Canare vs blue jean multichannel analog cables? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-24-2014, 01:07 PM - Thread Starter
AVKIK's Avatar
Quoted: 22 Post(s)
Liked: 24
I was wondering if anyone had experience with canare and or blue jean multichannel analog cables? If so, which do you prefer and why? They are about the same price so price isn't an issue. Please help me make this decision. Does the gold plated and beryllium On the canare connector make a huge difference as far as sound quality goes? I will be using these with an oppo 103D for both music and movies because my old denon 4802R receiver doesn't support Hdmi. Thanks guys.
AVKIK is offline
post #2 of 7 Old 01-24-2014, 01:11 PM
FMW
FMW's Avatar
Quoted: 1654 Post(s)
Liked: 1710
Cables don't have any effect on sound at all. None whatsoever. Buy whatever makes you happy.
FMW is offline
post #3 of 7 Old 01-24-2014, 01:30 PM
jim97219's Avatar
Quoted: 23 Post(s)
Some of the Blue Jeans cable is made by Belden here in the U.S. As I understand it, the cables are assembled in China but at least there are some U.S. jobs in the deal.
jim97219 is offline
post #4 of 7 Old 01-24-2014, 03:44 PM
gene c353's Avatar
Quoted: 177 Post(s)
Liked: 133
BlueJean, Tartan, Beldon...they're all very good quality without being silly-expensive. When I use the multi-channel analog inputs or even for two channel applications I always buy component video cables. They're dirt cheap since the advent of hdmi and work just as well as RCA cables..
Example...
http://www.accessories4less.com/make-a-store/item/PR192/ACOUSTIC-RESEARCH-Pr192-Pro-Ii-Series-Component-Video-Cable-12-Ft/1.html
These are hilarious!
http://www.accessories4less.com/make-a-store/item/MS290/ACOUSTIC-RESEARCH-Ms290-Master-Series-Component-Video-Cable-3-Ft/1.html
gene c353 is offline
post #5 of 7 Old 01-24-2014, 03:45 PM
audio4life's Avatar
Liked: 301
No effect, until one runs into a surprise.
audio4life is offline
post #6 of 7 Old 01-24-2014, 03:45 PM
Troyd's Avatar
Quoted: 66 Post(s)
Well I wouldn't say that for analog cables, that's for sure.
audio4life likes this.
Troyd is offline
post #7 of 7 Old 01-24-2014, 05:58 PM
sdv5's Avatar
Blue Jeans Cable company does not manufacture any of the cables they sell. They purchase the wire and connectors wholesale and then manufacture cables in their Seattle shop based on your order. Blue Jeans Cable can sell you fully assembled interconnect cables based on designs from Canare, Belden, etc. If you buy a Canare LV-77S cable from them, they will terminate it with Canare RCA plugs. So you are getting the real Canare deal from them.
The only thing you need to be concerned with when buying unbalanced (RCA) interconnect cables is proper EMI/RFI shielding if you happen to have a source of noise nearby. Sometimes, a set-top cable or satellite TV box can generate noise that can be picked up by interconnect cables if they happen to be very close to the coax cable going into the cable TV box. Canare LV-77S cable is very well shielded with a double braid copper shield, and will probably give you the best possible protection but you still may need to experiment with equipment placement.
I suspect it would be next to impossible to consistently tell the difference in sound quality between say Canare LV-77S and Belden 1505F, or many other interconnect cables. Some of the worst shielded interconnect cables that I owned were from Audioquest and Monster Audio. In general, Blue Jeans Cable is a highly respected and reputable shop that also happens to sponsor this forum. I would not hesitate buying from them. You can also buy your cables from Monoprice that is recommended by many forum members. Their interconnect cables are very inexpensive but certainly work well.
sdv5 is offline
Denon Avr 4802r Av Receiver 7 1 Channel
