SR7013, which is on sale at a local audio shop. It seems like it is a good choice for what I need.
Any thoughts would be appreciated
Dale.
Dale124 is offline
post #5413 of 5432 Old 12-22-2018, 12:59 PM
RickD1225's Avatar
Quoted: 343 Post(s)
Liked: 2862
I recently moved from the SC 25 to a Marantz SR6012 when I upgraded to 4K and Dolby ATMs. I really like it. With two 18” Subs the high end Audyssey MultiEQ XT32 really shines. I also needed the Pre outs as I have a 200 w/c Rotel power amp.
Spoiler!
RickD1225 is online now
post #5414 of 5432 Old 01-21-2019, 05:56 PM
higrpwdd's Avatar
Hey all.. I have a question about my SC-25. I recently bought the Marantz 7012.. loved it in movie mode was super clear..sounded great! Just couldn't get it to add any bass to my fronts when I wanted to listen to 2-channel stereo so I sent it back and hooked this back up. I am still happy with it just thought I needed to upgrade due to the 4k tv and I was possibly missing something. So back to the Pioneer. I have an ethernet cable hooked up to this but I can't seem to find the area under 'home media' where its supposed to get me to where i can get the latest firmware update. I get there but there is nothing that is for updating the unit. Any help?
I'm going to go out on Wed and look at some McIntosh block amps to see if they can help run my front speakers, Acoustic Zen Adagios. I can't seem to get them to sound like what they should. I'm looking for that warm tube sound out of them.. can't get that from this receiver. I think I can hook them up to this receiver..
higrpwdd is offline
post #5415 of 5432 Old 01-22-2019, 02:49 PM
Phantom Stranger's Avatar
Quoted: 620 Post(s)
Liked: 695
This unit has been out awhile. I wonder if the server for firmware updates is still available.
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #5416 of 5432 Old 01-23-2019, 06:01 PM
bbassinger's Avatar
This unit had to be updated via usb drive. It did not have internet accessible firmware updates to my knowledge. I had to have a service center create the usb for me many years ago for an update when I needed it. I don’t think they listed them online.
bbassinger is offline
post #5417 of 5432 Old 01-23-2019, 07:21 PM
DonH50's Avatar
Liked: 3646
+1. There was never a user core FW release AFAIK. You had to ship/take it to a service center. There was an AVS poster providing the updates and a detailed instruction set to install it but you did so at your own risk. I did successfully install a couple of the updates to resolve a few issues I had with it. The Home Media update is different. There is (was) also SW to allow you to grab more detail from the MCCAC runs but it did not allow you to modify and restore them (as I had really hoped!)
Edit: Google shows a few sites with FW if you care to try it.
DonH50 is offline
post #5418 of 5432 Old 07-18-2019, 06:15 AM
Kimwyn's Avatar
Quoted: 78 Post(s)
Liked: 34
This thread has been inactive for a while (to my detriment) but as I am getting back into audio after a 6 year sabbatical, I need to know if I have any reason to update my SC-27.
Let me clearly state, I do NOT need 4k, atmos or DTS X. Neither am I running any form of UHD material. My uses will be strictly blu ray with true HD and DTS MA. I do not have a 4k TV nor the likes. Do i need to upgrade my SC-27?
Kimwyn is offline
post #5419 of 5432 Old 07-18-2019, 05:36 PM
DonH50's Avatar
Liked: 3646
If I followed that, then no reason to update. My son is happily using my old SC-27.
DonH50 is offline
post #5420 of 5432 Old 07-19-2019, 05:14 AM
n3tfury's Avatar
Your S key is terrible
You don't need to do a thing other than enjoy the unit.
n3tfury is offline
post #5421 of 5432 Old 07-19-2019, 05:19 AM
Kimwyn's Avatar
Quoted: 78 Post(s)
Liked: 34
I've had persons say that but I cant see it for myself. On my screen everything looks fine. I'm using the app, maybe that's why.
