The Official Anthem AVM 60 thread - Page 24 - AVS Forum | Home Theater Discussions And Reviews
 4140Likes
post #691 of 9518 Old 02-23-2016, 02:31 PM
mkohman's Avatar
Quoted: 398 Post(s)
Liked: 340
It's not that I want to make changes. The cross over for my fronts are usually 100 hz and subwoofer is usually 120hz.. Subwoofer is now 250hz isn't that a bit too much?
mkohman is offline
post #692 of 9518 Old 02-23-2016, 03:02 PM
Edward Chen's Avatar
Just like my experience, I got umik-1 with REW.
Before ARC, I use REW to confirm SUB PEQ and distance even cut off frequency.
And before ARC calculation, I use the cut off above as profile 2(front 100Hz), profile 1 keep it was.
After upload, I use REW to check center again, the SPL of profile 2 100~130Hz looks terrible.
You may try it and sound it then decide if don't have REW.
Edward Chen is offline
post #693 of 9518 Old 02-23-2016, 03:12 PM
maxfli44's Avatar
Quoted: 87 Post(s)
Liked: 61
Both my subs are crossed over at 80hz, fronts set to 60 centre 80 and surrounds at 120.
maxfli44 is offline
post #694 of 9518 Old 02-23-2016, 05:26 PM
Red99's Avatar
Quoted: 776 Post(s)
Liked: 418
Are you talking about the crossover that is on the back of your subs amps? Im not familiar with ARC, but generally the crossover on the sub itself should always be set at max Hz. Then in the processor you set your mains to small, and set all speakers crossovers at 80Hz (if they ea will play down that far). 80Hz is THX standard. Any higher and the sub(s) can become localized. If the L/C/R is set higher, then if this subs are on the front wall, then its no problem. So depending on the room, speakers, and personal taste, a person may choose a different crossover. But unless the AVM60 is different from other AV processors, the crossover at the sub should always be wide open so you let the AV processor do all the bass management.
The way you have it now, you are lacking LFE from 80Hz to 120Hz on your surrounds.
Red99 is offline
post #695 of 9518 Old 02-23-2016, 05:47 PM
maxfli44's Avatar
Quoted: 87 Post(s)
Liked: 61
Well there you go been doing it wrong my whole life. Guess I should read the manual once in a while. Will try it out right away. Huh had no idea that was the way to set it up lol. Thanks I appreciate the tip.
maxfli44 is offline
post #696 of 9518 Old 02-23-2016, 05:58 PM
Red99's Avatar
Quoted: 776 Post(s)
Liked: 418
Well your way is the old school way before we got smart AVRs, smart phones, smart cars, smart bombs, etc... lol
Red99 is offline
post #697 of 9518 Old 02-23-2016, 06:16 PM
maxfli44's Avatar
Quoted: 87 Post(s)
Liked: 61
LOL you are right I am old :stuck_out_tongue_winking_eye:
maxfli44 is offline
post #698 of 9518 Old 02-25-2016, 01:47 PM
Dr_Gonzo_DK's Avatar
I got my AVM 60 ten days. Coming from a mxr 710, I'm pretty happy about the upgrade. But I have a problem: the ARC-software will not let me rename the configurations. I was able to rename Configuration2, but number 1, 3 and 4 I can not rename. When trying to, the name just changes back to configuration 1, 3 or 4, as soon as I'm done typing. Has any of you expirenced the same? Is there a solution to my problem?
Edward Chen likes this.
Dr_Gonzo_DK is offline
post #699 of 9518 Old 02-25-2016, 01:54 PM
Quoted: 42 Post(s)
Liked: 3
Have you done the update ?
Music can move you "with enough bass"
Bahltech is offline
post #700 of 9518 Old 02-25-2016, 01:58 PM
Yes. Both the latest firmware end version of ARC.
post #701 of 9518 Old 02-25-2016, 05:37 PM
Same as mine, only profile2 can be renamed.
But not big issue for me, biggest is can't wireless connect to my ASUS AP so couldn't use Play-Fi till now.
MyAv [email protected]
Anthem AVM60/QSC DCA 1644*3/BDP-S780/Viewsonic pro8200/Klipsch UltraII/Rythmik FV15HP
post #702 of 9518 Old 02-25-2016, 06:12 PM
DNbass's Avatar
Quoted: 23 Post(s)
It's been quite sometime since I've consistently visited one of my favorites sites. I'm very, very overdue for an AV upgrade and the Anthem is on my shortlist (subscribed).
