Denon AVR-X7200W 9.2/11.2ch 2014/2015 Receiver Details- - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 4808Likes
post #5041 of 5351 Old 09-23-2018, 07:54 AM
DrGerm's Avatar
Quoted: 21 Post(s)
Post
Originally Posted by Selden Ball View Post
Exactly what device are you plugging into it?
Originally I'm just trying to plug in a SNES Classic video game system. I really wouldn't think this to be fancy (i.e. really doubt it's 4K), so I'm still confused.
I plugged in an Xbox 360, a PS3, a 2017 MacBook Pro 15" and a windows 10 notebook PC and all those all work in the FRONT HDMI port.
If it's a 4K UHD device, your symptoms are consistent with you having a 2014 AVR-X7200W which was later upgraded to an A by having its main HDMI board replaced. Unlike the 2015 AVR-X7200WA shipped from the manufacturer, that HDMI upgrade process did not upgrade the front HDMI port to support HDCP V2.2. Only the rear ports can support modern 4K UHD devices.
I wonder how I can tell? I did get it from a 3rd party off Amazon. Obviously just chose the cheapest vendor. And it was purchased January 2016.
Edited to add: if you need to use the front port because of its convenience, a workaround would be to get a short male-to-female HDMI extension cable that you run under the receiver from the back panel so it sticks out in front of it.
Yes. Strictly convenience. All ports in the back are used, but I have an old thing or two. Just need to spend a little more time to take them out and tidy up.
Denon AVRX7200WA
7.2.2 [SVS Ultra + PB-13 Ultra + Prime Elevation]
Samsung UN85JU7100
"As you know, you build a home theater in the room your wife gives you, not in the room you might want or wish to have at a later time"
DrGerm is offline
post #5042 of 5351 Old 09-23-2018, 08:04 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
That does seem unusual. Are the ones that work generating 4K? FWIW, the front panel port, even when it's one that supports HDCP v2.2, is limited in bandwidth compared to the rear ports. If you press Setup and select General/Information, it'll provide some details about the incoming audio and video signals while it's plugged into a working port. That information might provide some hint as to what might be going on.
The original model number should be silkscreened in a box on the back panel. Also, the manufacturing date is encoded in the first few digits of the serial number.
DrGerm likes this.
Selden
Selden Ball is offline
post #5043 of 5351 Old 09-23-2018, 08:36 AM
DrGerm's Avatar
Quoted: 21 Post(s)
Post
I don't have any 4K devices. Yet.
With this SNES Classic:
in AUX 1 (FRONT, which isn't working)
Resolution. --- -> ---
Color Space --- -> ---
Pixel Depth --- -> ---
in AUX 2 (back, works)
Resolution. 720p:60Hz -> 720p:60Hz
Color Space RGB 4:4:4 -> RGB 4:4:4
Pixel Depth 8bits -> 8bits
So, I'm not thinking that requires a lot of bandwidth..
Is there a resource for interpreting the serial number? mine starts with 51115 _ _ _ _ _. I'm guessing 5/11/15 ?
UPDATE: I found one source via searching that suggests this may be (201)5/11 -- which turns out to be the same: November 2015.
Denon AVRX7200WA
Samsung UN85JU7100
DrGerm is offline
post #5044 of 5351 Old 09-23-2018, 08:44 AM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
This does seem unusual.....have you been using the same HDMI cable that works with the other devices that successfully display via AUX 1?
DrGerm likes this.
snpanago is offline
post #5045 of 5351 Old 09-23-2018, 08:48 AM
Liked: 2848
Are you using the same HDMI cable with the devices that work in the front connection? (I.e. I'm wondering if the cable might be at fault).
Another (related) possibility is that the signal level from the SNES might have a marginal amplitude and that the rear ports have a low enough threshold but the front one doesn't. Sometimes this can be compensated for by using a higher quality cable, one with lower attenuation and dispersion. As a result, "Certified Premium" cables often are recommended. They're usually required for 4K signals and work quite well when there are problems at lower bitrates.
I think your guess is correct.
I don't know of any official resource, but a quick Web search suggests the pattern that you deduced is used for several Denon models.
DrGerm likes this.
Selden
post #5046 of 5351 Old 09-23-2018, 08:49 AM
DrGerm's Avatar
Quoted: 21 Post(s)
Post
Yes. Same one which worked with 4 other devices. And also tried a couple other cables.
OK. I have an entire box of cables I could keep trying.... LOL. Project for tonight maybe.
I'm sorry, I'm just stumped and believe there's surely a simple thing I'm just doing wrong somewhere...
Denon AVRX7200WA
Samsung UN85JU7100
DrGerm is offline
post #5047 of 5351 Old 09-23-2018, 08:59 AM
Liked: 2848
Well, it's explicitly cables with the official rating of "Certified Premium" that I'm referring to so as to avoid the variations found in random "High Speed" cables. They don't cost any more, but they come with a special holographic certification tag.
