Marantz SR7009 Owner's Thread - Page 107 - AVS Forum | Home Theater Discussions And Reviews
 1002Likes
post #3181 of 3522 Old 06-19-2017, 03:22 PM
Quoted: 13 Post(s)
Liked: 3
Originally Posted by Selden Ball View Post
Marantz' hardware has essentially same design as Denon's, so they have exactly the same heating problems. Maybe people just don't bother writing about it. Either they need lots of open space (several inches on all sides) or they need external fans.
Yes, I plan on giving it 4-5 inches above the AVR and a bit less on the sides.
BTW, I see you have SR7009 - friend of mine who has SR7008 says internal temperature doesn't go above 40-45C usually, what about yours? Had a chance to listen to 4520 and compare the sound quality?
fructal is offline
post #3182 of 3522 Old 06-20-2017, 03:19 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2845
Mine is in "open air" on the top shelf of a shelving unit. It still gets rather warm to the touch. I dunno the exact temperature. It replaced an AV8003. I've never had a Denon to compare.
Selden
Selden Ball is offline
post #3183 of 3522 Old 06-30-2017, 12:08 AM
danielrg's Avatar
Quoted: 185 Post(s)
Liked: 62
A firmware update showed up for my SR7009 tonight. My wife was turning on theater for us to watch a movie and just said "yes" when it turned on. "It said it would only be 6 minutes"
Not sure what I just downloaded/updated to... I don't think I've gotten a firmware update since I bought it in Nov 2015.
Didn't see anything on the Marantz website about it. They say the latest FW for my Serial # is from Mar 2015.
After update my FW version is: 6845-3161-6010-06. Don't know what it was before...
Hardware and System engineer. Enjoy theaters, automation, media and the outdoors.
Love the hobby, but always have to remember to keep family first!
"The Escape Pod" - First Theater Build
danielrg is offline
post #3184 of 3522 Old 06-30-2017, 04:28 AM
Quoted: 4283 Post(s)
Liked: 5235
I got the same update. Does anyone know what it was for?
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #3185 of 3522 Old 06-30-2017, 08:10 AM
Liked: 2845
Did you already have the Pandora update which came out a few months ago?
Selden
post #3186 of 3522 Old 06-30-2017, 03:25 PM
Liked: 5235
Yes
John
jrref is offline
post #3187 of 3522 Old 06-30-2017, 09:10 PM
genesplitter's Avatar
Quoted: 117 Post(s)
Liked: 68
I got the firmware update notice today too with update time = 10 minutes (estimate). Choosing Included Items displays "Thes update improves overall performance and stability."
I didn't update yet but will likely do it over the weekend.
U-Turn Orbit Plus turntable, Marantz SR-7009 AVR, iNuke 6000DSP, DIY LinkwitzLab speakers, MartyCube + JohnnySub, BenQ W1070, Roku stick, Plex
genesplitter is offline
post #3188 of 3522 Old 07-04-2017, 09:57 AM
Liked: 0
The first troubleshooting step to perform would be a "soft reset" which simply involves powering off the AVR, pulling the power cord and HDMI cable connecting the AVR to the TV for 10 minutes. Doing this involves no loss of settings.
If still no joy, then you can perform a "Network reset" which requires pressing/holding the "MOVIE" and "MUSIC" buttons on the front panel for about 5 seconds while powering on the AVR.
Originally Posted by buggs1a View Post
^^^^^^ Thanks all. It's working again. Whew.
Having same problem, no on screen display for Pandora, airplay, internet radio, basically any of the built-in Marantz options. When on AppleTv or Cable box all displays and on screen menu's work perfectly. Have tried both a soft and network reset to no avail. Might try a network reset again. Any ideas? My unit is a refurb unit that is up to date with today's latest firmware.
jhenderson2872 is offline
post #3189 of 3522 Old 07-07-2017, 07:13 PM
Quoted: 41 Post(s)
Liked: 25
I got this firmware update as well, 6 minutes. After doing it, my receiver now (1) has skips in audio from all inputs and (2) is disconnected from internet -- It was on wifi, and just searches indefinately for any wifi now and also cannot work with wired. Clearly this firmware update has messed something up. Is there a way I can simply roll back to before the update, and if now, how do I reset the entire damn thing to stock specs? I REALLY do not want to have to recalibrate and adjust all my settings again, but this is intolerable!
