The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 443 - AVS Forum | Home Theater Discussions And Reviews
 19788Likes
post #13261 of 13365 Old 05-07-2019, 04:29 PM
DoctorM's Avatar
Quoted: 856 Post(s)
Liked: 259
Most remotes I find claim to be a replacement for the original remote, and I can't say I care for the button layout. For one thing, the volume buttons are smaller.
DoctorM is offline
post #13262 of 13365 Old 05-07-2019, 04:34 PM
jdsmoothie's Avatar
Quoted: 22602 Post(s)
Liked: 12296
There's also the option of using a Logitech Harmony remote as well which would likely be able to control all of your devices (eg. 650 controls up to 8 devices).
jdsmoothie is offline
post #13263 of 13365 Old 05-18-2019, 08:05 AM
cyberguyjeff's Avatar
Quoted: 42 Post(s)
Liked: 60
SAVE Config question:
I'm successful in saving the config.dat file as the file size is 956kb and it has data in the file however the Denon never comes out of 'saving' mode. It will display saving until I eventually cycle the power off/on by pulling the AC plug. I did a soft reset before the save procedure and the IP Control is set to "Always ON", I didn't try set to "Off in Standby" if that might have some bearing. Just wondering if anybody else experience this?
She's so fine, there's no tellin' where the money went!
cyberguyjeff is offline
post #13264 of 13365 Old 05-21-2019, 06:14 PM
adrsuhen67's Avatar
Hi all, I just got used avr x4000 my front is def tech Bp200tl and have dedicated sub polk psw 505. What is the best way to connect my speaker when run auto calibration? I did tried twice but always got crossover for my front is 150hz. TIA
adrsuhen67 is offline
post #13265 of 13365 Old 05-21-2019, 06:48 PM
mdavej's Avatar
Quoted: 3074 Post(s)
Liked: 1394
Turn the sub down. Cal is probably sensing too much from the sub and not enough from the front.
mdavej is online now
post #13266 of 13365 Old 05-21-2019, 06:58 PM
adrsuhen67's Avatar
You meant the polk 505? I put volume level on my polk only at 1/4.
post #13267 of 13365 Old 05-22-2019, 03:09 AM
jdsmoothie's Avatar
Liked: 12296
Connect Front L/R speaker posts to the Def Tech L/R speakers and connect the sub pre-out 1 to the PSW505. Review the Audyssey FAQ below on how to get the best from Audyssey.
https://www.avsforum.com/forum/90-re...d-part-ii.html
post #13268 of 13365 Old 05-22-2019, 04:22 AM
adrsuhen67's Avatar
I did that twice, first I did without power in front L/R built in amp and second with power in front L/R built in amp and the result still same.
post #13269 of 13365 Old 05-22-2019, 05:16 AM
adrsuhen67's Avatar
Also my main goal is be able to use front L/R built in sub and dedicated sub on HT and built in sub only on stereo music.
post #13270 of 13365 Old 06-10-2019, 06:49 AM
Liked: 0
connecting Denon amp to senheiser headphones
hi there everyone, absolutely new to this forum and looking for some help. recently purchased a set of senheiser 175 wireless digital headphones for the times where things need to be watched and monsters should not be woken, however I was a little disappointed as im not sure I can digitally connect them to my current amp
I have a Denon AVRX 4000 which seems to have 2 optical audio points, yet both of them are input not output. The headphone sender unit has either a 3.5 analogue input or digital optical input. im wondering if anyone out there has any ideas as to weather I can connect these digitally. 2 other units I have (Foxtel and apple tv) both have optical outputs, yet this is a pain to switch the cable every time I need to change what im watching
any assistance would be greatly appreciated
Regards
Paul
Name:	denon rear view .png
ID:	2578278   Click image for larger version
Paul Vanderweide is offline
post #13271 of 13365 Old 06-10-2019, 03:45 PM
jdsmoothie's Avatar
Liked: 12296
Regards
Paul
Correct. Most AVRs generally no longer feature optical outputs. You have a couple of options to connect to the wireless transmitter:
(1) Connect the optical outputs from the Foxtel and ATV to an optical switch --> https://www.monoprice.com/product?p_...FcdUhgodrsoCiA
(2) Connect the Zone 2 pre-outs to an RCA --> 3.5mm adapter and set the AVR's surround mode to ALL ZONE STEREO.
