The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2) - Page 232 - AVS Forum | Home Theater Discussions And Reviews
 101771Likes
post #6931 of 17802 Old 03-22-2016, 09:44 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 23657 Post(s)
Liked: 13022
Originally Posted by Liam1234 View Post
Sorry for asking again but I'm either brain dead or Denon gremlins are attacking.
Anyone know why when I power off the AVR (x2200W) , my TV shuts off, and then turns back on. Cant figure this out. They are plugged into two different electrical outlets.
THANKS
No worries posting again when there has been no response to your previous post.
Powering on/off is related to the HDMI-CEC/Control setting. Ensure HDMI-CEC is set to OFF on the TV and HDMI Control is set to OFF on the AVR.
jdsmoothie is offline
post #6932 of 17802 Old 03-22-2016, 09:55 AM
Selden Ball's Avatar
Quoted: 4819 Post(s)
Liked: 2864
THANKS
Does it actually power off (check the TV's standby/power light) or is it just turning off audio and video for a couple of seconds?
The latter is by design: when an HDMI device is turned off or on, all of the other HDMI devices have to re-sync. While that's happening, no A/V signals are seen/heard.
If it's actually powering off, that might be the result of having CEC enabled.
Selden
Selden Ball is offline
post #6933 of 17802 Old 03-22-2016, 10:17 AM
Liam1234's Avatar
Thanks for responding so quick!! I have learned a ton from reading your posts.
That solved it!
I now shut the AVR off, the TV screen goes blank for a second or two and comes back on (power never goes out on TV) (I have the HDMI pass through source set to ON on the AVR)
I'm assuming this is normal (ie. the TV going blank for a few second)
Liam1234 is offline
post #6934 of 17802 Old 03-22-2016, 10:19 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13022
That solved it!
Yup. HDMI must resync.
post #6935 of 17802 Old 03-22-2016, 10:35 AM
darkeclypse's Avatar
Quoted: 66 Post(s)
Liked: 56
I'm a little confused.. I'm at the beginning steps of upgrading my 5.1 to 7.1.2 and was doing a dry run with the reciever to see what was possable before hand, as in how many speakers I could use at once.
I selected 9.1 and floor at 5.1 with sb and fw selected and 4 for height speakers.
While using some atmos and dtx-x 7.1 material the sb and fw would not show active but height would. I had to change down to 2 speakers for heights to get the fw channel to light up.
I tried a bunch of blu rays to test it to make sure it wasn't the source and it was the same.
Is this a limitation of the x4200w reciecer? Or just the source?
Do you have to have a x6200w in order to actually run 7.1.4 or more?
I thought the specs say 11 channel processing which is the same for the x6200w.
darkeclypse is offline
post #6936 of 17802 Old 03-22-2016, 10:40 AM
jrogers's Avatar
Quoted: 275 Post(s)
Liked: 174
The wides won't be active for Atmos if you have 4 height speakers as you are already using all 11 channels: FL, C, FR, SL, SR, RSL, RSR, FHL, FHR, RHL, RHR. By switching to two height speakers or no rear surrounds, you can engage the wides. This is true for the x6200w as well - 13 connections, but only 11 channels active at a time (determined by surround mode).
Samsung UN75HU8500 TS01 w/SEK-3500U, K8500 UHD Blu-ray Player; Xbox One; Xfinity X1
Dolby Atmos and DTS:X 7w.1.4; Denon X6200W; Audiosource AMP102; GoldenEar SuperSat 60/60C, SuperSat 50, SuperSat 3/3C, Invisa 525; SVS PB-2000
Harmony Ultimate One; Insteon; Acoustimac
jrogers is offline
post #6937 of 17802 Old 03-22-2016, 10:48 AM
Quoted: 66 Post(s)
Liked: 56
Ok but I also tested 5.1 w fw and 4 height channels and the wides would not work. That's only 11 channels. I had to change the heights to 2 and then the wides would work and the height channel.
I tried 7.1.4 to see if I could go with the original plan of 4 height speakers and the wides would also work.
