Emotiva XMC-1 Owners Only Thread - Page 221 - AVS Forum | Home Theater Discussions And Reviews
 2610Likes
post #6601 of 7551 Old 02-28-2018, 08:58 PM
enricoclaudio's Avatar
Quoted: 3861 Post(s)
Liked: 4748
Originally Posted by sharok View Post
DIRAC Question:
After DIRAC run is finished and implemented in XMC-1, if the surrounds sound weak to you, is there any way to increase the surround speakers' levels (permanently) if you want to?
Go to Menu/Setup/Speakers/Dirac/Levels then go to Surround and increase or decrease the level for the speakers. Those settings stay and won't change even if you turn the XMC-1 off.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #6602 of 7551 Old 03-01-2018, 07:18 AM
sharok's Avatar
Quoted: 400 Post(s)
Liked: 117
Hi enrico,
Thanks again. I was told that the level values (speakers levels for DIRAC) cannot be changed in XMC-1. But it is good to know that they can be manually changed.
sharok is offline
post #6603 of 7551 Old 03-01-2018, 08:16 AM
tngiloy's Avatar
Quoted: 498 Post(s)
Liked: 315
DIRAC Question:
After setting the speaker levels to your desired level, go into Menu>Setup>Advanced>Backup Settings>Confirm.
If you ever run Dirac again or modify a Dirac reading in Full (and I bet you will) and load a new Dirac solution, Dirac will set all your speaker levels back to '0' after downloading.
You can then set the speaker levels back to your desired levels by going into Menu>Setup>Advanced>Restore Settings>Confirm.
This will save getting out your RS SPL meter everytime you reload a new Dirac solution. I learned this the hard way. Feel free to learn from my mistakes.
"When all else fails, read the manual."
tngiloy is offline
post #6604 of 7551 Old 03-01-2018, 09:30 AM
sharok's Avatar
Quoted: 400 Post(s)
Liked: 117
Many thanks for the tip.
I'm going to buy another subwoofer for my system. So, I will have two subs (Paradigm Seismic 110) near the corners of the front wall (Dual Mono). They will be the exact mirror image of each other. I think DIRAC will group them together. Is there anything that I need to do differently to get an accurate reading / correction for both subs or as long as I go to the DIRAC setting in XMC-1 and choose "dual mono sub" everything will run as expected?
sharok is offline
post #6605 of 7551 Old 03-01-2018, 09:48 AM
MUDCAT45's Avatar
Quoted: 599 Post(s)
Liked: 407
Just a reminder. A "0" reading on the levels does not mean the levels haven't been set by Dirac. They just show 0 as a reference. I assume so that you can easily remember what adjustments have been made from 0 rather than a different value for each speaker.
MUDCAT45 is offline
post #6606 of 7551 Old 03-01-2018, 10:31 AM
tngiloy's Avatar
Quoted: 498 Post(s)
Liked: 315
I realize that, and I actually wish it would show the levels it has chosen. I have a single rear speaker and Dirac consistently sets it 4-5dB too low by my RS DSP meter at the MLP. Think its a problem how it sets single vs 2 rear speakers. I think, even when set to 1 rear it assumes you have two.
Anyway, it's much easier to just 'restore' for me to get it back to my tweak levels.
tngiloy is offline
post #6607 of 7551 Old 03-01-2018, 11:38 AM
MUDCAT45's Avatar
Quoted: 599 Post(s)
Liked: 407
I had no doubt you knew that. I was mostly posting for sharok and perhaps others who did not.
tngiloy likes this.
MUDCAT45 is offline
post #6608 of 7551 Old 03-02-2018, 04:37 AM
falconxr6's Avatar
Must admit my system sounds absolutely aweful with Dirac, and I have the full version. It places the main speakers out of phase, which in turn affects the 2 subwoofers. It sounds amazing without the Dirac. Dissapointed, never had this issue with ARC on a previous Anthem receiver.
I am using the standard issue mic that came with the XMC-1 and a boom stand for the mic.
