The Official Anthem AVM 60 thread - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 4178Likes
post #2251 of 9734 Old 12-07-2016, 04:12 PM
Blackdevil77's Avatar
Quoted: 493 Post(s)
Liked: 229
Does anybody have problems with audio dropouts when using Dolby TrueHD? I had the same exact problem on my Integra DHC-80.3 but didn't really look too far into it because I only have 2 discs that use Dolby TrueHD and they both do it. Now with the AVM60, I have the same problem. I'm thinking this must be a problem with Dolby TrueHD instead of the processor since I had the same problem with 2 different processors.
Blackdevil77 is offline
post #2252 of 9734 Old 12-07-2016, 04:15 PM
dwaleke's Avatar
Quoted: 1460 Post(s)
Liked: 751
What movies?
I haven't noticed anything but I haven't had my avm 60 long.
dwaleke is offline
post #2253 of 9734 Old 12-07-2016, 04:32 PM
Quoted: 493 Post(s)
Liked: 229
Originally Posted by dwaleke View Post
What movies?
Right now Monsters Inc. is on and it's occasionally dropping out. Same thing happened with my Integra. Maybe something is up with my Oppo blu ray player. It's a BDP-93.
post #2254 of 9734 Old 12-07-2016, 04:34 PM
dwaleke's Avatar
Liked: 751
If it happens with both processors it's probably your player.
Might be time to upgrade to a 203. Or pick up the Samsung 4k player for cheap.
dwaleke is offline
post #2255 of 9734 Old 12-07-2016, 04:40 PM
Quoted: 493 Post(s)
Liked: 229
Yeah that's what I was thinking. Just ordered an HDMI cable since it was cheap to see if that fixes it. If not, might as well go for the UHD-203.
This is what I just ordered. I can change it if you guys know of a better cable. Not sure if it makes that much of a difference.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
post #2256 of 9734 Old 12-07-2016, 04:42 PM
dwaleke's Avatar
Liked: 751
Hdmi premium certified cables are what everyone is buying.
Everything I use is years old Amazon MediaBridge 18Gbps cables and they work perfect for me with 4k hdr.
dwaleke is offline
post #2257 of 9734 Old 12-07-2016, 05:46 PM
Lynkage's Avatar
Quoted: 130 Post(s)
Liked: 86
Originally Posted by Ellebob View Post
As an installer I would not rely on CEC for reliable control. If you need control from an App there are a number control systems that can control and simplify your system so you don't have to go between each devices app to control it. You might need some type of hardware depending on the system. Something like irule could work if all your devices can be controlled via IP otherwise you need some type of interface for non-IP controlled devices.
Oh man!!
This iRule stuff along with the Global Cache interfaces for gear that does not have ip interfaces is REALLY cool!!
Thanks for the heads up!
Lynkage is offline
post #2258 of 9734 Old 12-07-2016, 05:47 PM
Quoted: 493 Post(s)
Liked: 229
I just changed my order to this
I'm sure any of them would of worked. I just don't get what would be wrong with my current one but it's worth a shot.
post #2259 of 9734 Old 12-07-2016, 05:57 PM
dwaleke's Avatar
Liked: 751
Yeah I'd try it too.
dwaleke is offline
post #2260 of 9734 Old 12-08-2016, 06:07 AM
Liked: 0
Hello :-)
I have some problems with my AVM 60, sometimes if i leave it some days, and will power on, it is totally dead. It will not power on from remote or
front panel, have anyone any solution for this? My friend have a MX model, and have seen the same.
It happen 3 times for me, if i leave it for 2 weeks without power, and i plug it in, it was no problem again, it powered on as it should.
Let me hear all you know about this BUG.
acei is offline
post #2261 of 9734 Old 12-08-2016, 06:21 AM
COACH2369's Avatar
Quoted: 1207 Post(s)
Liked: 1006
I believe Monsters Inc and Finding Nemo both suffered from audio drop outs. This is off the top of my head, but if you change the audio from Bitstream to PCM on your player, it should fix it on those titles...
It has been a few years since I read that, so don't quote me 100% about it.
