The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2) - Page 411 - AVS Forum | Home Theater Discussions And Reviews
 101681Likes
post #12301 of 17508 Old 11-19-2016, 02:45 AM
brotbuexe's Avatar
Originally Posted by justthinking View Post
Is there a problem with Denon and Spotify right now?
Works fine on my 1200w from the Android App.
brotbuexe is offline
post #12302 of 17508 Old 11-19-2016, 03:00 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22003 Post(s)
Liked: 11927
Originally Posted by Jahjd2000 View Post
I have a simple question, I think. I read the manual but didn't find exactly what I was looking for.
I have a Denon x6200 and am running a 5.1.4 configuration.
My question is, using a 2 channel amp, can I run a separate zone (2 channels) and use the monitor out for a 2nd TV? I know I can run a zone 2 for music but the owners manual doesn't specify if I can also do another monitor.
Yup. That's the whole purpose for the Zone 2 HDMI monitor output.
For audio, simply connect the external 2CH amp to the Zone 2 pre-outs and raise the its volume to at least 80% of maximum (if there is a gain knob on it). Note however, the HDMI source must be set to PCM 2.0 in order to pass the audio to the Zone 2 speakers.
jdsmoothie is online now
post #12303 of 17508 Old 11-19-2016, 03:02 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11927
Originally Posted by Whopper80 View Post
Hi!
issue is resolved, but in order to resolve it i had to turn on the scaler to 4K for some reason. But all is working fine now Thanks again!
Great! Thanks for the follow up.
post #12304 of 17508 Old 11-19-2016, 10:19 AM
Jahjd2000's Avatar
Quoted: 50 Post(s)
Liked: 81
Thanks! I figured it was supported but for some odd reason the Denon manual only shows additional audio zones. Or maybe I didn't look deep enough in the manual.
I now just need to find a reasonable 2 channel amp. I believe there were recommendations in this thread.
Jahjd2000 is offline
post #12305 of 17508 Old 11-19-2016, 10:23 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11927
The one most often recommended is the AudioSource Amp100VS which normally runs $90-$130 on Amazon.
https://www.amazon.com/Audio-Source-.../dp/B00ZSEFU94
Madmax67 likes this.
post #12306 of 17508 Old 11-19-2016, 10:33 AM
Jahjd2000's Avatar
Quoted: 50 Post(s)
Liked: 81
Thanks again mate! You saved me a lot of search angst because the AVS Forum isn't loading properly for me. I can't access the search feature. I think it's a Java issue (user problem). I just ordered the amp off Amazon.
post #12307 of 17508 Old 11-19-2016, 04:30 PM
jsmiddleton4's Avatar
Quoted: 1038 Post(s)
Liked: 373
Listening to James Bond The Spy Who Loved Me. Its DTS-HD MA. Cycled through some of the new options. Wife like the DTS HD MA with the Dolby option.
jsmiddleton4 is offline
post #12308 of 17508 Old 11-19-2016, 04:33 PM
Liked: 373
And each time I point out this option. Very satisfying.
https://www.amazon.com/Onkyo-M-5010-...6VT2BGKAR8F7VC
post #12309 of 17508 Old 11-20-2016, 08:11 AM
KMFDMvsEnya's Avatar
Quoted: 311 Post(s)
Liked: 624
Originally Posted by subacabra View Post
...I noticed my bass didn't quite sound as awesome as it always has. I haven't messed with any settings since dialing everything in a few months ago to where I was very happy....
I double checked all my settings, knobs on subs etc thinking maybe my son messed with them. Everything was fine there.
The only change of late would be the dts Neural:X update(x6200)
Anyone else experience something like this?
I updated yesterday and noticed the same thing. I seem to have resolved the issue by going into Audyssey settings then manual settings and in my case after making one change of the center channel crossover from 60hz to 80hz the bass performance returned to its pre-update response.