Emotiva XMC-1 Pre/Pro Emotiva XPA-5 Gen3 Emotiva A-300 Focal Aria 926 Floorstanders Focal Aria CC900 Centre Aperus Verdus Bipole Rears Martin Logan Dynamo 1500X x 2 Subwoofers Oppo UDP-203 BluRay Logitech Harmony Ultimate Remote Philips 65inch 7101/79 UHD LED Display
falconxr6 is offline
post #6609 of 7551 Old 03-02-2018, 09:50 AM
Liked: 4748
Mine sounds great with Dirac preset. I have a miniDSP UMIK-1 mic from Cross Spectrum Labs, though. I have never used the mic that comes with the XMC-1. I did try before ARC (AVM60) and Audyssey (Marantz SR7008) and never liked the results. You can also check your impulse response overlays with REW to see if your speakers and subwoofer(s) are out of phase. Here is my impulse response graph so you can see the way it should look if your speakers and subwoofer(s) are in phase.
Name:	Impulse Response Enrico.jpg
tngiloy and dwa247 like this.
post #6610 of 7551 Old 03-02-2018, 01:03 PM
wilbur_the_goose's Avatar
Quoted: 459 Post(s)
Liked: 227
As far as I know, Dirac doesn't touch phase. What seating model are you using? Are using stereo subs or dual mono?
I have Dirac full and it works great, but I've never tried it with two subs.
Perhaps take another measurement?
wilbur_the_goose is offline
post #6611 of 7551 Old 03-04-2018, 09:34 AM
markymiles's Avatar
Quoted: 156 Post(s)
Liked: 80
Decided the best I could get with my funds as a replacement for my XMC-1 was an Arcam AVR390 used purely as a processor. Seems the best all round package with Dirac I could find.
Hoping it's not too much of a downgrade in audio quality. Happy to report back my findings if anyone is interested. Hopefully get it this week.
Once the RMC-1 and XMC-1 V3 are ready I may consider coming back to Emotiva. For now see you all later..............
Marc Alexander and Modicen like this.
markymiles is offline
post #6612 of 7551 Old 03-04-2018, 10:13 AM
Liked: 4748
Please report back. That's a solution that I would strongly consider in case the XMC-1 never gets the V3 HDMI board.
Modicen likes this.
post #6613 of 7551 Old 03-04-2018, 12:22 PM
Quoted: 459 Post(s)
Liked: 227
Isn't the Arcam AVR390 a receiver? Apples and Oranges comparing it to a processor.
post #6614 of 7551 Old 03-04-2018, 12:24 PM
MUDCAT45's Avatar
Quoted: 599 Post(s)
Liked: 407
Why?
MUDCAT45 is offline
post #6615 of 7551 Old 03-04-2018, 12:32 PM
Liked: 4748
It's a receiver with full pre outs so it can be used as processor. It's full 4K with HDMI 2.0a inputs and outputs, runs Dirac Live and it's ATMOS/DTS-X ready so at this point it offers more than the XMC-1.
wilbur_the_goose likes this.
post #6616 of 7551 Old 03-04-2018, 12:36 PM
Quoted: 459 Post(s)
Liked: 227
I wouldn't be able to use it - no balanced output. I'm not suggesting that it offers benefits - it's just that it's the way I have everything wired.
post #6617 of 7551 Old 03-04-2018, 12:37 PM
markymiles's Avatar
Quoted: 156 Post(s)
Liked: 80
Maybe in times gone by. These days lots of people are using receivers as Processors as the pre amp section is usually very similar if not identical to the processor equivalent. Why pay the extortionate price difference to get what, balanced outputs and perhaps being isolated from some theoretical noise from the amps ?? I'm certainly not paying twice the price for that privelege.
post #6618 of 7551 Old 03-04-2018, 12:53 PM
Quoted: 459 Post(s)
Liked: 227
Gentlemen - you make excellent points
post #6619 of 7551 Old 03-04-2018, 12:54 PM
Liked: 4748
Then go with the AV860 instead. BTW, Dirac Live on Arcam receivers and processor runs at 96KHz/24bit and it comes with full Dirac Live version from factory.
post #6620 of 7551 Old 03-05-2018, 09:15 AM
Quoted: 459 Post(s)
Liked: 227
$5500 is way, way out of my price range.
