Onkyo TX-NR3030 - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #241 of 250 Old 09-18-2018, 08:36 PM
mobileES's Avatar
Quoted: 85 Post(s)
Liked: 49
Been grabbing some Hi-Res Audio files from the net. Does anyone know why the USB port has limited supported sampling rates of FLAC files? Manual says sampling rates of 176.4 kHz and 192 kHz are not supported.
Has anybody connected a Hi-Res Audio device to this AVR?
Dolby Atmos 7.1.4 | Samsung 65" 4K KS8000 Series | Samsung UBD-K8500 UHD Player | Sony DVP-S7700 DVD Player | Onkyo TX-NR3030 Atmos Network Receiver | Energy Veritas 6.3 mains | Energy C-C1 center | Energy C-R100 surround sides and backs | (4) Energy Take Classic satellites heights | Velodyne VA 1215 XII Sub
mobileES is offline
post #242 of 250 Old 12-22-2018, 01:15 PM
zornikbe's Avatar
Liked: 0
Onkyo TX-NR3030 no sound from hdmi
Hello folks,
I've received my early christmas gift from Onkyo ...
No more hdmi audio for me.
The AV receiver does however shows me all the speakers icons, but no sound.
Is this a reflow candidate or do I need to solder a new part ?
Any DIY advice you tech's can give me ?
Thanks Yves
zornikbe is offline
post #243 of 250 Old 12-22-2018, 01:46 PM
Quoted: 182 Post(s)
Liked: 70
Have you check any other digital inputs/sources?
Originally Posted by zornikbe View Post
Hello folks,
Thanks Yves
XBR55X700D/Optoma UHD60
Denon AVR-X8500H
14 Gigaworks S750 Cubes
Acoustimass 15 Series 2 Sub
Too much to list here :)
Anh Nguyen is offline
post #244 of 250 Old 12-22-2018, 09:50 PM
Lozin's Avatar
Quoted: 337 Post(s)
Liked: 163
Hello folks,
Thanks Yves
That’s happened on my 1030 a few times. All I had to do was do a factory reset and that fixed it both times it’s happened to me. It will wipe out all your settings so if you try it write them down beforehand.
Lozin is offline
post #245 of 250 Old 12-23-2018, 05:42 AM
zornikbe's Avatar
Liked: 0
Tried all of the above and nothing ...
Factory reset => no effect
Other HDMI inputs and outputs => no effect
I only get sound from non HDMI sources, like USB, network streaming, tuner, ...
The TX display also shows me the correct audio format.
zornikbe is offline
post #246 of 250 Old 01-25-2019, 02:57 PM
Liked: 0
Onkyo TX-NR3030
Highlights/Specs:
*11.4 channels of power (allows up to 7.4.4 setup!)
*Dolby Atmos processing
*THX® Select2™ Plus Certified
*135 Watt (per channel) @ 8 Ohms
*185 Watt (per channel) @ 6 Ohms
*Wide Range Amplifier Technology (WRAT)
*HDMI 2.0 for 4K Video at 60 fps, and HDCP 2.2 Compatibility
*Separate Block Construction
*Dual 32-bit DSP Engines for High-Resolution Audio
*192K/32 Bit DACs (TI Burr-Brown 2ch x 7)
*4 subwoofer outputs (2 Pre-outs)
*Built-in Ethernet, Bluetooth (2.1 + EDR) & Wi-Fi® (802.11b/g/n)
*Spotify, Pandora, SiriusXM Internet Radio, Slacker, AUPEO! and TuneIn
*DLNA 1.5
*Three HDMI Outputs for Multizone Video
*4K Video Upscaling and ISF Calibration
*MP3, WMA, FLAC, WAV, Ogg Vorbis, AAC, Apple Lossless, LPCM and DSD up to 5.6MHz
*Mobile High-Definition Link (MHL)
*InstaPrevue Input Source Prevue
*Marvell Qdeo (30p) Upscaling
*Multi-Zone Audio and Front Channel Bi-Amping
*11.4 pre-outs, balanced XLR pre-outs, VGA PC input and powered/line outputs
*Built-in fan
*Signal-to-Noise Ratio: 110 dB (Line, IHF-A)
*Power Supply: AC 120 V, 60 Hz
*Weight: 48.5 lbs (22.0 kg)
*Dimensions (W x H x D): 17 1/8" x 7 13/16" x 18 3/8" (435 mm x 199 mm x 466.5 mm)
*Warranty: 2 years (from Onkyo)
anibalc80 is offline
post #247 of 250 Old 07-30-2019, 05:50 PM
mobileES's Avatar
Quoted: 85 Post(s)
Liked: 49
Strange thing I noticed the other day, the AVR has the LPF set to 120hz, so I set the bypass switch on the sub. When I flip that switch to use the sub's internal filter, which is set to 120hz as well, more bass is produced. Should be the same I'm thinking?
Also, in 2.1 Stereo mode, the bass volume is a lot lower than in All Channel Stereo.
Wondering if there is something wrong with my AVR....
My sub is a Velodyne VA-1215XII.
Edit: Nevermind, plugged in my 2nd Velodyne, same settings, switch the bypass/internal x-over switch on the sub, no difference in volume. So it seems the issue is in the bypass switch on my 1st sub.
mobileES is offline
post #248 of 250 Old 12-01-2019, 02:57 AM
Liked: 0
Onkyo TX-NR3030 doing 7.4.2 Atmos?
Hi all,
I have an Onkyo TX-NR3030, and recently managed to get a few THX speakers, 4 Atmos speakers and a subwoofer extra (All Onkyo)
The Onkyo is an 11.2 device, and I would like to setup the speakers in a 7.4.2 configuration (In essence using all the speakers I have got).
As the Onkyo isn 't really recent anymore (I know it can do Atmos), I wonder if the device will actually let me setup the speaker configuration in a 7.4.2 setup...
I hope that someone here can confirm this and maybe give me some pointers what to think of when setting it up like that...
All the speakers are THX certified (except for the Atmos probably). and I am also not too sure whether I should use optical or just use the HDMI ports for best results?
I am not ver knowledgable in this area, so any input from you is appreciated 🙂
Thanks in advance for your help!
FredsterNL is offline
post #249 of 250 Old 12-01-2019, 05:50 AM
Liked: 0
CORRECTION: Onkyo TX-NR3030 doing 7.2.4 Atmos?
Oops, messed up the order: I meant 7.2.4 (2 subs, 4 atmos)
post #250 of 250 Old 12-02-2019, 08:59 PM
mobileES's Avatar
Quoted: 85 Post(s)
Liked: 49
This shouldn't be problem, during the sound calibration setup it checks if there is a 2nd sub. I've ran 2 subs off of it before just experimenting.
mobileES is offline
TX-NR3030