I know this thread is to focus on the AVM60, but wanted to share others that I've been looking closely at, AV Pro, Amp, respectively:
Rotel: RSP1582 / RMB 1785
Parasound Halo: P7 / A51
Marantz: AV8802 OR 7702mkII / MM7055
Or combinations of the above. Although in different price range, I did look at Emotiva as well.
Last but not least, AVM 60 / MCA 525. I'd appreciate feedback from folks that have experienced with this combination or my short list.
DNbass is offline
post #703 of 9518 Old 02-25-2016, 10:30 PM
CM Harrington's Avatar
Quoted: 62 Post(s)
Liked: 347
Red face
Hey there!
I too have been out of this forum for so long, they didn't even have my login in the system anymore. Anyway, I have the AVM60 and a Parasound A51 feeding B&W 803D mains, and a HTM2D2 centre (via Anticables, although I'm not sure how much that matters). I play a good mix of high-res audio, and video. My surrounds aren't currently hooked up, due to room reconfiguration. I can tell you I really enjoy the sound from this combination. I haven't used the ARC room correction yet, as I don't have a PC with which to run it (Mac house). I watched Ant Man on Blu Ray recently, and used the Master Audio track, and I've never heard a more life-like reproduction. Once I dialed-in the speaker distances, it was a night-and-day difference.
I did have an annoying time with getting it to talk to my network. I wound up doing it via the Play Fi app on my iPhone, and only then would it connect. Not the best user experience, but in the end, I was able to accomplish my goal. I think the newer firmware updates fix some of this issue.
The Anthem folk have a really good return policy. I say give it a go.
CM Harrington is offline
post #704 of 9518 Old 02-26-2016, 07:17 AM
Liked: 2
The Rotel amp = yes, the preamp = no. Kept my Rotel amp, sent the predecessor to the RSP1582 back because of annoying delays in audio and some snap, crackle and pop in speakers. Read the same issue present in the 1582, so nixed that idea in favor of the AVM60. Couldn't be happier.
TomInKY is offline
post #705 of 9518 Old 02-26-2016, 01:49 PM
DNbass's Avatar
Quoted: 23 Post(s)
Thanks CM and Tom.
Although not technically required, I'm leaning towards getting the same brand for pre/pro and amp - unless there's some compelling reason to get the "best" option from my list. But keeping an open mind with the feedback too.
Anyone with experience with both Anthem pre/pro and amp combo?
DNbass is offline
post #706 of 9518 Old 02-26-2016, 03:17 PM
maxfli44's Avatar
Quoted: 87 Post(s)
Liked: 61
Thanks CM and Tom.
I run the AVM 60 MCA 50 combo works flawless. Have the amp made by Sonic Frontiers excellent amp.
maxfli44 is offline
post #707 of 9518 Old 02-26-2016, 07:03 PM
Charles J P's Avatar
Quoted: 145 Post(s)
Liked: 50
I just got my unit hooked up. I'm getting ready to run ARC. A few questions I haven't been able to figure out on my own. I've been an Onkyo user for over 10 years now. Is there a Pure or Direct mode on the Anthem? Is it a listening mode? Or do I need to setup multiple speaker profiles? If the latter, is there a way to switch profiles on the fly or do you have to go into the menus?
the lounj is a general interest/hobby discussion forum.
Charles J P is offline
post #708 of 9518 Old 02-26-2016, 07:48 PM
Kuch569's Avatar
I've had mine for about a month and still figuring it out. I don't think there is a pure direct mode, or many modes to switch through for that matter. On the input set up there is an area where you can select the default listening mode. I think if you select "last used" or something like that you can toggle through the available modes by hitting the mode button on the remote and then the down or up arrow. I was a little disappointed by the lack of selections of listening modes. I know most are just gimmicky, but I did like some of the live concert modes I had on older Yamaha and Denon AVRs. But I think you will find the sound quality is better than what you came from and the loss of these listening modes will not be a big deal. Good Luck.
Kuch569 is offline
post #709 of 9518 Old 02-26-2016, 09:16 PM
Quoted: 88 Post(s)
Pure or direct mode is suitable for AV processor in order to cut the power of video elements (anti-jitter) - increase the sound quality. No need here.
