Marantz AV8802 13.2 XLR Pre/Pro **Official Thread** - Page 510 - AVS Forum | Home Theater Discussions And Reviews
 12753Likes
post #15271 of 15377 Old 02-21-2019, 09:23 AM
Hammmerhead's Avatar
Quoted: 16 Post(s)
Is there a way to turn Audyssey on and of with the remote and not having to go through the GUI? Was hoping you could toggle through it with a button.
Also, after I ran Audyssey, I cant see where it changed the trims on my speakers. Sorry for newb questions, just getting acclimated to this unit
Hammmerhead is offline
post #15272 of 15377 Old 02-21-2019, 09:51 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 11030 Post(s)
Liked: 6573
Thanks for the explanation.
AustinJerry is online now
post #15273 of 15377 Old 02-22-2019, 08:28 AM
ptruce's Avatar
Hi!
I use DeRemote on my iPhone to control my Marantz as it gives a great graphical interface. You can easily turn Audessey on or off using the app. I do this quite frequently when I am calibrating my 4 subs for the room.
Peter
ptruce
Calibrated room - 3 turntables/many phono stages, Oppo 203, Intel NUC i7, Synology 216play, 5 Event speakers, 5 Aperion speakers, 4 sealed subs & Marantz 8802A - Auro 3D in 10.1 setup.
ptruce is offline
post #15274 of 15377 Old 02-22-2019, 02:46 PM
Quoted: 16 Post(s)
Originally Posted by ptruce View Post
Hi!
Peter
Thanks for the heads up!
post #15275 of 15377 Old 02-23-2019, 07:28 AM
Mark1000's Avatar
Quoted: 104 Post(s)
Liked: 45
Select (Pure) Direct on your remote.
Mark
leadliner and Hammmerhead like this.
Marantz 8802A | Rotel RB 1590 / 1555 | Bowers Wilkins 804D3 / HTM2D3 / DB3D / 703S2 / 706S2 | Oppo 205 | Bluesound NODE 2i | LG OLED65E8 | Denon AH-D7100 | Chromecast Ultra | Apple TV4K | Cable box 4K | Darbee Darblet
(Denon 4520 | LG OLED55E6 | B&W 703 / 705 / HTM7 / ASW700 | Oppo 203 / HA-2SE | Apple TV | Chromecast Ultra / Audio | Denon AH-D2000)
Mark1000 is offline
post #15276 of 15377 Old 02-23-2019, 07:47 AM
Liked: 6573
Mark
That disables bass management as well, which may not be desirable.
Hammmerhead likes this.
post #15277 of 15377 Old 02-23-2019, 08:48 AM
jdsmoothie's Avatar
Quoted: 22034 Post(s)
Liked: 11950
You can set up two Smart Select buttons for the same source. One with Audyssey ON and one with Audyssey OFF.
jdsmoothie is offline
post #15278 of 15377 Old 02-23-2019, 09:44 AM
Mark1000's Avatar
Quoted: 104 Post(s)
Liked: 45
OK. You win.
Mark1000 is offline
post #15279 of 15377 Old 03-01-2019, 12:14 PM
boe
boe's Avatar
Quoted: 1207 Post(s)
Liked: 545
Anyone notice the ALLM firmware update for the 8802a?
boe is offline
post #15280 of 15377 Old 03-01-2019, 01:30 PM
Liked: 6573
I'm pretty sure that came out months ago.
boe likes this.
post #15281 of 15377 Old 03-01-2019, 01:37 PM
boe
boe's Avatar
Liked: 545
Good to know - anything to get excited about?
boe is offline
post #15282 of 15377 Old 03-01-2019, 04:06 PM
Liked: 6573
You can read the release notes. I always recommend upgrading to the latest FW, whether the enhancements and/or fixes pertain to your setup or not. I have not heard of anyone who has had an issue with this FW version (or previous versions).
post #15283 of 15377 Old 03-03-2019, 10:21 AM
Quoted: 16 Post(s)
Thanks for everyone's help. I noticed that when playing a Blu ray audio disk, when I go to pure direct I get a big bass boost. I was assuming direct and direct pure were without any settings added. Would this be bass a management setting? When I leave it in AUTO it brings it back down, but it does sound better in Pure direct, but don't know how to tame it. My sub output level at its setting is about 25% I have Audyssey turned off.
