The Official Anthem AVM 60 thread - Page 293 - AVS Forum | Home Theater Discussions And Reviews
 4179Likes
post #8761 of 9745 Old 04-01-2019, 09:32 AM
HarleyRider's Avatar
Quoted: 148 Post(s)
Liked: 100
Originally Posted by dean122601 View Post
Does Arc work with two subs? Didn’t work for me.
What kind of setup are you doing with the subs prior to running ARC? You want to set the gain on each sub so that they match each other (i.e. they both measure 72-75 dB when measured separately). Then when measured together, they should measure 75-80 dB. Take manual measures with ARC with only one sub turned on at a time and adjust each one's level so they match one another. If ARC works fine up until it gets to the subs, my guess is that they're either too soft or too loud.
One other tip for subs in general, especially important when setting up multiple subs -- if your subs have built-in room correction, run that first on both subs before running ARC.
dean122601 likes this.
Pre/Pro: Anthem AVR 60 | 5.2.4 Config: MartinLogan ElectroMotion ESL X FL/FR, ESL C Center, Motion LX16 Surrounds, Motion 4i Atmos | Subs: Velodyne DD-15, Martin Logan Dynamo 1100x | Amplification: Emotiva XPA-3 Gen 1 FL/C/FR, Emotiva A-700 Surrounds and Atmos
Dedicated ARC Genesis Thread
HarleyRider is offline
post #8762 of 9745 Old 04-01-2019, 12:12 PM
Erod's Avatar
Quoted: 1281 Post(s)
Liked: 793
What day does the new ARC arrive?
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: RBH SV-661R and SV-661CR fronts, Jamo 626k4 side/rear surrounds, DefTech DI6.5R heights
Erod is offline
post #8763 of 9745 Old 04-01-2019, 01:20 PM
Legairre's Avatar
Quoted: 1248 Post(s)
Liked: 687
Anthem said April, but didn't state a specific date.
Erod likes this.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #8764 of 9745 Old 04-01-2019, 01:26 PM
Erod's Avatar
Liked: 793
Cool, thanks. I set a reminder for myself to poke around, but didn't see a date anywhere.
Curious what they mean by "improved algorithms". I wonder if there will be any difference aside from a cooler looking platform with a few more options.
Erod is offline
post #8765 of 9745 Old 04-01-2019, 01:33 PM
Legairre's Avatar
Liked: 687
Sounds like it's also more like Dirac and REW (with a miniDSP) where you can take a measurement and adjust the target curves and even make adjustments to individual speakers without re-running everything from scratch. I think one of the articles said it was totally new not just a new UI .
You can sign up here to be notified when it's available: https://www.anthemav.com/support/arc-genesis.php
Erod likes this.
post #8766 of 9745 Old 04-01-2019, 01:34 PM
Quoted: 572 Post(s)
Liked: 574
Does anyone have a good resource where you can order the rack kit for the AVM60?
Edit - I see just finding a good dealer is where I should start.
kaotikr1 is online now
post #8767 of 9745 Old 04-01-2019, 01:48 PM
Erod's Avatar
Liked: 793
Are you saying I need to buy a miniDSP to fully utilize it?
Erod is offline
post #8768 of 9745 Old 04-01-2019, 01:50 PM
Megalith's Avatar
Quoted: 86 Post(s)
If you were looking to buy one of these used, what would do you think would be a fair price? $2500?
Megalith is offline
post #8769 of 9745 Old 04-01-2019, 02:04 PM
Legairre's Avatar
Liked: 687
Oh no I'm saying if it is what I think it it is, it sounds like it will do what Dirac or REW (combined with a miniDSP) will do, but without buying anything at all. Sounds like with ARC Genesis I won't need REW + my miniDSP anymore.
Bill-99 likes this.
post #8770 of 9745 Old 04-01-2019, 02:42 PM
Erod's Avatar
Liked: 793
Ok, now you've got me excited.
WOKNROX likes this.
Erod is offline
post #8771 of 9745 Old 04-01-2019, 03:20 PM
Bill-99's Avatar
Quoted: 872 Post(s)
Liked: 549
I also am curious about what is meant by "improved algorithms". Is it simply faster but sounds the same? Sounds better? Or did someone simply refactor the code? Hard to know what this means!
Bill-99 is offline
post #8772 of 9745 Old 04-01-2019, 03:41 PM
shs1234's Avatar
Quoted: 226 Post(s)
Liked: 180
I thought that the hardware in the AVM 60 treated the 2 subwoofer ports as 1, with a single timing and PEQ. If so the it will not replace the need for miniDSP if you have multiple subs located at different distances from the MLPs.
