The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 171 - AVS Forum | Home Theater Discussions And Reviews
 2892Likes
post #5101 of 5185 Old 08-31-2019, 04:04 PM
davidl81's Avatar
Quoted: 66 Post(s)
Liked: 47
Spotify was removed from all pre-HEOS models last year via a firmware update. Use Spotify Connect from your phone/tablet.
Can anyone confirm that spotify connect works on the SR7008 with the latest firmware? I am looking at buying a used one just to run some outdoor equipment, but I need two zones and spotify connect is needed.
Thanks, David
Emotiva RMC-1
Mirage OMD C-2 Center;Mirage OMD-28 Mains;Mirage OMD-5 Surrounds
Mirage OMD-R Rears;Mono-Price 8" Alpha in Ceiling X4;Dual PSA S1510DF Subs
Sony VPL-VW385ES
Emotiva XPA DR-2 (Mains);XPA-9 (5.4)
davidl81 is offline
post #5102 of 5185 Old 09-13-2019, 12:31 PM
davidl81's Avatar
Quoted: 66 Post(s)
Liked: 47
FYI,
I did buy a used SR7008 and after firmware update Spotify Connect works very well when connected to my home network.
Emotiva RMC-1
Sony VPL-VW385ES
davidl81 is offline
post #5103 of 5185 Old 09-19-2019, 11:00 PM
Liked: 0
Marantz SR6008 front right channel issue
Hello. Hoping someone can provide me some guidance to avoid a trip to a repair shop. I have a Marantz SR6008, bought new in 2014. Its front right channel is presenting a couple of issues: low volume and distorted sound. I am sure it’s the A/V because I switched the front speakers and the issue moved to the front left speaker - front right functioning as it should. I tried hard reset multiple times and cutting power as well. Did not work. There is no sign of rust or corrosion anywhere. The unit looks like new. I opened the unit, but given my complete lack of experience with A/V decided not to disassemble it.
Besides the front right channel, everything else works like a charm.
Any suggestion on what could be the problem and potential solution?
Gerardo Vidal is offline
post #5104 of 5185 Old 09-20-2019, 09:26 AM
jdsmoothie's Avatar
Quoted: 24248 Post(s)
Liked: 13479
Possibly amp failure. Repair shop.
jdsmoothie is offline
post #5105 of 5185 Old 09-24-2019, 02:25 PM
Quoted: 274 Post(s)
Liked: 156
Marantz SR6008 issue
My Marantz 6008 shows the display but apart from that it has stopped working. I have my Oppo BDP plugged into it and nothing is showing up on TV. Same for the cable tv box...I have HTBP via Naim UnitiStar but nothing is working. I checked all the HDMI cables and they are working fine.
Options button when pressed on Marantz remote, shows nothing. I can toggle between different inputs like CBL/SAT, BlueRay, AUX etc. but nothing shows up on TV. For the sound mode, it's only picking stereo and if I press MDAX, it shows not available.
Pls help.
Dynaudio Focus 260 | Focus 210C | Naim SN3| Naim ND5XS2 | Oppo- 93 BDP | Ansuz X Series Speaker Cables | Audioquest RCA Cables | Ansuz Mainz D8 Diamond
Matrixman18 is offline
post #5106 of 5185 Old 09-24-2019, 05:03 PM
jdsmoothie's Avatar
Liked: 13479
Pls help.
First troubleshooting step would be doing a "soft reset" by simply powering off every device and AVR and unplugging their respective power and HDMI cables for 10 minutes. Plug all back in and power on the TV first, pause 5 seconds, AVR, pause 5 seconds, source. If no joy, then refer to your Owner's manual and do a microprocessor reset.
If still no joy, then repair or replace with a more current model that can pass 4k.
post #5107 of 5185 Old 09-25-2019, 04:06 AM
altpensacola's Avatar
Quoted: 320 Post(s)
Liked: 191
Pls help.
Does anything work that does not go thru the HDMI? like radio FM or network web radio?