Thanks all
post #15284 of 15377 Old 03-04-2019, 08:06 PM
boe
boe's Avatar
Liked: 545
Just curious - does anyone have a link to the release notes? I googled and even downloaded the firmware for thumb drive and couldn't find them. I'm sure they are easy to find but I'm not succeeding.
boe is offline
post #15285 of 15377 Old 03-04-2019, 08:38 PM
Liked: 6573
https://www.avsforum.com/forum/90-re...l#post56976092
https://marantz-uk.custhelp.com/app/...w-latency-mode
boe likes this.
post #15286 of 15377 Old 03-04-2019, 08:45 PM
boe
boe's Avatar
Liked: 545
Good to know - thanks.
boe is offline
post #15287 of 15377 Old 03-10-2019, 08:45 AM
Quoted: 140 Post(s)
Liked: 208
I posted same question in the CIH forum, but... why is the 8802a not vertically stretching? On/off - makes no difference. It still shows 16:9...
Thank you in advance for any ideas
edit: nevermind- 4k at 60fps cannot be stretched by the marantz... the oppo it is...
hope this helps to somebody with similar issue and wondering
partcrash is offline
post #15288 of 15377 Old 03-22-2019, 08:23 AM
dmarcink's Avatar
Quoted: 189 Post(s)
Liked: 125
If HDMI-CEC is enabled on both my AV8802a, and Bravia-Sync (HDMI-CEC) on my Sony A1E OLED....
1. Will the Sony come out of standby when the AV8802a comes on?
2. Will the Sony go into standby when the AV8802a goes off?
Something I will try this weekend. Just looking for experiences with HDMI-CEC controls.
"Every time I put the line in the water I said a Hail Mary and every time I said a Hail Mary I caught a fish." - Fredo
Sony XBR65A1E-Marantz AV8802a-Oppo BDP-203-Parasound Halo A21 & A31-ZoneMaster 1250 -Zamp v.3 (x2) -Paradigm Studio Sub-15 -Vandersteen Signature 2ce Mk II -Vandersteen VCC-2 center -Energy RVSS Surrounds -Yamaha NS-IC800 ceiling Atmos(x4)- Furman Elite 15i
dmarcink is offline
post #15289 of 15377 Old 03-22-2019, 10:31 AM
jdsmoothie's Avatar
Liked: 11950
You'll need someone who has that exact model to respond as HDMI-CEC is rather iffy otherwise.
post #15290 of 15377 Old 03-26-2019, 07:50 AM
dmarcink's Avatar
Quoted: 189 Post(s)
Liked: 125
I did enable HDMI-CEC on both my AV8802a, and Bravia-Sync (HDMI-CEC) on my Sony A1E OLED.
I now use just the Sony's remote "ON" button to take the panel and AV8802a in-and-out of standby.
Works great.
dmarcink is offline
post #15291 of 15377 Old 04-01-2019, 04:21 PM
Maddmaster's Avatar
Quoted: 104 Post(s)
Liked: 48
There is also an Android version of the remote control app just like the Apple. So your options are open for both iPhone, iPad, Android Phone and Android OS tablets. The GUI is much easier than going thru the screens using your remote control.
Definitive Technology:Front Height - Mythos Gem XL
Front - Mythos ST-L, Center - Mythos 10 & 8
Side Surround - Gem XL
Back Surround - Gem XL
Sub - Supercube Ref, SVS SB13 Ultra, SVS SB16 Ultra
There can never be enough music
Maddmaster is offline
post #15292 of 15377 Old 04-09-2019, 08:21 AM
Gates's Avatar
Quoted: 291 Post(s)
Liked: 143
For the life of me I can't figure out a problem...I decided to hook up a OPPO 93 as a backup in my AV rack and I get no sound, only video. Connected it to different outputs with same result. Tried the OPPO on my TV upstairs and I get sound, so it's not in the player. Everything is to Bitstream. Changed the HDMI cable, same. Went into the 8802 and checked all the settings and even reset to default the inputs. Also made sure the setting for AVP or TV was set to AVP. Frustrated.