ETA: I have two 7009's actually. One upstairs I am not updating!
I tried pulling power cable, but did not remove any hdmi cables (why?) and only waited 20 seconds, not 10 minutes. Will try this later and also will try the network reset. If this doesn't work, what is the next step? Even if network is fixed, my audio on all sources is still skipping (happesn about once every 3-4 minutes a brief judder/skip).
MikeR397 is offline
post #3190 of 3522 Old 07-07-2017, 10:15 PM
Mike Butny's Avatar
Quoted: 1032 Post(s)
Liked: 2293
I do not have any issues after the firmware upgrade.
woodhead2 likes this.
Mike Butny is offline
post #3191 of 3522 Old 07-07-2017, 10:33 PM
jdsmoothie's Avatar
Quoted: 22007 Post(s)
Liked: 11931
Yes ... if you can download an earlier firmware update, then you can roll the AVR back to that firmware version, otherwise you can try doing a network reset as I describe in post 3162.
jdsmoothie is offline
post #3192 of 3522 Old 07-08-2017, 06:22 PM
Quoted: 41 Post(s)
Liked: 25
I downloaded the "latest" firmware which was dated from March via http://us.marantz.com/us/Support/Pag...ctupdates.aspx and installed it via USB per the instructions. Instantly fixed the issue, able to connect to wifi, stream airplay, and so far no sound skipping. Right away I was asked again to update firmware to the one that messed it up before to "improve system stability" and I said no thanks, don't remind me again!
VideoGrabber likes this.
MikeR397 is offline
post #3193 of 3522 Old 07-08-2017, 09:47 PM
danielrg's Avatar
Quoted: 185 Post(s)
Liked: 62
I'm glad that resolved things. I wanted to see what happened on the forums before I updated mine, but my wife was trying to be helpful. Fortunately, I haven't had any issues at all - though I haven't tried streaming from my DLNA server yet... Good to know we can roll back if needed.
danielrg is offline
post #3194 of 3522 Old 07-09-2017, 07:49 PM
wagnerc's Avatar
Quoted: 46 Post(s)
My receiver just stopped. On start it tries to power up and then the red light blinks. I have removed all cables and done a factory reset, but it is still not starting up. I had beeen using it just before without issue.
wagnerc is offline
post #3195 of 3522 Old 07-10-2017, 03:08 AM
Liked: 2845
Unfortunately, that means that something has failed in the amplifier circuitry. You'll have to contact Marantz about getting it repaired.
Selden
post #3196 of 3522 Old 07-10-2017, 04:04 AM
jdsmoothie's Avatar
Liked: 11931
Try doing a series (at least 4-5) of microprocessor resets in a row. If the AVR is connected via a power strip, try removing the power strip and connect the AVR directly to the wall. Was there a recent electrical related incident in the home? Otherwise, if still no joy, if the SR7009 was purchased new from an authorized dealer, it would come with a 3 year warranty so should still be covered for Marantz warranty repair, additionally, if purchased with a credit card, the card issuer may cover it for an additional 4th year as well. Contact your closest authorized Marantz repair facility for an RMA.
post #3197 of 3522 Old 07-16-2017, 04:33 PM
Quoted: 102 Post(s)
AUDYSSEY BEST PRACTICES:
Hi there. I've just reinstalled my SR7009 after running an Anthem MRX 1120 for a few months. I need to run Audyssey again to optimize my system.
Current setup:
Paradigm Prestige 85F L+R
Paradigm Prestige 45C Center
Paradigm Monitor 3 v3 Surrounds
Paradigm Studio CC 470 Surround Back
Dolby Atmos height
Dual SVS SB-2000 Subwoofers
Emotiva XPA-5 Amp (Currently just running Atmos Rear Height speakers)
My question is: Are there any hacks/best practices for getting the most out of Audyssey XT32? I've looked in this thread and in the Audyssey thread but haven't found anything definitive. Has anyone found anything for the 7009?