Also REW does much more than analyze the frequency response of the speakers in the room. It also measures distortion, impulse response, decay with waterfall and spectrogram, RT60, etc.. I am really looking forward to using ARC on my Mac and being able to use some of new features, but I also anticipate I'll still need REW for fine tuning the room.
SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, HDFury Integral 2, Oppo UDP 203, Panasonic DP-UB820, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Dual Velodyne DD15 Subwoofers.
shs1234 is offline
post #8773 of 9745 Old 04-01-2019, 05:18 PM
Legairre's Avatar
Liked: 687
Very true the AVM 60 and MRX series treat the subs as one and it's also true it won't replace the miniDSP for everyone, but for me it will because both my subs are the same distance from the MLP. As for REW, I use it for the initial measurement and then use it's EQ screen to build a house curve and take more measurements until I get it right and then to import that into the miniDSP.
I also use REW to gain match my subs but that's a one a time thing and that could also be done with my SPL meter instead of the one in REW or I could break out the UMIK-1 and REW for that if I need too. I don't really use most of the features in REW so while I know it won't replace REW and the miniDSP for everyone, but for my needs and what I use REW and the miniDSP for it at least sounds like it could replace them for me.
post #8774 of 9745 Old 04-01-2019, 06:40 PM
shs1234's Avatar
Quoted: 226 Post(s)
Liked: 180
My 2 identical subs are also the same distance from the MLPs and symmetrical in the room, and they also have 8 bands of PEQ built in, so I haven't felt the need for a miniDSP. When REW suggests the need for EQ of the subs, I dial the same setting into both subs and keep the gains the same, then test again. When I am happy with what I can do with REW and the sub's PEQ, I let ARC have a run at the fine tuning. Very much looking forward to doing that on my Mac!
Legairre likes this.
shs1234 is offline
post #8775 of 9745 Old 04-01-2019, 06:57 PM
Legairre's Avatar
Liked: 687
I kind of have to do it the opposite way. I run ARC first (even though Anthem recommends EQing first). I run ARC first and then EQ with the miniDSP, because I have a house curve and if I ran ARC after EQing and building the house curve ARC would just flatten my house curve.
shs1234 likes this.
post #8776 of 9745 Old 04-02-2019, 07:51 AM
Jonas2's Avatar
Quoted: 2841 Post(s)
Liked: 1813
If you have no other choice but to pay MSRP, then maybe. Really depends. How old is it? Is it complete with all the packaging, accessories, etc.?
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #8777 of 9745 Old 04-02-2019, 12:20 PM
Quoted: 117 Post(s)
Liked: 27
Dears,
I'm a new owner of an OLED TV which happens to have HDR10+.
Is AVM60 able to passthrough HDR10+? I know it's stated for HDR, HLG and DV, but what about HDR10+?
Did anyone here succeed on playing HDR10+ over it?
Sent from my SM-G955U1 using Tapatalk
Sent while surfing
Cricket-RJ is offline
post #8778 of 9745 Old 04-02-2019, 02:37 PM
Erod's Avatar
Liked: 793
Originally Posted by Cricket-RJ View Post
Dears,
Unsure, but if not, a firmware update should fix that.
There's so little HDR10+ right now.
Erod is offline
post #8779 of 9745 Old 04-02-2019, 02:49 PM
Quoted: 117 Post(s)
Liked: 27
Yep, but you probably know how it works. My new toy needs to be tested.
I have "Bad Times at The Al Royale" to test it. I'll plug my Oppo 203 straight to the TV to see if it's working. Oppo recognizes the stream as HDR10+, but the Output is HDR10 when connected to AVM60. I'll check my firmware version to see if it's the latest one.
Sent while surfing
post #8780 of 9745 Old 04-02-2019, 02:54 PM
Erod's Avatar
Liked: 793
I would email Anthem, too. Unfortunately, as a projector guy, I can't get DV or 10+ anyway.
Erod is offline
post #8781 of 9745 Old 04-02-2019, 03:18 PM
BarryDMartin's Avatar
Quoted: 37 Post(s)
You may have trouble finding used units, but I think that $2500 would be too high. If you get a friendly dealer I think you "should" be able to get a new unit for between $2500 and $2600.
I'm in Canada so my market conditions are somewhat better with Anthem being a Canadian company. The Cdn MRSP is about $500 less than the USA MRSP when converted to a common currency. I got an extra discount when I bought my AVM 60 because I also bought an amplifier at the same time. I paid about $2670 Cdn (plus our 11% taxes). This works out to about $2100 USD. I doubt you get get a price near this good, but you should be able to get similar discount from an aggressive US dealer.
