Denon AVR-X7200W 9.2/11.2ch 2014/2015 Receiver Details- - Page 170 - AVS Forum | Home Theater Discussions And Reviews
 4808Likes
post #5071 of 5351 Old 09-27-2018, 11:55 AM
jdsmoothie's Avatar
Quoted: 22423 Post(s)
Liked: 12197
Originally Posted by fmalczewski View Post
Yeah, I kinda forgot how many amplified channels were available. Too bad can't seem to get the three front channels bi-amped though, unless I missed something.
The one other apparently missing feature I thought would be available was the ability to backup the settings somewhere for later reload just in case. (Not quite the same thing, but in my old receiver I was able to save in memory and then later reload my settings the time or two I'd mucked something or other up and couldn't quite figure out what I had done that was wrong. Even something like that would be handy, though so far knock on wood I haven't needed to do that with the 7200.)
Otherwise so far all else is great. Though I was surprised this morning to find my ethernet hard connection had somehow been changed to wi-fi... don't recall doing that myself (but who knows), something to watch. At this point I don't use ethernet much, but sooner or later...
Networking models (excluding HEOS models) to include the X7200W are able to back up the configuration + Audyssey file to a PC using the Web Control feature.
fmalczewski likes this.
jdsmoothie is offline
post #5072 of 5351 Old 09-27-2018, 01:22 PM
avman09's Avatar
Quoted: 117 Post(s)
Liked: 111
Originally Posted by Selden Ball View Post
In principle you can use Y connectors on the receiver's preamp outputs and two external amps for each of the speakers that you want to biamp. If you do it that way, the receiver's own biamp settings are not involved.
I think you probably meant to respond to post#5064. I wasn't the one asking about biamp, but thanks anyway.
avman09 is offline
post #5073 of 5351 Old 09-27-2018, 04:41 PM
DrGerm's Avatar
Quoted: 21 Post(s)
Post
Originally Posted by Wflagg View Post
Dont beat yourself up. NES and SNES classics dont work on the front port of any Denon models.
http://manuals.denon.com/AVRx6300h/N...SYxchsdjun.php
Last line on that page is the answer.
this appears on almost EVERY xseries receiver except the 7200, but im pretty sure its true there as well.
the NES/SNES classic devices can only output in RGB color.
The result is its simply incopatable with that port.
That's very interesting.
However, I don't know how to reconcile this with the 7200? Per a prior thread of reply, I tried a "certified premium" HDMI cable, and it totally works.
I just looked at the same figure, regarding video conversion, for the 7200, and it has a little different caveat listed. Says "The HDMI connector on the front panel is not compatible" only in regards to 4K 60/50 Hz (which I'm not using).
So, I guess I got lucky that this model is different? Because this happens to be a very convenient solution to what I'm using it for
http://manuals.denon.com/AVRX7200WA/...SYxchsdjun.php
Denon AVRX7200WA
7.2.2 [SVS Ultra + PB-13 Ultra + Prime Elevation]
Samsung UN85JU7100
"As you know, you build a home theater in the room your wife gives you, not in the room you might want or wish to have at a later time"
DrGerm is offline
post #5074 of 5351 Old 09-28-2018, 02:01 PM
fmalczewski's Avatar
Quoted: 224 Post(s)
Liked: 77
Okay, apparently I missed those buttons at the bottom when I was poking around on my Mac the other day. Now saved.
That's the good news...
The bad news however is that I just noticed that for some reason the Denon (2016) AVR Remote app on my iPad doesn't see the X7200WA any more. It's been a while since I used it, a few months at least, but it did work rather well back then when I was playing around with it. The 7200 doesn't show up in the list of Detected Denon AVRs, and when I type in the same IP address to Add Devices that I just used for saving, I now get "This device is not supported." Downloaded it and tried it with an old (iOS9) iPod too, same thing (so it's not just iOS 12 messing things up)...
snpanago likes this.
fmalczewski is online now
post #5075 of 5351 Old 09-28-2018, 02:35 PM
Quoted: 224 Post(s)
Liked: 77
Probably one of the side effects of the last 7200 firmware update. A thing or two that used to work fine no longer did, the only change being the firmware, until I replaced the relevant cables a couple months later with those monoprice ones you linked to. And then I replaced all of the rest of my old hdmi cables with them too just to be safe from now on.
(This is with only a 1080p plasma set in the mix, fwiw, no 4K tv yet.)
post #5076 of 5351 Old 09-28-2018, 04:39 PM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
Same issue here. I still get iPad control with the DeRemote app, though.
snpanago is offline
post #5077 of 5351 Old 09-28-2018, 05:30 PM
Quoted: 224 Post(s)
Liked: 77
I wondered about that app when I was checking to see what was available… might try it out at some point.
