The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2) - Page 268 - AVS Forum | Home Theater Discussions And Reviews
 101725Likes
post #8011 of 17632 Old 05-06-2016, 09:50 AM
TinyRK's Avatar
Quoted: 223 Post(s)
Liked: 132
Just bought a x3200 and after finally running Audissey I noticed, that when I use Spotify Connect I don't get any Audio.
It shows as playing music on the TV and the front display.
Watching TV, I do get audio, so there's no hardware issue.
After a Processor reset, I have sound with Spotify Connect, so something with Audissey and Spotify is not working.
Am I missing something?
Thanks in advance
LG 65E6 | Denon x3200 | Klipsch RP-280F - RP-450C - RS-62II - R-115SW
TinyRK is offline
post #8012 of 17632 Old 05-06-2016, 10:22 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22561 Post(s)
Liked: 12279
Thanks in advance
Does the same issue present when using internet radio as well? Try running Audyssey again and see what happens as there should not be an issue.
jdsmoothie is offline
post #8013 of 17632 Old 05-06-2016, 11:12 AM
TinyRK's Avatar
Quoted: 223 Post(s)
Liked: 132
I had the same issue with an x2200 I had before. I'll check the Internet Radio once I get home.
TinyRK is offline
post #8014 of 17632 Old 05-06-2016, 01:29 PM
Quoted: 197 Post(s)
Liked: 86
I had a similar issue yesterday I have a 910, my Internet was down, but my LAN, was up, after resetting my Internet I attempted to play Sirius, it showed that it was playing, but no sound. Attempted a network reset, not sure if it did anything, I held down setup and mode while powering on just to see what would happen, it appeared to reset something, once I performed this procedure I was able to get audio, and no settings were lost.
While I'm not sure if that reset method I performed did anything, I tried a regular power off and on with no luck. I do believe that this helps to confirm that denon AVRs have issues with unreliable Internet connections.
Sent from my STV100-2 using Tapatalk
Mrjmc99 is offline
post #8015 of 17632 Old 05-06-2016, 03:46 PM
donjulio's Avatar
Internet connections? I have a X4200W, and most items works. My biggest complaint is the Internet connection. When I have no Internet connection, if I select "Internet Radio", and connect to. Sirius on-line the X4200W will establish a connection and Sirius works and then the Denon App works. But this means there is no remote operation over lan until I use the hand held remote and select Internet Radio. But so far, this has worked. I wish the AVR had an Internet "ping" command.
donjulio is offline
post #8016 of 17632 Old 05-06-2016, 05:36 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
Any AVR would have issues with an unreliable internet connection which is established by your modem.
post #8017 of 17632 Old 05-06-2016, 05:49 PM
Deckman37's Avatar
Quoted: 45 Post(s)
When I built my theater, 7.1 setups were just beginning to be discussed (2002). I built it for that configuration. I also didn't know much about surround speaker height then, so my surrounds and rear surrounds are both rather elevated, about 5.5' high. Unfortunately my construction makes lowering them difficult. Never the less I would like to take advantage of the current sound possibilities. I have a drop ceiling with the tiles about 7.5' high. I can install ceiling speakers easily. I have a 4200 so the question is should I install ceiling speakers, and if so should it be two or four. Can I even do four? Thanks.
Deckman37 is offline
post #8018 of 17632 Old 05-06-2016, 05:51 PM
Quoted: 197 Post(s)
Liked: 86
Normally I would agree, but once the Internet has been reestablished and device rebooted the "normal" way it should work without a device reset of any kind.
Mrjmc99 is offline
post #8019 of 17632 Old 05-06-2016, 06:40 PM
BenjaminG's Avatar
Quoted: 20 Post(s)
Originally Posted by Selden Ball View Post
My understanding is that Dolby Vision requires support only in the disc player (or other source device) and in the display device, not in the AVR. It is supposed to work fine with HDMI v1.4, for example.
You're probably thinking of HDR10, which is what requires HDMI V2.0a. Discs which include any form of HDR, including Dolby Vision, are required to include HDR10, but Dolby Vision itself doesn't require HDR10, so streaming services might not include both.
I believe that's the case too. I'm just checking to see if the receiver successfully passes the content through.
BenjaminG is offline
post #8020 of 17632 Old 05-06-2016, 07:24 PM
galonzo's Avatar
Quoted: 1373 Post(s)
Liked: 1781
You'll need to decide between 5.X.4, or 7.x.2 with an external amp; so your standard 5 "bed" channels plus top-fronts and top-rears in the ceiling (losing your surround-rears), or adding two ceiling speakers directly above (actually slightly forward) of the MLP as top-middles.
Madmax67 likes this.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #8021 of 17632 Old 05-06-2016, 08:32 PM
Prime316's Avatar
Quoted: 190 Post(s)
Liked: 207
Originally Posted by nohcho View Post
I understand the frustration, but let me tell you, dts x ain't all that unless you have the speaker lay out for it. Also, neural X is kind of a let down especially for music where the vocals are too much in the center. Dolby surround is much better in my opinion.
Sent from my LG-H830 using Tapatalk
Now that's depressing. I bought this receiver for Atmos...huge disappointment with add on speakers. Now you're telling me that Dtsx isn't all that great. I could have just stayed with my Onkyo 809.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #8022 of 17632 Old 05-06-2016, 09:00 PM
Quoted: 585 Post(s)
Liked: 167
You sure could have but thats just my opinion. Now let me make clear on what i stated, native atmos track is good and native dts x is good, i was saying that the neural x upmixer wasn't, all that.
galonzo likes this.
nohcho is offline
post #8023 of 17632 Old 05-06-2016, 11:10 PM
Madmax67's Avatar
Quoted: 2217 Post(s)
Liked: 2515
Current older Denon model owner with a quick question. Will the 2015 Denon X receivers be getting the firmware upgrade that allows using either the DSU or Neural-X with either a Dolby or DTS encoded disc soon? Yamaha has this feature in the Aventage receiver and I've heard it is coming for the Denon as well.Thanks in advance.
