The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 4846Likes
post #4771 of 5161 Old 05-30-2017, 11:13 AM
Quoted: 74 Post(s)
Liked: 6
X2100w headphone amp impedance
Where can I find info on the headphone amp impedance of the Denon x2100w? This detail is not provided in the specs. Would it be useful to buy a headphone that has the same impedance level as the amp?
Sent from my iPhone using Tapatalk Pro
pssriram16 is offline
post #4772 of 5161 Old 05-30-2017, 12:07 PM
jdsmoothie's Avatar
Quoted: 23713 Post(s)
Liked: 13060
By calling Denon customer support as I suggested in your other thread asking the same question.
pssriram16 and Squirrel! like this.
jdsmoothie is offline
post #4773 of 5161 Old 05-30-2017, 12:36 PM
Quoted: 74 Post(s)
Liked: 6
Thanks very much I will call Denon I did not get a notification on your other post thank you
post #4774 of 5161 Old 05-30-2017, 12:48 PM
Squirrel!'s Avatar
Quoted: 847 Post(s)
Liked: 534
Any decent headphone will be compatible...
pssriram16 likes this.
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #4775 of 5161 Old 05-30-2017, 01:34 PM
M Code's Avatar
Quoted: 1140 Post(s)
Liked: 745
The majority of stereo headphones available today are low impedance and will work fine...
However some of the earlier Synheiser headphones were high impedance and do not work well with present AVRs..
Just my $0.02...
M Code is online now
post #4776 of 5161 Old 05-30-2017, 01:37 PM
Quoted: 74 Post(s)
Liked: 6
Just my $0.02...
Thanks for the info.
Can you advise a range of low impedance compatible? Under 300 ohm is ok? Or is it too high?
post #4777 of 5161 Old 05-30-2017, 02:13 PM
M Code's Avatar
Liked: 745
<300 Ohm U should be fine..
The brands we prefer are AKG, AudioTechnica, Grado, note that comfort is also important as they can feel different.
Just my $0.02...
post #4778 of 5161 Old 06-05-2017, 10:42 AM
ItsL0G4N's Avatar
Quoted: 22 Post(s)
How to enable true 5.1? Denon AVR X2100W
I feel really stupid asking this, but I need to know, lol. For a little less than two years i've been running a 4.2 setup, (front right and left, rear right and left and two 12" subs). The way i've been running my audio was just to put my receiver in "All Zone Stereo".
Now I have finally purchased my center and am running a 5.2, I was wondering if my way of all zone stereo is the way I should go about it or is there a way to make my 5.1 content play without all zone?
When I have All Zone turned off, it only uses the front 3 speakers and subs. When watching lets say Netflix with a 5.1 show it still only uses the front 3.
ItsL0G4N is offline
post #4779 of 5161 Old 06-05-2017, 11:08 AM
jdsmoothie's Avatar
Liked: 13060
The only time to use "ALL ZONE STEREO" is when you actually are using a Zone 2. Once you have run Audyssey again to configure the center speaker into your setup, you would simply select the MOVIE button on the remote and select either Dolby Digital or DTS for surround audio.
Also note that the X2100W is discussed in the 2014 Denon AVR Owner's thread linked below.
https://www.avsforum.com/forum/90-rec...hread-faq.html
post #4780 of 5161 Old 06-05-2017, 11:15 AM
ItsL0G4N's Avatar
Quoted: 22 Post(s)
That helps a lot! When selecting movie as an option i get
Stereo
Dolby PLII Cinema
DTS Neo:6 Cinema
Multi Ch Stereo
Mono Movie
Virtual
Now the only one that enables all the speakers is Multi Ch Stereo.
ItsL0G4N is offline
post #4781 of 5161 Old 06-05-2017, 11:23 AM
eljaycanuck's Avatar
Quoted: 2040 Post(s)
Liked: 2923
I would pick Stereo but I don't think it matters which one you select - if the receiver detects 5.1 it should automatically play 5.1.
By any chance, are your Surround speakers hooked up to the Rear Surround binding posts instead of the Surround binding posts?
eljaycanuck is offline
post #4782 of 5161 Old 06-05-2017, 11:23 AM
jdsmoothie's Avatar
Liked: 13060
Stereo
Dolby PLII Cinema
DTS Neo:6 Cinema
Multi Ch Stereo
Mono Movie
Virtual
Did you run Audyssey? The "rear" speakers should be connected to the "SURROUND" speaker posts, not the "SURROUND BACK" speaker posts if you only have a 5.1 setup. The SURROUND BACK speaker posts are only used if you have a 6.1 or 7.1 setup.
post #4783 of 5161 Old 06-05-2017, 11:35 AM
ItsL0G4N's Avatar
Quoted: 22 Post(s)
The rears are connected to the "surround" posts, not the surround rear. Yes, I did run Audyssey
ItsL0G4N is offline
post #4784 of 5161 Old 06-05-2017, 11:50 AM
jdsmoothie's Avatar
Liked: 13060
Either the Dolby or DTS mode should also enable the "Surround" speakers when a 2CH source is being received, while they should also be enabled when a DD/DTS 5.1 audio signal is being received.
post #4785 of 5161 Old 06-05-2017, 11:54 AM
ItsL0G4N's Avatar
Quoted: 22 Post(s)
I believe I have it figured out! The LR Front and Backs weren't as loud as they used to be. But they are playing audio.