COACH2369 is offline
post #2262 of 9734 Old 12-08-2016, 02:29 PM
Quoted: 33 Post(s)
Liked: 9
Received my new AVM 60 today. Figured I would need to update the firmware. Nothing happened. Tried 4 times. Does that mean I have the most recent firmware? Tried using 3 different usb drives to no avail. Am I the only one who thinks the operating manual is not very informative?
B&W 804 D3 Mains; B&W CM Center S2; B&W CWM7.4 Rears
SVS SB-2000 Sub; Samsung Plasma TV
Anthem A5, Anthem AVM60, Benchmark DAC3 L
Rega Saturn CD; Oppo BPP-93 Blu-Ray; Furman Elite-20 PF Power Conditioner
!Jerry is offline
post #2263 of 9734 Old 12-08-2016, 02:50 PM
Quoted: 493 Post(s)
Liked: 229
I had the same problem. Did you unzip the file and extract it to the USB drive? If so, try alternating which USB port you use. The rear one wouldn't work for me for some reason, but the front one did.
Also, make sure there is nothing else on the flash drive.
post #2264 of 9734 Old 12-08-2016, 02:52 PM
Quoted: 493 Post(s)
Liked: 229
Thanks for the info, that's definitely good to know!
post #2265 of 9734 Old 12-08-2016, 03:36 PM
Quoted: 33 Post(s)
Liked: 9
There is nothing indicating it is a zipped file, i think. When right clicking the file there is no unzip or extract all selection. Am i missing something?
Actually I have unzipped it. Just two files, instruction text file and the .fw file
!Jerry is offline
post #2266 of 9734 Old 12-08-2016, 03:39 PM
Quoted: 493 Post(s)
Liked: 229
If you click on it, is there anything anywhere that you can click that says extract file or extract all? What version of windows are you using?
post #2267 of 9734 Old 12-08-2016, 03:46 PM
Quoted: 33 Post(s)
Liked: 9
Blackdevil, I did unzip it. Sorry. When I clicked the download zip file and copied to usb drive it automatically unzipped. Tried different formats of the drive; exFat and NTFS.
!Jerry is offline
post #2268 of 9734 Old 12-08-2016, 04:00 PM
dwaleke's Avatar
Liked: 751
Chances are it needs to be formatted FAT32. Most things cannot read exFat or NTFS.
dwaleke is offline
post #2269 of 9734 Old 12-08-2016, 04:08 PM
Quoted: 33 Post(s)
Liked: 9
That makes sense. For some reason FAT32 wasn't an option. Hmmm.
Found a drive that will let me format to FAT32. Will try that.
!Jerry is offline
post #2270 of 9734 Old 12-08-2016, 04:19 PM
dwaleke's Avatar
Liked: 751
Windows prevents you from formatting larger drives as FAT32 as there are a lot of limitations. Smaller drives can be formatted FAT32.
A program called Rufus works very well in Windows.
bigdogaxis likes this.
dwaleke is offline
post #2271 of 9734 Old 12-08-2016, 04:47 PM
Quoted: 33 Post(s)
Liked: 9
Nope. Still just sits there at the "Update USB >" screen. I was afraid of all the potential problems. I have emailed Anthem.
!Jerry is offline
post #2272 of 9734 Old 12-09-2016, 11:27 AM
Liked: 0
Hello All Anthem AVM 60 Owners and Enthusiasts:
I'm looking for feedback on which AVP to purchase with HDR gaming as a priority. I have an HDR-capable TV, PS4 Pro, Xbox One S, power amp, and surround sound speaker setup. However, my current AVP does NOT support HDMI 2.0a, HDCP 2.2, or HDR. I've narrowed down the potential AVPs to the following:
- Yamaha CX-A5100
- Marantz AV7703
- Anthem AVM 60
I realize there are many minor differences between these AVPs. I use my AVP for movies/games about 99% of the time; so listening to music etc. is not a concern for me. My concern is their ability to accurately and efficiently pass-through or process HDR.
I'm posting this in multiple areas in order to try and get feedback from all those who may have experience with the aforementioned AVPs.
Thanks in advance.