Host of The Beginner Audiophile Podcast http://beginneraudiophile.com - @beginneraudiophile on IG
This Week: Paradigm Prestige 85F mains | Paradigm Prestige 45c center | Paradigm Monitor 3 surrounds | Marantz SR7009 | Emotiva XPA-5 | Marantz 5005 Blu-Ray | Apple TV 4 | REGA DAC.
emptyo is offline
post #3198 of 3522 Old 07-17-2017, 03:34 AM
Liked: 2845
Current setup:
Dolby Atmos height
I don't know of any best practices for XT32 which don't also apply to the lesser versions. Other than resolution, the major difference is in the support for dual sub outputs in those devices with XT32 which include Sub EQ XT. Best practices for dual sub placement are separate from the use of Audyssey.
If you haven't already done so, please take the time to look through the Audyssey 101/FAQ. It will help you to get a good calibration. The instructions in the receivers' owners manuals are pathetically inadequate.
Selden
post #3199 of 3522 Old 07-17-2017, 09:16 AM
Quoted: 102 Post(s)
Ok thanks selden.
emptyo is offline
post #3200 of 3522 Old 07-17-2017, 09:21 AM
jdsmoothie's Avatar
Liked: 11931
Current setup:
Dolby Atmos height
Why waste the power of the XPA-5 on your Rear Height speakers? Consider instead using it to power the L/C/R which require far more power to drive them.
Also, here's a best practice tip: Don't hold the Audyssey mic in your hand or place it on pillows or boxes to get it to your seated head height, rather instead use the included "rocketship" cardboard stand or better yet a camera tripod or mic boom stand.
post #3201 of 3522 Old 07-17-2017, 09:22 AM
Quoted: 102 Post(s)
That's how I had them set up before actually. This time, I wanted to set the receiver up to default. I wanted to get a reference of how it sounded with the stock amps before I use the external again.
emptyo is offline
post #3202 of 3522 Old 07-25-2017, 05:00 PM
VideoGrabber's Avatar
Quoted: 522 Post(s)
Liked: 324
Thanks for the tip, Mike. Never a bad idea to grab a copy, while it's available. Since they appear to only maintain a single version, that means when they update the site with the next one, this will go away. Even if it turns out it is more stable.
VideoGrabber is offline
post #3203 of 3522 Old 07-28-2017, 02:25 PM
samboy87's Avatar
Quoted: 76 Post(s)
Liked: 40
This is the latest update Changelog (EU) if you guys want to know
Changelog SR7009
Last updated:- 29/06/2017
Firmware Vers: 6845-3161-6040-06 (MZ17-024, SR7009N1B,SR7009N1SG, SR7009T1b, SR7009T1SG )
Due to different hardware, the actual displayed firmware version may be slightly different. Please use the online update function to update your unit to latest version.
1) The Spotify Connect Server side of Spotify will be updated. So, the customer
will not be able to play Spotify after updating. (When updating the firmware
of the product, the customers currently using Spotify Connect can continue to
use the Spotify Connect function even after updating the Spotify Connect
Serve.)
2) Even if the customer registers the Audyssey MultEQ XT32 setting to the
Quick Select in the following specific operation, the setting of the MultEQ
XT32 changes when calling the Quick Select.
2-1) Select the Tuner function.
2-2) Set the MultEQ XT32 to "Reference".
2-3) Store the Quick select.
2-4) Call the Quick select.
2-5) The Audyssey MultEQ XT32 is set to OFF.
The symptom is a problem that the setting of the MultEQ XT32 changes when
3) The product cannot play the specific Podcasts (Radio1 RAI, Radio2 RAI) on
the Internet Radio. The symptom is a problem that the specific Podcasts
cannot be played.
4) German-specific text characters (Ä, Ö and Ü) are not displayed correctly
when the customer plays a specific IR station (WDR3 FM93.1 Cologne Live)
in Germany.
The symptom is a problem that German-specific text characters (Ä, Ö and Ü)
are not displayed correctly.
5) The temporary display of GUI on the TV screen (SOURCE, INPUT, SOUND,
VOLUME) may not disappear even after a certain time when the customer
turns on the AV receiver. The symptom is a problem that the temporary
display of GUI on the TV screen may not
samboy87 is offline
post #3204 of 3522 Old 07-29-2017, 03:07 PM
Liked: 5235
Does anyone know how to raise the input level of the audio via the HDMI Arc channel?
I have to raise the volume to 45 on my 7009 when using my set top box or Netflix, for example in order to get a reasonable amount of volume. It just doesn't seem right.