But thanks anyway.
Kimwyn is offline
post #5422 of 5432 Old 07-19-2019, 10:11 PM
n3tfury's Avatar
But thanks anyway.
So you can see.
n3tfury is offline
post #5423 of 5432 Old 07-20-2019, 09:28 AM
DonH50's Avatar
Liked: 3646
It's been discussed elsewhere and appears to be a bug in the phone OS.
DonH50 is offline
post #5424 of 5432 Old 07-30-2019, 11:24 AM
fussy's Avatar
Playing FLAC files on SC-27
Between a CD player failure (in a system that also plays files from USB) and getting a car that plays music from a USB stick, I've finally given in to ripping my CDs. My FLAC files play fine (and sound great) in those systems.
My SC-27 won't 'see' FLAC files on a USB stick. [does see (and play) MP3 files]
Yesterday I set up HMG access to my laptop and tried streaming my FLAC files . . No go --folders full of FLAC files show up as "empty". [my MP3 files will display and play]
Is there something special I need to do to play FLAC on the SC-27?
fussy is offline
post #5425 of 5432 Old 11-07-2019, 04:01 PM
Kimwyn's Avatar
Quoted: 78 Post(s)
Liked: 34
Long time owner of the SC27. So long that this is the first time using it in about 5 years. I bought it as soon as it released and loved it to death. Everything seems to be working amazing still and the sound is still as sweet as ever.
But of course, there is one issue and that's why I'm here. This is the first time I'm using it for 7 channels as I only ran 5 before. The SBL is working but the SBR isnt. I checked to make sure it wasnt the speaker itself, but the speaker works when I put it on another channel. I made sure to go to speaker setup and make sure the setup is set to surround back normal as well as to make sure it recognizes two surround back speakers. When I run a manual test, output comes from the SBL but not the SBR. So i am sure it's that channel.
Can anyone tell me why this would happen? Also, would it be that the amp for that channel is dead? Also, in running 7.1 material, is that channel even that necessary? Could i live without it? Please let me know your thoughts.
Kimwyn is offline
post #5426 of 5432 Old 11-07-2019, 04:05 PM
RickD1225's Avatar
Quoted: 343 Post(s)
Liked: 2862
Sounds like a blown amp on that channel. The SB speakers are the least used. I think you could run a 6.1 with a single back channel. I have a SC- 25 that I am still using on my back patio for music and TV.
shivaji likes this.
Spoiler!
post #5427 of 5432 Old 11-07-2019, 04:31 PM
Kimwyn's Avatar
Quoted: 78 Post(s)
Liked: 34
Thanks for that and that is what I was thinking. But how could the amp be blown if it was never even used? I've never connected anything to that binding post.
Kimwyn is offline
post #5428 of 5432 Old 11-07-2019, 06:45 PM
RickD1225's Avatar
Quoted: 343 Post(s)
Liked: 2862
That is a good question and I have no answer. Have you run MCACC and it didn’t excite that speaker?
Spoiler!
post #5429 of 5432 Old 11-08-2019, 06:13 AM
Kimwyn's Avatar
Quoted: 78 Post(s)
Liked: 34
That is a good question and I have no answer. Have you run MCACC and it didn’️t excite that speaker?
No I haven't as yet but I don't think that would make a difference because the system recognizes the speaker on the screen.
Kimwyn is offline
post #5430 of 5432 Old 11-08-2019, 07:18 AM
shivaji's Avatar
Quoted: 1355 Post(s)
Liked: 1390
it very well could be that the rear channel is not working for one reason or another and you could easily live without it. The next thing to look at is the wire and its connection point at the backs of the SC27. If you are using banana plugs or similar, make sure that that the terminations are tight and plugged in securely at the receiver and speaker. Not much else you can do. The suggestion of running mcaac, was just an idea to see if the SC would pump sound through that particular speaker while it was doing its thing.
shivaji is offline
