Official Integra DTR-20.3/30.3/40.3/50.3 Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #361 of 366 Old 07-23-2019, 06:54 PM
Quoted: 24 Post(s)
You question is very general, but assuming you have set the AVR to proper in put selection for the audio and have the Dune playing content like DTS or Dolby Thru HD there shouldn’t be an issue.
You should be able to see audio source on the screen.
B SUBASCHANDRA BOS is offline
post #362 of 366 Old 07-23-2019, 07:43 PM
bobknavs's Avatar
Quoted: 2332 Post(s)
Liked: 1663
Not sure what your issue might be, but an S/PDIF (coaxial or optical) cable does not pass high definition multichannel audio.
If the player and the AVR are configured correctly, HDMI is the way to go.
bobknavs is offline
post #363 of 366 Old 07-29-2019, 12:22 AM
moigpsrocks's Avatar
Quoted: 88 Post(s)
Receiver sound stopped working(Integra DTR 30.3)
My Receiver sound stopped working(Integra DTR 30.3).
I wanted to post pictures of the setup but this forum blocked my link to google photos.
Does anyone know if this is a common issues with Integra receivers?
moigpsrocks is offline
post #364 of 366 Old 07-29-2019, 01:50 PM
Quoted: 115 Post(s)
Liked: 44
What are the symptoms? Some of the most common are:
1) everything works but there is no sound - this typically means the DSP has failed - very common on the x0.3 generation
2) when you turn it on it shuts off and flashes the standby light - blown channel
3) when you touch the On button, absolutely nothing happens. No lights, no clicks.... nothing - main power relay failure
The DSP issue is well documented on this (and other forums). Your receiver is in the right age range for the chip to have worn out. Onkyo/Integra extended the warranty but it has now run out so I hope this isn't the issue. Regardless, any recommendations will need to comprehend what you mean by "stopped working".
TJMotter is online now
post #365 of 366 Old 10-13-2019, 08:06 PM
The_Nephilim1's Avatar
Quoted: 89 Post(s)
Liked: 24
I have what I think is the ultimate Dumb Question.. I just noticed 2 things about this AVR (40.3) one it only has 2 prongs on the power cord, and 2 it has a seperate Ground plug on the back..
Now I know thing should be grounded so is this ground intended to be hooked up by myself and grounded to my Electric Box's ground wires?? I believe the answer is yes but what size wire should I use?
The_Nephilim1 is offline
post #366 of 366 Old 10-14-2019, 08:57 AM
eriksells916's Avatar
Quoted: 507 Post(s)
Liked: 192
Most mid to high end receivers have the 2 prong detachable power cord.
No, that ground on the back is for the phono (record player)
eriksells916 is offline
Integra