post #13272 of 13365 Old 06-12-2019, 11:17 AM
holl_ands's Avatar
Quoted: 957 Post(s)
Liked: 527
Sennheiser FAQ says that RS-175 WL Headphones will only accept (Stereo) PCM Optical Input mode (NOT the usual default "BITSTREAM", i.e. Surround mode)....so there is NO advantage to using Optical Interface compared to simply using an adapter cable to connect RS-175's 3.5-mm Audio Input to your choice of Denon's Audio L/R RCA Output Jacks, which could be either Media Player L/R, Front L/R, Zone2 L/R or Zone3 L/R (as viewed from Left to Right on Rear Panel):
https://en-us.sennheiser.com/wireles...e-audio-rs-175
http://manuals.denon.com/AVRX4400H/N...SYultsfrsy.php [Denon Rear Panel Descriptions]
https://www.google.com/url?sa=t&rct=...ZSs6edeRqbaaSW [Denon User Manual]
Media Player L/R Output (and L/R Input) appears to be equivalent to the old TAPE IN/OUT connections....which would be ideal since it is at a constant signal level....so only have to use RS-175's Volume Control.
Front L/R Output is part of the Pre-Out block and would be under control of the Denon's Volume Control.....in addition to RS-175's Volume Control....so you are likely to be blasted out by the Sound Level when you go back to listening via Speakers [which would have to be Disabled for listening via Headphones...IF that is even possible]....so best to look elsewhere.
Zone2 L/R or Zone3 L/R RCA Jack Outputs are also viable alternatives with INDEPENDENT Volume Controls, although you would have to figure out how to configure your AVR:
http://manuals.denon.com/AVRX4400H/N...Ynqubzpha.php#
So I would ALSO recommend you use Zone2 (or Zone3) L/R RCA Jack Outputs....and adjust Zone2 (or Zone3) Output Level so that sound from headphones at Max Volume settings is just within "safe" listening level. At the RS-175's Transmitter Unit, use the AUDIO INPUT SELECTION switch to select either 3.5-mm Analog L/R Input or Optical Input....and an Optical Switch to select either Fostec or AppleTV.
IF you want a more automated system with a Remote Control, you COULD use something like the fol. 3-port Optical Switch where the Analog Audio L/R signal from the Denon first goes through an inexpensive Analog-to-Optical Converter, so RS-175 is always operated with Optical Input:
https://www.amazon.com/J-Tech-Digita.../dp/B00HQ2R38C [3-to-1 Optical Switch with R/C]
https://www.amazon.com/Digital-Optic.../dp/B01HERN6EI [L/R RCA Audio to Optical Converter]
holl_ands is offline
post #13273 of 13365 Old 06-13-2019, 05:42 PM
tdog4871's Avatar
Need help with E400
Just purchased a 2019 Samsung Q70R tv and while watching Netflix through TV the sound goes in and out because the receiver won't stay in Dolby. Makes watching impossible.
any suggestions????
I can watch through xbox or blu ray player with no issues.....just the app through the TV.
Update: I switched to optical and sound issue is re4solved, but how do I get the audio source to change when I pick the app? Ex. Loaded Netflix app and NBA game audio still playing while Netflix video playing. With ARC it of course switches audio to Netflix when app is loaded.
tdog4871 is offline
post #13274 of 13365 Old 06-13-2019, 09:08 PM
jdsmoothie's Avatar
Liked: 12296
Originally Posted by tdog4871 View Post
Need help with E400
any suggestions????
Press the "TV Audio" button on the remote.
post #13275 of 13365 Old 06-15-2019, 04:41 PM
tdog4871's Avatar
thank you!!
tdog4871 is offline
post #13276 of 13365 Old 06-16-2019, 10:07 AM
tdog4871's Avatar
JD, how can I get DTV remote to do volume when optical?
