The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2) - Page 474 - AVS Forum | Home Theater Discussions And Reviews
 101714Likes
post #14191 of 17585 Old 07-09-2017, 09:32 PM
Murilo's Avatar
Quoted: 272 Post(s)
Liked: 62
Originally Posted by Boggle View Post
ok I have found a weird way of fixing it. I am using an epson 5040ub. When I lower the resolution from 4096X2160 to 3840X2160, all of my sound options come back and atmos starts working again. In light of this I am thinking its not the firmware after all.
Ugh not sure if it was this update, but it took me months to figure out a fix for denon frequently not showing up as a spotify connect device, now i believe after this latest update it once again will not show up as a spotify connect device.
The work around originally was that it seemed not to like a static ip address or after awhile it would just disappear, so I made a dhcp reservation for the avr and it worked fine for months, now its disappearing again.
They really need to get it together.
Murilo is offline
post #14192 of 17585 Old 07-10-2017, 04:29 AM
Liked: 0
AVR's can't mix audio, rather only the Karaoke mixer can do this; however, you could play audio from one source to the Zone 1 speakers and audio from a second source to the Zone 3 speakers.
HI,
Thanks for the reply. However, can the Zone 3 and Zone 1 speakers be the same?
keashdoc is offline
post #14193 of 17585 Old 07-10-2017, 05:12 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22388 Post(s)
Liked: 12182
Originally Posted by keashdoc View Post
HI,
Yes, using the "ALL ZONE STEREO" setting.
jdsmoothie is offline
post #14194 of 17585 Old 07-10-2017, 05:16 AM
asere's Avatar
Quoted: 1914 Post(s)
Liked: 590
With the x4200 can you run audyssey for 2 different speaker layout like one for dsx and another for 5.2.2 Atmos and be able to switch back and forth?
Sent from my SM-G935P using Tapatalk
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #14195 of 17585 Old 07-10-2017, 05:30 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12182
Yes, but you would have to first SAVE each config file to a PC file and then LOAD each file back (~10 minutes) when you wanted to use that specific configuration. The 2016 and newer models are able to use the new Audyssey MultEQ Editor app which saves the EQ files on a smart phone/tablet and then takes only a couple of minutes to load back to the AVR so much easier to swap back and forth.
post #14196 of 17585 Old 07-10-2017, 05:34 AM
asere's Avatar
Liked: 590
How do I load to pc?
asere is offline
post #14197 of 17585 Old 07-10-2017, 05:37 AM
mrtickleuk's Avatar
Quoted: 4696 Post(s)
Liked: 6971
You can't.
The SAVE goes to the PC.
The LOAD goes from the PC to the AVR.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #14198 of 17585 Old 07-10-2017, 05:43 AM
asere's Avatar
Liked: 590
Originally Posted by mrtickleuk View Post
You can't.
Yes I meant how do I save to pc then load back to avr?
asere is offline
post #14199 of 17585 Old 07-10-2017, 05:57 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12182
Using the Web Control feature (p. 170 Owner's manual).
post #14200 of 17585 Old 07-10-2017, 07:44 AM
kokishin's Avatar
Quoted: 1255 Post(s)
Liked: 1271
See section 4.i. of this post: https://www.avsforum.com/forum/90-rec...-2-2-a.html#e9
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon Fire TV Stick, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is online now
post #14201 of 17585 Old 07-10-2017, 12:16 PM
Blue Moon's Avatar
Liked: 0
Denon X3200W receiver help..
I have had two of these units, one that came with the system when we moved in, and one that we got under warranty because our speakers weren't turning off when the box was off (they are powered through it). Ever since we got the replacement we have had this issue of our tv stays on when we switch to the projector.
By doing this we change the view from the samsung tv we have on the wall, to the projectors screen that comes from the ceiling, before when we switched between the tv to the screen, the tv would turn off and we couldn't see the picture flashing behind the retractable screen, whereas now we can.
it's as if the amp switches inputs but leaves the tv on. If we turn the tv behind the screen off the projector turns off as well and then a few seconds later the tv will turn back on and the projector will turn back on...weird huh?
I know there must be a setting with the denon set-up menus, but i'm not sure what I should be looking for, any help with this?
(Sorry if this is the wrong subsection)
Blue Moon is offline
post #14202 of 17585 Old 07-10-2017, 12:54 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12182
Although a PJ + TV configuration can work using the X3200W, it is not designed for using a TV and PJ in the same room (as are the same year X2200W and X4200W models which have dual main zone HDMI outputs specifically designed for the PJ + TV use case) as the second HDMI output is for Zone 2 which must be powered on/off separately from the main zone. The first unit likely had no issue at all as when the main zone power is turned off, so to must the Zone 2 be powered off as well otherwise it will remain on per design.
