The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 75 - AVS Forum | Home Theater Discussions And Reviews
 4846Likes
post #2221 of 5161 Old 12-30-2014, 04:03 AM
jdsmoothie's Avatar
Quoted: 23453 Post(s)
Liked: 12897
Originally Posted by blckthree View Post
"However, after running Audyssey Setup, if you are using a sub, go into the Denon GUI and change ALL speakers to SMALL and raise any crossovers that were set below 80Hz up to either 60Hz or 80Hz (whichever you prefer). This not only transfers those lower frequencies to the sub (which is generally able to handle them better as it's got it's own amp) but also frees up some extra headroom for the AVR."
This was in the Audyssey Setup section, I am generally pleased with the sound of my S700W after running Audyssey, but wondering how to change the Speaker size to small and adjust the crossovers, just to see how that sounds. I have searched and can't find a way of doing that. The only place I saw the ability to do that was in the Manual EQ section, would that not erase the Audyssey setup?
If I listened to my wife, I would leave well enough alone, but I can't resist the urge to tinker with it.
Mike
Make the SMALL/80Hz change in Manual Setup which then become the "active" settings used by the AVR. The settings in Audyssey Setup cannot be erased so you can more easily return to them using the RESTORE setting.
jdsmoothie is offline
post #2222 of 5161 Old 12-30-2014, 04:05 AM
jdsmoothie's Avatar
Liked: 12897
Originally Posted by pacemaker View Post
Not too happy that the second HDMI output cannot just mirror the main!
Reason I got it was to run one to a tv and the other to a projector, which it have done but it now requires some fussing around, making sure zone two is actually on, plus it is set to the same source as the main!
What a pain
Looks like I will have to resort to an HDMI splitter!
Did you try a soft reset? Hard reset?
post #2223 of 5161 Old 12-30-2014, 04:08 AM
jdsmoothie's Avatar
Liked: 12897
Originally Posted by keyweez360 View Post
Purchased the X2100W today. Have a problem. When the AVR is powered on and there is no audio currently playing, there is a fairly audible beeping/interference noise coming from the speakers. Like a faint dial up modem sort of sound.
Have no clue whatsoever what might be causing this.
5.1 setup, everything connected via standard cabling, sub via digital coax, AM/FM antenna, power strip. Crossovers all at 80, 4K upscaling enabled.
Nearby devices include a TV, PS3, digital cable box, Ethernet power line adapter.
Any suggestions?
Disconnect every cable/wire from the unit and start adding back one at a time to determine the cause.
post #2224 of 5161 Old 12-30-2014, 04:11 AM
Liked: 2
Does this override all the Audyssey settings or does it just adjust the settings changed in Manual Setup and leave all the other Audyssey settings as they were?
Mike
blckthree is offline
post #2225 of 5161 Old 12-30-2014, 04:20 AM
jdsmoothie's Avatar
Liked: 12897
The Audyssey Setup settings (which don't include the actual "EQ" settings) are copied to Manual Setup. Any changes you make in Manual Setup become the "active" settings and override the same settings in Audyssey Setup. You don't have any access to the Audyssey EQ settings so cannot change those in Manual Setup.
blckthree likes this.
post #2226 of 5161 Old 12-30-2014, 06:46 AM
pacemaker's Avatar
Quoted: 30 Post(s)
Having read up it seems it is how it's supposed to be.
Zone2 must be on and both zones must be set to same input.
Be nice to have an override to just make both HDMI's mirrored.
pacemaker is offline
post #2227 of 5161 Old 12-30-2014, 06:54 AM
jdsmoothie's Avatar
Liked: 12897
Sure, if that is what you are trying to accomplish as they are independent zones. You implied it was not working correctly. You may be better served returning the X3100W and getting the X2100W instead which has dual main zone HDMI outputs designed for those with TV and PJ in same room.
post #2228 of 5161 Old 12-30-2014, 08:34 AM
Done Deal DR's Avatar
Quoted: 99 Post(s)
Liked: 147
Originally Posted by SirDracula View Post
Has anyone updated the firmware on the S900W? Any problems? Improvements?
