Denon AVR-X7200W 9.2/11.2ch 2014/2015 Receiver Details- - Page 154 - AVS Forum | Home Theater Discussions And Reviews
 4808Likes
post #4591 of 5351 Old 10-13-2017, 05:43 AM
robert9674's Avatar
Quoted: 1255 Post(s)
Liked: 792
Maybe hopefully it was for Dolby Vision
Sent from my SAMSUNG-SM-N915A using Tapatalk
Sony A1E
Triton one
robert9674 is offline
post #4592 of 5351 Old 10-13-2017, 07:22 AM
josey88's Avatar
Quoted: 308 Post(s)
Liked: 33
I`ll wait for JD to find out what this is in order to update ... No more surprises .
josey88 is offline
post #4593 of 5351 Old 10-13-2017, 08:09 AM
sikclown's Avatar
Quoted: 1681 Post(s)
Liked: 832
I don't think it is for Dolby Vision. A x4100 owner got a firmware update in the past couple days as well and in far as I know the only 2014 (ish) AVR that will get Dolby Vision is the x7200wa (I could be wrong). I haven't had a chance to swap my 4k Apple TV to my Denon after the update to test but usually firmware updates that add major features like Dolby Vision say that on the update package. This one just said performance improvements (or something along those lines). I want it to be for DV though
LG OLED 65C7P, Denon AVR-X7200WA, Apple 4K, Oppo UDP-203, PS4, Xbox One X
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
LG OLED 55C8PUA, Denon x4400h, Apple TV 4K, Panasonic DP-UB820,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #4594 of 5351 Old 10-13-2017, 08:44 AM
Liked: 2
Have been confused lately about the maximum speaker layout this receiver can drive, is it possible to use it for a 7.2.4 dolby atmos layout? Of course with an external 2-channel amp
chroman is offline
post #4595 of 5351 Old 10-13-2017, 08:55 AM
Brian-HD's Avatar
Quoted: 141 Post(s)
Liked: 70
22 mins update
Brian-HD is offline
post #4596 of 5351 Old 10-13-2017, 09:02 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
It's complicated:
With no external amps, the X7200W can provide power to as many as 9 speakers at the same time (5.1.4, 7.1.1 or 9.1.0). It can decode audio for up to 11 speakers at the same time (7.1.4 or 9.1.2), but you have to add at least two external power amplifiers. If you add at least 4 channels of external amplification, it can calibrate and be connected to as many as 13 speakers (9.1.4), but only 11 of them can be active at the same time. Which 11 are active is determined by which audio processing option you choose in the receiver.
Selden
Selden Ball is offline
post #4597 of 5351 Old 10-13-2017, 09:11 AM
jk246's Avatar
Quoted: 124 Post(s)
Liked: 113
Yes, as you say, with an external 2-channel amp (and speakers )
I bought a Emotiva BasX A-150, which is a bit of overkill, but decided to do so in case I want to re-task it later for use with my editing equipment. There's a lower powered model, the A-100 that JD suggested to me would be a good fit for surround speakers. The BasX line are well-made, the 2 models I mentioned have trigger inputs on them -1/8" mono (not stereo per Emotiva) jacks on them that are compatible with Denon's trigger outputs (12vdc), and work nicely to turn power on/off to the Emotiva when the Denon is powered on and off.
jk
jk246 is offline
post #4598 of 5351 Old 10-13-2017, 12:36 PM
Nalleh's Avatar
Quoted: 2562 Post(s)
Liked: 3451
Originally Posted by Selden Ball View Post
It's complicated:
Actually 14 speakers, if you have the Auro 3D update. Sub2 pre-out to VOG(also ext. amped)
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
post #4599 of 5351 Old 10-13-2017, 12:41 PM
Liked: 2848
You're right, of course: connected goes up to 14 with Auro3D, but then only 10 speakers can be active while actually using Auro3D.
Nalleh likes this.
