The Official Anthem AVM 60 thread - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 4141Likes
post #601 of 9525 Old 02-14-2016, 04:42 AM
Edward Chen's Avatar
When I just hook up AVM60, I just use the value as onkyo 5008 Audyssey before.
The sub is 0 db same by RCA cable, other use XLR cables. After run ARC change to +9 db, confirm by Umik-1 by REW the level is equal to others.
I think gain of RCA signal should be originally less than XLR, so need add some specific gain.
The AVM60 wireless WiFi capability is worse with my ASUS AP, finally both use wire Ethernet cable than ARC can found AVM, this problem took me 3hrs to debug.
Edward Chen is offline
post #602 of 9525 Old 02-14-2016, 05:08 AM
Shrike645's Avatar
Quoted: 102 Post(s)
Liked: 67
Originally Posted by mkohman View Post
Thank you Nick, I have emailed Tech Support but don't think I will hear from them untill Monday.. I will wait and see what they say. Any note of when DTS X firmware will be updated? Many thanks
Monday is a holiday so don't expect to hear anything.
Shrike645 is online now
post #603 of 9525 Old 02-14-2016, 06:30 AM
MitchPope's Avatar
Quoted: 34 Post(s)
Liked: 29
Is that using the latest firmware with the network fix?
MitchPope is offline
post #604 of 9525 Old 02-14-2016, 06:38 AM
Nugget's Avatar
Quoted: 204 Post(s)
Liked: 206
The latest firmware did not fix the wifi problem for me. I have to use the play-fi app to setup wireless. Trying to do it from the anthem can never see any networks.
I like cars, airplanes, running, and coding || current gear: two eyes, two ears, one brain, and some other junk.
Nugget is online now
post #605 of 9525 Old 02-14-2016, 08:28 AM
jerbob's Avatar
Quoted: 13 Post(s)
I had the same problem. MY AVM 60 could not find my network even though I had the latest firmware installed. I was using the push button mode from my router but no love. The push button method had worked for every other device that I had installed in my system. Finally I manually connected by typing in my network password.
jerbob is offline
post #606 of 9525 Old 02-14-2016, 08:46 AM
raffin's Avatar
Quoted: 46 Post(s)
Liked: 46
I was finally able to get mine working on wireless using the play-fi app. I can ping it from my computer, it shows it is connected on the AVMs network menu. All is good, right? No, because my ARC software will still not see it. Guess I'll have to wait for the next firmware update.
raffin is offline
post #607 of 9525 Old 02-14-2016, 11:49 AM
Steve Goff's Avatar
Quoted: 442 Post(s)
Liked: 252
Monday is a holiday in Canada?
Steve Goff
Steve Goff is offline
post #608 of 9525 Old 02-14-2016, 12:07 PM
MitchPope's Avatar
Quoted: 34 Post(s)
Liked: 29
In Ontario where Anthem's headquarters are, and a few other provinces.
post #609 of 9525 Old 02-14-2016, 03:26 PM
Yes, 0.0.035 released on Feb 4.
And how can find the app on Google play?
post #610 of 9525 Old 02-15-2016, 01:49 AM
jimchao's Avatar
Quoted: 32 Post(s)
Liked: 33
My suggestion for your sub level adjustment is to setup your sub level in the mid of volume position, then go to manual level setup and use calibration signal itself to setup your sub to 75db, then run ARC. If this is still the same situation, you should move your sub to a better position.
jimchao is online now
post #611 of 9525 Old 02-15-2016, 04:00 AM
Thank your suggestion.
I think I lost this step since used to be 5008 Audyssey will remind me adjust sub level before EQ measurement begin.
I may use quick measurement of ARC.
post #612 of 9525 Old 02-15-2016, 06:18 PM
splotten's Avatar
Quoted: 292 Post(s)
Liked: 140
Originally Posted by Bahltech View Post
Got my Avm with my 525 amp, I'm setting it up as time permits and waiting for my XLR Canare cables to arrive. I have connected just my 2 front speak with RCA cables.
Seeing as this I my first pre/pro I'm wondering if it's normal to have a small pop when opening the amp or closing it. My 1120 was dead silent. It's not be big pop/crackle from the speakers but still weird to hear this in a amp of that price.