post #6621 of 7551 Old 03-09-2018, 10:49 AM
dwa247's Avatar
Quoted: 25 Post(s)
Liked: 57
Here is a link to the latest Emotiva Pod Cast: https://cdn.shopify.com/s/files/1/25...87908707991001
Media Room System: Pioneer Elite Kuro PRO-111FD, Oppo UDP-203, Roku Streaming Stick+, Emotiva XMC-1 Processor (5.2 Setup), Emotiva XPA-5 Gen 2 Amp, (4) GoldenEar Aon 2 Speakers, (1) GoldenEar SuperCenter X, (2) SVS SB-1000 Subs, Logitech Harmony 900 Universal Remote, and Furman Elite-15 PFi Power Conditioner
Computer Audio System: AudioQuest DragonFly Red DAC, AudioQuest JitterBug, Audeze LCD-X Headphones, and Audiofly AF180 In-Ear Monitors
dwa247 is offline
post #6622 of 7551 Old 03-15-2018, 01:22 PM
dkersten's Avatar
Quoted: 743 Post(s)
Liked: 1289
Hmm, so April for getting chips to manufacturer, then they will build RMC-1's first, and after that the XMC-1 upgrades. So probably late June or July before we can even send them in.. That is discouraging, my theater will be done around end of June and I've been planning to upgrade my XMC-1 since Feb 2017 thinking for sure it would be out before my theater is done... At least the RMC-1 might be available by then, so maybe I will sell the XMC-1 and just buy the RMC-1... Just another hit to the budget...
dkersten is offline
post #6623 of 7551 Old 03-15-2018, 02:21 PM
tngiloy's Avatar
Quoted: 498 Post(s)
Liked: 315
Yeah. I'm sure the RMC-1 will be ready on time. They always release their products right on time. Their track record is impeccable.
Sorry. The sarcasm is aimed at Emotiva, not you.
My wife tells me I should be more positive, so here it goes. OK, I'm sure none of the products will be ready on time. Positively.
tngiloy is offline
post #6624 of 7551 Old 03-15-2018, 02:31 PM
Liked: 4748
Positive like Dorothy?
tngiloy, Modicen and WOKNROX like this.
post #6625 of 7551 Old 03-15-2018, 05:40 PM
Quoted: 459 Post(s)
Liked: 227
post #6626 of 7551 Old 03-16-2018, 01:50 AM
markus767's Avatar
Quoted: 5651 Post(s)
Liked: 2696
"It is taking longer than we anticipated" – really? That's a first
Not sure why people don't buy equipment that is available right now with features they actually need and be done with it. Emotiva is neither first nor better nor different from the competition.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #6627 of 7551 Old 03-16-2018, 05:38 AM
Wireless member
pepar's Avatar
Quoted: 1507 Post(s)
Liked: 946
It would be interesting to know, if it is knowable, what percentage of A/V enthusiasts make their buying decisions based on a detached analytical approach that is devoid of all emotion. I would think that the percentage would Be small.
Jeff
Marc Alexander likes this.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #6628 of 7551 Old 03-16-2018, 10:28 AM
Quoted: 58 Post(s)
If I could find an XMC-1 gen 2......
Could I upgrade later to the new HDMI boards?
I really don’t want to wait until June.
If anyone knows of a XMC-1 slightly used for sale - let me know?
George
Acousticmoods is offline
post #6629 of 7551 Old 03-16-2018, 10:35 AM
Wireless member
pepar's Avatar
Liked: 946
From the grousing here I would think that you should be swamped with offers.
Acousticmoods likes this.
pepar is offline
post #6630 of 7551 Old 03-16-2018, 10:45 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1991 Post(s)
Liked: 1441
George
Yes. The HDMI board is customer installable.
- Rich
Oppo UPD-205 x 2 | UPD-203 | Sonica DAC | Emotiva XMC-1 (v3) | Revel Salon2s, Voice2, Studio2s | Benchmark AHB2 x 4 | ATI AT522NC | Velodyne HGS-15 | LG 77C9 | Lumagen 2020 | HDFury Vertex x 2
RichB is offline
