It was working fine yesterday but now it refuses to switch on for more than 5 seconds. It automatically shuts off with a blinking red, power light. I tried to do factory reset but it didn't work. The same thing happened 2 months ago and they have the whole HDMI board replaced. I am not sure why it happened again as the amp if well-ventilated and shouldn't show any signs of overheating. Any inputs?
Update:
1) Tried dismantling all cables... didn't work
2) Tried to do a factory reset again by unplugging the main power cord... didn't work
3) Tried to do a factory reset again by pressing 2 buttons as indicated in the manual... didn't work
4) Tried a different power source... didn't work
Saw a message at Amazon that one guy is experiencing the same problem after the firmware update. I did the firmware update but that was months ago. Is this the culprit? Is there a way to roll back to the old, factory firmware settings?
Fast blinking light (2/sec) generally means loose speaker wire touching another post, playing 4-ohm speakers too loud, or amp failure.
Slow blinking light (1/2 sec) generally means a ventilation issue.
Disconnect all wires from the unit. If it still powers off when connected directly to a wall outlet (ie. not going through a UPS or switch) then it will likely have to go back for repair as no way to "roll back" the firmware.
Thanks for the tip. Mine blinks around 1 per sec and i am 90% sure that ventilation is not an issue. Since i've returned once just less than 2 mths, the marantz has plenty of upper 10inches and back space of at least 5inches. I am also using a USB fan to aid the airflow.
Problem is how i can be sure this won't happen again in the future even after they repaired it. I am not sure if the HDMI board is the problem to start with.
Yep, that's what I did. Disconnected everything and waited for a few hours yesterday. Still the same problem happens. Very disappointed with this set. I am not sure if it's due to the firmware upgrade or just pure bad luck.
Same story! After firmware update everything has spoiled!
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