Music, more music.
altpensacola is offline
post #5108 of 5185 Old 09-25-2019, 09:22 AM
Quoted: 274 Post(s)
Liked: 156
Radio is not working. It keeps on flashing "Connect Wait..."
post #5109 of 5185 Old 10-09-2019, 05:30 PM
Liked: 0
Hello jdsmoothie (and others here willing to provide advice)
I took the receiver to a repair shop a couple of weeks ago... today they told me that they need to replace 15 transistors. Parts would cost $105 (according to them the transistors would be bought from Marantz) and $250 for labor, totalizing $350 to fix it. Sounds like quite a bit of money on transistors and quite a bit of labor to replace them, but I do not have experience to really assess that. Can anyone provide some guidance here? Does the fix price seem right or not?
post #5110 of 5185 Old 10-10-2019, 01:04 AM
jdsmoothie's Avatar
Liked: 13479
No comment on repair cost; however, considering a used SR6008 can be purchased for not much more than that, you would be better served putting that $350 towards a more current model with XT32 and newer features (eg. 4k).
post #5111 of 5185 Old 10-18-2019, 02:47 PM
Frank123's Avatar
Originally Posted by ronin22 View Post
Thanks JD - I think the light was blinking more like once a second and it's just weird to me because it's only happened twice.
I'll start checking out the items you mentioned though
Was there a solution/reason for this? Happened to me as well.
Frank123 is offline
post #5112 of 5185 Old 10-18-2019, 04:02 PM
Frank123's Avatar
Originally Posted by Ewingr View Post
I have a refurbished SR7008, and have had it a couple years. Almost from the start I have had times where it will click and shut off. Seems like a circuit protection thing. (Of course, I really have no idea).
I was going to ship it down to have it checked out, but it is very infrequent, so if it doesn't happen while at the shop, they won't know what to fix.
It's actually been a few months since it has happened, but today it did it, I turned it off, and back on, and it happened 4 times. I've had same results after an unplug and even a hard reset where I had to go through setup again.
Any thoughts?
Any luck figuring this out? My 7008 is doing same thing. Appreciate it.
Marantz SR-7008, Crown XLS-1502, Pioneer DV-578A, Technics SL-DD2; Polk Monitor70 mains, RTi-A5s s/s, CSi-A4, HTS12; Panamax 4310.
Frank123 is offline
post #5113 of 5185 Old 10-18-2019, 04:38 PM
Ewingr's Avatar
Quoted: 93 Post(s)
No. It still does it, but not often.
Ewingr is offline
post #5114 of 5185 Old 10-18-2019, 05:30 PM
Frank123's Avatar
OK thanks. Mine won’t stay on longer than 10 seconds. If I get it fixed I’ll let you know.
Frank123 is offline
post #5115 of 5185 Old 10-18-2019, 05:38 PM
Ewingr's Avatar
Quoted: 93 Post(s)
OK thanks. Mine won’️t stay on longer than 10 seconds. If I get it fixed I’️ll let you know.
Thanks. I appreciate it.
Good luck.
Ewingr is offline
post #5116 of 5185 Old 10-20-2019, 04:38 AM
Frank123's Avatar
Originally Posted by favian View Post
I appreciate your help. I figured out the manual was wrong with the biamp hook up drawing. The diagram onscreen showed different and that solved that issue.
I found out the same when I was wiring my 5.1 bi-amp + zone 2. Manual diagram is wrong, on-screen diagram is correct.
Frank123 is offline
post #5117 of 5185 Old 10-21-2019, 05:03 AM
Quoted: 320 Post(s)
Liked: 191
One thing I have found out with the 7008 is if it does shut down, and it seems there are a lot of things that can cause it to shut down, is I must wait at least 5 minutes or more to start it again, if not it will go right back out. This is of course if the shut down was caused by something not physical like a loose speaker connection.
Mine will even shut down if someone turns it off and I come in a turn it back on too soon, What is too soon? Even 15 minutes.
After several years of use, other times it has shut down on me:
When I turned on the TV and the 7008 at the same time.
When I plugged it into a new UPS.
When I turned it on before the computer hooked to it had booted up and that device was selected.
When I turned it on too fast after an update software.
When I plugged in a new subwoofer (nothing was wrong,) I just had to wait a few minutes more for some reason.
I can't even remember all the times it shut down. But each time I have to wait at least 5 10 minutes.
I now go ahead and unplug it each time.
