Sc-1223 no dts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-23-2013, 06:58 AM - Thread Starter
paquettepack's Avatar
Hey all:
Just jumped on the great amazon deal the other day and got my new sc-1223. Sounds good, but I can't get it to show me that it's decoding a dts signal. With various blurays, I can get it to show me PCM or Dolby digital, but no dts, even when I select the dts hd audio on the bluray.
I have a Sony bdp-s5100 bluray player if that's the issue. I could find a obvious setting on the bluray player to fix this?
I am running a 5.1 setup.
Thanks for the help!
paquettepack is offline
post #2 of 5 Old 12-23-2013, 07:13 AM
ss9001's Avatar
Quoted: 653 Post(s)
Liked: 658
are you looking in the right place? assuming you have the player set to bitstream not decoding to PCM, it's there...
see # 3
LEAD Technologies Inc. V1.01
it's an indicator not the bold lights in the middle of the display.
and you might try reading the manual - hyperlinked pdf file on the AV Nav disc. that's where I got the attached page from...if I can find it so can you wink.gif
I have an SC-68 and it has the same display layout.
Steve
ss9001 is online now
post #3 of 5 Old 12-23-2013, 07:32 AM
ss9001's Avatar
Quoted: 653 Post(s)
Liked: 658
one more thing for you -
the main display will display DTS-MSTR but only if you aren't adding additional surround processing, such as ProLogic IIx or NeoX. if any processing is added, the main display will display the processing mode.
if you select Auto Surround, Direct, Pure Direct ALC, Optimum Surround with the remote button or i-app, then the main display will read DTS-MSTR.
but the indicator lights will be displayed all the time.
oztech likes this.
Steve
post #4 of 5 Old 01-01-2014, 05:32 PM
blkntan's Avatar
PaquettePack - I had the exact same problem with a Sony BDP-S370 bluray.
The solution for me was to change the BD Audio Mix Setting under Audio Settings on my BDP-S370 to OFF. Once I did this, the main display on the SC-1223 started showing DTS-MSTR (etc.) and the proper audio format in section 3 of the front display as mentioned by SS9001.
Just thought I would let you know in case you hadn't figured it out yet.
blkntan is offline
post #5 of 5 Old 02-14-2014, 05:23 PM
curtisb's Avatar
Quoted: 71 Post(s)
Liked: 75
So have you guys gotten the receiver to show you DTS Master or Dolby TrueHD with the most recent firmware? I can't via my PS3 (it is set to bitstream and the receiver is set to auto, and I've tried direct). My PC's HDMI audio connection says the receiver only reports supporting DD, DTS, and DD EX. Beyond frustrated with this thing.
curtisb is offline
Pioneer Sc 1223 K 7 2 Channel Network Ready Receiver , Sony Bdp S5100 3d Blu Ray Disc Player With Wi Fi
