The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2) - Page 413 - AVS Forum | Home Theater Discussions And Reviews
 101725Likes
post #12361 of 17635 Old 11-22-2016, 06:02 AM
Pappa's Avatar
Originally Posted by Pappa View Post
I recently purchased an Echo Dot (2nd gen) and connected it to my s910w via bluetooth.
The initial pairing was successful and the echo dot plays through the s910w as designed.
However, switching inputs from Bluetooth to another input (any other input) and back to Bluetooth the echo dot never reestablishes the bluetooth connection.
The s910w goes into the initial "pairing" setup, like it was never paired to the receiver. The Alexa APP shows the Echo Dot as paired but the s910w doesn't seem to be remembering the pairing. Does the s910w show a list of paired bluetooth devices?
Any suggestions?
NOTE: I am using the Echo Dot along with a Logitech hub and it works amazing changing inputs and turning stuff on and off.
Ex: "Alexa turn on ESPN" turns on all necessary components and turns DISH NETWORK to ESPN. Programming the Logitech from Android App is so much easier that old method of PC and USB cable.
UPDATE: I got it working! After much research I found that the Echo cannot pair with a bluetooth receiver/speaker that requires a passcode be entered. That got me thinking... (insert smoke here). I was putting the s910w into bluetooth pairing mode then starting the pairing sequence from the Echo. It would never keep the pair, the receiver would show the pairing code but the Echo has no interface to enter it.
The solution was to REVERSE the sequence, I started the Echo searching for a bluetooth THEN started the s910w pairing sequence. For whatever reason it paired and now keeps the pair when switching inputs! Hallelujah! Hope this can help some other inmates here!
stevesreed likes this.
Pappa is offline
post #12362 of 17635 Old 11-22-2016, 06:33 AM
jsmiddleton4's Avatar
Quoted: 1038 Post(s)
Liked: 373
jsmiddleton4 is offline
post #12363 of 17635 Old 11-22-2016, 07:31 AM
Super Moderator
DrDon's Avatar
Quoted: 2295 Post(s)
Liked: 4339
Threads merged. Please see THIS POST.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
post #12364 of 17635 Old 11-22-2016, 08:12 AM
lujan's Avatar
Quoted: 4590 Post(s)
Liked: 2664
Originally Posted by joeyvaz View Post
Updating to the latest firmware (just showed up this morning on my unit) fixed the Pandora log in issue. Glad this was finally fixed.
I don't really use Pandora so I haven't noticed anything different about the update. I hear we can now use DTS upmixer for Dolby content and vice versa but I haven't tried those yet.
lujan
561 Ultra HD
721 HD
4 SD
lujan is online now
post #12365 of 17635 Old 11-22-2016, 09:11 AM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 669 Post(s)
Liked: 308
I have a question.
I have a little indoor over the air antenna hooked up to my Panasonic VT60 via coax cable. Other than my X6200, which is connected via HDMI to the ARC capable HDMI connection on the TV, it's the only thing connected to the TV. Whenever I try to view the OTA content with the X6200W turned on, meaning ARC is engaged for audio, I experience occasional picture freeze ups and audio cut outs.
Could this simply be an issue with the HDMI cable or is it likely an inherent issue with the television and/or ARC? The cable is a few years old, but it's supposedly "high speed". When the 6200 is off, the picture and audio are fine.
I've experienced similar issues in the past when multiple sources are hooked up to a tv, and powered on, and I'm trying to use a coax feed. Sometimes if the DirecTV tuner was on, it would interfere with the antenna feed coming in via coax etc. When I turned the DirecTV tuner off, everything would be fine.
Has anyone else experienced this type of problem?
I've considered getting an external digital tuner that I could use to feed the OTA content through the X6200, which I believe would eliminate this issue, but I don't want to have to do that if something else might be causing this problem.
B T C is offline
post #12366 of 17635 Old 11-22-2016, 11:58 AM
jrogers's Avatar
Quoted: 275 Post(s)
Liked: 174
Was just reviewing settings on my 6200, and was wondering what, if any, changes to reference level offset folks have decided to use for various sources. I'm assuming most are using 0dB for blu-ray players, but am curious if anyone has experimented and decided on different settings for other devices? In particular, xfinity set-top box and xbox one.