I love the unit despite of this.
Music, more music.
post #5118 of 5185 Old 11-20-2019, 09:35 PM
Quoted: 27 Post(s)
OPPO UDP203 connected to SR5008. Peculiar audio dropout issue.
Can anyone shed light on this puzzling issue please:
I have HDMI1 out from an OPPO 203 connected directly to my LG TV 55E8 ARC in, and OPPO HDMI2 out (audio only) to the SR5008 AVR.
The OPPO HDMI Audio format is set to Bitstream and the SACD Output it is set to PCM (both as per OPPO recommendations).
All UHD BD, BD, DVDv, DVDa play just fine in the HDMI connection mode to the SR5008, however there is an issue with SACD and CD playback.
The problem is that within about 2-5 minutes of SACD or CD playback, a single short audio interruption (dropout) occurs. Once it happens, everything is OK until the end of play. If I insert another disc then it repeats, again only once.
Needless to say that the issue is not replicated through the multichannel analogue outputs for SACD playback, or digital (optical) output for CD playback from the OPPO to the corresponding inputs on the Marantz.
It makes no difference if the TV is on or off, or the HDMI cable to the TV is disconnected during SACD and CD playback.
It seems like an HDMI handshake issue between OPPO and Marantz, but not sure as all the video discs and DVDa have no issue whatsoever with HDMI connection.
I have asked OPPO to look at this for me, and have reported it and supplied a log file to them about 16 months ago.
They are dragging their feet as they have wound down to minimal engineers, and will drop out of support completely in the next few months. They have acknowledged an attempt at fixing the issue in firmware, but have not succeeded.
I am interested to know if anyone else has experienced this and is there a resolution from the SR5008 perspective?
eraniolo is offline
post #5119 of 5185 Old 11-22-2019, 06:18 AM
170watt's Avatar
Marantz SR5008 RDS
Sorry I post this here, I am not using this forum frequently, I apologize if it's the wrong spot.
My question is this: anyone knows how to select the RDS function on the FM? When I select option, while the input is on "Tuner", there is no such function on the list (no RDS, PTY, TP, Radio Text). Are there different versions with/without this functionality? By the way, located in Canada.
On another topic: I bought this used, and didn't (still don't) know much about its functionality. I was a bit concerned that it was hot/warm even during standby, until I realized that the zone2 was on. I think I've seen someone complaining about being hot while in standby, that's why I mentioned this.
170watt is offline
post #5120 of 5185 Old 11-23-2019, 08:07 AM
Quoted: 320 Post(s)
Liked: 191
I thought RDS Radio data was automatically displayed as long as you selected an HD FM station that provided that. There is something in the manual about HD1 or HD2 signals and options pages 70-74.
Music, more music.
post #5121 of 5185 Old 11-23-2019, 04:45 PM
170watt's Avatar
Thanks for your reply. I thought that too, but looks like this model does not have such functionality (although as per manual it should have). By the way, the reference to RDS is on pages 64-66 in the manual.
And as I mentioned, I don't see any RDS reference at all, when I check the option menu (that shows up on the TV display, when tuner input is selected). Wonder if it has to do with the fact that it's a Canadian model.
170watt is offline
post #5122 of 5185 Old 11-23-2019, 07:16 PM
Quoted: 320 Post(s)
Liked: 191
My manual is a PDF file.
I checked my tuner and discovered this for a local HD FM station, on the tuner there was one channel, but on the internet radio the same station had 2 regular HD signals and one HD2 signal, the HD2 signal shows the data. I don't use the tuner option much at all so am going to research more. I am in the US.
Music, more music.
post #5123 of 5185 Old 12-04-2019, 11:11 PM
stanjohn123's Avatar
Quoted: 24 Post(s)
Marant SR 6008 grounding issue, HELP Plz !
I am having a very strange problem with my SR 6008 all of a sudden. My wall sockets grounding is perfect as I do not have any grounding issue when I connect my TV to that socket. However if I connect my SR 6008 AVR to that same socket, my AVR gets grounding issue. I know this because, once my AVR is powered, if I place a tester on exterior screws of the AVR, there is power/current on it. Also when I tested all the speakers output, there is power coming out from both +ve and -ve (Black/Red) outputs as a result if I try to play some music there is too much static noise along with music.
