Denon 3806 auto setup help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-03-2014, 03:42 PM - Thread Starter
newyorkjets00's Avatar
When I run the auto setup it does the front speakers then center then does back right and hangs a couple mins then does back left and sub. Is that normal? After the sub I get this screen, this is where I'm stuck.. Any help id appreciate!
newyorkjets00 is offline
post #2 of 4 Old 01-03-2014, 04:27 PM
afrogt's Avatar
Quoted: 2177 Post(s)
Liked: 1442
Phase error usually means check your wiring to make sure you don't the positive and negative wires crossed. Could be on the receiver terminals or speaker terminals. Just make the same wire is going to the red terminals on the speaker and receiver, same for black terminals.
Afro GT
afrogt is online now
post #3 of 4 Old 01-03-2014, 04:50 PM
jdsmoothie's Avatar
Quoted: 22611 Post(s)
Liked: 12304
Phase errors are quite common (due to the speaker design or the room dynamics) and as long as the wiring is visually confirmed to be correctly connected, as the Owner's manual indicates, simply press SKIP and move on to the next mic position.
jdsmoothie is offline
post #4 of 4 Old 01-04-2014, 07:45 AM - Thread Starter
Thanks guys
Denon Avr 3806 Av Receiver