-Tom
Sent from my 710C using Tapatalk
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is online now
post #8024 of 17632 Old 05-06-2016, 11:13 PM
Quoted: 27 Post(s)
Do you think denon will update their flagship model this year? I want to buy one but thinking of waiting a little bit so I could get it a little cheaper.
ElBerryKM13 is offline
post #8025 of 17632 Old 05-06-2016, 11:19 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
No, not until Dec 2017 as I noted in the new 2016 Denon AVR Owner's thread .......
https://www.avsforum.com/forum/90-rec...l#post43790578
post #8026 of 17632 Old 05-06-2016, 11:21 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
-Tom
Later in 2016, yes.
post #8027 of 17632 Old 05-06-2016, 11:34 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
You can certainly add (2) height speakers above the FL/FR speakers as either Front Height/Top Front. Whether you can add (2) more slightly forward of the main listening position will depend on how close they would be to the current SL/SR speakers as the closer they are the less of an impact you will have from them, otherwise, you can do at least the (2) up front for sure.
post #8028 of 17632 Old 05-06-2016, 11:43 PM
Madmax67's Avatar
Liked: 2515
Later in 2016, yes.
Thank you JD . Appreciate it.
post #8029 of 17632 Old 05-07-2016, 12:35 AM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
How much power are my speakers actually getting from Denon 4200?
Currently have a 4200 and after reading that so many people have Emotiva amps I have to wonder why.
I generally watch movies at volume level 50 and TV shows at level 40 (due to loud commericals).
So am I under powering and/or damaging my five (5) ML LX16 speakers using the 4200? The MLs are rated to handle 200 watts. Thanks
Carrick is offline
post #8030 of 17632 Old 05-07-2016, 01:18 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
More likely <5% of all owners actually use an external amp as the internal amps provide more than enough power (for even many of those owners using an external amp). Although ML speakers are generally 4-ohm and require more power than 8-ohm speakers, if you are not hearing any distortion at the volume level you have selected, the internal amps are providing sufficient power.
post #8031 of 17632 Old 05-07-2016, 02:51 AM
Kazz063's Avatar
Quoted: 105 Post(s)
Liked: 102
I have an odd occurrence happening with my 4200, every now and then the volume overlay pops up all by itself, not sure but I think when it popped up last time I saw the volume level change. Has anyone else seen this behaviour on their unit?
Kazz063 is offline
post #8032 of 17632 Old 05-07-2016, 02:58 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
Could be your TV is doing this.
post #8033 of 17632 Old 05-07-2016, 07:27 AM
TinyRK's Avatar
Quoted: 223 Post(s)
Liked: 132
I guess, when someone is listening somewhere else with the Spotify Account - like my wife on her iPhone while I tried to connect it from her ipad to the AVR, it doesnt't stream music.
I wish Denon would notify one, if music is already streaming somewhere else.
Women...
TinyRK is offline
post #8034 of 17632 Old 05-07-2016, 10:32 AM
SeaniePants's Avatar
x2200 model question:
I realize zone two cannot play HDMI audio. However, let's say I'm watching a baseball game on Zone 1 (HDMI) and I want to duplicate Zone 1 audio on Zone 2. Is that possible?
I think not, but I wasn't sure if I was overlooking something.
SeaniePants is offline
post #8035 of 17632 Old 05-07-2016, 11:09 AM
Witchboard's Avatar
Quoted: 189 Post(s)
Liked: 187
Question about the Bluetooth on the 4200. You can only use the receiver as a playback device from a Bluetooth device, correct? Basically, I can't pair headphones to the 4200?
Witchboard is offline
post #8036 of 17632 Old 05-07-2016, 11:10 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3015
JD just helped me with an order through AVS AV Science for an X4200W as an upgrade for my much older AVR-888. It will be here before the end of this coming week. Thanks JD!
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #8037 of 17632 Old 05-07-2016, 11:29 AM
lujan's Avatar
Quoted: 4585 Post(s)
Liked: 2660
Yes, we all get a lot of good and valuable information from JD as well, thanks!
lujan
559 Ultra HD
721 HD
4 SD
lujan is online now
post #8038 of 17632 Old 05-07-2016, 11:49 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
Correct. You would need to add a 3rd party Bluetooth transmitter.
post #8039 of 17632 Old 05-07-2016, 11:51 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12279
If you don't mind stereo in the main zone as well ... select OPTION - ALL ZONE STEREO on the remote. Otherwise if you want to maintain 5.1 in the main zone, then also connect an analog audio cable (red/white) from the source to the same source name analog inputs (eg. CBL/SAT).
post #8040 of 17632 Old 05-07-2016, 12:13 PM
Witchboard's Avatar
Quoted: 189 Post(s)
Liked: 187
That's what I figured. Thanks.
4:4:4 , alexa , arc , audyseey , Audyssey , avr , AVR-X2200W , bluetooth , chroma , connect , Denon , denon 2200w , denon x1200w , lfe , s710w , s910w , spotify , x-1200w , x1200w , x2200w , x3200w , x4200 , x4200w , x6200w , Yamaha