If I run my set top box through the 7009 to the TV then I know there is an option in the Inputs to raise or lower the volume but since the video is going directly to the TV, and the sound via TV audio/hdmi ARC, this is grayed out.
BTW I have the digital output on my Sony A1E and my Verizon VMS 1100 stb to max and there is nothing else I can change.
Any ideas?
Thanks in advance!
John
jrref is offline
post #3205 of 3522 Old 07-30-2017, 08:23 AM
rsonnens's Avatar
Quoted: 602 Post(s)
Liked: 452
Any ideas?
Thanks in advance!
FYI, 45 sounds about right for a Denon or Marantz receiver. I don't think you have an issue except that of expectations of how the volume scale works.
jrref likes this.
rsonnens is offline
post #3206 of 3522 Old 07-30-2017, 09:18 AM
Liked: 5235
Thanks, the only other thing that's driving me nuts is when I use the HDMI ARC from the Apps, it works pretty consistently meaning if i'm watching Netflix, it decodes dolby digital, etc.. but with the stb connected, as I change channels, the 7009 seems to loose sync, decodes whatever then switches back to dolby digital. Very annoying. I get something similar when i'm watching Amazon video. When the stream is coming up to speed, the 7009 switches in and out of Dolby Digital + until the stream is up to speed then sometimes I can watch for 20 minutes then loose the sound. If I pause, go back or forward in the movie then press play, the sound comes back and everything is good again. I'm not sure if all this is interrelated.
I'm thinking of using my stb's optical out and feed it to the 7009 to get around this since the stb is never going to send anything more than dolby digital in the near term. Do you think the HDMI ARC is working properly or do you think something is wrong and I should reset the 7009?
John
jrref is offline
post #3207 of 3522 Old 07-30-2017, 10:11 AM
rsonnens's Avatar
Quoted: 602 Post(s)
Liked: 452
Hard to tell where the issues are with respect to negotiating formats but in general running audio thru the set and to any AVR seems to be unpredictable depending upon TV brand. I suspect your issues are with the TV.
I have a LG C7 and not the AE1 but I found Amazon streaming very unreliable as compared to Netflix with the TVs built in app. (It also somehow screws up my hardwired enet connection while streaming--no other apps do that...must be an LG bug.)
As for everything else (DirectTV, AppleTV, BluRay <non 4k>, Nintendo Wii U) I run everything thru the AVR to the TV. With my older Sony 4k set (850a) everything worked great; with my LG I've had to disable ARC/CEC because of issues I have with LGs CEC screwing up my receivers input during the power on sequence--and use a harmony remote to start everything up.
jrref likes this.
rsonnens is offline
post #3208 of 3522 Old 08-02-2017, 08:28 AM
dan webster's Avatar
Quoted: 262 Post(s)
Liked: 232
I am having the same problem with audio drop outs ever since i installed the new update. When i go to the marantz product update the only firmware it shows is from march 2015 which i downloaded to a flash drive. Is this the correct one to roll back this crappy new update?
Dolby Atmos 7.2.4 YamahaCX-A5200 Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 Sony UBP-X800 4K Ultra HD Blu-ray Jvc RS520 projector
silver ticket 125 2.35 screen Golden Ear Triton 5 L&R
super center XXL triton 7's sides Martin logan motion 12 rears
4 RSL C34 in ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is offline
post #3209 of 3522 Old 08-05-2017, 11:42 AM
Quoted: 17 Post(s)
Liked: 2
I am having similar problems with the new update from 6-29-2017, audio dropout, no WiFi connection and even have a subwoofer problem on one main speaker (FL) no bass output. Rolling back to march update as I type.
Takes about an hour.
Def Tech BP3000's/CLR2500/BP2004's Powered by Marantz SR7009
Chris
lubeman1 is offline
post #3210 of 3522 Old 08-05-2017, 01:39 PM
Quoted: 262 Post(s)
Liked: 232
The firmware roll back was a success. However the first time i installed it with a flash drive it stopped after about ten minutes with an error. I unplugged the receiver for 10 minutes and tried it again and it worked just fine. Everything seems perfect now. Just to clarify this is my sons marantz.
media mode , second sub , SR7009 , svs 20-39 , usb dac