Reminds me of my young days when I had amps in my car with the biggest speakers I could fit.
Make sure to turn on your power amps on Last and turn off power amps First. Then only the power amps them selves can thumb while any source related thumbs or pops are muted.
splotten is offline
post #613 of 9525 Old 02-16-2016, 12:46 AM
yuppi's Avatar
Is it the DAC chips inside AVM60 are still unknown?
yuppi is offline
post #614 of 9525 Old 02-16-2016, 01:39 AM
jimchao's Avatar
Quoted: 32 Post(s)
Liked: 33
Could anyone describe how the performance is after running ARC on AVM60? Specially on ATMOS audition. Does the dragonfly flies at specific position all over the sound field in "Leaf" on DOLBY ATMOS DEMO DISK? You should hear a clear frying track. IMO, Rain fall or anything coming from upper speakers is easy to perform, to hear a sound in specific position in your sound field is not easy to playback if the adjustment does not reach an accurate status. Any comment?
post #615 of 9525 Old 02-16-2016, 01:44 AM
Liked: 0
Oppo 105D vs Anthem AVM 60
I have been using the 105D as a prepro with XLR stereo out. The unit has SABRE 32 bit DACs. Sound quality is excellent but there are a number of usability issues (HDMI handshakes, freezes etc) and I am considering changing to the AVM 60 but not sure about how the sound quality will be with the (still unknown) DACs in the AVM 60.
What do you all think - will it be an upgrade in sound quality going from the Oppo DACs to AVM 60 DACs? Appreciate any thoughts/feedback
akbh is offline
post #616 of 9525 Old 02-16-2016, 07:49 AM
Bluecow003's Avatar
Quoted: 318 Post(s)
Liked: 302
Placed an order for the AVM60 on Sunday along with an Outlaw 7700 amp and I'm looking forward to getting them. My first shot at separates. It should be a huge step up from the 8 year old Pioneer low/midrange AVR I've been using. I just got a Umik-1 as well, so I'll be taking a shot at REW too.
Bluecow003 is offline
post #617 of 9525 Old 02-16-2016, 11:24 AM
Quoted: 88 Post(s)
Known by Anthem, but they don't want to divulge the model - official email. Anyway, DACs are AKM, like in Marantz. Marantz 8802 has 4490.
Mike RO is offline
post #618 of 9525 Old 02-16-2016, 12:22 PM
Steve Goff's Avatar
Quoted: 442 Post(s)
Liked: 252
Statements from Nick strongly suggest to me that the AVM 60 uses the AK4458vn. He said it has the latest, greatest AKM multichannel DACs. Of course few of us could reliably identify the DAC used by the sound produced.
Edward Chen likes this.
Steve Goff
post #619 of 9525 Old 02-16-2016, 12:26 PM
Steve Goff's Avatar
Quoted: 442 Post(s)
Liked: 252
I'd still like to know whether the HDMI ports are now HDMI 2.0a compliant and can now pass UHD signals with high dynamic range and wide color gamut. Can anyone, including Anthem folks, answer this question?
Steve Goff
post #620 of 9525 Old 02-16-2016, 01:29 PM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2384
That's what the specs say:
  • HDMI & Video
  • HDMI 2.0a
  • HDCP 2.2
  • 4:4:4 Subsampling at 4K60 (18.2 Gbps)
  • High Dynamic Range (HDR)
  • BT.2020 Color Gamut
  • On-Screen Display with 4K 50/60
  • 4K 50/60 Switching
stanger89 is offline
post #621 of 9525 Old 02-16-2016, 02:52 PM
Steve Goff's Avatar
Quoted: 442 Post(s)
Liked: 252
  • HDMI & Video
  • HDMI 2.0a
  • HDCP 2.2
Sure, but other processor/AVRs say the same but need a software/firmware update to be fully HDMI 2.0a compliant. The Denon and Marantz units, for example, are also advertised as 2.0a compliant, but they are only now in the process of updating them to be so, as part of the update including DTS:X. So far, only the AV8802A and the 7200AW have been updated. I ask because my Samsung UHD 4K blu-ray player arrives tomorrow.