JVC DLA-RS1000, 120″ EluneVision Reference Studio AudioWeave 2.35:1 CinemaScope screen, Marantz AV8802a Pre/Pro, Anthem MCA 525, Anthem MCA 225, Anthem PVA-4, Paradigm CI Elite E80-R ceiling speakers x4, Paradigm Prestige 95F, Paradigm Prestige 15B x4, Paradigm Prestige 55C, Paradigm Signature Sub 1, Panasonic UDP820 UHD player, OPPO 203 UHD player, Richard Gray 1200c Custom power conditioner, AC Infinity AIRCOM X4.
Gates is offline
post #15293 of 15377 Old 04-09-2019, 09:11 AM
jdsmoothie's Avatar
Liked: 11950
Try doing a "soft reset" by powering off the AVP and unplugging the power cord for a few minutes, which should result in no loss of settings.
post #15294 of 15377 Old 04-09-2019, 09:23 AM
Gates's Avatar
Quoted: 291 Post(s)
Liked: 143
I'll try but I still get sound from my 203 though?
Gates is offline
post #15295 of 15377 Old 04-09-2019, 12:27 PM
DOC1963's Avatar
Quoted: 115 Post(s)
Liked: 148
Contact OPPO support... they have a special (firmware) patch that helps their older HDMI 1.4 products play nicely with HDMI 2.0 boards. It's not available on their site, so you'll have to contact them directly. Shooting them an email will do...
DOC1963 is online now
post #15296 of 15377 Old 04-11-2019, 09:02 AM
Gates's Avatar
Quoted: 291 Post(s)
Liked: 143
Thank you I will contact them today. Have been pretty busy so I didn't get a chance yet.
Gates is offline
post #15297 of 15377 Old 04-11-2019, 03:43 PM
Gates's Avatar
Quoted: 291 Post(s)
Liked: 143
It worked, thanks a bunch!
DOC1963 likes this.
Gates is offline
post #15298 of 15377 Old 04-13-2019, 10:06 AM
steady teddy's Avatar
Quoted: 180 Post(s)
Liked: 66
Been losing connectivity lately with the Deremote app on both iPhone & iPad. Already did a soft reset (unplugged then unit for 10 minutes) which fixed it only briefly. The 2016 AVR Marantz app works fine. So does the Web UI.
I can't even connect if I enter the IP manually.
I have Simple Control for my entire HT setup and I know that app cannot be running at the same time in order to use Deremote. I made sure that app is closed out but still nothing. 8802A is connected via Ethernet and shows up in attached devices in my network in the Netgear interface.
Any ideas?
Mains: Revel Salon2's powered by ATI AT6002
Center: Revel C208
Surrounds: Revel F208
SW: SVS PB 13 Ultra
Amp: Emotiva XPR5 (surrounds & center)
LG 65 B6P & EF9500
steady teddy is offline
post #15299 of 15377 Old 04-13-2019, 11:46 AM
Quoted: 180 Post(s)
Liked: 66
Any ideas?
Never mind!
I forgot (DUH) I added a Simple Control Hub iPod to my system which is always running unless I close the app myself. That was preventing the Deremote app from opening.
Center: Revel C208
SW: SVS PB 13 Ultra
LG 65 B6P & EF9500
post #15300 of 15377 Old 04-13-2019, 06:24 PM
jdsmoothie's Avatar
Liked: 11950
Never mind!
Thanks for reporting back with your solution.
So many post a question and regardless of whether following a suggested solution by another member or resolve it on their own, never post back to let others know what resolved their issue.
marantz av8802