AlexRearden is offline
post #2273 of 9734 Old 12-09-2016, 12:45 PM
COACH2369's Avatar
Liked: 1006
- Yamaha CX-A5100
- Marantz AV7703
- Anthem AVM 60
Thanks in advance.
Back in March I switched from a Denon 4520 to the new Anthem AVM60. The main reason I did this was due to the room correction software in the Anthem. In my room, the jump from Audyssey to ARC was well worth the difference in price. I had also looked at the Marantz AV7702MKII at the time. My room is only used to watch movies and the occasional sporting event and with ARC I was able to get things sounding exactly the way I wanted.
When I had the Denon and was using Audyssey I also had to have a NanoAVR in the loop to dial things in to my liking. That being said, the new Marantz AV7703 is supposed to have an app coming out that will allow you some new flexibility with Audyssey...
I don't have any experience with the Yamaha, so I can't comment on that one.
post #2274 of 9734 Old 12-09-2016, 01:28 PM
Quoted: 33 Post(s)
Liked: 9
Got it to work. I'm embarrassed to say what I was doing wrong. Thanks to all who tried to help!!!
!Jerry is offline
post #2275 of 9734 Old 12-09-2016, 02:55 PM
Liked: 0
COACH2369:
Thank you for your reply. My room is pretty terrible acoustically so the ARC system might help. I currently have a Marantz AV7702 (not the mkII) and the Audyssey system did an OK job of calibration; I've had several Bose that did just as good if not better using their tech.
Do you run 4K UHD and HDR from any sources through your AVP to a compatible TV?
Thanks again.
post #2276 of 9734 Old 12-09-2016, 04:45 PM
COACH2369's Avatar
Liked: 1006
COACH2369:
Thanks again.
Yes, I run 4K through the Anthem and I have a JVC X750R(RS500) paired with the Panasonic 4K player.
post #2277 of 9734 Old 12-09-2016, 05:29 PM
Liked: 0
COACH2369:
Have you had any problems running 4K through the Anthem? Audio or video dropouts etc.? I will be running a PS4 Pro and Xbox One S through my AVP to an LG OLED65B6P.
post #2278 of 9734 Old 12-09-2016, 10:01 PM
CM Harrington's Avatar
Quoted: 66 Post(s)
Liked: 370
COACH2369:
4k/4k HDR work just fine, as long as you stick to certified HDMI cables for your entire chain. Any non-certified cable is a crapshoot. (I've the 65E6P).
LG 65E6P | Parasound A51 | Anthem AVM 60 | B&W 803D, HTM2D2 | Anticables
Oppo UDP-203 for transport | Clearaudio Performance DC Wood for analogue | Mac mini for streaming
Roon for music catalogue | Plex for video catalogue
CM Harrington is offline
post #2279 of 9734 Old 12-09-2016, 11:47 PM
All That Jazz
Bob Fosse's Avatar
Quoted: 271 Post(s)
Liked: 333
My apologies if what I am asking has already been answered in this thread, but does anyone know specifically what the newest software address and if it's worth doing at this time? I am hesitant to do it as I have no issues and the sound from my AVM 60 is great!
A/V SYSTEM: Sony A9G 77” (main), Sony A9F 65”, Sony A8G 65”, Anthem 525, Anthem AVM 60, ProAc D80 L+R, ProAc Response CC, AT surrounds, JL112E, Oppo 203 103 83, TiVo Bolt, Apple 4KTV, Shunyata Triton 3/Denali v2, Auralex room tx, black out curtains. 2 CHANNEL STEREO: Aurender N10, Ayre QX-5 & PS Audio DS DACs, PS Audio DMP SACD transport, Ayre KX-R 20 preamp, Ayre MX-R 20 amp, Sonus Faber Amati Futura speakers.
Bob Fosse is offline
post #2280 of 9734 Old 12-10-2016, 04:59 AM
Quoted: 493 Post(s)
Liked: 229
I'm not sure what it addresses, but I know it has absolutely no problems connecting once the latest firmware is installed. The problems I had were due to a faulty calibration mic. Other than that, everything else worked easily and perfectly.
antehm arc genesis , anthem avm 60 , the official anthem avm60 thread
