Sirius/XM Server Disconnected - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 63 Old 08-18-2018, 09:29 AM
Liked: 2
Originally Posted by Jeff Blanding View Post
Hi All
Any updates to this SiriusXM disconnect or channel jumping issues?
I am still having channel jumping issues and I have a Denon AVR-E400, latest firmware, hardwired to router. I'm not sure if the app on my Android is causing the jump or if the receiver is doing it. I assume the receiver. I tried all the usual things, resets, hard resets, power unplug.
Curious if anyone else is still having these issues, I'm about to dump this thing out the window.
I'm having the problem with my Marantz sr7010 when you call them they tell you we know about the issue and we are working with siriusxm to fix it.
djmel138 is offline
post #62 of 63 Old 09-11-2018, 10:57 AM
Liked: 2
The issue described in this thread is in regard to SiriusXM only. Any other network issues is more likely related to your modem/router. Try resetting your modem/router as well as unplugging the power cord of the E400 for 10 minutes.
Denon is not the one having this issue Marantz as well this has been going on since April 2018 SiriusXM if the issue is not fixed I will drop both Marantz and SIRIUSXM.
djmel138 is offline
post #63 of 63 Old 09-11-2018, 04:38 PM
jdsmoothie's Avatar
Quoted: 23192 Post(s)
Liked: 12720
You just quoted my post from over 4 years ago which has nothing to do with the current issue to which you are referring.
jdsmoothie is offline