ARC obviously makes things a lot easier with one less remote.....not sure why I have sound issues with HDMI passthrough and Netflix.
tdog4871 is offline
post #13277 of 13365 Old 06-16-2019, 10:24 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1630
DirecTV remotes are programmable, so you just need to find the code for your model AVR.
https://www.directv.com/DTVAPP/conte...hread/11030941
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #13278 of 13365 Old 06-16-2019, 11:52 AM
mdavej's Avatar
Liked: 1394
Audio 1360 (31360) should work fine on most DirecTV, cable and one-for-all remotes.
Then set punch thru to the audio device. Works on older DTV remotes. But AVR control may have been removed from newer ones.
post #13279 of 13365 Old 06-20-2019, 09:51 AM
tdog4871's Avatar
thank you. Changing a TV after a few years is like starting all over. Much appreciated.
tdog4871 is offline
post #13280 of 13365 Old 07-29-2019, 09:24 AM
Liked: 1
Can my denon avr-x4000 auto select the sound mode based on the source?
Hi all
I want my amp to switch to 2.1 for music sources like tuner or internet radio then if I select blue ray or cable\sat it must automatically switch to 5.1. Can it do this and how?
I've just moved from a Yamaha amp to the demon and have it mostly sorted, but this I'm just not getting yet. Likely a learning curve issue but any advice would be appreciated.
Tia
Drew
DrewZA is offline
post #13281 of 13365 Old 07-29-2019, 09:37 AM
afrogt's Avatar
Quoted: 2177 Post(s)
Liked: 1442
Just select STEREO on the remote for those inputs like tuner and internet radio. It will remember that setting the next time you switch to it. I have 5 Denons in two homes and they all work the same way.
Now, if you have one single source that you use to watch movies, listen to Pandora, stream Netflix and Prime, etc then it would be difficult to have a default setting.
But my cable/sat, blu ray, dvd and media player input all automatically use multichannel sound such as Dolby D, DTS, True HD, Atmos depending on the signal. My CD and Internet radio input play in stereo.
Afro GT
afrogt is online now
post #13282 of 13365 Old 07-29-2019, 10:43 AM
jdsmoothie's Avatar
Liked: 12296
Use a Quick Select for each one up to 4.
post #13283 of 13365 Old 07-29-2019, 11:14 AM
Liked: 1
Thank you. That will sort me out nicely.
Next question: I bi amp my front mains. As soon as I select the bi amp option in the menu system it greys out the option to set up 2 channel sound so the stereo option disappears and I'm left with multi channel only across all sources. If I move to 5.1 plus b to get a bi amp effect but still have access to the 2 channel sound it comes with a couple of quirks like only running one front amp channel when I move to stereo... How do I get the bi amping done properly and still manage to go 2.1 when I need to?
DrewZA is offline
post #13284 of 13365 Old 07-29-2019, 12:13 PM
Liked: 1
OK managed to answer my own question by delving deeper into the user manual... The bit I was missing was that I needed to hold down the sound mode button on the remote until a selection menu pops up and then could select what I wanted.
Problem solved - now back to fine tuning each mode. Very pleased with the receiver so far. A worthy upgrade to the Yamaha.
DrewZA is offline
post #13285 of 13365 Old 07-29-2019, 03:33 PM
jdsmoothie's Avatar
Liked: 12296
Important to note that using a receiver's passive "bi-amp" mode is not likely to provide any real benefit, certainly not in additional power as there is only one power supply, but if you have the extra speaker wire, no harm in giving it a go.
post #13286 of 13365 Old 07-30-2019, 08:13 AM
Liked: 1
Yep - I have read this before, but I started bi-amping more out of (quite frankly) having something to do with those extra amp channels that I have no other use for and the recommendations of various hifi salespeople. I must say I think it does make a noticeable difference for me (Or perhaps it's all in my head!) - It just seems 'sweeter'. I'm not after massive volume, but rather that sweet atmospheric feel in the room.