ItsL0G4N is offline
post #4786 of 5161 Old 06-06-2017, 09:02 AM
Dan in St. Louis's Avatar
Quoted: 394 Post(s)
Liked: 316
Right, because now they are playing only the surround ambience instead of the full left or right content.
M = Mega, m = milli. K = Kelvin, k = kilo. B = Bytes, b = bits. G = Giga, g = gravity. Dan in Saint Louis
Dan in St. Louis is offline
post #4787 of 5161 Old 06-07-2017, 12:41 PM
Quoted: 74 Post(s)
Liked: 6
What about the sound mode? Does it automatically select CINEMA mode or MUSIC mode when 5.1 signal comes thru?
post #4788 of 5161 Old 06-07-2017, 05:26 PM
jdsmoothie's Avatar
Liked: 13060
Only if you have previously selected that mode before.
post #4789 of 5161 Old 06-08-2017, 12:48 PM
Quoted: 74 Post(s)
Liked: 6
If I listen to cd in STEREO/MUSIC mode and then I switch to bluray then I see the DOLBY shows up automatically. But the mode doesn't switch to CINEMA on its own. I think sound mode should be associated with a signal type rather than input source.
post #4790 of 5161 Old 06-09-2017, 07:33 AM
Quoted: 394 Post(s)
Liked: 316
And how would the receiver know?
post #4791 of 5161 Old 06-09-2017, 09:22 AM
Quoted: 74 Post(s)
Liked: 6
If source is DOLBY 5.1 then sound mode should switch to CINEMA.
If source is STEREO then it has to be music so should switch to MUSIC.
post #4792 of 5161 Old 06-09-2017, 10:10 AM
jdsmoothie's Avatar
Liked: 13060
There are plenty of non-HD TV shows in PCM 2.0 so STEREO doesn't necessarily mean music.
dgyope and pssriram16 like this.
post #4793 of 5161 Old 06-09-2017, 02:06 PM
Quoted: 394 Post(s)
Liked: 316
It is my understanding that it works the other way around:
• The MOVIE, MUSIC, or GAME button memorizes the last sound mode selected for
its button. Pressing MOVIE, MUSIC, or GAME recalls the same sound mode as the
one selected at the previous playback.
• If the content played back does not support the previously selected sound mode,
the most appropriate sound mode for the content is automatically selected.
In other words, "MOVIE" can remember "Dolby" while "MUSIC" might remember "Stereo." Not Dolby or Stereo memorizing Music or Movie.
post #4794 of 5161 Old 06-14-2017, 03:01 PM
Quoted: 74 Post(s)
Liked: 6
post #4795 of 5161 Old 06-14-2017, 07:53 PM
Quoted: 64 Post(s)
Liked: 7
NEED HELP Denon AVR-S500BT - No Remote - Bluetooth add my iphone
Looking for some help as to how i can pair the iphone to this receiver to use for bluetooth audio.
Unfortuantly it looks like you how to have the remote that goes with the receiver. Any luck on where i can buy one of these that is not 40 dollars on amazon or ebay lol . ??
I have tried lots but unable to pair my iphone with this receiver without the remote.
I have tried apps store remote apps but you need to be paired first with it.
Thanks in advance to your reponses
Also is there a cable i can buy to go from iphone 6 to the phones port or setup mic port or usb ?
when i plug my charger usb cable from phone into usb port it says not supported
adamf4i7783 is offline
post #4796 of 5161 Old 06-15-2017, 12:56 AM
jdsmoothie's Avatar
Liked: 13060
1. AFAIK, you'll need to either purchase the original remote (RC-1196) or you can also purchase a Harmony universal remote which would likely control all of your components to include the S500BT. The OEM remote can be purchased for < $20 on eBay.
http://www.ebay.com/itm/Denon-RC-119...3D112232213922
2. iPhone wired connection to the S500BT is not supported.
Also note the S500BT is discussed in the 2014 Denon AVR Owner's thread linked below ...
post #4797 of 5161 Old 06-15-2017, 06:14 AM
Quoted: 64 Post(s)
Liked: 7
Thanks for the reply
post #4798 of 5161 Old 06-15-2017, 06:16 AM
Quoted: 64 Post(s)
Liked: 7
Actually real quick if you buy a universal remote how do you pair it with the receiver ?
As im seeing you have to hit the option button thats oon the denon remote but like i said you have to pair it to communicate with it to even use it in the first place lol ?
post #4799 of 5161 Old 06-15-2017, 06:53 AM
jdsmoothie's Avatar
Liked: 13060
You download the settings from the Logitech (Harmony) data base for the particular devices you're trying to control via IR.
post #4800 of 5161 Old 06-20-2017, 12:57 AM
Liked: 0
Problem with Denon AVR-X2100W after update
Hi
Yesterday my Denon AVR-X2100W showed me notification about software update. I allowed the update. After updating the software version is 3600-3161-6661 and there is a problem with the web interface and device control from the phone application if the device is in standby mode (it is connected with LAN by cable). In standby it responds for pings. In Settings, IP Control is set to Always. There is any solution for that? Is it possible to restore the previous software from firmware denon eu according to the instructions on the page (version 3600-0161-6640 available there)?
Bieniu is offline
buzz , buzzing , Denon , denon s500bt , hum , humming , X1100W , X2100W , x3100w , X4100W
