The official Dolby Atmos thread (home theater version) - Page 1952 - AVS Forum | Home Theater Discussions And Reviews
 28490Likes
post #58531 of 58863 Old 05-18-2020, 02:07 PM
schwock5's Avatar
Quoted: 240 Post(s)
Liked: 83
Originally Posted by blake View Post
Question about Atmos surround speaker height.
Why does Dolby list average floor to ear height of 45" ? I looked at the seats I have ordered, which are fairly typical theater seats (Seatcraft Equinox), and they list floor to cushion = 21.5". The average bum to eye/ear height in males is 31.5" (googled anthroprometric data). So this puts your ears 53" off the floor (not 45").
Since Atmos surrounds should be equal to ear height (Trinnov actually recommends 12" above ear height), my required speaker height seems to be considerably higher than the usual recommendations.
yes, but do these seats recline? where are your ears when this seat is in reclined position?
EYES: Sony 75z9d
EARS: Klipsch: Front - RF7 | Center - RC7 | Side Surround - RF35 | Rear Surround - RS35
BRAIN: Marantz 8012
FOOD: Oppo BDP 103D: HD and 3D, SACD/CD | Sony UBP‑X700: 4K | Marantz 1975 6300 Turntable (Grado Blue Cartridge)
schwock5 is offline
post #58532 of 58863 Old 05-19-2020, 05:29 AM
Quoted: 1599 Post(s)
Liked: 313
*Update - I just picked up a 2019 Shield. I am able to get Atmos to light up on the NAD while playing Some Amazon Prime content.
That said, I CANNOT get Atmos to light up on any content from Netflix .e.g. The Dirt, House Arrest, Luke cage. (NAD displays Dolby Digital Plus but no Atmos).
Disney+ same thing. NO ATMOS but probably for reasons stated above regarding COVID.
[UPDATE] turns out it's the NOHASSLEAV matrix switch from Amazon that wont make the HDMI handshake with the NAD M17v2. Hooking up the 2019 NVidia Shield PRO directly to the NAD solved the ATMOS issue (Atmos via Netflix, Disney + works fine). Put the Matrix switch back in the mix and found that switching the inputs back and forth on the NAD solves the problem but it's essentially a bandaid fix.
For some reason when I watch Disney plus programs with atmos or anything on Netflix that Has atmos through my Apple TV 4K it only shows “PCM Surround” on the Reciever (NAD 758) instead of Dolby Atmos like it does when I play Dolby atmos movies or games on my XBOX X-is this normal and same for wveryone else?
Sony 75Z9D (5.2.4) Samsung 65JS9500
Monitor Audio Gold 200(2), Gold 350, Gold 50(2), Gold CT280-IDC(4). SVS PC4000(2).
NAD 758, Anthem MCA-5
Apple TV 4K, Nvidea Shield. Mac Mini (2018). Samsung UHD BluRay and X-Box One X. 14 Sonos
Chirosamsung is offline
post #58533 of 58863 Old 05-19-2020, 06:20 AM - Thread Starter
markus767's Avatar
Quoted: 6597 Post(s)
Liked: 3498
Why do you waste people's time by asking the same question over and over again in different threads without ever following through? https://www.avsforum.com/forum/90-re...l#post59661952
dfa973 likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #58534 of 58863 Old 05-19-2020, 09:26 AM
Liked: 313
Sorry, I just wanted clarification if the PCM was truly atmos from other people’s experience to see if it is just a NAD quirk. That’s why.
post #58535 of 58863 Old 05-19-2020, 09:32 AM - Thread Starter
markus767's Avatar
Liked: 3498
And when can you bring yourself to answer the questions in the linked thread so this issue has a chance of getting resolved?
mrtickleuk and dfa973 like this.
Markus
post #58536 of 58863 Old 05-19-2020, 11:12 AM
eaayoung's Avatar
Quoted: 357 Post(s)
Liked: 215
Anyone know if Directv outputs Atmos? I have the Genie server plus the 4K mini and have setup the menu to pass Atmos but not getting it. Passes PCM only per my Denon receiver. I should add, I’m splitting the content via HDMI after the mini with one HDMI cable to the receiver and another cable to the TV.
eaayoung is offline
post #58537 of 58863 Old 05-19-2020, 01:24 PM
deano86's Avatar
Quoted: 723 Post(s)
Liked: 389
You probably answered your own question.... splitting the HDMI audio output will most likely limit it to the capabilities of the lowest available option... thus if your TV can not process Dolby audio, it will force your Directv to output in PCM... Why are you splitting? I take it your receiver has Atmos decoding capability but is not 4K compliant?
