The "Official" Denon AVR-4311CI/AVR-A100 thread [NO PRICE TALK] - Page 839 - AVS Forum | Home Theater Discussions And Reviews
 2509Likes
post #25141 of 25164 Old 07-08-2019, 03:09 PM
MRAYB's Avatar
Quoted: 322 Post(s)
Liked: 728
Just saw your reply. Like you were sending it to me. You like the 4400?
MRAYB is online now
post #25142 of 25164 Old 07-08-2019, 08:17 PM
giomania's Avatar
Quoted: 770 Post(s)
Liked: 495
Originally Posted by gnirlum View Post
I feared that was the reality that I was going to have to accept. Already upgraded main system to a 4400 last winter (primarily for 4K). Our second system was happier with the 4311 but has not been downgraded to an even older Onkyo.
If you are interested, I just retired a 4311. I have an Audyssey Pro license for it, as well as a Pro kit.
Sent from my iPhone using Tapatalk Pro
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is online now
post #25143 of 25164 Old 09-08-2019, 12:28 PM
Osamede's Avatar
Quoted: 72 Post(s)
Liked: 53
How does the sound quality on Denon 4311 hold up compared to a 3-4 year old used low-midrange receiver? I just need 2.0 or 2.1 for film/TV/music in a small room, to power some Sonus Faber Toy Towers and maybe a sub i necessary,
Osamede is offline
post #25144 of 25164 Old 11-09-2019, 08:07 AM
Daffypuck's Avatar
Quoted: 60 Post(s)
Much better inmo.
Daffypuck is offline
post #25145 of 25164 Old 11-09-2019, 11:10 AM
jdsmoothie's Avatar
Quoted: 23179 Post(s)
Liked: 12714
As a former "flagship" model that uses Audyssey MultEQ XT32, it should still compare quite well, especially to non-XT32 models if using Audyssey.
jdsmoothie is offline
post #25146 of 25164 Old 11-16-2019, 09:22 PM
swilson317's Avatar
Zone 2 & 3 suddenly silent
Today, I had zone 3 on for music in the backyard. When I came inside, I turned off zone 3 and attempted to turn on zone 2. I heard nothing. I then tested zone 3 again. Nothing. Unless I'm missing something simple, it seems that I lost the amps for zone 2 & 3.
I can't remember when I bought this receiver, but it was my first multi zone AV receiver. It has served me well over the years.
I did use a small speaker to test the terminals right on the back of the receiver. I confirmed that both zone 2 & 3 were on, but I got nothing from the terminals.
Anyone have any further troubleshooting suggestions or does it sound like I need to find a repair shop? I'm not quite ready to replace this receiver unless the repairs are cost prohibitive!
Thanks, Steve
swilson317 is offline
post #25147 of 25164 Old 11-16-2019, 09:49 PM
swilson317's Avatar
Thanks, Steve
Good news! I vaguely remembered that there is a reset procedure. I found it on page 138 of the PDF manual! YAY! The reset restored audio back to zone 2 & 3. I just had to reassign the amps and rename the zones.
Thanks, Steve
post #25148 of 25164 Old 12-01-2019, 08:13 AM
Darin's Avatar
Quoted: 105 Post(s)
Liked: 110
I'm having some CEC issues between my 4311 and my Samsung Q90, so cross-posting here in case anyone has any suggestions. I just bought a Panasonic UHD Blu-ray player. Since the 4311 can't handle 4k/HDR, I made sure to buy a player with dual HDMI outputs so I could run the video straight to the TV, and audio to the AVR. But CEC is getting in the way. If I set the TV's input to the Blu-ray player, it automatically sets the AVR's input to to the TV for ARC. If I set the AVR back to the proper audio input for the blu-ray playter, the TV automatically switches to the input from the AVR. It seems IMPOSSIBLE to individually choose an audio source for the AVR and a video source for the TV unless I go in to the settings in the TV and disable Anynet AND go into the settings on the AVR and turn off HDMI control. But if I do that, neither the TV nor the receiver allow me to use ARC to get audio from the TV back to the AVR. The vast majority of our watching is sourced from the TV (broadcast or streaming via the TV), so I need audio returned to the AVR most of the time. I suppose an alternative is to use a separate digital audio connection back to the AVR, though I don't have a spare optical input. Perhaps I could juggle some things, but even if I did that, I'd be giving up higher audio formats from Netflix, etc. Is my only other option going into the set-up menus for both the AVR and TV and disabling CEC every time I want to watch a blu-ray, then going back in and re-enabling it when I'm done?!?