Samsung UN75HU8500 TS01 w/SEK-3500U, K8500 UHD Blu-ray Player; Xbox One; Xfinity X1
Dolby Atmos and DTS:X 7w.1.4; Denon X6200W; Audiosource AMP102; GoldenEar SuperSat 60/60C, SuperSat 50, SuperSat 3/3C, Invisa 525; SVS PB-2000
Harmony Ultimate One; Insteon; Acoustimac
jrogers is offline
post #12367 of 17635 Old 11-22-2016, 03:13 PM
schmidtwi's Avatar
Quoted: 232 Post(s)
Liked: 176
Just bought a 4200, will be here tomorrow. This will replace a 4311ci, which has the option to use the external amp on the front LR. Does the 4200 have this option? Or is the amp limited to only the ATMOS speakers?
The Schmidt Haus Theater - WIP (or not) since 2010
schmidtwi is offline
post #12368 of 17635 Old 11-22-2016, 03:33 PM
batpig's Avatar
Quoted: 4851 Post(s)
Liked: 5172
The 4200 has pre-outs for all channels.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #12369 of 17635 Old 11-22-2016, 03:51 PM
stevejason777's Avatar
Quoted: 12 Post(s)
Depends on whether it meets your feature/input/output requirements as the current replacement for the 3808CI is the X6300H. Also important to note that only the X7200WA still features multi analog inputs (ie. SACD player). The 3808CI is a 130W AVR vs. the 95W X2300W so will also depend on the impedance/sensitivity of your speakers as to whether this spec is moot or not. Audio quality should be similar after running Audyssey as both the 3808CI and X2300W use the same MultEQ XT. However, as others have indicated, you're better served upgrading to an XT32 model (eg. X3300W or X4200W or X4300H), selecting the model that best meets your feature/input/output requirements.
Thanks for the suggestions. I'm still using my ancient DefTech BP30's as my mains. I'll be upgrading my OPPO 103 to the 203 when it comes out. Maybe the X3300W will fit in my budget. Just purchased an LG OLED B6, an expensive year.
stevejason777 is offline
post #12370 of 17635 Old 11-22-2016, 06:43 PM
schmidtwi's Avatar
Quoted: 232 Post(s)
Liked: 176
Thanks batpig. I know it has all the preouts, I just wanted to make sure I have the option to use the amp on the main LR when I go with 5.2.4.
The online manual shows the ATMOS speakers using the external amp in a 5.2.4 config. I will use an iNuke 1000, so want the power on the mains.
post #12371 of 17635 Old 11-22-2016, 07:08 PM
schmidtwi's Avatar
Quoted: 232 Post(s)
Liked: 176
Originally Posted by Tarheels_23 View Post
S/O to HiDEF Lifestyle. I ordered the x4200, and received a free upgrade to the x4300H. You can imagine my surprise when the x4300H was delivered this morning. I thought maybe there's been a mistake, but they wrote "Free Upgrade" on the receipt.
Merry Christmas to me.
Very nice - you definitely got an early Christmas! I just ordered the last X4200 from HiDEF Lifestyle on Sunday (through Newegg). I hope they oblige me with the "Free Upgrade".
But I'll be happy with the 4200 at that price.
jsmiddleton4 and mrtickleuk like this.
post #12372 of 17635 Old 11-22-2016, 07:55 PM
Tarheels_23's Avatar
Quoted: 41 Post(s)
Check back in if you get the x4300H as well. I'd be interested in knowing.
Tarheels_23 is offline
post #12373 of 17635 Old 11-22-2016, 08:15 PM
chemist323's Avatar
Although your current configuration assures no lag as all video is passed to the TV directly, lag is rarely discussed in this thread so apparently not a problem when the devices are connected directly to the AVR with the "i/p Scaler" setting to OFF and if necessary, setting the "Video Conversion" setting to OFF as well.
Thanks appreciate the help jdsmoothie
chemist323 is offline
post #12374 of 17635 Old 11-22-2016, 08:17 PM
chemist323's Avatar
Wow that's awesome, i would've gone for that deal. I went through electronics expo, no tax in CA
post #12375 of 17635 Old 11-22-2016, 09:11 PM
asere's Avatar
Quoted: 1924 Post(s)
Liked: 597
When listening to NEURAL X. Why do the top heights come on more then the surrounds? It seems like the surrounds are off yet with standard DD the surrounds come on.