deano86 is offline
post #58538 of 58863 Old 05-19-2020, 06:21 PM
eaayoung's Avatar
Quoted: 357 Post(s)
Liked: 215
My Denon 4500 receiver and splitter are both 4K capable. But my Panasonic ZT tv isn’t. I tried it with HDMI and optical and neither one would pass Atmos. But maybe the problem is the content.
eaayoung is offline
post #58539 of 58863 Old 05-20-2020, 01:23 AM
UKenGB's Avatar
Quoted: 69 Post(s)
Liked: 51
I had the exact same problem with my AppleTV 4K. No matter what I played, the AVR (Yamaha 3050) NEVER showed it as Atmos. It was hard to determine what was the cause.
In the end I found it was a 'quirk' of the AppleTV. Although it was correctly set to use Atmos when available, it was NOT doing that. I had to first set it to use HDR, which made the picture worse as my TV is not HDR, but the AVR did then show it was receiving Atmos. I then turned HDR OFF in the AppleTV, so back to normal picture, however it continued to correctly output Atmos when appropriate.
I have no idea why the AppleTV behaved like this, seems like a bug to me and I've no idea if Chirosamsung is suffering from the same problem. BUT, I can say that I had the 'no Atmos' problem on all 4 AppleTVs here and I was able to fix it 100% by following the above procedure on each of my AppleTVs, so they all now reliably output Atmos when they should, whereas previously, they never did.
Try it. Hope it helps.
UKenGB is offline
post #58540 of 58863 Old 05-20-2020, 03:49 AM
anothermib's Avatar
Quoted: 203 Post(s)
Liked: 71
Originally Posted by Dan Hitchman View Post
The last I read, it looks like the Xbox rewraps everything Dolby at least into Atmos even if it actually isn't. Unless MS fixed this, it would be super annoying.
I read somewhere, that they resolved that in some beta. However, that is still the behavior I am getting for all streamed media. What has changed is that the Xbox now appears to do some sort of upmixing on its own, so all channels are actually being used even for non Atmos content. Previously the unused channels remained silent and the Atmos encoding prevented upmixing on the processor. Still not perfect as one can’t influence what is actually happening, but ok for most practical purposes IMHO.
anothermib is offline
post #58541 of 58863 Old 05-20-2020, 07:41 AM
Liked: 313
Sorry, I just wanted clarification if the PCM was truly atmos from other people’️s experience to see if it is just a NAD quirk. That’️s why.
Yes
post #58542 of 58863 Old 05-20-2020, 07:42 AM - Thread Starter
markus767's Avatar
Liked: 3498
Yes
"Yes" what?
Markus
post #58543 of 58863 Old 05-20-2020, 08:16 AM
mrtickleuk's Avatar
Quoted: 6208 Post(s)
Liked: 9031
"Yes" what?
Indeed. . I feel your pain!
Q: "When will you answer the question you keep refusing to answer?"
A: "Yes".
You couldn't make it up!
gwsat and dfa973 like this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #58544 of 58863 Old 05-20-2020, 08:36 AM
Liked: 313
Hi-I tried moving the Apple TV video from HDR and then back to SDR and HDR again but that didn’t change my NAD receiver to show Dolby atmos-it still shows PCM surround on Dolby atmos content...
post #58545 of 58863 Old 05-20-2020, 08:51 AM - Thread Starter
markus767's Avatar
Liked: 3498
mrtickleuk likes this.
Markus
post #58546 of 58863 Old 05-20-2020, 09:27 AM
Liked: 313
Yes
"Yes" what?
Yes is answering your question. The question that I answered from you was will you post on the NAD thread once I figure out a solution to the problem of not having my Apple TV 4K display “ATMOS” on the receiver instead of “PCM SURROUND”
That’s what you asked and that’s what I replied yes to
I PMed you to explain-now I will do so to the other poster as well-that if I can get the answer to the question from the broader sample of people in the Dolby atmos thread that perhaps have an Apple TV that doesn’t display atmos on their receiver either, I can then see if it is unique to the NAD 758 or if this is a Apple TV 4K and all receiver displaying atmos question. Hence me posting this also in the Dolby Atmos Thread
Does this make sense or does it seem like “you can’t make this stuff up” still?
post #58547 of 58863 Old 05-20-2020, 09:51 AM
PeterTHX's Avatar
Quoted: 585 Post(s)
Liked: 447
Originally Posted by xavierlehnsherr View Post
And that's the reason why I could hear sound from the top a lot and why it really gave me an impression that it was more immersive than Atmos.
