Help With X2000 Reset, Please... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-26-2014, 12:21 AM - Thread Starter
Liked: 0
Embarrassing, but true. I cannot figure out how to reset my AVR-X2000. I have followed the simple enough sounding instructions in the manual (as I understand them) a dozen or more times, and nothing ever flashes. What is the trick? Help, please!
bertlj is offline
post #2 of 5 Old 10-29-2014, 03:55 AM
jdsmoothie's Avatar
Quoted: 23720 Post(s)
Liked: 13061
With the AVR in Standby, you press/hold the 2 buttons on the front panel while powering the AVR to ON using the ON/Standby button on the front panel.
https://www.avsforum.com/forum/90-rec...l#post23134213
jdsmoothie is offline
post #3 of 5 Old 10-29-2014, 09:04 AM - Thread Starter
Liked: 0
JD - Thank you so much for reply. You have confirmed my understanding of the microprocessor reset process. I have attempted this process dozens of times and the results never change... nothing happens other than x2000 turns on. I have continued to hold the +and- buttons until my fingers turned blue, but nothing ever flashes.
Any suggestions appreciated!
bertlj is offline
post #4 of 5 Old 10-29-2014, 09:43 AM
jdsmoothie's Avatar
Liked: 13061
Try using the <Zone 2 Source> and <Dimmer> buttons (ie. Network reset) instead of the <Tuner Preset +> and <Tuner Preset -> buttons. Also press and release the ON/Standby button while continuing to hold the two other buttons.
post #5 of 5 Old 10-29-2014, 01:34 PM - Thread Starter
Liked: 0
JD - Again, thank you very much! I THINK I found a solution. Plugged in Ethernet and using Web Control I discovered Main was Off but Zone 2 was On. Turned off the zone using Web Control and then microprocessor reset seemed to go exactly as described in the manual (and exactly like you description).
THANK YOU!
bertlj is offline
reset , X2000