So it seems I'm being limited to 7.1.2 = 9 channels active.
post #6938 of 17802 Old 03-22-2016, 10:53 AM
batpig's Avatar
Quoted: 5040 Post(s)
Liked: 5514
No. Read the specs again and also review the beginning of this thread. The X4200W is a 9ch processing model, max. The 6200/7200 can do 11ch.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #6939 of 17802 Old 03-22-2016, 11:04 AM
Quoted: 66 Post(s)
Liked: 56
Ok I guess I'm getting it all mixed up. I thought the x4200 was a 9amp 11 channel reciever.. meaning it will process 11 channels if you use an extra sep 2 channel amp to power them.
post #6940 of 17802 Old 03-22-2016, 11:13 AM
Liked: 2864
Nope, sorry. The AVR X4200W is a 7 amp/9 channel device.
See page 231 of its owner's manual, where it says
9.1ch :
* Setting to use the 7-channel power
amplifier within this unit and an
external power amplifier connected to
PRE OUT connector to play back up to
9.1-channels.
* You can connect speakers for up to
13.1-channels for MAIN ZONE.
Speakers to output audio are
automatically switched for playing back
up to 9.1-channels in accordance with
the input signal and sound mode.
The owner's manual can be downloaded from http://manuals.denon.com/avrx4200w/na/en/
Selden
post #6941 of 17802 Old 03-22-2016, 11:24 AM
Quoted: 66 Post(s)
Liked: 56
After reading threw the manual for the x6200w I see you can't choose more then 2 height speakers if using front wide speakers as well (page 62). So no point with me spending 900 more for the 6200 if I can't still get 7.1.4 using front wides.
post #6942 of 17802 Old 03-22-2016, 11:28 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13022
From post 1 of this thread ....
- X4200W - MSRP $1499 , 7.2CH (expandable to 9.2 with external 2CH amp, ie. 5.2.2 --> 5.2.4 / 7.2.2), 125W, HDMI In/Out (8/3, main/main/Zone 2 outputs)
- X6200W - MSRP $2199 , 9.2CH (expandable to 11.2 with external 2CH amp, ie. 5.2.4 / 7.2.2 --> 7.2.4), 140W, HDMI In/Out (8/3, main/main/Zone 2 outputs)
post #6943 of 17802 Old 03-22-2016, 11:32 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13022
That's only true if you have 5.1 + SB + FW + HT(4). If your 7.1.4 setup consists of 5.1 + FW + HT (4) then all 11 speakers will be active when playing an Atmos or DTS:X audio track or when using DTS Neural:X. However, the FW will not be active when using the Dolby Surround upmixer mode.
post #6944 of 17802 Old 03-22-2016, 01:27 PM
Dougb59's Avatar
Quoted: 60 Post(s)
HDMI Maximum Distance with AVR Question
I'm deciding where/how to locate an IP-based security camera DVR that I will connect to my 6200 receiver for viewing my security cameras on my Zones 1 and 2 TVs. I think the DVR outputs 1080p. I've tested with a 25' HDMI cable between the DVR and receiver, and another 25' HDMI going to my Zone 2 TV, and it worked fine. However, I've decided that the best location for my security DVR will require a 50' HDMI cable from the DVR to the receiver. I've read that 50' is about the maximum length for an HDMI cable. Does the 6200 receiver amplify the HDMI input signal in some way, or by having a 50' HDMI on the input side, and a 25' HDMI on the output (Zone 2 monitor) side, am I effectively using a 75' HDMI cable? Do you think this configuration will work? Should I get a Redmere active HDMI cable for the 50' run? Don't plan to require 4K capability from the security DVR, but I do want 4K capability between my receiver and the TV in Zone 2. Thank you in advance for any advice on how best to configure this.
Dougb59 is offline
post #6945 of 17802 Old 03-22-2016, 01:34 PM
Liked: 0
Hi all,
I'm in the need of some help. I got myself a Denon x2200w and an Onkyo 646 at home at the moment. I'm trying to decide which one to keep. I've run the calibrations on both, as you're meant to, on a 5.1 setup. Now I find the sound to be just about right on the Onkyo, but I'm having problems getting the sound good on the Denon. The main problems I'm having are that the bass seems to be a bit over powering and I've found it's harder to hear the dialog on the Denon. Now I know that with the help of the settings I can probably get the sound to the way I want it on the Denon, but I'm just not sure which of all the settings to change. I could really need some help to point to the best settings in the menu that i can tinker with. If anyone could help it would be greatly appreciated.
pauldc is offline
post #6946 of 17802 Old 03-22-2016, 01:42 PM
cmdrdredd's Avatar
Quoted: 4262 Post(s)
Liked: 4574
Originally Posted by pauldc View Post
Hi all,
Check in your Denon setup menu under Audio > Audyssey and see if you are running Dynamic EQ or Dynamic Volume. If they are enabled try disabling them. Dynamic EQ will boost the bass and surround levels a bit in an attempt to compensate for human hearing being less sensitive to certain frequencies. Basically at lower volume levels it will boost the sub and the surrounds a bit to give the audio more dynamics. Some people like it and some people just disable it. It's something to try. Dynamic volume will adjust the volume level and can sometimes cause things to appear quieter than they would be normally. This is on purpose to avoid loud swings in sound level. Some people use this at night, some turn it off.