Steve Goff
post #622 of 9525 Old 02-16-2016, 03:22 PM
maxfli44's Avatar
Quoted: 87 Post(s)
Liked: 61
Guess you get to try it and tell us if it works then
maxfli44 is offline
post #623 of 9525 Old 02-16-2016, 05:06 PM
Steve Goff's Avatar
Quoted: 442 Post(s)
Liked: 252
There have been so many problems with getting the Samsung players to work and properly interpreting the results that it would be helpful to know the actual capability of the AVM 60.
Steve Goff
post #624 of 9525 Old 02-16-2016, 06:48 PM
Nugget's Avatar
Quoted: 204 Post(s)
Liked: 206
I've been unable to pass HDR content through my MRX 1120. There's a handshaking failure if I set my television (Sony X930C) HDMI input to the "Enhanced HDMI" mode that is necessary to receive the HDR content. I have a ticket open with Anthem support on the issue, but have not heard anything back. If I set the television input to enhanced mode, everything breaks. I can't get audio out of my Blu-ray player, and my UHD Blu-ray player and my Fire TV both freak out and I just get simulated static for video. HDMI 1.4 sources (my Apple TV) don't appear to be impacted by the problem.
Bypassing the Anthem "fixes the glitch."
post #625 of 9525 Old 02-16-2016, 08:45 PM
Steve Goff's Avatar
Quoted: 442 Post(s)
Liked: 252
Thanks, Nugget, though this wasn't the answer I hoped for. Are you sure that the Enhanced HDMI setting is required on the Sony? If it allows the Sony to accept 4K 60p at 4.4.4, that is the likely culprit. The Samsung should not revert to 60p at 4.4.4 for its menus, as many cables and devices will have trouble with that signal. I know the Anthem specs say it can take 4K 60p at 4.4.4, but so far such a connection hasn't worked on several devices that supposedly meet that spec.
Steve Goff
post #626 of 9525 Old 02-16-2016, 10:25 PM
Liked: 0
Hello guys,
Am new to here, got question wanna ask for help
I have similar connecting problem with my newly purchased AVM 60. The ARC couldn't find the it but I can control the amp via the Anthem mobile app (I assume it is 'found' in the home wireless network)....I am not sure if it is the problem of my wireless router which I use Apple Airport Extreme...and I am not familiar with the network stuff, it cause me so frustrated as I would like to try the ARC to tune my room.
Hope you guys can share some tips and hints
Many thanks
Eddie
eddiengan is offline
post #627 of 9525 Old 02-16-2016, 10:27 PM
Liked: 0
Hello guys,
Many thanks
Eddie
post #628 of 9525 Old 02-17-2016, 01:03 AM
Originally Posted by eddiengan View Post
Hello guys,
Many thanks
Eddie
For my ASUS AP, finally both AVM60 and laptop wired by Ethernet cable than ARC can found AVM.
Suggest try this way
MyAv [email protected]
Anthem AVM60/QSC DCA 1644*3/BDP-S780/Viewsonic pro8200/Klipsch UltraII/Rythmik FV15HP
post #629 of 9525 Old 02-17-2016, 01:28 AM
I also use onkyo 5008 Audyssey XT32 before and measure SPL by REW using umik-1.
I compare the center channel low frquency SPL chart after ARC running, the diff of center channel only replace pre-processor and RCA to XLR cable.
The compare result between Audyssey and ARC I feel is quite comparable above 50Hz, below ARC may have more +3~5dB sound level.
post #630 of 9525 Old 02-17-2016, 07:38 AM
Nugget's Avatar
Quoted: 204 Post(s)
Liked: 206
My understanding is that the enhanced setting is required for the Sony television to accept HDR color. But it does also enable 4K 60p 4.4.4. Here's the relevant screen shot. I don't claim to really understand any of this deeply. All I know for certain is that with enhanced turned on I have to bypass the Anthem or all hell breaks loose and nothing works right. With the K8500 plugged straight into the television it looks fantastic, though.
I'd encourage you to contact Anthem support directly if you haven't yet. More reports of problems (and specific equipment combinations that they might be able to use for reproducing the issue) will certainly help.
antehm arc genesis , anthem avm 60 , the official anthem avm60 thread