Unfortunately for me it makes DTS:X more "annoying" than immersive.
Being able to hear the tops all time doesn't make it more natural sounding, particularly when dialogue and other sounds get routed there or to the surrounds when they're supposed to be up front.
Josh Z and tigerhonaker like this.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #58548 of 58863 Old 05-20-2020, 10:11 AM - Thread Starter
markus767's Avatar
Liked: 3498
Looks like you have a very hard time understanding what was said. Is there some kind of language barrier?
I've asked you to post your current settings. Screenshots would suffice. This would be a first step in methodically finding a solution for your issue.
I did NOT ask you to post AFTER you've resolved the issue as my ATV4K and 758 is working just fine and I do get Atmos. So the problem is likely YOU and nothing else.
So can you please send those 2 screenshots so we all can move on to something more productive and less time consuming?
Markus
post #58549 of 58863 Old 05-20-2020, 10:44 AM
Ricoflashback's Avatar
Quoted: 2078 Post(s)
Liked: 1569
***Jesus, tough crowd today. Holier than thou, piling on - - so what if the person has asked the question twice or didn't fully research the answer? Maybe other folks will benefit from the information again - - and not a link. In the time you took to beat down that person, you could have posted the answer already.
Home Theater Setup
SONY 75X900F & 49X900E, Denon X6700H & Emotiva XPA-3, OPPO 103 - 9.1.4 Setup - Speakers - Studio 60's-V.5 (FL/FR), CC-690-V.5 (C), ADP 590-V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub, Cornered Audio (FH/RH), Definitive Technology (Front Wides). Stereo 2 Channel Only - Dali Evidence 470 & MartinLogan Forte Amplifier/Streamer with ARC.
Ricoflashback is offline
post #58550 of 58863 Old 05-20-2020, 11:18 AM
bobbyhollywood's Avatar
Quoted: 39 Post(s)
Liked: 55
Much of the discussion of Atmos and how it's utilized reminds me of the old days when surround sound started to take hold in home theatre. A good number of adopters took the attitude that if they had paid for surround, they should be hearing it all the time - ignoring the intents of the original sound mixers. Some of them would adjust their levels so the surrounds played much higher than they were supposed to be in order to get a more constant surround presence.
This is of course quite different than discussions of films whose Atmos mixes are just plain underwhelming, even at correct levels.
gwsat and PeterTHX like this.
bobbyhollywood is offline
post #58551 of 58863 Old 05-20-2020, 11:59 AM - Thread Starter
markus767's Avatar
Liked: 3498
Are you referring to my post? If yes, how absurd! Chirosamsung asked for help in the NAD 758 thread. I've asked him to provide additional information in order to help him troubleshoot the issue which more likely than not is simply user error. Instead of following up he posted the same question here. When asked when he ever will provide the information necessary for troubleshooting he answered "yes".
Markus
post #58552 of 58863 Old 05-20-2020, 12:06 PM
Liked: 313
That’️s what you asked and that’️s what I replied yes to
I PMed you to explain-now I will do so to the other poster as well-that if I can get the answer to the question from the broader sample of people in the Dolby atmos thread that perhaps have an Apple TV that doesn’️t display atmos on their receiver either, I can then see if it is unique to the NAD 758 or if this is a Apple TV 4K and all receiver displaying atmos question. Hence me posting this also in the Dolby Atmos Thread
Does this make sense or does it seem like “you can’️t make this stuff up” still?
No language barrier. I reside in Canada. Can you remind me of the screen shots needed and I’ll take them shortly-I May have missed that part in the various back and forths
post #58553 of 58863 Old 05-20-2020, 12:09 PM - Thread Starter
markus767's Avatar
Liked: 3498
I've posted that link multiple times and just 7 posts back.
Here it is again: https://www.avsforum.com/forum/90-re...l#post59661952
Markus
post #58554 of 58863 Old 05-20-2020, 02:16 PM
Liked: 313
No language barrier. I reside in Canada. Can you remind me of the screen shots needed and I’️ll take them shortly-I May have missed that part in the various back and forths
Replied in other thread but these are my settings
ID:	2729802   Click image for larger version
post #58555 of 58863 Old 05-20-2020, 04:04 PM
GeorgeHolland's Avatar
Quoted: 103 Post(s)
Liked: 91
I’m just starting to research this now that it seems my Onkyo PR-SC5508 had another HDMI board failure and I have a Marantz AV7705 arriving Thursday.
I will scan the thread and try some search terms but can’t see reading all 1952 pages.
