Looking to Upgrade receiver Need advice please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-13-2014, 02:59 PM - Thread Starter
jmbaruch85's Avatar
I am new to all this recently just upgraded some things in my HT system.
what I have:
Receiver: Sony STR-DG800
Speakers: RF-52 II, RC-52 II, my backs are cheap SP-BS22 (will eventually up grade to matching reference series)
Subwoofer: DT SC4000
TV: Sharp 70" 4k upscaling Q+ 3D TV
PS3 (soon to be ps4)
Samsung BD-F7500 3D 4k Upscaling Blueray player
I have been thinking about upgrading my receiver. Reason being I feel like the sony isn't pushing enough for the RF series speakers. When I switch to stereo mode just pushing the fronts I can hear a difference in power. I hope I am not under powering the new klipsch front towers and center. I was looking at the Yamaha 2030 adventage. I just want something that will adequately run my system and leave me open to upgrade in the future. I feel like woofers could use more power in the towers with these speakers being so bright. what should I do? Keep my current receiver? Or could I be pushing these speakers to give me a fuller sound? Yes, I have adjusted the EQ and calibrated the speakers.
Any advice would be great, thank you.
jmbaruch85 is offline
post #2 of 5 Old 03-14-2014, 06:49 PM
aspoerri's Avatar
I don't know much about the sony receivers but you may look at using that just as the pre amp and getting an actual amplifier. I have a co-worker that has those speakers and is using a pioneer and we calibrated that and it sounds great! Or I would suggest a denon or marantz they are my favorites.
aspoerri is offline
post #3 of 5 Old 03-14-2014, 07:10 PM
phantom52's Avatar
Quoted: 336 Post(s)
Liked: 301
May I suggest something from NAD.
http://www.crutchfield.com/p_745T748V2/NAD-T-748V2.html
Or better even yet.
http://www.crutchfield.com/p_745T758/NAD-T-758.html
Either of these deserve a serious look also.
As for a Yamaha the one below is an excellent deal.
http://www.amazon.com/Yamaha-HTR-7065-channel-receiver/dp/B00AZE78KQ
phantom52 is offline
post #4 of 5 Old 03-14-2014, 09:50 PM
carminepesce's Avatar
Quoted: 223 Post(s)
Liked: 199
I have to agree with Phantom....I'm upgrading my Denon to a NAD in the next week or so....Running Def Tech PM 1000 / PC2000 & numerous reviews & Def Tech themselves even recommend NAD....Be aware though that NAD doesn't fill their receivers with "bells & whistles" just good clean POWER!!!!
Good Luck
Carmine.
Vizio M55-e0 Display Oppo 103D
NAD T758v3
SVS PB-1000 Sub
Wharfedale Diamond 220, 220c 210 system
carminepesce is offline
post #5 of 5 Old 03-14-2014, 10:46 PM
jdsmoothie's Avatar
Quoted: 23240 Post(s)
Liked: 12748
With a dedicated subwoofer in the setup, the FL/FR speakers should ideally be crossed over at 80Hz. The Yamaha A2030 is the lowest model that can EQ the subwoofer so would be an excellent choice for upgrade as would the Denon X4000 which uses Audyssey MultEQ XT32. Both models can calibrate dual subs should you decide to add another sub at a later date whereas lower models from each mfr with dual sub pre-outs using nothing more than an internal "Y" splitter.
jdsmoothie is offline
Sony Str Dg800 7 1 Channel Home Theater Receiver With Hdmi Passthrough , Klipsch Rf 52 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rc 52 Ii Reference Series Center Channel Loudspeaker Black Each , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Samsung Electronics Bd F7500 Blu Ray Disc Player , Yamaha Rxa2030bl Aventage Home Theater Receiver