I updated my step son's S900W this past weekend, no issues but I've read others have had issues with various Denon models. I didn't have any issues with my X2100W either. As far as improvements, the change logs are posted on page 1... nothing was particularly important to me.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #2229 of 5161 Old 12-30-2014, 10:25 AM
rahulp001's Avatar
Quoted: 117 Post(s)
Does anybody know if there is a auto power on feature on X2100W via Bluetooth?
Last couple of days (after the firmware update), every morning my receiver would turn on from stand by and switch to Bluetooth (paired with my phone).
Never experienced this and don't see any settings about this either.
Any clue?
rahulp001 is offline
post #2230 of 5161 Old 12-30-2014, 11:28 AM
pacemaker's Avatar
Quoted: 30 Post(s)
The 2100 was what I ordered but the dealer was out of stock so I upgraded. Just assumed they would be the same or at least offer this common option....doh!
Didn't really want you use an HDMI splitter in case of loss of picture quality. Anyone know of a lossless splitter?
post #2231 of 5161 Old 12-30-2014, 11:45 AM
ppith's Avatar
I also performed the update to my receiver a few days ago. The update said it would take 11 minutes which was close to around 15 minutes for me on 20MB DSL including post installation stuff. It didn't wipe out my Audyssey settings so maybe Denon figured out a way to retain them across updates.
On an unrelated side note, I previously posted that I had to adjust my subwoofer gain around +5.0db after the calibration with the volume set to 10 o'clock. This was before I turned on the Dynamic EQ mode. I'm no longer using the subwoofer gain and have plenty of bass.
I'm very happy with my receiver cooler and receiver. I've run hours of Netflix/Blu-ray/DVDs at high volumes with no issues. The internet radio search for holiday music was perfect once I found one without advertisements. It was also great to adjust the volume from the Denon App while I was in my dining room since my remote would have been out of range from there.
As I've said previously, I'm still not sure why receiver manufacturers don't include PC style fans to keep the receiver cool. For now, it will be a mandatory purchase for me whenever I have to get a new receiver.
ppith is offline
post #2232 of 5161 Old 12-30-2014, 11:53 AM
jdsmoothie's Avatar
Liked: 12897
Although there have been a few exceptions, this has been the case for quite a few years now.
post #2233 of 5161 Old 12-30-2014, 12:19 PM - Thread Starter
batpig's Avatar
Quoted: 5021 Post(s)
Liked: 5478
It's a digital signal. There is no loss of quality from copying it to two outputs. If the splitter sucks then you could get drop-outs or other full blown errors, but if it works, it works. There is no such thing as partial degradation with digital signals.
pacemaker likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #2234 of 5161 Old 12-30-2014, 04:49 PM
PJL99's Avatar
Quoted: 533 Post(s)
Liked: 372
I think an HDMI splitter will output the same to all outputs as the least capable down steam connection supports, both in audio and video, although some will output appropriate signals. If all downstream sources are equal, then there is no "loss."
PJL99 is offline
post #2235 of 5161 Old 12-30-2014, 06:02 PM
ronton3's Avatar
Quoted: 56 Post(s)
HEOS link
Free Denon HEOS Link with purchase of X3100W
This past fall Denon released a new competitor to Sonus wireless speakers called HEOS. A promo has been going on with the new Atmos models in that a purchase also includes a new Denon HEOS Link ($349 MSRP) which is a small Roku sized box that can be used to stream a source connected to the X3100W to one or more HEOS speakers located in your home, or can also be used to stream to the X3100W using the Denon HEOS app (eg. iHeartRadio). Denon has now extended this promo to include the X3100W as well with a purchase thru Jan 31.
What do I have to do to get mine? ron(happy new X3100 owner)
ronton3 is offline
post #2236 of 5161 Old 12-30-2014, 07:40 PM
decarden's Avatar
Has anyone done a real comparison between the X7200 and the Yamaha RX-A3040? I have to replace my beloved 4308CI so looking for suggestions?
decarden is offline
post #2237 of 5161 Old 12-30-2014, 09:17 PM
ten2344's Avatar
FW Update List
Does Denon list what is included in its Firmware updates for the AVR-2100W?
ten2344 is offline
post #2238 of 5161 Old 12-31-2014, 02:57 AM
Liked: 0
I picked a denon 3100w too. I would be interested in the free heos link also.