I also checked the used market here, but currently there is no units listed on https://www.canuckaudiomart.com/ which is the best Canadian site for used components. I have seen some in the past and they usually listed for around $2300 Cdn.
Hope that helps.
Jonas2 likes this.
Anthem AVM 60, 7.2.4 configuration with Emotive XPA-7 Gen3 and Anthem PVA 4 amplifiers.
B&W 683 S2 (FLR); B&W HTM61 S2 (C); B&W 685 S2 (SLR); B&W 685 S2 (RSLR); 4 x B&W CCM663 (Ceiling/Presence/Atmos); 2 x Sunfire HRS-12 (Subwoofers)
LG OLED65E6P, OPPO UDP-203, Project RPM1 Carbon Turntable, Apple TV 4K, Ultralink HDC-150 Power, Harmony Elite Remote, Arris Cable Box, Primacoustics London 12 Room Treatment
BarryDMartin is offline
post #8782 of 9745 Old 04-02-2019, 03:42 PM
Quoted: 117 Post(s)
Liked: 27
I will, thanks.
As a married guy I can't get a projector! WAF = zero.
Sent while surfing
post #8783 of 9745 Old 04-02-2019, 03:42 PM
Quoted: 117 Post(s)
Liked: 27
I will, thanks.
Just did the test here and Oppo to TV plays HDR10+.
I have the option of running two cables, one for video straight to the TV and then other for audio only at AVM60, but I would really like running only one cable.
Sent while surfing
post #8784 of 9745 Old 04-02-2019, 05:03 PM
shs1234's Avatar
Quoted: 226 Post(s)
Liked: 180
I will, thanks.
It was my wife who first convinced me to go with a projector, but that was almost 20 years ago. At the time we were using a rear projection set, big at that time, maybe 40" or 50"! I wanted something bigger and she said, there must be a better way of watching TV that bigger and bigger boxes dominating the room. I said, how about a projector mounted on the ceiling at the back of the room and a screen at the front of the room that rolls up and down. She said, "great". Been with a projector ever since, and my wife!
Today flat panel displays don't dominate the room like the old RPTVs, but there is still something to be said for a screen that disappears into the ceiling.
Cricket-RJ likes this.
shs1234 is offline
post #8785 of 9745 Old 04-02-2019, 07:03 PM
Quoted: 117 Post(s)
Liked: 27
Anthem was pretty fast on replying my request.
Unfortunately, not with the best news:
"At this time I do not have any information regarding whether or not the AVM 60 will offer an update to offer HDR10+ in the future. I apologize for any inconvenience. "
post #8786 of 9745 Old 04-03-2019, 07:56 AM
Erod's Avatar
Liked: 793
I'm sure Anthem, like a lot of companies, wants to see this war play out first like all the others.
Erod is offline
post #8787 of 9745 Old 04-03-2019, 08:52 AM
Nikola Tesla's Avatar
Quoted: 48 Post(s)
Liked: 39
Chances are the Samsung-developed HDR10+ will fade away as HLG gains traction. HLG is broadcast-friendly and is the only HDR format that is. HLG is also compatible with SDR televisions.
HDR10+ may survive, but Anthem is wise to hide in the grass and wait to see what shakes out. Adding 10+ capability may open a can of worms that will compromise performance with DV.
Nikola Tesla is offline
post #8788 of 9745 Old 04-03-2019, 09:34 AM
beastaudio's Avatar
Quoted: 5657 Post(s)
Liked: 5521
Major response anomalies should be taken care of very first before ARC. While doing so, don't build the house curve, just fix any major peaks. You should then run ARC and let it flatten out the response further. Only after ARC should you go back in and apply your low shelf boost to get your house curve back. This is far and away the best process as it keeps ARC from being too aggressive, as well as allowing you the ability to just defeat the house curve in your mini and re-run ARC if you need to for whatever reason...then just "Unmute" the low shelf again when you are done.
beastaudio is offline
post #8789 of 9745 Old 04-03-2019, 10:27 AM
Legairre's Avatar
Liked: 687
Any major anomalies have already been taken care of with placement of my dual subs using quick measure. I then run ARC and then I build my house curve.
post #8790 of 9745 Old 04-03-2019, 12:55 PM
beastaudio's Avatar
Liked: 5521
That's why I said only "Major" anomalies. Goodonya that the dual setup and good positioning already mitigates that. These are the first and foremost design suggestions and should be taken into account long before ANY type of EQ is done, manual OR auto.
antehm arc genesis , anthem avm 60 , the official anthem avm60 thread