Sadly, I don't think you're doing anything wrong. The pre/pro obviously has something strange going on in its front HDMI port. Only you can decide if it's annoying enough to be sent in for repairs, which might or might not actually fix anything.
If there are any video adjustments you can make in the SNES, you might try them. D&M traditionally have had problems with video settings of "Deep Color". I dunno if that might be the case here.
DrGerm likes this.
Selden
post #5048 of 5351 Old 09-23-2018, 09:02 AM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
Can you bypass the AVR and connect your SNES Classic directly to your tv’s HDMI input? Maybe you have a defective Nintendo unit.
snpanago is offline
post #5049 of 5351 Old 09-23-2018, 10:05 PM
Liked: 0
Does Denon still honor the HDCP 2.2 upgrade for the 7200W models? Can the upgrade be purchased? I'm considering picking up one granted I can upgrade it myself but need the 4k support.
KINGKONGG is offline
post #5050 of 5351 Old 09-24-2018, 03:17 AM
jdsmoothie's Avatar
Quoted: 22428 Post(s)
Liked: 12200
You'll have to contact United Radio, Syracuse, NY and ask them if they still have any kits available.
jdsmoothie is offline
post #5051 of 5351 Old 09-24-2018, 08:34 AM
Nalleh's Avatar
Quoted: 2530 Post(s)
Liked: 3393
Can the 7200 WA process Atmos MAT as it comes from XBOX one and APPLE TV4K ?
Reason i ask, is i have the 8500 in main zone, and the 7200 connected to the HDMI zon2 out, and if i watch XB1X or ATV4K on the 8500(Atmos fully working), and then turn on zone 2, Atmos can no longer be played.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #5052 of 5351 Old 09-24-2018, 09:36 AM
sikclown's Avatar
Quoted: 1681 Post(s)
Liked: 832
Yes it can process it but I don't think you can get Atmos through Zone 2. With Zone 2 set to the same source as the 8500 I think everything gets downgraded to 2 channel PCM. You can try to set Zone 2 for HDMI pass-through but I don't think that will change the outcome.
Update:
Ignore this. I have no idea what I am talking about lol
LG OLED 65C7P, Denon AVR-X7200WA, Apple 4K, Oppo UDP-203, PS4, Xbox One X
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
LG OLED 55C8PUA, Denon x4400h, Apple TV 4K, Panasonic DP-UB820,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #5053 of 5351 Old 09-24-2018, 09:40 AM
jdsmoothie's Avatar
Liked: 12200
Actually, as long as the Zone 2 HDMI sink can process Atmos, it will pass via the Zone 2 HDMI Monitor output.
post #5054 of 5351 Old 09-24-2018, 09:45 AM
sikclown's Avatar
Liked: 832
Interesting. Even with the same source being played in both zones?
sikclown is offline
post #5055 of 5351 Old 09-24-2018, 09:47 AM
jdsmoothie's Avatar
Liked: 12200
Yes.
post #5056 of 5351 Old 09-24-2018, 09:49 AM
sikclown's Avatar
Liked: 832
Yes.
Learn something new every day.
sikclown is offline
post #5057 of 5351 Old 09-24-2018, 12:19 PM
josey88's Avatar
Quoted: 308 Post(s)
Liked: 33
Well, Today is Monday September the 24th and the Pandora fix for the 7200WA is still nonexistent . Six days to the end of the month (it was supposed to be available on September ... ? ) but there are still 6 more days on the month so , I keep waiting .
josey88 is offline
post #5058 of 5351 Old 09-24-2018, 12:25 PM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
Please refresh my memory, what is the Pandora issue? I am able to stream my Pandora account without issue on my 7200WA.
snpanago is offline
post #5059 of 5351 Old 09-24-2018, 12:47 PM
DrGerm's Avatar
Quoted: 21 Post(s)
Thumbs up
I'll be honest, I didn't think this would be the solution. But IT WORKS. Using a Monoprice "Certified Premium" cable.
Thank You.
vn800art likes this.
Denon AVRX7200WA
Samsung UN85JU7100
DrGerm is offline
post #5060 of 5351 Old 09-24-2018, 03:10 PM
Nalleh's Avatar
Liked: 3393
Sure, i have done this for almost 4 years, but like i said, it doesn’t work now with Xbox and ATV4K(Atmos MAT), hence my question.
Nalleh’s HT
Nalleh is offline
post #5061 of 5351 Old 09-24-2018, 04:03 PM
Liked: 2848
Thank You.
You're very welcome.