Fp1213 is offline
post #2239 of 5161 Old 12-31-2014, 03:57 AM
jdsmoothie's Avatar
Liked: 12897
If you review posts 3-6 on page 1, you'll find a lot of very helpful information to include the firmware change log listed in post 6.
post #2240 of 5161 Old 12-31-2014, 03:59 AM
jdsmoothie's Avatar
Liked: 12897
The HEOS Link promo applies to purchases made Dec 29 - Jan 31.
post #2241 of 5161 Old 12-31-2014, 04:01 AM
jdsmoothie's Avatar
Liked: 12897
Unlikely as the X7200W has just been released in the last week. Also, this is the wrong thread, as the X7200W is covered in the following two threads ....
https://www.avsforum.com/forum/90-rec...l#post26013786
https://www.avsforum.com/forum/90-rec...r-details.html
post #2242 of 5161 Old 12-31-2014, 06:21 AM
pacemaker's Avatar
Quoted: 30 Post(s)
Ah, just realised what you said about being independent zones. So should the following work?
Main: TV connected through ARC, select whatever input you like and turn off when not in use and just use:
Zone 2: Projector, set 12v trigger to zone2 bluray,media etc but leave main off. So when turning on zone2 screen will drop and go up when zone2 off?
post #2243 of 5161 Old 12-31-2014, 06:34 AM
jdsmoothie's Avatar
Liked: 12897
post #2244 of 5161 Old 12-31-2014, 06:57 AM
pacemaker's Avatar
Quoted: 30 Post(s)
It should yes.
Try later
Be even better if the HDMI CEC control turned the PJ on too
post #2245 of 5161 Old 12-31-2014, 09:39 AM
Liked: 0
Hi,
I am having problems with Denon X2000 and X2100 EDIDs.
I have laptop with 1080p and monitor with 1200p. Connecting with HDMI like Laptop>AVR>Monitor.
Everything works fine with X2000, and edid looks like this:
(detailed resolution is fine).
If, however I connect X2100 (which has same settings as X2000), I get this edid:
(detailed resolution is low now).
So using X2100 I can only set resolution up to 1080p - 1200p is impossible to get.
I tried copy/pasting that detailed resolution from X2000 to X2100, and I managed to get 1200p on it, however, then I lost sound via HDMI completely...
So, is there anything that can be done to X2100 to make it act like older X2000, or will I have to return X2100 and keep X2000?
phemark is offline
post #2246 of 5161 Old 12-31-2014, 10:00 AM
PJL99's Avatar
Quoted: 533 Post(s)
Liked: 372
Originally Posted by phemark View Post
Hi,
What happens when you click the Add button under the Detailed Resolution box? Can you add your custom resolution?
PJL99 is offline
post #2247 of 5161 Old 12-31-2014, 10:56 AM
Liked: 0
Yes, I added 1200p 60hz, but monitor showed that it doesnt support that (as I think its 59.xx).
But I said, I coppied that 1200p, 59hz setting from working AVR, and I got 1200p, but didnt get audio with that.
phemark is offline
post #2248 of 5161 Old 12-31-2014, 12:28 PM - Thread Starter
batpig's Avatar
Liked: 5478
Consumer AV devices like your receiver don't support computer resolutions, only the "standard" consumer video resolutions. So a resolution like 1920x1200 will not be supported.
Setup Guide and FAQ
batpig is offline
post #2249 of 5161 Old 12-31-2014, 03:32 PM
keyweez360's Avatar
Quoted: 112 Post(s)
Got my audio interference issue solved (it was my Ethernet powerline adapter) but now I have a new problem:
Whenever I use the X2100W's i/p scaler, HDMI @ 4K, the image intermittently goes black for 5-10 seconds and then comes back. Happens with both my PS3 and cable box.
Any ideas?
keyweez360 is offline
post #2250 of 5161 Old 12-31-2014, 03:40 PM - Thread Starter
batpig's Avatar
Liked: 5478
Any ideas?
So it only happens at 4k resolution from AVR to display, but not when transmitting lower resolutions?
I would suspect the HDMI cable from the AVR to the display, since it's common for an HDMI problem to manifest when pushing higher bandwidth data that's not an issue with lower bandwidth signals.
Setup Guide and FAQ
batpig is offline
buzz , buzzing , Denon , denon s500bt , hum , humming , X1100W , X2100W , x3100w , X4100W