Sent from my SM-G900P using Tapatalk
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #12376 of 17635 Old 11-22-2016, 09:53 PM
jcp2's Avatar
Quoted: 72 Post(s)
Liked: 64
I've noticed the same thing running 7.1.4
jcp2 is offline
post #12377 of 17635 Old 11-22-2016, 09:58 PM
loknload's Avatar
Quoted: 137 Post(s)
Liked: 100
You can use the external amp with the mains. I have mine set up that way using an Adcom GFA-545II to power my Energy RC70's. Somewhere in this thread is a post I put up of my settings but it's pretty easy when you go into speaker setup, set it to 9.1, and then tell it you have 4 height speakers and set the pre-out to mains.
loknload is offline
post #12378 of 17635 Old 11-22-2016, 10:00 PM
asere's Avatar
Liked: 597
It even happens with DD+DSU.
asere is offline
post #12379 of 17635 Old 11-23-2016, 02:18 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22569 Post(s)
Liked: 12282
Assign Mode: 9.1
Floor
- Layout
: 5ch & SB
Height
– Height Sp
: 2ch
- Layout: Top Middle
- Pre-out: Front
Assign Mode: 9.1
Floor
- Layout
: 5ch
Height
– Height Sp
: 4ch
- Layout: Top Front + Top Rear
- Pre-out: Front
jdsmoothie is offline
post #12380 of 17635 Old 11-23-2016, 06:19 AM
Gabatta's Avatar
Quoted: 119 Post(s)
Liked: 70
Nice! You must have hit it just right as they ran out of stock, as the 4200 is no longer listed on their website. 4200s are drying up everywhere.
Gabatta is offline
post #12381 of 17635 Old 11-23-2016, 08:42 AM
toneman's Avatar
Quoted: 59 Post(s)
Liked: 39
LOL--I've experienced the above issue as well (OTA signal degradation manifests itself when I turn on the DirecTV box, and disappears when I turn it off)...and here I am/was thinking that perhaps it may have been a combination of my location being somewhat close to the fringe of OTA HD reception and the indoor antenna I was using (antennaweb says indoor antenna should work for my location).
Tony
toneman is offline
post #12382 of 17635 Old 11-23-2016, 09:15 AM
asere's Avatar
Liked: 597
In listening to Pandora. Will the audio be better using Pandora on the 4200 vs the Oppo 103d since 4200 has the better DAC 32 or is it all the same?
asere is offline
post #12383 of 17635 Old 11-23-2016, 10:42 AM
schmidtwi's Avatar
Quoted: 232 Post(s)
Liked: 176
It is Christmas!! I received a X4300H this morning. The shipping invoice was marked "Free Upgrade to AVR-X4300H!!"
I sent the Sales Manager a thank you email. I will do business with them again!
post #12384 of 17635 Old 11-23-2016, 10:46 AM
mrtickleuk's Avatar
Quoted: 4859 Post(s)
Liked: 7151
You're soooo lucky! Congrats.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #12385 of 17635 Old 11-23-2016, 10:59 AM
batpig's Avatar
Liked: 5172
This is because Neural:X is super aggressive about moving any direct effects to the overhead speakers. It's why a lot of people dislike it vs. DSU unless you really want that emphasized overhead effect.
Setup Guide and FAQ
post #12386 of 17635 Old 11-23-2016, 11:18 AM
asere's Avatar
Liked: 597
I feel the rear surrounds disappear too with DSU.
asere is offline
post #12387 of 17635 Old 11-23-2016, 11:26 AM
mrtickleuk's Avatar
Liked: 7151
Interesting. Would anyone who has 7.1.4 care to comment on how much comes out of the rears in this setup?
Given a choice of 7.1.2 vs 5.1.4, if the up-mixers are both pulling so much out of the rear channels, it would be a waste to go with 7.1.2?
Sent from my PC using Chrome.
_______________
post #12388 of 17635 Old 11-23-2016, 11:32 AM
Liked: 373
So what did you lucky stiffs end up paying for your X4300's?
post #12389 of 17635 Old 11-23-2016, 11:53 AM
batpig's Avatar
Liked: 5172
I don't notice any issue with rear surrounds "disappearing" with Dolby Surround upmix. The aggressive overhead usage of Neural:X upmix is widely reported but I wouldn't necessarily jump to conclusions about other things which don't have broad consensus.
mrtickleuk likes this.
Setup Guide and FAQ
post #12390 of 17635 Old 11-23-2016, 12:08 PM
Quoted: 189 Post(s)
Liked: 92
Guys,
Do you think I should get a Refurbished x3200w with extended warranty or a refurbished x2300w with 1 year warranty (there's no extended wrranty for this one yet)?
Right now the x3200 is about $430 + ext warranty and the x2300 goes for $450
LDBaha is offline
4:4:4 , alexa , arc , audyseey , Audyssey , avr , AVR-X2200W , bluetooth , chroma , connect , Denon , denon 2200w , denon x1200w , lfe , s710w , s910w , spotify , x-1200w , x1200w , x2200w , x3200w , x4200 , x4200w , x6200w , Yamaha