So running the audyssey setup really made quite a hash of things and it took me a long while to find my way around and rectify everything. Well, perhaps that is putting it incorrectly. What it did was drop the levels on everything significantly except my rears. This tells me the amp feels my rears are underperforming and I should perhaps look at upgrading them.
My fronts are a pair of Paradigm Monitor 9's, centre is a Paradigm CC290, single sub - Paradigm PS-1000 and then the rears are simply a pair of smaller Jamo bookshelf speakers that are highly likely to be the cause of the Audyssey problem. Should I replace them with a matching set of Paradigm rears, do you think the Audyssey setup will be more inclined to get it right?
DrewZA is offline
post #13287 of 13365 Old 07-30-2019, 08:22 AM
jdsmoothie's Avatar
Liked: 12296
In most cases when a member posts that Audyssey didn't do a good job, it generally means the EQ was incorrectly run (perhaps positioning of the speakers or positioning of the mic).
Take some time to review the Audyssey FAQ ---> https://www.avsforum.com/forum/90-re...d-part-ii.html
DrewZA likes this.
post #13288 of 13365 Old 07-30-2019, 11:07 AM
Liked: 0
Help with AVR-X3000 iRadio functionality
First, I completely understand this receiver is pretty old, but in general its been fantastic for me and my family and I really don't want to replace it right now. This receiver is the main hub for all A/V right now in my family room, the place where my kids watch cartoons all the time and where my family and I want the majority of our TV, Movies, etc. It's also the unit we use for two zones while having friends and family over for parties etc. It's pretty important.
The receiver is running the most current version of firmware and I have reset the microprocessor once to troubleshoot, i've also done the simple unplug power about 200 times over the last couple months.
The trouble is that one of the most used features on this receiver, the iRadio/Network audio functionality is basically dead. No matter what I do, no matter how I use the receiver (via web controls, via AVR-Remote app, via actual remote or front controls), the minute I try to access iRadio or Network, the device attempts to play the last played iRadio station. The station plays fine, but I cannot select any other station or iRadio function. For example, using AVR-Remote, if I go into network and try to select Pandora, it starts play the previously played iRadio station and will never load pandora. If i browse the iRadio menu and select a different station, it continues to play the previous station and never starts the new select.
This is super frustrating and Denon has been less than helpful. I contacted the support which was a joke too. For one, I contacted their email address for support several times and never heard back, I called their phone number several times and got this absurd message that says "we're sorry, we have high call volume, try again later" and hangs up on me. I used to design IVR systems, that's a joke. Finally I submitted a case through their online support request system, and got a canned email that basically says "send it to our service center" which could have 4-6 week turn around. Seriously? Have zero entertainment in my main living space for that long.
Zero troubleshooting help from Denon. This is my third Denon receiver, may be my last if I have to replace it right now.
Any one experience similar iRadio issues and have some suggestions?
5280tunage is offline
post #13289 of 13365 Old 07-30-2019, 11:41 AM
jdsmoothie's Avatar
Liked: 12296
There's a lot of very helpful information provided in posts 1-7 of this thread. Refer to post 5 and do a "Network reset."
post #13290 of 13365 Old 07-30-2019, 12:45 PM
Liked: 1
And I did just that - read it top to tail, and you are quite correct - I have some homework to do before rerunning the setup according to spec. Thanks for the heads up - there's quite a bit I did not either understand properly or do correctly to get a proper result. There goes my weekend!
mrtickleuk likes this.
DrewZA is offline
airplay problems , apple 4k tv , assistance , Audyssey , avr , chromecast ultra , d&m firmware writer , dead , dead avr-x4000 , Denon , Denon Avr X4000 7 2 Channel Home Theater Receiver , denon avr-x4000 , Denon Avr4310ci Receiver , denon x2000 , denon x4000 , dolby digital plus , firmware , fuzz , google home , hdmi , hdmi handshake , lan , looking for help , netflix 5.1 , receiver , RS232 , support , x1000 , X3000 , zone 2