Pretty lame if Denon has intentionally (or otherwise) unsupported us with its apps.
post #5078 of 5351 Old 09-28-2018, 06:51 PM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
Agreed. Although the DeRemote app isn't free, it's my favorite to control the Denon avr.
snpanago is offline
post #5079 of 5351 Old 09-29-2018, 11:04 AM
Quoted: 224 Post(s)
Liked: 77
Good to know. When I get a chance I'll definitely check it out.
post #5080 of 5351 Old 10-02-2018, 03:59 PM
josey88's Avatar
Quoted: 308 Post(s)
Liked: 33
Well, so far , it is October the 2nd and still no fix update for the Pandora issue on the 7200WA that , according to Denon , was supposed to be out on September .
I am wondering how long we will have to wait until Denon fix this thing …!!!
josey88 is offline
post #5081 of 5351 Old 10-02-2018, 04:04 PM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
Pandora streams fine on my unit, I recently checked in response to your last post on this. I can't understand why if there needs to be a fw fix for this.
snpanago is offline
post #5082 of 5351 Old 10-02-2018, 04:21 PM
mantaraydesign's Avatar
Quoted: 278 Post(s)
Liked: 45
Is this receiver still worth getting today? Looking to buy a new receiver and the price is in my range. Mainly for movies but once in awhile, I do enjoy 2 channel music using Direct Mode.
Thanks for any advice!
mantaraydesign is offline
post #5083 of 5351 Old 10-02-2018, 05:10 PM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
In my opinion it is a big yes! However, it might be overkill if you are not really going to use up to 9 channels, up to 2 subwoofers, Dolby Atmos, DTS:X, immersive audio upmixers, or its video processing and AV source switching. Even if you do not, I'm sure you will enjoy its networking and Bluetooth features, and over all build and sound quality.
mantaraydesign likes this.
snpanago is offline
post #5084 of 5351 Old 10-03-2018, 01:59 PM
josey88's Avatar
Quoted: 308 Post(s)
Liked: 33
Well, yours must be the only one that streams Pandora without a problem . My 7200WA stopped streaming Pandora more than a month ago and I have been waiting for the update fix that it was posted to be out in Sept but it is October already and so far , nothing .
https://denon.custhelp.com/app/answe...75Mv8v~zj~PP~m
josey88 is offline
post #5085 of 5351 Old 10-03-2018, 02:23 PM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
I'm sorry to hear about this. I don't know if my AVR is the only one that streams Pandora properly......hopefully other owners can check their device and chime in.
snpanago is offline
post #5086 of 5351 Old 10-03-2018, 03:08 PM
josey88's Avatar
Quoted: 308 Post(s)
Liked: 33
I wonder if JD knows anything about it … He is always pretty much on top of everything .
Can you find out what is going on about the fix delay , JD ? Many Thanks …..
josey88 is offline
post #5087 of 5351 Old 10-03-2018, 06:16 PM
Quoted: 224 Post(s)
Liked: 77
Yeah and what's up with the Denon AVR Remote app not working with the X7200WA any more? Any info JD?
(Downloaded the DeReomte app the other day but didn't get a chance to play with it, but I think I'll go do that now...)
post #5088 of 5351 Old 10-04-2018, 04:18 AM
jdsmoothie's Avatar
Liked: 12197
Sorry, but no help here as my source has been silent for awhile now.
post #5089 of 5351 Old 10-04-2018, 06:09 AM
camacho8's Avatar
Quoted: 95 Post(s)
Liked: 45
I have the pandora sign in issue as well,It stays stuck on "OK" after a quick flash of "please wait" when trying to sign in.
65 Sony A1E-Oled - Calman Home Ent/C6 HDR2000
Denon - 7200WA - Mirage Speakers
Roku Ultra/Sony UBP-X800M2/4K Firestick
camacho8 is online now
post #5090 of 5351 Old 10-04-2018, 09:24 AM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
Very strange. When I use the Denon’s Pandora app, the login is automatic and my favorites are displayed. Scroll, select and play. I doubt this is a factor, but I’ll mention that I’ve connected to the internet via an Ethernet cable as opposed to WiFi.
snpanago is offline
post #5091 of 5351 Old 10-04-2018, 10:19 AM
Quoted: 224 Post(s)
Liked: 77
Peculiar. Well I hope things get straightened out.
post #5092 of 5351 Old 10-04-2018, 08:35 PM
josey88's Avatar
Quoted: 308 Post(s)
Liked: 33
That is exactly what is happening to my 7200WA as well .
josey88 is offline
post #5093 of 5351 Old 10-05-2018, 06:50 PM
Quoted: 278 Post(s)
Liked: 45
I just bought the avr-x7200wa and have some questions regarding installation. I would like to do a 5.1.4 speaker setup. But before I do the auto calibration, do I need to change any settings with the avr-x7200wa to get the best results?
