Sony STR-DH740 and speaker question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-07-2014, 05:31 PM - Thread Starter
subfanatic's Avatar
I got this receiver, I hooked up my Klipsch pro media satellites to it, so far I don't seem to have any problems. I looked up the Pro media satellitesĀ and from what I can tell they are 4 Ohms. Is it possible I'm going to have a problem with the receiver because they don't have enough Ohms? Ā It says on the Sony specs page below that it hasĀ 4 Ohm/8 Ohm Switching (6 Ohm)
Ā
http://store.sony.com/7.2-channel-4k-a-v-receiver-zid27-STRDH740/cat-27-catid-All-Speakers-and-Stereo-Components
subfanatic is offline
post #2 of 6 Old 04-08-2014, 06:37 AM
FMW
FMW's Avatar
Quoted: 1654 Post(s)
Liked: 1710
Probably not. You could encounter overheating at high volume levels so just keep things at normal levels.
FMW is offline
post #3 of 6 Old 04-08-2014, 12:29 PM - Thread Starter
subfanatic's Avatar
Ok, sounds good. Ā So far I have only connected 2 of them, would it be more of an issue if I hooked up more of the Klipsch Satellites or pretty much be ok except for very high volumes?
post #4 of 6 Old 04-08-2014, 12:57 PM
FMW
FMW's Avatar
Liked: 1710
It is high volume that will bring out any potential problems. Feel the top of the receiver from time to time. It should be warm but no hot. It it gets hot, cut the volume.
FMW is offline
post #5 of 6 Old 04-08-2014, 01:07 PM - Thread Starter
subfanatic's Avatar
Sounds good.
post #6 of 6 Old 02-15-2015, 11:43 AM
rjhseven's Avatar
Quoted: 633 Post(s)
Liked: 103
I can't get my newly installed rear surrounds to work with this receiver. using auto Test tone as per manual. Wired correctly. Any advice?
Memphis Tiger Fan-Sports enthusiast
rjhseven is offline