More specifically I looked into the various Audyssey settings and considered a Restore but did not, then followed that with looking at the manual settings. I believe that perhaps just simply looking into the settings menus fixed the bass issue. YMMV.
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is offline
post #12310 of 17508 Old 11-20-2016, 10:21 AM
Zebo51's Avatar
Quoted: 24 Post(s)
Question
2015 Denon AVR FAQ, Setup, and Troubleshooting Guide
y. Why "Multi Ch In" and not DD/DTS/Dolby TrueHD/DTS MA HD/Atmos/DTS:X?: This is because your source device (eg. Blu Ray player or HTPC) is set to "PCM" and so it is decoding/uncompressing the audio to PCM. If you want the AVR to do the decoding (although it won't matter audio quality wise which one decodes it) so you can see the compressed audio track on the AVR's front panel display then set the source device to "bitstream" with either the Secondary Audi/BD Audio Mix set to OFF. Note that when playing an ATMOS or DTS:X BD (after installing the DTS:X firmware update, ETA early 2016), the source device must be set to "bitstream"/Secondary Audio (OFF).
I have the X3200W. Just replaced an older HTPC with an Intel NUC6i5SYH. Running windows 10 on it. I have it plugged into the BluRay HDMI input on the x3200w. When I hit the info button I have the following:
Sound: Multi Ch in
Signal: PCM
On my old HTPC I had it somehow set to bitstream as my display always showed DTS or whatever format was being used. Anyone know how to do this on the NUC I have? See attached image.
Thankks
Zebo51 is offline
post #12311 of 17508 Old 11-20-2016, 10:30 AM
doctorwizz's Avatar
Quoted: 752 Post(s)
Liked: 252
Sound: Multi Ch in
Signal: PCM
Thankks
You need to set it to "Stereo". Not 5.1
Then config whatever apps to use the Denon audio device.
doctorwizz is offline
post #12312 of 17508 Old 11-20-2016, 10:39 AM
Zebo51's Avatar
Quoted: 24 Post(s)
That didn't work. Now Denon info says Sound: Stereo and Signal still shows PCM.
I'm using MPC-HC for playback.
Zebo51 is offline
post #12313 of 17508 Old 11-20-2016, 10:42 AM
erwos's Avatar
OK, weird problem. My wife and son were playing some PS4 this afternoon, and my AVR-X3200W suddenly stopped pushing video to the TV. We could hear sound fine, but no video whatsoever from any of the sources on the receiver. Checked all connections, nothing loose. Switching HDMI ports on the TV didn't help. I could not get the Denon "background graphic" to come up, either. Performed a hard reset as per the thread instructions. Still no change.
Are there any other tricks I can try, or is it time to wade into the swamp that is Denon support? Terrible time for this to happen, ugh.
ETA: Zone2 seems to work still.
erwos is offline
post #12314 of 17508 Old 11-20-2016, 11:07 AM
doctorwizz's Avatar
Quoted: 752 Post(s)
Liked: 252
Actually setting to stereo won't affect bitstreaming. It is just better for DSU.
Do you have a codec pack installed like KlLite? MPC seems to need them.
Probably need to config LAV like this
post #12315 of 17508 Old 11-20-2016, 11:49 AM
jrg6771's Avatar
Quoted: 24 Post(s)
Liked: 35
Hiss after firmware update on my AVR-X6200W
HELP, anyone have an elevated noise floor (hiss) on all channels after updating their firmware. Ever since I updated the firmware this week for the DTS Neuro X/ Dolby Surround cross-mix I have had this hiss.
These are some of the things I've noticed:
1- Audible at any volume on any source but especially noticeable above -5 db on the master volume.
2 - Increases in volume if I use DTS Neuro X up-mixer (more so than Dolby Surround).
3 - Only present if the output indicators are lit up.
4 - Much more noticeable if Audyssey is engaged.
I have done a reset and re-ran Audyssey, and eliminated all sources on at a time and have the same results.