Blue Moon likes this.
post #14203 of 17585 Old 07-10-2017, 02:05 PM
Blue Moon's Avatar
Liked: 0
In short, I have to have zone 2 off in order to just watch the PJ and not have the TV on behind it?
post #14204 of 17585 Old 07-10-2017, 02:22 PM
Blue Moon's Avatar
Liked: 0
The ultimate issue is that, zone 1 connects to my HT speakers, and zone 2 connects to my outdoor speakers. So if I have zone 1 off while watching a movie the sound is being passed to the outdoor speakers and no sound comes through my HT speakers.
post #14205 of 17585 Old 07-10-2017, 03:08 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12182
That would work, yes.
post #14206 of 17585 Old 07-11-2017, 10:08 AM
Pictures at an Exhibition's Avatar
Liked: 0
x4200w question. I am running in 5.1 mode. No wide,rear, ceiling or anything else. I run the front L&R speakers using an external two channel amp hooked to the front pre out and the center and L&R surrounds from the 4200 itself. OK no problems here.
I have tried to add another set of front speakers with another separate external amp as per the manual by changing the amp assignment to 5.1+ second pair of front speakers A&B as desired using the surround back pre out for speaker B as per the manual.
I want to run the second pair of speakers (B) in just two channel.
Now if I choose speaker A, I get sound out of both (A+B) front pairs. If I choose speaker B I get sound from both (A+B) front pairs. Same if i choose A+B. I have looked at several options including; 7.1-channel + speakers used exclusively for 2-channel playback and the 9.1 option just to see if using the pre out a different way would work. No luck.
As I understand it the pre outs are powered all the time regardless if you use them or not. It seems that the amp assigns are limited. If I choose 7.1 or 9.1 then the 4200 says to use pre out for zone 2 and 3, or some other combination. The amp never indicates how to choose what I want to do. It seems that I am restricted to using just one external amplifier not two (at least the way I want to as per above). If anyone has any tips or point out what I am missing please chime in.
Otherwise I am thinking I might have to replace both amps for one amp with an A B switch on the front panel. I do not want to use a speaker switch box.
Pictures at an Exhibition is offline
post #14207 of 17585 Old 07-11-2017, 02:20 PM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
Hi, @Pictures -- the amp assign for speaker mode A+B controls the assignment of the power amps, but as you've discovered, the associated preamp RCA outs will always be hot regardless of whether you switch between A, B, or A+B.
If you just want to play B, it should be easy to mute or turn off the external power amp driving the A set of speakers....?
Primary (2.1): Thiel CS 1.2 / Velodyne F1000 sub / Adcom GFA-555 Mk2 / Rotel 970BX / Sony CDP-CA9 ES
Secondary (5.1): Paradigm Mini-Monitor v.3 / CC270 v.3 center / ADP-170 v.2 surrounds /
SVS SB1000 sub / Marantz SR-6010 / AppleTV + Win7 PC / BenQ BL3200PT
cswiger is offline
post #14208 of 17585 Old 07-11-2017, 04:50 PM
Liked: 0
Thanks for the heads up. Sometimes a possible solution is just within grasp but, you dont see it. I will give that a try tonight or tomorrow.
post #14209 of 17585 Old 07-12-2017, 01:05 PM
Liked: 0
Hi and thanks again. Your idea was spot on but, i wound up using the loop throughput on the amp that had one to the other amp. Then i used your idea to just turn one off. Its a workaround that bypasses using the Avr's A-B switch. I lose a few of the options available from the Avr but, i can do what needs to be done.
Unless i run in direct mode the second pair of speakers winds up using Audyssey's settings for the first pair. I'm sure there is no way around that. I am not saving a second profile to the pc and loading them back and forth. So direct it is. Thanks again
post #14210 of 17585 Old 07-12-2017, 01:26 PM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
A solution that works well enough may not be perfect, but if you are OK with it, then it seems to be good enough.
cswiger is offline
post #14211 of 17585 Old 07-12-2017, 01:28 PM
frankmar's Avatar
Quoted: 89 Post(s)
This is actually a good thing for most of us and something that would occur with Dynamic Volume enabled.
Originally Posted by frankmar View Post
One Problem I noticed, and did not get solved in the previous update, was that some commercial announcements the volume would go down, then on the main program, volume would come to normal.
I hope this got solved in the new firmware update.
Seems a little better, but on CNN the main commercials the volume would go down not every time, now have not noticed any volume change But within the 3minutes commercial, a 10 seconds announcement the volume goes down, then next commercial volume goes OK. I will follow this more closely.