I turn both of those settings off.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #6947 of 17802 Old 03-22-2016, 02:01 PM
galonzo's Avatar
Quoted: 1470 Post(s)
Liked: 2012
Hi all,
@pauldc , after doing this, I would add that you can also try the Setting>Audio>Audyssey>Flat setting to "tame the bass" even more (without tweaking any levels first, I still use Reference after doing the following); after setting up Audyssey, I will go in and adjust any crossovers that were set below 80Hz at least up to 80Hz (BUT NEVER DOWN from where they were set) under Settings>Speakers>Manual Setup (this will not negate the filters applied by running Audyssey).
Hope this helps
Main: UN78HU9000/SEK-3500 | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630)
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | TiVo Mini | Roku P+
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Heat (1995) and other UHD Digital codes (and some HD codes)
galonzo is online now
post #6948 of 17802 Old 03-22-2016, 02:01 PM
Quoted: 14 Post(s)
Liked: 0
Hello Gurus, a simple question it may be. but I have been trying to find out a solution for it. I got a denon avr s710w receiver and bought it to use with my movies as well as music files. I have netflix which plays in surround speakers but i recently realized that youtube does not provide surround sound encoding to their files and which results in a stereo listening experience from youtube. My question is, is there any setting or configuration change I can do in my receiver to force the stereo sound to all of my surround channels. My main intent is to utilize all the speakers for listening to stereo music. I know there some plugins in windows machines which does that but not sure itf something is readily available in the receiver side. If not, may be someone can suggest a better video songs tube where i can get some surround experience .. thanks guys!
vipinckv is offline
post #6949 of 17802 Old 03-22-2016, 02:38 PM
kokishin's Avatar
Quoted: 1358 Post(s)
Liked: 1433
Hi all,
I have a 6200 with Pioneer Elite Dolby Atmos integrated speakers in a 5.1.4 config. I've been experimenting with improving the dialog clarity also. I had all my my crossovers set for 80Hz. I set the CC crossover at 150Hz and boosted the CC +2dB and I think that helped. I also turned off Dynamic EQ and Dynamic Volume. I had a hard time understanding the dialog of American Sniper prior to making the changes. The dialog seemed clearer after the changes. I'm open to other suggestions.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon FTV Stick 4K, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is online now
post #6950 of 17802 Old 03-22-2016, 02:38 PM
cmdrdredd's Avatar
Liked: 4574
Most music is not encoded in surround. Generally it's stereo only. Any usage of surround speakers will be virtual surround. Some songs or types of music do not benefit from this. On your remote you can press the music button and cycle through some virtual surround modes and even select a multi-channel stereo mode where you will get stereo information to each speaker. This works even from a 2 channel source.
You're on the right track IMO. The first step will be turning off dynamic volume and dynamic EQ and evaluate the difference. Boosting the center's level can help as well. I personally don't do this but many people seem to like it boosted a bit. Do note that some movie scenes are mixed with muffled dialog on purpose to create an effect. Interstellar is one that comes to mind that was mixed that way.
post #6951 of 17802 Old 03-22-2016, 02:49 PM
kokishin's Avatar
Liked: 1433
Yeh... For the most part I could only understand Charlize Theron in "Mad Max: Fury Road". Maybe it's the movies I'm watching?
post #6952 of 17802 Old 03-22-2016, 03:52 PM
zalusky's Avatar
Quoted: 138 Post(s)
Liked: 80
So I just purchased a X4200W upgrading from my old AVR-991
I have a L/C/R front speakers in my TV cabinet along with a subwoofer. Due to the shape of the room I have 4 ceiling speakers.
2 that are overhead of the sectional sofa (which has a wall behind it) and 2 that are slightly ahead of the sofa and on the sides.