Selden
post #4600 of 5351 Old 10-13-2017, 01:08 PM
sikclown's Avatar
Liked: 832
Firmware update log (posted by JD in the 2014 thread):
10/12/2017
SYMPTOM:
- When playing the DSD file from USB drive between 0:59-1:07 minute marks several clicking sounds can be hear that are not part of the track. When playing the same file on the computer (software converted to PCM) or via Blu-Ray player (PCM over HDMI)
- Spotify does not Play Songs from the cue.
- Impossible to play WAV file in the HAP-Z1ES (SONY Audio Player) at the network function.
No Dolby Vision yet.
sikclown is offline
post #4601 of 5351 Old 10-14-2017, 07:02 AM
Robert Saccone's Avatar
Quoted: 25 Post(s)
I have the 7200wa and will be replacing my 1080p display soon. My HDMI cable run to the display is about 25 ft. I imagine I will have to upgrade the HDMI cable. Does monoprice make a cable that will do the job or should look to at others?
Rob
Robert Saccone is offline
post #4602 of 5351 Old 10-14-2017, 04:32 PM
Quoted: 967 Post(s)
Liked: 668
Rob
Go get a Blue Jeans Cable Series 1 HDMI cable. I have seen some people have issues with Monoprice.
LG 65C7P (Also XBR65X900E and XBR55X900E)
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #4603 of 5351 Old 10-15-2017, 08:16 AM
petetherock's Avatar
Quoted: 1711 Post(s)
Liked: 896
Rob
How about this:
https://www.amazon.com/dp/B06X3QDY4M..._t3_B0141R4GZM
petetherock is offline
post #4604 of 5351 Old 10-30-2017, 06:54 AM
Callsign_Vega's Avatar
Quoted: 540 Post(s)
Liked: 376
Guys is there a way to hook up my AVR-X7200WA to my PC as to use the AVR-X7200WA DACs for sound instead of my PC's sound card? Say via USB? Would drivers be needed?
Callsign_Vega is offline
post #4605 of 5351 Old 10-30-2017, 07:08 AM
Quoted: 540 Post(s)
Liked: 376
Sure. Connect the 3.5mm headphone output to a RCA converter and connect that to the FL/FR multi analog inputs on the X7200WA.
Ya but wouldn't the headphone jack be using analog signal supplied by the on-motherboard sound? I'm trying to keep the sound digital until it gets to the AK4490 32-bit DACs in the 7200WA.
Right now my PC is hooked up to the 7200WA through TOSLINK. But doesn't the digital signal from the TOSLINK still go through the on-board sound?
post #4606 of 5351 Old 10-30-2017, 07:20 AM
jdsmoothie's Avatar
Quoted: 22557 Post(s)
Liked: 12278
Oops! Misread your post thinking you wanted to bypass the AVR DAC.
Yes, using TOSLINK input will use the AVR DAC.
jdsmoothie is online now
post #4607 of 5351 Old 10-30-2017, 07:30 AM
robert9674's Avatar
Liked: 792
Using the USB or TOSLINK input will use the AVR DAC.
What if he used hdmi from his video card to the 7200wa? Isn't that the same thing?
Sony A1E
Triton one
post #4608 of 5351 Old 10-30-2017, 07:49 AM
Quoted: 540 Post(s)
Liked: 376
Would USB provide better bitrate than the TOSLINK? I understand TOSLINK is quite bandwidth limited. I only use 2-channel stereo though. Any way to check the bit-rate and frequency of my motherboard to Denon TOSLINK?
Unfortunately I have my VR headset hooked up to my video cards sole HDMI output.
post #4609 of 5351 Old 10-30-2017, 08:29 AM
Manni01's Avatar
Quoted: 5428 Post(s)
Liked: 5614
You can use a DP to HDMI or DVI to HDMI adapter for your VR headset, and use the GPU HDMI for the AVR. This is what I've done. The VR headset doesn't need the sound through HDMI as it uses USB (at least that's the case for my Oculus Rift).
I have:
1080 Ti HDMI > X7200WA
1080 Ti DVI>HDMI > Oculus Rift
Just make sure the adapter is DVI-D (not DVI-I) to get full HDMI 1.4 bandwidth (at least as much as the Oculus needs).