I understand that in the case of AVM 60 it ought to have a proper ARC multiple settings and to select them for menu. Am I wrong ?
For stereo we could use an equaliser, even looks obosolete. A good SH one.
How does remote looks like ? - somebody in the forum said that is a Joke. Is so Poor ? - material quality, design...Could you attached a photo ? I am curious.
Mike RO is offline
post #710 of 9518 Old 02-27-2016, 12:10 AM
I think there are only direct and Dolby surround mode in multiple channels input if w/o atmos, and can have more surround effect mode just in stereo input.
Avbuzz review about 1120
Anthem 新機到港
http://www.avbuzz.com/audio-video/201602/anthem全球首發/
post #711 of 9518 Old 02-27-2016, 02:24 AM
HeffeMusic's Avatar
Quoted: 458 Post(s)
Liked: 194
Hello,
I have the 1120, and there is a direct 2 ch mode that shuts off ARC and all digital processing. It is in the profile settings.
HeffeMusic is offline
post #712 of 9518 Old 02-27-2016, 12:26 PM
Quoted: 145 Post(s)
Liked: 50
OK, one more question. I'm trying to update the firmware but the unit just says "Error check USB or FW" I've tried two different USB sticks. I've tried formatting them multiple ways etc.
EDIT: I was trying at first using my Mac and needed format the thumb drive with Windows. Once I switched over, I ended up copying the ARC setup .exe file over instead of the FW. Once I got the actual FW file on the thumb drive it was fine.
post #713 of 9518 Old 02-27-2016, 12:46 PM
dlinsley's Avatar
Quoted: 490 Post(s)
Liked: 379
There's a new promotion just started today that runs through the end of March. With an AVM60 purchase (or the 720 and 1120 AVRs) you get a choice of the Paradigm PlayFi amp or wireless speaker (normally $500 and $800). This may push me over the edge in the next few weeks
http://www.anthemav.com/specials/wireless-2016.php
dlinsley is online now
post #714 of 9518 Old 02-27-2016, 04:04 PM
seanimus's Avatar
Liked: 0
On the D1 I could set rear speakers = surround speakers for 5.1 channel audio. Can I do that on AVM 60?
seanimus is offline
post #715 of 9518 Old 02-27-2016, 04:26 PM
Applemike68's Avatar
Quoted: 237 Post(s)
Liked: 52
This helped me out as well, just upgraded to a 1120.
How do you like the av60 and the paradigm 85f? Before I pull the trigger on the 95's, I would like to hear them first.
Applemike68 is offline
post #716 of 9518 Old 02-27-2016, 07:32 PM
Bluecow003's Avatar
Quoted: 318 Post(s)
Liked: 302
My AVM60 just arrived from Anthem a little over a week ago. Sure would have been nice to get the free PlayFi speaker. I wonder if they will let me still get it somehow.
Bluecow003 is offline
post #717 of 9518 Old 02-28-2016, 08:48 AM
maxfli44's Avatar
Quoted: 87 Post(s)
Liked: 61
Great combination, being the same company you can only think they were extensively tested together. The speakers do require a good burn in to sound their best.
maxfli44 is offline
post #718 of 9518 Old 02-28-2016, 02:30 PM
Quoted: 62 Post(s)
Liked: 347
Gah!
Why is it the early adopters always get burned??
post #719 of 9518 Old 02-28-2016, 02:35 PM
Quoted: 62 Post(s)
Liked: 347
Update:
I sent in an email to customer support. I'll let folks know how it pans out. ::fingers crossed::
post #720 of 9518 Old 02-28-2016, 03:42 PM
Liked: 1
Originally Posted by DS-21 View Post
Why would you think that obsolete and cumbersome connections (plus a gratuitous DA/AD loop) would result in better "stereo sound" than a modern connection?
7.1 analog in is a nice feature. It allows one to try other multichannel DACs and use audio interfaces to get good multichannel measurements (this can be worked around to some extent, but its a pain). Extraneous AD/DA conversion is not an issue in Direct mode. The compensating feature with the AVM 60 is switchable speaker setups in memory. Is anyone using this feature?
bartrinsic is offline
antehm arc genesis , anthem avm 60 , the official anthem avm60 thread
