The Official Anthem AVM 60 thread - Page 333 - AVS Forum | Home Theater Discussions And Reviews
 4245Likes
post #9961 of 9992 Old 05-10-2020, 09:04 AM
Liked: 0
Originally Posted by ManMower View Post
Is ARC turned on? I think some older versions of ARC Genesis made mistakes that resulted in clipped audio. Doing a new run with the latest version could resolve that. Simply turning it off could be a lower effort test.
You nailed it. I turned it off and problem seems to have disappeared. Thanks for the advice!!
foodandvine is offline
post #9962 of 9992 Old 05-11-2020, 04:29 PM
MarkJW's Avatar
Hello, was watching TV went out for a smoke and my AVM60 shut itself off. Thought one of my dogs accidentally jumped on my Control4 remote. Tried turning it on, no luck. Push power button once, nothing, twice, it goes into screen that says MCU force update. Updated software, goes from 0% to 100% shuts off again. Tried unplugging it, hit power on 5 times, plug back in nothing. Emailed Anthem, closed now, anyone else dealt with this issue? Also tried plugging directly into wall, no difference.
MarkJW is offline
post #9963 of 9992 Old 05-12-2020, 03:29 AM
szepi0808's Avatar
Originally Posted by sgmsmg View Post
Could any of you AVM60 owners classify the sound signature? I currently have a Yamaha CX A5100 and was wondering how it would differ if I made a move to the Anthem. I know this is very subjective and has a lot to do with the rest of your system. I have Parasound Halo amplifiers and Polk Audio LSiM speakers so my systems already tends to be on the warmer side of things.
https://avx.hu/forum/viewtopic.php?t=75704&start=350
The winner, with a big advantage: AVM60
Sony VPL-VW570ES, Screenline Fashion 136"1.4 Diamond 4K, Egreat A10, Yamaha AVENTAGE CX-A5200, 2db. Arcam Diva P1000, M&K Sound 950 THX , SVS SB16-Ultra 7.1.4 Atmos, AQ, IsoTek, Supra, QED
https://avx.hu/forum/viewtopic.php?f...313de5f1671dbf
szepi0808 is offline
post #9964 of 9992 Old 05-12-2020, 07:15 AM
Jonas2's Avatar
Quoted: 3229 Post(s)
Liked: 2158
Do the system reset - hold Select and press Power at same time. See what happens....
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #9965 of 9992 Old 05-12-2020, 08:35 AM
MarkJW's Avatar
Yes did that multiple times, Anthem tech support says it needs to come in. 😡
MarkJW is offline
post #9966 of 9992 Old 05-12-2020, 09:11 AM
BGLeduc's Avatar
Quoted: 2761 Post(s)
Liked: 2671
Is it still under warranty and where did you buy it?
My 720 lost an HDMI input 2 1/2 years into the warranty. I purchased from Crutchfields, so I reached out to see where I could send it for service. They simply swapped it for a brand new replacement.
If you are under warranty, and you have a great dealer, maybe you will get lucky.
BGLeduc is online now
post #9967 of 9992 Old 05-12-2020, 10:18 AM
MarkJW's Avatar
Bought the unit from a guy who purchased it from a dealer in Santa Monica Definition Audio, he did not go through with his home theater project. Bought it from him new sealed off Ebay. Anthem is saying their warranty does not transfer between owners!! Sure does when you buy a car! Horrible policy! Not happy with Anthem atm!
MarkJW is offline
post #9968 of 9992 Old 05-12-2020, 04:28 PM
pbc
pbc's Avatar
Quoted: 501 Post(s)
Liked: 223
Hey guys, having some issues with my AVM60 and in particular the speaker level settings (which I posted in the ARC thread). Basically for some reason turning the subwoofer setting all the way up or down does nothing to the SPL levels of my subwoofers, and secondly, when I run the test tone it only passes through one of my two subwoofers and sounds much more high pitched. Even though running ARC it sweeps both woofers, and I get audio from both subs during playback.
Tried a factory reset, but it didn't do anything. I am on the latest firmware, 1.4.095, but wanted to try upgrading to a beta if anyone has it or downgrading one version. I can't recall if this issue existed before hand.
Arc post here https://www.avsforum.com/forum/90-re...l#post59626562
My DIY Subs ... https://www.avsforum.com/forum/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #9969 of 9992 Old 05-12-2020, 04:51 PM
Jonas2's Avatar
Liked: 2158
Did they give you an idea of what might be the issue?