Has anyone else run in to this and have a work-around?
Darin is offline
post #25149 of 25164 Old 12-01-2019, 11:03 AM
duc135's Avatar
Quoted: 356 Post(s)
Liked: 445
Have you tried just using one HDMI from the UHD player to the TV? I have a similar setup as you, but instead of the Samsung and Panasonic, I have a Sony TV and LG UHD player. I have the LG connected directly to the TV then use ARC to send the audio back to the 4311. I also have other UHD devices connected directly to the TV and use ARC for all those as well. When I turn on the devices the TV will automatically change inputs and the 4311 input remains on TV for the audio. If I turn off the 4311 then the TV will automatically switch to the internal speakers.
duc135 is online now
post #25150 of 25164 Old 12-01-2019, 11:15 AM
Darin's Avatar
Quoted: 105 Post(s)
Liked: 110
Thanks for the reply. No, I'm sure that would solve the switching issue, but the whole point was maintaining full quality. Since neither the Q90 nor the 4311 support eARC, it can't pass the full quality uncompressed multi-channel audio streams via ARC. It would have to use something lower. There have been rumors that the Q90 would receive an eARC update, but even if it does, I doubt the 4311 will, considering it's age.
Darin is offline
post #25151 of 25164 Old 12-01-2019, 11:37 AM
duc135's Avatar
Quoted: 356 Post(s)
Liked: 445
In that case, get a programmable remote and ditch ARC altogether. ARC is working as designed in your case. ARC has no way of knowing that you're splitting the signals to two different devices. As far as I know, the only way to do what you want is manually set the inputs. The other option would be to get a new AVR that does 4K passthrough.
post #25152 of 25164 Old 12-01-2019, 11:49 AM
Darin's Avatar
Quoted: 105 Post(s)
Liked: 110
Yeah, I have one, the problem is I can't find a way to disable the auto-switching part of CEC while keeping ARC. Most of our viewing is TV content... OTA, streaming apps in the TV, etc., and the only way to get that audio back to the receiver at the best quality possible (keeping DD+, etc.) is via ARC. It just boggles my mind that higher end products don't consider that you might be using programmable remotes or other external control components, and maybe don't want HDMI making my switching decisions.
Darin is offline
post #25153 of 25164 Old 12-01-2019, 11:59 AM
duc135's Avatar
Quoted: 356 Post(s)
Liked: 445
The 4311 has assignable 2 optical and 2 coax digital inputs. Can any of your other devices be switched to the coax or analog RCA inputs? That would free up one of the optical inputs for the TV. Then you can disable ARC and use the remote for turning on your devices and switching to the proper inputs.
If not, you can get an optical splitter box like this one. Just make sure only one source device is on at a time.
post #25154 of 25164 Old 12-01-2019, 02:12 PM
Darin's Avatar
Quoted: 105 Post(s)
Liked: 110
Right, as I mentioned, that is an option, though I'd then lose out on higher audio formats from the TV, like DD+ in Netflix. I was hoping there was some trick to keep the receiving from changing inputs via CEC, but it sounds like there isn't.
Darin is offline
post #25155 of 25164 Old 12-25-2019, 08:30 PM
Liked: 0
Hello, not sure I am using the right thread.