The AVR's power cable is fine as I tested it too and there is phase / power coming out only from 1 phase side, no power comes out from the cables ground or neutral side.
I have attached photos of the problem so you can best understand the issue.
Can anyone tell me what the problem is and how I can solve it.
ID:	2649650   Click image for larger version
ID:	2649652   Click image for larger version
stanjohn123 is offline
post #5124 of 5185 Old 12-06-2019, 08:08 AM
Aardvark7rules's Avatar
Liked: 2
That is a scary looking problem you have there and I would be very careful working on this yourself. You shouldn't have any voltage potential difference between the case of your AVR and ground. I don't know what the other side of your probe is connected to but it can't be the same ground as the AVR. I know you said that you tested the AVR power cable but I would try another power cable. I would also test the AVR without anything else plugged into it in case you are having some strange problem with another device on another AC outlet with a different ground level? Try plugging the AVR into a different AC outlet to see if the problem stays with the AVR or the outlet. Perhaps there is an internal problem in the AVR that has disconnected the grounding inside of the AVR from the case... but all of this sounds potentially very dangerous and should be looked at by an electronic tech...
Good luck and be very careful!
Aardvark7rules is offline
post #5125 of 5185 Old 12-07-2019, 08:52 AM
Quoted: 24 Post(s)
Thanks for your reply. I tried 4 different cables and I had nothing hooked up to the receiver. Also to the same socket I had connected my TV and there was no issue at all. There seems to be a problem in the internals of the receiver only.
I did something else, I had connected a separate wire from the screws that you see in the photos and grounded it to another socket separately. This solved the earthing issue but the sound from my speakers were still bad, that is, I was getting a lot of weird static noises along with the music I tried to play. So something is definitely screwed in my AVR now.
post #5126 of 5185 Old 01-27-2020, 01:29 PM
Quoted: 18 Post(s)
Liked: 4
Hi All,
I have recently developed problem with internet radio on my SR6008. If I pick any of the options in internet radio I just get a ticker tape announcement saying "Go to marantzradio.com for further information about vTuner". It even plays this back as speech through the speakers! This happens no matter what I select, except for "Recently Played". In that section, internet stations play back fine!
This has only just started happening recently. Though potentially coincides with me turning the power off at the wall when I was testing some new smart meters. But it's connects to the internet fine, and works for the few stations in recently played.
Edit: Looking at the website, it seems they want $3 a year in order to use the internet radio indexing, so I guess that is it.
Richard Nutman is offline
post #5127 of 5185 Old 01-27-2020, 09:19 PM
jdsmoothie's Avatar
Liked: 13479
Originally Posted by Richard Nutman View Post
Hi All,
Correct. vTuner is no longer supported as it was replaced by TuneIn on more current models.
post #5128 of 5185 Old 01-27-2020, 10:41 PM
Deadbydawn71's Avatar
I haven’t had my 6008 connected to the net for about a year. It was connected through a co axel convertor back when I had cable tv. I asked for a direct ethernet cable that ran from my router, through the attic, and terminating behind my ent. center on the wall. The isp at the time was Verizon and this “Installer” said he didn’t go into attics. I am going to call and see if the new isp will do it or hire someone myself. I have no idea what updates I may have missed.
Deadbydawn71 is offline
post #5129 of 5185 Old 01-27-2020, 10:49 PM
torii's Avatar
Quoted: 4392 Post(s)
Liked: 2550
I dont know what updates you may expect...but with an avr this age I would be skeptical about subjecting it to bricking. my 7008 going strong w/out updates. now if hdmi got updated by firmware I might give it a go for sure.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #5130 of 5185 Old 01-27-2020, 11:08 PM
I know you know a lot about this but I thought the 6008 was 4K compatible ? It says (in my manual) the 6008 will let the 4K signal pass through the unit unchanged.
I have no experience with 4k but I thought it was a higher quality picture and that was it.
audio , avr , bass management , bluray , crossover , Marantz , Marantz Sr5008 , Marantz Sr6008 , Marantz Sr7008 , network , passhtough , passthrough , question , SR6008 , uhd