Did the seller provide you the original proof of purchase? If not, Santa Monica Definition Audio will have a record of the sale by serial#. They *might* be able to intervene on your behalf. There's not much in it for them, but it might be worth a call just to see.
The non-transferable warranty is typical - Denon/Marantz, NAD are the same. I'd imagine a lot of brands are.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #9970 of 9992 Old 05-12-2020, 07:21 PM
MarkJW's Avatar
I found the proof of purchase with my name on it. Was under the shipping label on the box lol. Had to go to my storage to get the box.
No idea from Anthem on what is causing the unit to freeze in MCU forced update mode. Will see in a couple weeks I guess.
The non-transferable warranty is typical - Denon/Marantz, NAD are the same. I'd imagine a lot of brands are. [IMG class=inlineimg]/forum/images/smilies/frown.gif[/IMG]
MarkJW is offline
post #9971 of 9992 Old 05-13-2020, 08:11 AM
Jonas2's Avatar
Liked: 2158
Sounds like you might be able to get it covered under warranty then??
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #9972 of 9992 Old 05-19-2020, 06:38 PM
Nexgen76's Avatar
Quoted: 814 Post(s)
Liked: 233
I been working on my theater room since last Aug getting the gear & items i need. So i purchased my Anthem AVM60 bout two months ago. My subs are going to be three Devastors power by NX6K & NX3K non-dsp I want to know do I really need miniDSP HD? I heard that ARC Genesis could the same things as MiniDSP is this true?
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #9973 of 9992 Old 05-19-2020, 06:45 PM
pbc
pbc's Avatar
Quoted: 501 Post(s)
Liked: 223
No, ARC can't do anywhere near what a MiniDSP can do, very different applications. E.g., no additional delays, no ability to set a high pass filter, etc.
If it was a sealed sub, and you had substantial room gain down low, MAYBE, ARC would be enough...but you'll want the MiniDSP for our Devastators.
Dave Vaughn likes this.
pbc is offline
post #9974 of 9992 Old 05-19-2020, 06:53 PM
Nexgen76's Avatar
Quoted: 814 Post(s)
Liked: 233
Thank you for your reply....I asked because some guy in one of the facebook home theater groups I'm in said he got rid of his minidsp HD because it could do the same thing with ARC Genesis. His subs were duel PSA TV42 IPAL. For some reason, I knew that didn't sound right what he said.
Nexgen76 is offline
post #9975 of 9992 Old 05-19-2020, 07:02 PM
pbc
pbc's Avatar
Quoted: 501 Post(s)
Liked: 223
That's a sub which already is EQ's by PSA (already has a built in high pass and likely some shaping of the curve). Very different beast from a DIY sub. Love the 1099's in your pic, I'm considering those as well for a basement theater build.
pbc is offline
post #9976 of 9992 Old 05-19-2020, 07:06 PM
Nexgen76's Avatar
Quoted: 814 Post(s)
Liked: 233
Those are 1299....I love them..thxs
Sent from my SM-N950U using Tapatalk
Nexgen76 is offline
post #9977 of 9992 Old 05-20-2020, 10:47 PM
tranle's Avatar
Quoted: 79 Post(s)
If you use only minidsp you will need to do multiple Digital-to-Analog and Analog-to-Digital conversion. For example if you have a blu-ray in DTS-MA you need to convert to analog for feed minidsp which convert to digital to apply its filter and reconvert to analog for output. Also it does not work with amplifiers with balance input.
But minidsp does very well multi-subwoofer which ARC cannot do. it takes all the subwoofer as one and cannot different calibration for each of them.
So if you have multiple subwoofer you will need to use both minidsp and ARC.
Nexgen76 likes this.
tranle is offline
post #9978 of 9992 Old 05-21-2020, 06:10 AM
mitchlampert's Avatar
Quoted: 162 Post(s)
Liked: 70
Sure it does. You just need a cable that has an RCA end and a balanced end. Worked in my system just fine.
mitchlampert is online now
post #9979 of 9992 Old 05-23-2020, 11:06 AM
pbc
pbc's Avatar
Quoted: 501 Post(s)
Liked: 223
Going to run some REW sweeps today or tomorrow on my subs. Is there a simply way with the AVM60 to 1) turn off ARC and 2) turn off all speakers other than the sub(s) or do I have to unplug the speakers from the balanced outs?
pbc is offline
post #9980 of 9992 Old 05-23-2020, 01:38 PM
Roger Dressler's Avatar
Quoted: 3399 Post(s)
Liked: 2153
Turn off the power amp?
