The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 4846Likes
post #4741 of 5161 Old 03-21-2017, 12:58 PM
Quoted: 121 Post(s)
Is there any way to hook up QC-35 headphones or any other bluetooth headphones to the AVR-X2100W so I can listen to tv shows and movies after the family goes to bed at the volume level that I want?
I know I can connect an iphone/ipod
redrovermiami is offline
post #4742 of 5161 Old 03-21-2017, 01:03 PM
Quoted: 957 Post(s)
Liked: 471
there are various devices that should allow this
what unused outputs do you have?
also some tv's have this ability
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #4743 of 5161 Old 03-21-2017, 01:14 PM
jdsmoothie's Avatar
Quoted: 23652 Post(s)
Liked: 13019
You can purchase a 3rd party Bluetooth transmitter and connect it to the Zone 2 pre-outs and then also connect a red/white analog audio cable from the cable/sat box to the CLB/SAT analog audio input on the X2100W.
jdsmoothie is offline
post #4744 of 5161 Old 03-22-2017, 05:44 AM
Quoted: 121 Post(s)
Any suggestions where to get one thats half decent and inexpensive? or am I better off just purchasing a 6 foot headphone cable?
post #4745 of 5161 Old 03-22-2017, 12:53 PM
PJL99's Avatar
Quoted: 533 Post(s)
Liked: 372
Why not just connect the transmitter directly to the cable/sat analog audio output (or TV) (assuming the have one)? That way the Denon does not have to be on since the OP indicated they were watching TV at night when other went to bed and did not want to disturb them. (Maybe I'm missing something but this seems simpler.)
PJL99 is offline
post #4746 of 5161 Old 03-22-2017, 12:58 PM
jdsmoothie's Avatar
Liked: 13019
Yes, that would likely work as well, as long as that was the only source that he wants to listen to via the Bluetooth headphones.
post #4747 of 5161 Old 03-22-2017, 06:01 PM
Quoted: 121 Post(s)
Doing this won't recreate the 5.1 sound or you can't really get that with headphones?
The analog sound isn't as good as the digital?
post #4748 of 5161 Old 03-22-2017, 11:45 PM
PJL99's Avatar
Quoted: 533 Post(s)
Liked: 372
Well aren't headphones only two speakers (2 channels)? Suggest you think about that for a moment in the context of your 5.1 (channel) question.
PJL99 is offline
post #4749 of 5161 Old 03-22-2017, 11:59 PM
jdsmoothie's Avatar
Liked: 13019
Either configuration would be passing analog audio.
post #4750 of 5161 Old 03-23-2017, 05:27 AM
Quoted: 121 Post(s)
I guess then I dont need the receiver I dont think unless my tv doesnt have the red/white RCA jacks for audio out.
Something like this then would do the job Im assuming
https://www.amazon.com/eranton-Porta...smitter+for+tv
post #4751 of 5161 Old 03-25-2017, 06:42 PM
Quoted: 1067 Post(s)
Liked: 874
Need help with my S900 W model; all of a sudden today when I select Internet radio it defaults to Sirius/XM even after selecting Pandora or Local Stations
And it will not move off of it, same happens when I inserted a USB Flash drive. Recognized the stick & displayed all the artists & albums but after selecting an album it went to Sirius/XM yet again.
anyone ever experience this?? I did unplug AVR for 30 seconds and tried again... but same result; Should I unplug the AVR for a lot longer perhaps??
thanks......
yanks1 is online now
post #4752 of 5161 Old 03-26-2017, 05:46 AM
jdsmoothie's Avatar
Liked: 13019
thanks......
Soft reset = 10 minutes power cord unplugged
If still no joy, then do a network reset as noted in post 5 of this thread.
post #4753 of 5161 Old 03-26-2017, 07:17 AM
Liked: 874
Thx JD; I unplugged my AVR last night for 30 mins and is operating normal again!! 30 seconds evidently does nothing
Primary set-up 5.2.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; 2 Outlaw X12 Subs & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
post #4754 of 5161 Old 04-19-2017, 10:39 AM
Alanlee's Avatar
Quoted: 497 Post(s)
Liked: 350
I am having difficulty getting something straight. I have asked this question before, but walked away unclear. I am probably going to purchase another Oppo. I am wondering if it is necessary to spend an extra $750 for the 205 DAC ($1299) when I am looking to buy a new Denon AVR later this year. The Oppo 203 is $549. As a practical matter for my music and movie watching requirements, I would be buying the 205 for the DAC. I guess this is an awkward way of asking would having a DAC in the Denon and a DAC in the Oppo be redundant, or is the Oppo DAC that much better than say the 2017 Denon flagship AVR?
7.4.6.2 system with Denon 8500, Additional Amps: Emotiva (front and center), NAD (2nd set of surrounds), NAD (Top Middle, Top Surround), classic Klipsch speakers.
Alanlee is offline
post #4755 of 5161 Old 04-19-2017, 10:46 AM
jdsmoothie's Avatar
Liked: 13019
In order to take advantage of the Oppo DAC, you would connect the Oppo to the AVR with the multi-analog audio cables which in turn would disable Audyssey. Although a minority of owners do this, the vast majority prefer to use HDMI, using the AVR's DAC and also being able to use Audyssey. If you plan on purchasing the X7400H, you would likely be better served with the 203.
post #4756 of 5161 Old 04-19-2017, 10:54 AM
Alanlee's Avatar
Quoted: 497 Post(s)
Liked: 350
Ok thanks - I am going to print this answer out and glue it to my arm. I keep forgetting.