My older AVR-4311 had a zero db noise floor and so did this receiver before this latest update.
James
LG: OLED65C6P 65" OLED Panel
Marantz: SR7010 & Adcom: GFA555 x 2 L/R and Center
Definitive: BP30 x 6 for bed layer and CLR2000 for center duty
Definitive: ProMonitor 1000 x 4 for ATMOS/DTSX heights
SVS: PB12-Plus x 2 and Crown: XLS 1002 powering BK LFE
jrg6771 is offline
post #12316 of 17508 Old 11-20-2016, 12:18 PM
Liked: 373
"HELP, anyone have an elevated noise floor (hiss) on all channels after updating their firmware"
No.
post #12317 of 17508 Old 11-20-2016, 05:01 PM
Foundation42's Avatar
Quoted: 77 Post(s)
Liked: 95
I haven't noticed any change, but I'll give it a closer listen.
jrg6771 likes this.
Foundation42 is offline
post #12318 of 17508 Old 11-20-2016, 05:31 PM
doctorwizz's Avatar
Quoted: 752 Post(s)
Liked: 252
Whoops. The codec install is only if using MPC. MPC-HC has them built in.
But you can get to that screen in MPC-HC by pressin the letter O to go to options, internal filters, and clicking Audio Decoder at the bottom there.
Edit: Also, in v1.7.10 of MPC-HC:
Completely new Internal Audio Renderer:
Uses sanear project as backend
Requires Windows Vista or newer
Outputs sound through WASAPI (shared or exclusive)
Employs automatic channel downmixing
Provides stereo crossfeed processing option (for headphones)
Tries to preserve signal pitch when playing at custom rate (time stretching)
Supports bitstreaming
Note that you need to select the new renderer in options in order to use it
So to select it press O to get to options, audio renderer. Select exclusive mode also.
Zebo51 likes this.
post #12319 of 17508 Old 11-20-2016, 06:04 PM
jrg6771's Avatar
Quoted: 24 Post(s)
Liked: 35
Thanks, after some additional research, I have found that some 6300 users are having the exact same problem. I'll call Denon tomorrow.
jrg6771 is offline
post #12320 of 17508 Old 11-21-2016, 06:54 AM
Quoted: 159 Post(s)
Liked: 39
How to get more clarity from centre speaker?
I have Denon 4200 and Paridigm 5.1 speaker configuration. I have tried so many different settings but have not been able to improve clarity from the centre speaker. Conversation is kinda muffled, not crisp, almost as if it needs more treble. Are there any specific settings people have found that can improve the clarity?
Treck216 is offline
post #12321 of 17508 Old 11-21-2016, 06:57 AM
asere's Avatar
Quoted: 1912 Post(s)
Liked: 589
Will the Echo mode ON help keep the receiver cooler?
Also does ON impact the sound quality?
Sent from my SM-G900P using Tapatalk
diverdra likes this.
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #12322 of 17508 Old 11-21-2016, 07:24 AM
dark1x's Avatar
Quoted: 16 Post(s)
So it has become evident to me that the X3200w does not actually properly support YUV422 input at higher color depths.
When inputing 420, the receiver will read up to 12-bit but when using 422, I notice increased color banding, and the receiver reports "---" as the color depth suggesting that it isn't accepting it properly.
It apparently DOES work on the X3300w, however.
It seems like something they could fix in firmware (maybe?) but it's highly annoying.
dark1x is offline
post #12323 of 17508 Old 11-21-2016, 07:30 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11927
1. Yup .. about 10 degrees cooler.
2. Shouldn't be any impact on sound quality at below reference volume levels (<80/0db).
post #12324 of 17508 Old 11-21-2016, 07:31 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11927
Any video related issues should be reported to Denon directly to register the issue.
post #12325 of 17508 Old 11-21-2016, 07:33 AM
asere's Avatar
Liked: 589
Cool, thank you. Also is there a way to check the receiver temp?
asere is offline
post #12326 of 17508 Old 11-21-2016, 07:36 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11927
Running Audyssey MultEQ XT32 alone should help to improve the center channel dialog quite a bit, certainly over the lower MultEQ/MultEQ XT versions, however, you can also further improve audio quality by doing one or more of the following:
1. Ensure the center speaker is pulled out to the edge of the cabinet and angled up towards your head (ie. not flat pointing towards your knees).