If anyone wants to make quick recommendations for my initial setup while I’m getting up to speed, I would appreciate it.
I currently have FL, center (with bass bin), FR, RS, RR, LR, LS, 18” Subwoofer, 2 ea. 15” subwoofers calibrated as one sub. Speakers include an Infinity Compositions Prelude FL/C/FR and surrounds and two Infinity Cascade Model Three V's. I have 3 additional Infinity Cascade Model Three V’s available if they would work. I have a better set of 5 speakers in another room I can move to replace the Preludes but I want to try these first. I use the other room for my music listening.
My room is a sealed dedicated Theater in my Basement. Approximately 12’ 6” Wide, 18’ Long and a 7’ 10’ high ceiling. Main Listening position has my eyes just over 9 feet away from the screen.
Edit: I just set up my AV7705 and noticed I can configure a single speaker for Surround Back. I'm not opposed to new speakers but configuring a single rear back would give me 4 ea, Infinity Cascade Model Three V’s I could use for Heights. I'll need to find 3 amp channels somewhere. They do have wall mount brackets.
https://www.crutchfield.com/S-ctCym4...ver-gloss.html
Thank you.
ID:	2729884   Click image for larger version
ID:	2729886   Click image for larger version
ID:	2729888   Click image for larger version
ID:	2729890   Click image for larger version
Name:	Heights Front Speakers 2 1000p.jpg
ID:	2740448   Click image for larger version
Name:	Heights Rear Speakers 2 1000p.jpg
Last edited by GeorgeHolland; 06-11-2020 at 09:54 AM. Reason: Added 2 images, Heights Installed
GeorgeHolland is offline
post #58556 of 58863 Old 05-20-2020, 07:37 PM
Quoted: 113 Post(s)
Liked: 61
Thumbs up. This site has a lot of poison. Well really the internet, but at 57 I'm just a dinasuer
Rich 63 is offline
post #58557 of 58863 Old 05-20-2020, 08:11 PM
Quoted: 80 Post(s)
Liked: 45
I don't have the receiver you have, but the MAT decoding that ATV4k uses outputs PCM and an ATMOS capable receiver should decode it properly. Will the NAD tell you that's what it's doing? Found the following in another forum, it should apply to the ATV4k as well:
Dolby Atmos in Dolby MAT
The Dolby Metadata-enhanced Audio Transmission (Dolby MAT) encoder resides in a Blu-ray player to pack the variable bit-rate Dolby TrueHD bitstreams for transmission over the fixed bit-rate HDMI connections. A MAT decoder is subsequently employed in an AVR to unpack the Dolby TrueHD bitstreams. With the introduction of Dolby Atmos, we have expanded this technology to support encoding of Dolby Atmos content as lossless pulse-code modulation (PCM) audio.
A key benefit of Dolby MAT 2.0 is that Dolby Atmos object-based audio can be live encoded and transmitted from a source device with limited latency and processing complexity. Among the possible sources are broadcast set-top boxes, PCs, and game consoles. The Dolby MAT 2.0 decoder in an AVR outputs the object-based audio and its metadata for further processing. The Dolby MAT 2.0 container is scalable and leverages the full potential of the HDMI audio pipeline.
Sony XBR-65A9F, Sony UBP-X700, Denon AVR-890 (cooled by AC Infinity AIRCOM T10), Apple TV 4K, HDFury Vertex, B&W 600 series & LM1s in 7.1 config, Harmony Elite, Hubitat Home Automation, Philips Hue lights
avsngaiouser is offline
post #58558 of 58863 Old 05-20-2020, 11:29 PM - Thread Starter
markus767's Avatar
Liked: 3498
This way: https://www.avsforum.com/forum/90-re...l#post59682536
galonzo likes this.
Markus
post #58559 of 58863 Old 05-21-2020, 06:03 AM
chi_guy50's Avatar
Quoted: 2400 Post(s)
Liked: 2511
I didn't realize they had lawyers in prehistoric times!
Living Room: Sony XBR-65Z9D; Oppo UDP-203; TiVo Roamio Pro/DarbeeVision DVP 5000S; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H; Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55X950G,
Sony UBP-X800, TiVo Mini/DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
post #58560 of 58863 Old 05-21-2020, 07:38 AM
Josh Z's Avatar
Quoted: 5305 Post(s)
Liked: 4394
I approve of your choice of room colors.
GeorgeHolland likes this.
Josh Z
Television and Home Theater Writer/Editor, Primetimer.com
My opinions are my own and do not necessarily reflect those of my employers, whomever they may be.
Josh Z is offline