Alanlee is offline
post #4757 of 5161 Old 04-20-2017, 09:44 AM - Thread Starter
batpig's Avatar
Quoted: 5039 Post(s)
Liked: 5513
It's pretty simple -- if you're connecting with HDMI, there is no advantage to the x05 Oppo vs. the x03 Oppo.
Kazz063 likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #4758 of 5161 Old 04-30-2017, 09:43 PM
Alanlee's Avatar
Quoted: 497 Post(s)
Liked: 350
Thanks Batpig: I bought the 203, passing audio through the Denon AVR, and so far I'm getting along fine.
Alanlee is offline
post #4759 of 5161 Old 05-05-2017, 08:36 AM
Liked: 0
Firmware upgrade failure
While attempting a firmware upgrade my S700W abruptly cut out, apparently blowing the 100mA fuse that is a pretty common issue. I replaced the fuse and the front panel came back but now I am stuck in the "Update Retry" loop that I can't seem to fix. I have tried connecting using ethernet instead of wireless and reinitializing but to no avail. Should it detect a USB drive if I try to load the firmware that way or am I likely looking at having to buy a new receiver?
davej13_13 is offline
post #4760 of 5161 Old 05-05-2017, 08:58 AM
Quoted: 957 Post(s)
Liked: 471
go here
https://usa.denon.com/us/downloads/productupdates
when you download your firmware there should be instructions on how to force a usb update
service - directv
(slow build out)
mdram is offline
post #4761 of 5161 Old 05-05-2017, 10:01 AM
Liked: 0
Originally Posted by mdram View Post
go here
Thanks, I did see this page but forgot to capture the serial # before leaving for work. I'll give this a try tonight. Hopefully it works, was looking forward to finally watching Rogue One this weekend.
post #4762 of 5161 Old 05-05-2017, 10:07 AM
Quoted: 957 Post(s)
Liked: 471
i had the same thing a while back for my 2100, it did work for me
service - directv
(slow build out)
mdram is offline
post #4763 of 5161 Old 05-05-2017, 10:45 AM
jdsmoothie's Avatar
Liked: 13019
There is a lot of very helpful information that is provided in the first 6 posts of this thread to include post 5 - Network reset (which should resolve the "Update Retry" issue) and post 6 - firmware updates.
post #4764 of 5161 Old 05-08-2017, 12:55 PM
Liked: 0
I had tried the network reset, didn't fix it and neither did trying a USB firmware update. The receiver had issues before like bluetooth never working so I picked up a Pioneer VSX-831 on sale and it seems great so far.
post #4765 of 5161 Old 05-19-2017, 10:28 PM
Alanlee's Avatar
Quoted: 497 Post(s)
Liked: 350
I'm just saying
I bought an Oppo 203 and plugged the audio ( #2 output ) into the Denon 5200 and the video into the Vizio TV ( #1 output ) and I have bought myself some time to get past the HDCP 2.2 barrier created by the entertainment mafia to lock people out of the stuff they buy. I can play a UHD DVD, hear ATMOS audio and see 2180P video. Yahoo - I guess I may be the last person on earth to find this work around.
Alanlee is offline
post #4766 of 5161 Old 05-21-2017, 04:52 PM
Liked: 0
Originally Posted by stygz View Post
No problem. Mine locks up at every use. Almost always remains a problem after a soft reset. Agreed a great receiver except that main problem. It's kind of a big one for me as online music is my main source. I even started to have airplay issues when I got an iPhone 7.
Hi,
I was wondering if you ever got this resolved. My S920W is doing the same thing.
DBWire is offline
post #4767 of 5161 Old 05-22-2017, 04:09 AM
stygz's Avatar
Quoted: 91 Post(s)
Hi,
Sort of. I ended up sending in my 2100 for warranty. They put in some new parts supposed to make it better. However, I ended up trading in my 2100 in for a 4300 through Denon. At he same time I picked up a powerline wired router through amazon. Best $60 spent. Zero drops of connection. On a second note the 4300 works perfectly with my iPhone 7. The new software and such on the 2016 models is great!
stygz is offline
post #4768 of 5161 Old 05-29-2017, 12:31 PM
Quoted: 74 Post(s)
Liked: 6
Hi guys
Question on the x2100w purchased two years ago.
What is the impedance of the headphone amp in this unit? I cannot find the info on the user manual or on the specs. This information would be useful to purchase a compatible headphone with matching impedance I suppose.
Sent from my iPhone using Tapatalk Pro
pssriram16 is offline
post #4769 of 5161 Old 05-29-2017, 08:15 PM
Quoted: 74 Post(s)
Liked: 6
Originally Posted by pssriram16 View Post
Hi guys
Any help or advise?
post #4770 of 5161 Old 05-30-2017, 07:08 AM
jdsmoothie's Avatar
Liked: 13019
Unknown. Perhaps best to call Denon to confirm.
pssriram16 likes this.
buzz , buzzing , Denon , denon s500bt , hum , humming , X1100W , X2100W , x3100w , X4100W