2. Run Audyssey again if any speaker positioning made above.
3. If using Audyssey Dynamic EQ, for cable/sat sources, set the Reference Level Offset to 10db which will reduce the bass impact of Dyn EQ making dialog easier to hear.
4. Simply increase the volume of the center speaker.
post #12327 of 17508 Old 11-21-2016, 07:37 AM - Thread Starter
jdsmoothie's Avatar
Liked: 11927
This is what I use ---> https://www.amazon.com/Etekcity-Lase...3H8NRBBH90PH70
asere and Squirrel! like this.
post #12328 of 17508 Old 11-21-2016, 07:55 AM
Tarheels_23's Avatar
Quoted: 41 Post(s)
S/O to HiDEF Lifestyle. I ordered the x4200, and received a free upgrade to the x4300H. You can imagine my surprise when the x4300H was delivered this morning. I thought maybe there's been a mistake, but they wrote "Free Upgrade" on the receipt.
Merry Christmas to me.
schmidtwi, Mrjmc99 and mrtickleuk like this.
Tarheels_23 is offline
post #12329 of 17508 Old 11-21-2016, 08:59 AM
Pappa's Avatar
Bluetooth - Amazon Echo Dot (2nd gen)
I recently purchased an Echo Dot (2nd gen) and connected it to my s910w via bluetooth.
The initial pairing was successful and the echo dot plays through the s910w as designed.
However, switching inputs from Bluetooth to another input (any other input) and back to Bluetooth the echo dot never reestablishes the bluetooth connection.
The s910w goes into the initial "pairing" setup, like it was never paired to the receiver. The Alexa APP shows the Echo Dot as paired but the s910w doesn't seem to be remembering the pairing. Does the s910w show a list of paired bluetooth devices?
Any suggestions?
NOTE: I am using the Echo Dot along with a Logitech hub and it works amazing changing inputs and turning stuff on and off.
Ex: "Alexa turn on ESPN" turns on all necessary components and turns DISH NETWORK to ESPN. Programming the Logitech from Android App is so much easier that old method of PC and USB cable.
Pappa is offline
post #12330 of 17508 Old 11-21-2016, 09:05 AM
bowtye8's Avatar
Quoted: 16 Post(s)
Have the X4200W setup for 5.1.2(Atmos).
About a month ago while watching a movie its started to crackle. When I would try to adjust speaker levels. All were OK except for my Atmos speakers. Nothing during the test tone. All other speakers had the test noise coming out of them.
I ended up switching the amp back to 5.1 +Zone 2
All working fine for the past 30 days.
Last night I was getting ready to watch Transformers 3 with my son. I said let me try the 5.1.2 setting again.
Set that in AMP assign then went to speakers levels. Had nothing out he Atmos speakers then 5 sec later the pink test noise started. All seemed good.
About 30mins into the move the crackle started really bad. Went back to 5.1 +Zone 2 ) and finished off the movie.
I guess I can try a full AMP reset???
Or maybe Warr... Hope not!!!! Amp was purchased on Nov 12th 2015.
Dennis
bowtye8 is offline
4:4:4 , alexa , arc , audyseey , Audyssey , avr , AVR-X2200W , bluetooth , chroma , connect , Denon , denon 2200w , denon x1200w , lfe , s710w , s910w , spotify , x-1200w , x1200w , x2200w , x3200w , x4200 , x4200w , x6200w , Yamaha
