Macbook Pro to AVR help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-21-2015, 10:51 AM - Thread Starter
kwell88's Avatar
Quoted: 27 Post(s)
This may be a silly question, but I am struggling and am hoping somebody can lend a helping hand. I have a Pioneer VSX-523 and would like to connect my MBP (13 inch late 2011) to use for streaming movies. I have been able to connect via mini-display port to HDMI for video, and mini-optical to toslink for audio. I have the toslink connected to the only input available on the reciever and the HDMI run to my "dvd" HDMI input. Can anybody explain how to make both audio and video work at the same time? Thanks in advance for the help!
kwell88 is offline
post #2 of 5 Old 02-21-2015, 03:25 PM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2845
Unfortunately, my copy of the Pioneer 523's manual is corrupted.
There should be a setting in the receiver which tells it to associate the TosLink connection with the DVD input.
There should be a setting in the receiver which tells it what audio connection should have priority when the DVD input is selected: HDMI, digital or analog. (select digital).
FWIW, the 522's manual says switch to the DVD input. Then press Signal Sel and choose Audio Signal O1 (Optical 1). Presumably that's similar.
Unfortunately, I'm unfamiliar with Macs, but I'm surprised that it doesn't provide audio over the DisplayPort connection. My 5-year-old Windows laptop does. When the receiver is turned on, has the DVD input selected, and is connected to the DisplayPort-to-HDMI adapter cable, an option should appear in the Mac's audio configuration menu to send sound to the receiver. The option will only be present on the Mac when the receiver is powered on and DVD playback is selected.
You might get more help in the HTPC forum at https://www.avsforum.com/forum/26-hom...ter-computers/
Selden
Selden Ball is offline
post #3 of 5 Old 02-21-2015, 04:02 PM - Thread Starter
kwell88's Avatar
Quoted: 27 Post(s)
I did that, turned it off, turned it back on, and it worked like a charm.. Thanks so much for the help! I knew it was something simple that I was missing.
kwell88 is offline
post #4 of 5 Old 02-21-2015, 06:00 PM
rkeeney's Avatar
Quoted: 13 Post(s)
On my Mid 2010 Macbook Pro 15", I am able to use the HDMI cable to pass both video & audio. I believe that if you go into system preferences, sound, output and select HDMI when you have your MacBook connected to your receiver.
Robert
Robert K.
rkeeney is offline
post #5 of 5 Old 02-21-2015, 09:01 PM
Worf's Avatar
Quoted: 796 Post(s)
Liked: 516
Yeah, I think since 2009 MacBooks supported audio over HDMI. You may need to make sure your adaptor supports it, but if you bought it in the past 5 years it should.
Just use that and be done.
Worf is offline