To turn off ARC, open the Input Setup menu.
Dave Vaughn and madrac like this.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #9981 of 9992 Old 05-23-2020, 06:53 PM
iStorm's Avatar
Quoted: 874 Post(s)
Liked: 225
Is there any way to get wireless to work on the AVM60? The wireless setup on my new AVM60 does not work. It just hangs after clicking on wireless setup. I upgraded to the latest firmware and cant get the wireless setup to even respond on this brand new AVM60. Thanks for any help or suggestions. I'm trying to get it connected to calibrated ARC.
iStorm is offline
post #9982 of 9992 Old 05-23-2020, 11:50 PM
tranle's Avatar
Quoted: 79 Post(s)
The Anthem ARC only works if your laptop is on the same Network subnet as your AVM60. If you have a wireless router then check what IP was assigned to your AVM60 and what IP was assigned to your laptop.
tranle is offline
post #9983 of 9992 Old 05-25-2020, 10:36 AM
asherman8's Avatar
Quoted: 22 Post(s)
Both HDMI Out 1 & 2 Don't Work
I've had my AVM 60 in a dedicated theater for about a month. All working well until all of a sudden, no picture.
-I have tried new HDMI cables and confirmed my sources (AppleTV, Sony Blu-Ray) work when directly connected to my Sony Projector bypassing the AVM 60.
-I have tried hooking up a 40" Sony 4K TV monitor just to make sure there's not a Projector/AVM 60 problem, no luck.
-I have done a Hard Reset (and painstakingly put back in all of my settings), no luck.
Does anyone think replacing the Firmware (which is up to date) would be of any use? I'm trying to think of anything short of having my theater out of commission for a couple months while the unit gets returned, worked on, shipped back and forth, etc.
Thanks in advance!
asherman8 is offline
post #9984 of 9992 Old 05-25-2020, 11:02 AM
ituriforest's Avatar
Liked: 5
Thanks in advance!
Check Imput Setup-Audio Imput if is HDMI ARC NO Image so switch to HDMI
ituriforest is offline
post #9985 of 9992 Old 05-25-2020, 11:06 AM
asherman8's Avatar
Quoted: 22 Post(s)
Thanks for your input.
I have Audio for all my input sources set to HDMI (not HDMI ARC).
Darn, looking for something like that that I'm just missing....
post #9986 of 9992 Old 05-25-2020, 12:57 PM
aandpwoodley's Avatar
Quoted: 32 Post(s)
Thanks in advance!
I had the same happen with mine, I managed to get the picture back by doing the following.
Connect one of the devices directly to the TV or projector taking the AVM60 out of the loop, check you're getting a picture, then connect that device back to the Anthem as normal, then using just the main monitor out set everything back up.
You should, well I did get the picture back, I have reverted to just using the one monitor out which to be honest I should have been using it like that from the start.
Give it a try and let me know
aandpwoodley is offline
post #9987 of 9992 Old 05-25-2020, 01:08 PM
asherman8's Avatar
Quoted: 22 Post(s)
I have checked and got a picture from each of my individual sources directly connected to my projector.
I only have HDMI Out 1 that I use from the AVM 60 to the projector.
Still No picture passing through the AVM 60 making me surmise the HDMI Output is shot…
post #9988 of 9992 Old 05-25-2020, 01:57 PM
Liked: 2153
What does the front panel display report for picture format?
Have you tried using HDMI 2 output?
post #9989 of 9992 Old 05-25-2020, 02:00 PM
asherman8's Avatar
Quoted: 22 Post(s)
Front Panel says 1080P (which really shouldn’t be correct because it’s a 4K AppleTV input as well as a Sony 4K Blu-ray).
Yes, tried HDMI Out 2, same nothing…
post #9990 of 9992 Old 05-25-2020, 02:30 PM
Liked: 2153
Ok, just checking the easy stuff.
And the display reports no signal -- it's not just a black image? If you open the AVM setup menu, nothing appears?
Got any other displays handy to try? I realize this is a "long shot."
antehm arc genesis , anthem avm 60 , the official anthem avm60 thread