My question is : if I buy a Dolby Atmos capable Bluray player (example the Panasonic UB9000), can I have the Atmos sound going through the 4311ci to the 7.1 speakers connected to it, using the receiver only as an amplifier? I am not sure how the Dolby Atmos is decoded by time the player and sent out.. would it be through hdmi?
Supersonick is offline
post #25156 of 25164 Old 12-25-2019, 10:39 PM
duc135's Avatar
Quoted: 356 Post(s)
Liked: 445
Yes it will work fine. The UHD player does not process the Atmos channels. It is passed in the bitstream for the 4311 to process via HDMI. Since the 4311 is not Atmos capable it will just ignore the additional Atmos channel information and will continue to process the 7.1 channels as it normally would.
post #25157 of 25164 Old 12-25-2019, 10:50 PM
MRAYB's Avatar
Quoted: 322 Post(s)
Liked: 728
Not being able to pass the newer sound mixes is one of the reasons I sold my 4311CI. That and more/better options for my zone 2. I miss the old girl. Hell of a receiver. Sold it to a co-worker who uses it just for music in his four bay garage/woodshop. Still sounds amazing. Replaced mine with an X4400H snagged new on Amazon for nearly half off. Well worth it.
MRAYB is online now
post #25158 of 25164 Old 12-26-2019, 08:22 AM
krabapple's Avatar
Quoted: 495 Post(s)
Liked: 470
THe UB9000 claims to be able to decode (process) Dolby Atmos. If you set the UB9000 to decode Dolby Atmos (rather than pass a bitstream), the decoded Dolby signal would be passed as PCM over HDMI. THe AVR does not have to be Atmos-decoding in that case. You would have to physically reconfigure a standard loudspeaker 7.1 setup -- reposition two of the surround speakers to make them height speakers.
krabapple is offline
post #25159 of 25164 Old 12-26-2019, 09:44 AM
duc135's Avatar
Quoted: 356 Post(s)
Liked: 445
Was not aware of that. Thanks for the info. However, if the OP set to bitstream he would still be okay. If bitstream doesn't have issues I would think that would be the preferred format as it lets the AVR/Prepro do the decoding. Not sure how the 4311 will react if he set to PCM in this case.
post #25160 of 25164 Old 12-26-2019, 01:43 PM
batpig's Avatar
Quoted: 4996 Post(s)
Liked: 5434
Do you have a citation for that? I just checked the manual and I don't see any mention of Atmos decoding internally. I've never heard of a player doing that.
MRAYB likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #25161 of 25164 Old 12-26-2019, 04:58 PM
krabapple's Avatar
Quoted: 495 Post(s)
Liked: 470
I was going by Product Specs on the Best Buy site, which say:
Surround sound decoders
Include Dolby Digital Plus, Dolby TrueHD, DTS-HD Master Audio, DTS-HD High Resolution, Dolby Atmos and DTS:X for an immersive listening experience.
https://www.bestbuy.com/site/panason...?skuId=6350371
post #25162 of 25164 Old 12-26-2019, 05:06 PM
batpig's Avatar
Liked: 5434
OK, I would not put any stock in that. On the actual Panasonic product page in the specs they note "Bitstream Ouput" for Atmos/DTS:X, as opposed to "Decode and Bistream Output" for the standard channel-based formats. Which is what you'd expect. I don't know of any BDP's that internally decode the Atmos bitstream.
krabapple likes this.
Setup Guide and FAQ
batpig is offline
post #25163 of 25164 Old 12-26-2019, 10:44 PM
Liked: 0
Thank you All. I think this last post have the answer I was looking for.. there is no internal decoding for Atmos in the player. So I’ll need to look for a proper receiver. !
post #25164 of 25164 Old 12-27-2019, 06:45 AM
miguelbarroso's Avatar
My 4311 is still holding strong... I do not see myself adding speakers to the ceeling, unless I had a dedicated room. My system is in the living room, so it needs to be quite inconspicuous. 5.1 is good enough
miguelbarroso is offline
Audyssey , AVR-4311CI , Denon , Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr A100 100th Anniversary 9 2 140w