A DP to HDMI adapter works too but it's more difficult to find a compatible adaptor, the Cable Matters one works fine though.
Works great
Manni01 is online now
post #4610 of 5351 Old 10-30-2017, 08:48 AM
Quoted: 540 Post(s)
Liked: 376
I have:
Works great
Hmm, interesting. I guess I am wondering now if it would even be necessary already connected via TOSLINK since I only send stereo sound from my PC to receiver.
I have my home theater setup differently on the 7200WA for 7.1 via HDMI from my UHD Blu-Ray player.
post #4611 of 5351 Old 10-30-2017, 09:25 AM
nerdkiller's Avatar
Quoted: 101 Post(s)
Liked: 37
Fairly sure that D&M AVRs don't have USB DACs built in that allow you to connect a PC. For that you would need a USB-B port which I don't see anywhere. The USB-A ports on the X7200 are for connecting hard drives and USB sticks.
nerdkiller is offline
post #4612 of 5351 Old 10-31-2017, 12:16 AM
jdsmoothie's Avatar
Liked: 12278
Correct, my post was a general reference although edited for OP's use case.
post #4613 of 5351 Old 10-31-2017, 06:50 PM
Quoted: 540 Post(s)
Liked: 376
Any word on MQA support? I've been listening to master recordings via Tidal desktop app (software MQA) and it sounds amazing. Curious if receivers were going to be able to process.
post #4614 of 5351 Old 11-03-2017, 08:59 AM
jdsmoothie's Avatar
Liked: 12278
Dolby Vision and HLG update to be released
This update has been confirmed to be released to the X7200WA in March 2018.
post #4615 of 5351 Old 11-06-2017, 07:37 PM
sathron's Avatar
Quoted: 23 Post(s)
Thanks for the heads up jdsmoothie. Where did this information post? On Denon's site? I've been looking for an update over the month or two. Can't wait.
7.2.4 : Denon AVR - X7200WA, Emotiva XPA-5, Oppo UDP -203, LG OLED65C6P, (2)SVS SB16-Ultra’s, SVS Ultra Towers (Fronts), SVS Ultra Center, SVS Ultra Surround (Rear Surrounds), SVS Prime Elevation (Surround), Golden Ear Invisa 650 (x4 Heights), Apple ATV4K
sathron is offline
post #4616 of 5351 Old 11-06-2017, 08:17 PM
plasmaowner's Avatar
Quoted: 72 Post(s)
Liked: 34
Hello can someone tell me how to do a complete, full, factory reset??
I did the reset below but it didn't seem to reset EVERYTHING...
Turn off the power using Power Button .
Press Power Button while simultaneously pressing INFO and BACK.
Remove your fingers from the two buttons when “Initialized” appears on the display.
I don't want to receiver to remember ANY of my settings, is there a different way to do this?
plasmaowner is offline
post #4617 of 5351 Old 11-06-2017, 08:32 PM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
Try, unplugging the unit, depress the up and down cursors simultaneously while replugging the power cord back in.
snpanago is offline
post #4618 of 5351 Old 11-06-2017, 09:09 PM
Quoted: 72 Post(s)
Liked: 34
I will try this when I get home, should I do the factory reset again first?
post #4619 of 5351 Old 11-06-2017, 10:58 PM
nc88keyz's Avatar
Quoted: 371 Post(s)
Liked: 232
OF, since I care about dolby vision now ( 77g6) in route, can I expect the 7200wa DV/ HLG update before end of year. MY NR1607 already got it last month or so. Im sure you added somewhere, juat cant locate at the moment. Thank you.
Sent from my SM-G935V using Tapatalk
nc88keyz is online now
post #4620 of 5351 Old 11-07-2017, 01:55 AM
jdsmoothie's Avatar
Liked: 12278
Using the UP/DOWN arrow buttons performs a "Network reset" which also includes a microprocessor reset. Try doing either reset at least 4-5 times in a row which should return just about all settings to factory default.
AVR-X7200W
