The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ - Page 399 - AVS Forum | Home Theater Discussions And Reviews
 2424Likes
post #11941 of 11949 Old 09-04-2019, 06:18 AM
jdsmoothie's Avatar
Quoted: 22596 Post(s)
Liked: 12295
Originally Posted by DJLittleMike View Post
Oh, I didn't think about that. I'll have to take a look. If I find that DV is enabled still, is that an issue?
Not unless the AVR does not meet your required volume needs.
jdsmoothie is online now
post #11942 of 11949 Old 09-04-2019, 06:22 AM
DJLittleMike's Avatar
Sorry, maybe I wasn't clear. I meant that I used to keep the volume around 35. You said that's probably due to Dynamic Volume. Then maybe Dynamic Volume got turned off, so now I have to keep it around 50, which you said is normal. But if DV is turned *on* and I still have to go to 50 for sufficient volume, that means I'm turning it higher than I used to. Isn't that indicative of an issue?
DJLittleMike is offline
post #11943 of 11949 Old 09-04-2019, 06:34 AM
jdsmoothie's Avatar
Liked: 12295
You were very clear. You're using a 7 year old model. Although this may indicate the amp may be failing, as long as you're still able to achieve the volume level you prefer (without going over the recommended maximum of 80) then there's no issue for you.
post #11944 of 11949 Old 09-04-2019, 07:07 AM
Oh gotcha. So possibly an issue, but easily worked around by just turning the volume up. When I have my air conditioner running, I've had to bring it up to 70ish, but so far I haven't had to push it to 80. Hopefully that holds up.
If I did feel like replacing it, is there a direct successor to it (or maybe a few at this point, it IS 7 years old)?
post #11945 of 11949 Old 09-04-2019, 08:50 AM
jdsmoothie's Avatar
Liked: 12295
The current direct successor to your 1913 is the S950H which still uses the same Audyssey MultEQ. Review post 1 in each of the 2018 and 2019 Denon AVR Owner's threads to review feature differences between models to determine if you want a feature in a higher level model.
post #11946 of 11949 Old 09-04-2019, 08:55 AM
Thanks for your help. Yeah, with the newer versions of Audyssey, maybe a direct successor would not be the way to go. Haha. I'd love to integrate Google Assistant (I know support is limited for the time being, but expected to improve). I'll poke around. Maybe I can get a good deal on A4L and upgrade while I'm at it.
post #11947 of 11949 Old 09-04-2019, 09:00 AM
jdsmoothie's Avatar
Liked: 12295
The different versions of Audyssey (ie. MultEQ, XT, XT32) have been available since 2010. The major change has been that XT32 has moved down to the X3000 series in 2016.
post #11948 of 11949 Old 09-04-2019, 09:12 AM
Right. At the time, getting XT32 would cost me a lot more than I paid for the 1913. But now, I can get it on a lower model, so it's a cheaper upgrade path. There are so many model numbers to keep track of. I think I was looking at the X3500 yesterday. That one might hit all the features I'd be interested in.
post #11949 of 11949 Old 10-06-2019, 06:27 PM
Ryan25's Avatar
Scored a 2113 for $75
No diff from the original MSRP, but sounds so much better. 4K & pre-outs FTW.
Ryan25 is offline
Denon , denon 2113 , Denon Avr 1513 Receiver , Denon Avr 1613 Receiver , Denon Avr 1713 Receiver , Denon Avr 1913 Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 3313ci Receiver