PRESENTLY:    TCP55VT60               PS3 SLIMIR 2 BT RE-BL DENON X2200W [B] FIBETV
MOTOROLA PVR VIP-2262
PARADIGM MONITOR 7 v6 front speakersKLIPSCH SUBWOOFER
KSW10
kLIPSCH SATELITE SS-1kLIPSCH CENTER SC-1HARMONY ONE
PARADIGM ATOMS V6 (front height) NOW SYSTEM IS 5.1.2
frankmar is offline
post #14212 of 17585 Old 07-12-2017, 07:19 PM
Vagrant Pistol's Avatar
Quoted: 47 Post(s)
Liked: 49
Hope someone can help me with this. My 4300 all of a sudden is making the center speaker very high pitched and really low. It sounds like hearing someone through the speaker of a phone; not on handsfree mode or using the speaker button to hear someone. All my other speakers sound fine. I noticed it today when I was about to watch a movie on my PS4. It wasn't like that yesterday which is the odd thing. I tried different HDMi cables, plugged the source into a different input on the receiver, tried my Xbox one and I still got the same thing. I switched the Movie sound mode to different presets with no luck. The only one that made my center speaker sound normal was 'Multi Channel Stereo. So, I know the center speaker is ok and the tweeter didn't go. I did have a power outage the other day when I was playing PS4, but I have everything hooked up to my Monster Power HTS 3600. I know thats just a safe guard and it doesn't guarantee anything in the long run, but I'm thinking the power outage may have something to do with it. I don't know. I had many power outages here this summer with on issue though. Just wondering if someone else knows of this problem and what it could be.
"A Video Game Junkie At His Finest"
[1000+ games with 30 Consoles and counting]
Gamer Tag on Xbox and PSN: Vagrant Pistol
Sony 930E - Denon X4200W - Polk RTiA 7 - RTiA 3 - CSiA 6 - SVS SB12 Plus - PS4 Pro - Xbox One X
Vagrant Pistol is offline
post #14213 of 17585 Old 07-12-2017, 07:20 PM
xjagox's Avatar
Quoted: 42 Post(s)
Liked: 39
My x2200w got locked up over the weekend. No output to the projector or speakers and the display on the receiver kept getting stuck at "Update Retry>>". No comms with the Denon app either.
I ended up having to do a factory reset to resolve it. Kind of annoying, but glad it's back working again.
xjagox is offline
post #14214 of 17585 Old 07-12-2017, 08:27 PM
frankmar's Avatar
Quoted: 89 Post(s)
Do a channel test or check the Center wire connections to speaker and to AVR.
KSW10
frankmar is offline
post #14215 of 17585 Old 07-12-2017, 08:44 PM
Quoted: 47 Post(s)
Liked: 49
Just did both. Still getting the same issue. On the 'Tone' test, my center sounded sharper than all the other speakers. A bit more high pitched. While the others sounded a bit deeper. Checked 'Pure' also and it's set too auto. Its just weird that the center sounds normal only on 'Multi Channel Stereo'.
post #14216 of 17585 Old 07-13-2017, 04:09 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12182
Have you tried swapping the FL and Center speaker connections to see if the same issue present when the FL speaker is taking on center CH duties?
post #14217 of 17585 Old 07-13-2017, 04:10 AM
frankmar's Avatar
Quoted: 89 Post(s)
Check you center channel settings on the setup and also in the Option. Play with the + or - see if you see a diff.
I did a backup on before the firware upgrade and after the upgrade. just in case.
KSW10
frankmar is offline
post #14218 of 17585 Old 07-13-2017, 06:43 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
I don't see any mention of you trying a "soft reset" -- unplug from wall power for 10 minutes.
Sometimes a very brief power outage or line voltage spike can wreck havoc with digital equipment, especially when it's just barely long enough for some bits to be scrambled and some not. Unplugging from wall power for a while often can clear up that type of problem.
Selden
Selden Ball is offline
post #14219 of 17585 Old 07-13-2017, 10:58 AM
Quoted: 47 Post(s)
Liked: 49
I did that and voice sounded fine on the front speaker. Now Im wondering if it is my center.
That didn't do do anything.
Did that and its still the same.
I just called Denon and in the end, I did a master reset and the problem still persists. So now Im gonna have to bring this to a service center. Which is an hour away from where I live. Im just now sure if I should go or buy another center because @jdsmoothie idea made make think if its my center.
...and thanks for assist guys
post #14220 of 17585 Old 07-13-2017, 11:33 PM
Liked: 1
6200W issue.
I keep getting audio dropouts be it using a source from TV or android box. From TV it is dolby surround. From Android box it can be dolby surround, DTS.
I have done a HDMI reset following the instructions from the 1st page to no avail.
I have also changed the HDMI port for the Android box, still with the same issue. Did not change TV HDMI as there is only 1 hdmi with ARC.
I am using Monoprice HDMI certified premium HDMI cables.
Can I definitely say there is a problem with the HDMI board on my AVR? TIA.
libratiger is offline
4:4:4 , alexa , arc , audyseey , Audyssey , avr , AVR-X2200W , bluetooth , chroma , connect , Denon , denon 2200w , denon x1200w , lfe , s710w , s910w , spotify , x-1200w , x1200w , x2200w , x3200w , x4200 , x4200w , x6200w , Yamaha