So whats the best configuration: TM + SB or TM + TR
I am assuming If I go TM + TR I will need a aux amplifier.
Its a little confusing to understand how the amplifier treats the TM/TR speakers vs SR/SB speakers.
zalusky is offline
post #6953 of 17802 Old 03-22-2016, 03:57 PM
cmdrdredd's Avatar
Liked: 4574
Hrm...I could understand Tom Hardy and the other characters for the most part. There were only a few parts that were a bit harder to understand but nothing was unintelligible.
post #6954 of 17802 Old 03-22-2016, 04:02 PM
batpig's Avatar
Liked: 5514
Do you have surrounds at ear level? Or are the four speakers in the ceiling the only other speakers besides the LCR up front?
(or in other words, 9 total or 7?)
Setup Guide and FAQ
post #6955 of 17802 Old 03-22-2016, 04:02 PM
cmdrdredd's Avatar
Liked: 4574
If it were me I would try setting the 2 speakers over the MLP as surround speakers for a 5.1 configuration and use the two speakers that are positioned slightly forward of the MLP as top middle and see what happens. Try playing some Atmos content and see what you think. I'm not exactly sure how the speakers in the ceiling will react to surround information with the other set playing the atmos effects since generally speaking, surround information is supposed to come from the bed layer at or slightly above ear level with Atmos specific audio coming from the upper layer.
If you need information on where to find some Dolby Atmos demos you could PM me because it's outside the scope of the thread topic and I don't want to clutter it with links and such.
post #6956 of 17802 Old 03-22-2016, 04:43 PM
zalusky's Avatar
Quoted: 138 Post(s)
Liked: 80
Nothing at ear level except for L/C/R front speakers. Two ceiling speakers directly above the main part of the sofa and two ceiling speakers about 3 feet forward and to the sides of the sofa. These were previously used in a 7.1 config but with the X4200W I am wondering if there is a better way.
We will be remodeling shortly and the sofa will love 3 feet back with the directly overhead speakers causing some more separation from the other two ceiling speakers.
zalusky is offline
post #6957 of 17802 Old 03-22-2016, 04:57 PM
diverdra's Avatar
Quoted: 45 Post(s)
Liked: 38
Just hooked up X3200W with Martin Logan AFX ATMOS speakers (confit in signature). Playing "Expendables 3" bluray with ATMOS sound on Oppo 93. Sound drops out for a second about every 10 minutes. When I back up and replay, sound dropout isn't there so I assume it's not the disc. Switched HDMI cable to new cable with bandwidth 18Gbps. Reseated cable. Still persists. I'll try my other ATMOS bluray (Mad Max) but is there a known problem with the 3200? I didn't find anything searching this thread or reading the trouble shooting post. I'm on FW 3400-5140-3455. TIA.
Sony XBR 75X950G, Denon AVR-X3300W w/ Sunfire Theatre Grand Amp (5.1.2); Oppo UDP-203; Fire 4K Stick; Martin Logan Vantage & ML Ctr, Sur, Sub & Motion AFX ATMOS speakers.
diverdra is offline
post #6958 of 17802 Old 03-22-2016, 05:11 PM
batpig's Avatar
Liked: 5514
OK, first thing to understand is you can't run a "3.1.4" setup, you HAVE TO have surround speakers.
I would try a 5.1.2 with the speakers directly overhead set to "Top Middle" and the speakers to the sides set to "Surround".
Or just leave it as 7.1 and be done with it.
Setup Guide and FAQ
post #6959 of 17802 Old 03-22-2016, 05:15 PM
batpig's Avatar
Liked: 5514
The problem is the Oppo 93 uses a BD decoding chipset which can't handle the seamless branching used in some Dolby TrueHD encodes. It's a known issue with this player and others which use the same chipset.
It's not the receiver.
D Bone and diverdra like this.
Setup Guide and FAQ
post #6960 of 17802 Old 03-22-2016, 05:41 PM
diverdra's Avatar
Quoted: 45 Post(s)
Liked: 38
Thank you, BP! You saved me many hours of PD.
diverdra is offline
4:4:4 , alexa , arc , audyseey , Audyssey , avr , AVR-2310CI , avr-s710w , AVR-X2200W , bluetooth , chroma , connect , Denon , denon 2200w , denon x1200w , lfe , s710w , s910w , spotify , x-1200w , x1200w , x2200w , x3200w , x4200 , x4200w , x6200w , Yamaha