Selden
post #5062 of 5351 Old 09-26-2018, 07:38 AM
avman09's Avatar
Quoted: 117 Post(s)
Liked: 111
The X7200WA has a custom amp assign feature that says " the internal amplifier of this unit is assigned as desired". Does that mean if someone connect the FL,FR,C,SL,SR pre outs to an external amp, then the unused internal FL,FR,C,SL,SR can be re-assigned to any other channels such as the 4 Atmos height channels, surround back channels, zone 2 etc?
avman09 is offline
post #5063 of 5351 Old 09-26-2018, 10:13 AM
jdsmoothie's Avatar
Liked: 12200
All but the C, SL, SR, HT1L, HT1R can be reassigned. AFAIK, no other model (except the Denon "flagship" models) of any major brand mfr has this capability.
Review post 2 in the other X7200W Owner's thread for a table view:
https://www.avsforum.com/forum/90-re...200-x7200.html
post #5064 of 5351 Old 09-26-2018, 05:52 PM
fmalczewski's Avatar
Quoted: 224 Post(s)
Liked: 77
Yup. AFAIK, no other model (except the Denon "flagship" models) of any major brand mfr has this capability.
Okay, how about this one? For now I only have five speakers (and a sub) and I want to bi-amp all five of them. Can this be done?
Or failing that, how about bi-amping the front and the center speakers (all three)?
(I know you you think bi-amping offers nothing, but I'd still like to know... I do have the FL and FR bi-amped and prefer it that way, but I wouldn't mind doing it with one or more of the others like I used to do with my previous Denon.)
fmalczewski is offline
post #5065 of 5351 Old 09-27-2018, 03:55 AM
jdsmoothie's Avatar
Liked: 12200
No as it's not recommended to connect external and internal amp power to the same speaker and to do it with just internal amp power you would need at least 10 on board amps.
The newer 11CH (X6400H, X6500H) and 13CH (X8500H) models feature 5.1 Bi-amp as an AMP ASSIGN setting.
post #5066 of 5351 Old 09-27-2018, 06:17 AM
avman09's Avatar
Quoted: 117 Post(s)
Liked: 111
Thank you very much. So that means if I use an external 3 channel amp to power the FL,FR,C using the pre-outs, I can re-assign the FL and FR for the HT1L, HT1L to do 7.1.4, but if I use an external 5 channel amp to power the FL,FR,C,SL,SR, I can still only re-assign the FL and FR because the C, SL, SR will simply sit idle right? By the way, in the HT1L and HT1R columns, the table shows no signal, what does that mean?
If so, the manual is misleading because it does not spell out the restriction on C,SL,SR.
Also, there is a pre-amp option for the amp assign, so if selected the internal amps are supposed to stop operating, is the pre-amp mode then better than Eco ON in terms of power consumption and heat reduction?
Thanks again for clearing up things the manual does not.
avman09 is offline
post #5067 of 5351 Old 09-27-2018, 06:35 AM
jdsmoothie's Avatar
Liked: 12200
1. Correct.
2. It means no signal is sent via those speaker posts in "Custom" mode.
3. "Pre-amp" mode does not disable the amps, rather simply shunts the signal from getting to them.
avman09 likes this.
post #5068 of 5351 Old 09-27-2018, 07:57 AM
Liked: 2848
In principle you can use Y connectors on the receiver's preamp outputs and two external amps for each of the speakers that you want to biamp. If you do it that way, the receiver's own biamp settings are not involved.
Selden
post #5069 of 5351 Old 09-27-2018, 09:52 AM
Quoted: 224 Post(s)
Liked: 77
Yeah, I kinda forgot how many amplified channels were available. Too bad can't seem to get the three front channels bi-amped though, unless I missed something.
The one other apparently missing feature I thought would be available was the ability to backup the settings somewhere for later reload just in case. (Not quite the same thing, but in my old receiver I was able to save in memory and then later reload my settings the time or two I'd mucked something or other up and couldn't quite figure out what I had done that was wrong. Even something like that would be handy, though so far knock on wood I haven't needed to do that with the 7200.)
Otherwise so far all else is great. Though I was surprised this morning to find my ethernet hard connection had somehow been changed to wi-fi... don't recall doing that myself (but who knows), something to watch. At this point I don't use ethernet much, but sooner or later...
post #5070 of 5351 Old 09-27-2018, 10:01 AM
Quoted: 18 Post(s)
Dont beat yourself up. NES and SNES classics dont work on the front port of any Denon models.
http://manuals.denon.com/AVRx6300h/N...SYxchsdjun.php
Last line on that page is the answer.
The HDMI connector on the front panel supports YCbCr 4:2:0 format only.
this appears on almost EVERY xseries receiver except the 7200, but im pretty sure its true there as well.
the NES/SNES classic devices can only output in RGB color.
The result is its simply incopatable with that port.
Wflagg is offline
AVR-X7200W
