Pioneer Sc-1522 upgrade to UMC-200/UPA-700 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 11-26-2013, 11:23 AM
HKPolkMe's Avatar
Originally Posted by GusGus748s View Post
I had the SC-1222, but I returned it and got the SC-1522 mainly for 12v triggers and 9.2 set up. Either one will work for what you want, but the SC-1222 doesn't have any 12v triggers, but the HK3700 does come with one 12v trigger. Emotiva is probably the best bang for your $$$ for an affordable amp. I ended up buying 2 Outlaws M2200, and 1 Outlaw M200 to power up my front 3 speakers. I like the Outlaw amps because they come with 12v triggers or you can use their MUSIC option, which pretty much turns on the amp as soonest any sound is being sent to it. It takes about a min. to shut down once you turn off your AVR.
From my understanding the 12V trigger, turns the connected external amp ON when the AVR is turned ON right? Otherwise, like the SC1222, I would need to turn ON the amp manually, right?
7.2 HT Setup:
***Polk RTIA9 / CSIA6 / FXIA6 / RTIA3**Dual PB-2000**Pioneer SC-1222K**Panasonic 65"VT60**Sony BDP-BX510***
HKPolkMe is offline
post #32 of 39 Old 11-26-2013, 11:47 AM
GusGus748s's Avatar
Quoted: 429 Post(s)
Liked: 706
Affirmative. 12v triggers turns on the amp when you turn on the AVR. Or you can use a smart power strip. I've got one of those, and it works well if you don't have 12v triggers. Or if you buy the Outlaw amps they have the music option, which pretty much acts as a 12v trigger.biggrin.gif
HKPolkMe likes this.
GusGus748s is offline
post #33 of 39 Old 11-26-2013, 01:14 PM
HKPolkMe's Avatar
Thank you sir! I'll have to check out those amps! I was actually looking at the emotiva or even the crown.
7.2 HT Setup:
HKPolkMe is offline
post #34 of 39 Old 11-26-2013, 01:33 PM
GusGus748s's Avatar
Quoted: 429 Post(s)
Liked: 706
Crown amps are good amps and inexpensive, but their cooling fan are loud. I had a QSC-GX3 and I just couldn't stand how loud the fan was. I ended up selling it. The Outlaw amps run cool and silent.
post #35 of 39 Old 11-26-2013, 01:58 PM
HKPolkMe's Avatar
Perfect! That's what I like to hear...experience from an owner! Thx again!
7.2 HT Setup:
HKPolkMe is offline
post #36 of 39 Old 11-26-2013, 02:13 PM
FMW
FMW's Avatar
Quoted: 1654 Post(s)
Liked: 1710
So do the amps in his AVR.
FMW is offline
post #37 of 39 Old 11-26-2013, 03:16 PM
HKPolkMe's Avatar
Just picked up the Pioneer SC-1222 from Costco for $399.99 plus tax...to run my 2.0 system that consist of the RTIA9s! Hoping to find a deal on a CSIA6 these next few days! If not, I'll just get it from the Polk EBay store. One question, do I still need to run the room correction thing with a 2.0???
7.2 HT Setup:
HKPolkMe is offline
post #38 of 39 Old 11-26-2013, 06:43 PM
GusGus748s's Avatar
Quoted: 429 Post(s)
Liked: 706
post #39 of 39 Old 11-27-2013, 06:55 PM
dfi85's Avatar
The 1222/1227 run pretty warm, maybe mine does because of where it is located in my rack. But that is one of the reason I went separates now.
dfi85 is offline
Pioneer Sc 1522k 9 2 Channel Av Receiver , Emotiva Upa 700 Seven Channel Power Amplifier , Emotiva Umc 200 7 1 Home Theater Preamp Surround Processor , Martin Logan