Also, on the back of the avr-x7200wa, which speaker connections do I use to connect the 4 ceiling speakers? I put a red square around the speaker connections with the 2nd picture, are those connections correct to use?
Please see the attached pictures.
Name:	Dolby Atmos 1.jpg
ID:	2464532   Click image for larger version
Name:	Ceiling Speakers.jpg
post #5094 of 5351 Old 10-06-2018, 02:49 AM
Quoted: 224 Post(s)
Liked: 77
Try reading through the manual. These are fairly basic questions that can be answered pretty readily that way. And there are tons of things you may need to know about your receiver so may as well get familiar with it.
post #5095 of 5351 Old 10-06-2018, 05:27 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
If the receiver is not new-in-box (i.e. if it's refurbished or used) be sure to do a "return-to-factory-settings" reset. Do it several times in a row to ensure that all of the previous owner's settings are cleared out. Sometimes, for example, they'll have disabled some of the input connections, making them "hidden". This can be quite frustrating.
The Audyssey speaker calibration ignores all of the initial speaker-related settings and changes them to what it thinks is appropriate. You might not agree with those changes, though, and can modify them in the "manual" speaker settings menu. In particular, after calibration, change any "Large" speaker designations to be "Small" and raise any crossover frequencies which are lower than 80Hz to be 80Hz. Don't lower any which are higher, though.
You should seriously consider using the receiver's "Setup Assistant". That script tests each speaker connection individually so you can make sure that they're all done correctly.
Yup: the Height1 connections go to the front overhead speakers and the Height2 connections go to the rear overhead speakers. You have to set appropriate speaker designations, though: Front Height or Top Front for the Height1 connections and Rear Height or Top Rear for the Height2 connections, depending on where you mount the speakers.
If you haven't already, please take the time to look through the Audyssey 101/FAQ. It'll help you to get a good calibration. The instructions in the equipment's owner's manual are pathetically inadequate.
Selden
Selden Ball is offline
post #5096 of 5351 Old 10-06-2018, 06:29 AM
snpanago's Avatar
Quoted: 676 Post(s)
Liked: 692
I don’t think this will make you feel any better, but now my Pandora login exhibits the frozen behavior you describe. When I last checked in response to your first post about this, my account was still active and no login was necessary. I just wanted to eliminate any confusion I may have created.
So, hey, when’s that fix coming Denon?
vn800art likes this.
snpanago is offline
post #5097 of 5351 Old 10-09-2018, 08:50 AM
Quoted: 224 Post(s)
Liked: 77
Fwiw, a new version of the Denon 2016 AVR Remote iOS app was available last night, didn't have a chance to try it out, maybe tonight.
From the (pretty generic) notes: "Your Denon product may require a firmware update to work with this app. Please update the firmware via the system setup menu. (General>Firmware) If the App doesn't work well, please try to unplug the power cord of the main unit and reinsert into the power outlet or check your home network".
post #5098 of 5351 Old 10-09-2018, 05:42 PM
Quoted: 224 Post(s)
Liked: 77
Ok, so I just tried the updated Denon app. It did not see my 7200. And it no longer has the option of typing in the IP address that may/not have been a workaround when it was being stubborn in past times (though that didn't work either the last prior time or two I tried that approach. I recall it did somewhere along the line however). So no new firmware, guess I just need to unplug and reinsert.
post #5099 of 5351 Old 10-10-2018, 06:30 AM
josey88's Avatar
Quoted: 308 Post(s)
Liked: 33
Well, it is October the 10th and for the Denon`s Pandora fix for the 7200WA … still nothing .
josey88 is offline
post #5100 of 5351 Old 10-10-2018, 06:45 AM
Quoted: 278 Post(s)
Liked: 45
Question regarding the Amp Assign.The manual is confusing about the speaker configurations. If I am doing the 5.1.4 speaker setup, should the Amp Assign look like this:
Also, the manual is showing that I need an external amp for the rear ceiling speakers. Do I need to buy an external amp just to have 2 more ceiling speakers? Here is what I am trying to do:
AVR-X7200W
