The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2) - Page 495 - AVS Forum | Home Theater Discussions And Reviews
 101704Likes
post #14821 of 17559 Old 11-16-2017, 07:08 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22160 Post(s)
Liked: 12032
Originally Posted by Steve Hurtado View Post
HDMI 2.0 question. What the avr-x4200w upgraded from 2.0a to 2.0b?
I have an xboxoneX and just purchased a LG OLED65B7.
Any tips on how I should run the hdmi cables? Configuration to the TV, ARC, and to the xboxoneX?
Suggestions on cables I should purchase?
HDMI 2.0b includes HLG. The DV+HLG firmware update is expected to be released to these 2015 next summer 2018.
You'll want to use "Premium" certified 4k/18gbps HDMI cables (see Monoprice).
galonzo and Steve Hurtado like this.
jdsmoothie is offline
post #14822 of 17559 Old 11-16-2017, 07:50 AM
Steve Hurtado's Avatar
Liked: 3
Thank you.
What is your thoughts on their Essentials Certified Premium High Speed HDMI Cable?
Steve Hurtado is offline
post #14823 of 17559 Old 11-16-2017, 08:12 AM
galonzo's Avatar
Quoted: 1333 Post(s)
Liked: 1702
@Steve Hurtado , any cable that has the holographic Premium Certified label will do, I use these without issue since switching
stikle and Steve Hurtado like this.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Glory and other UHD Digital codes (and some HD codes)
galonzo is offline
post #14824 of 17559 Old 11-16-2017, 11:55 AM
stikle's Avatar
Quoted: 949 Post(s)
Liked: 1114
@Steve Hurtado
I've had really good luck with Monoprice certified cables, and they are really cheaply priced.
stikle is offline
post #14825 of 17559 Old 11-16-2017, 03:06 PM
bytebuster's Avatar
Quoted: 130 Post(s)
Liked: 36
5200 dropping video/audio
Folks,
The output on my 5200 is connected to an epson 5030. Every now and then, 1-2 hours into a movie (most of the time a blu ray), I see a signal drop for 1 to 2 seconds. Initially I reckoned it must be the 50 foot cable to the projector.
Replaced that with a new active fiber optic hdmi cable. Same issue.
Then I instead connected the projector directly to the blu ray source. I connected the AVR to the blu ray source using a co-ax cable. Now 1-2 hours in, i see audio drops. No more video drops. Based on this I am thinking its the AVR that is dropping the ball?
Anyone seen something like this? To me it really seems like some kind of over heat is leading up to this given that I typically see the issue a few hours into watching a blu ray source. I don't see this often (if ever) if I use a regular HD source like the cable box.
bytebuster is offline
post #14826 of 17559 Old 11-17-2017, 07:48 AM
Dan in St. Louis's Avatar
Quoted: 358 Post(s)
Liked: 258
HDMI 2.0 question. Suggestions on cables I should purchase?
These:
Steve Hurtado likes this.
M = Mega, m = milli. K = Kelvin, k = kilo. B = Bytes, b = bits. G = Giga, g = gravity. Dan in Saint Louis
Dan in St. Louis is online now
post #14827 of 17559 Old 11-22-2017, 11:20 PM
SeanTek's Avatar
Originally Posted by lcubed View Post
are you sure that the wired connection is configured properly for your network?
airplay probably won't work if the wired connection is broken.
(fwiw, i have to use a wired connection since my denon refuses to connect to my WIFI due to poor connectivity in my listening room)
Yes, the wired connection is configured properly.
I am going to check this out again over this Thanksgiving weekend, and will see if a firmware update has addressed this issue.
galonzo likes this.
SeanTek is offline
post #14828 of 17559 Old 11-22-2017, 11:26 PM
subacabra's Avatar
Quoted: 1636 Post(s)
Liked: 4746
Originally Posted by bytebuster View Post
Folks,
I've had a similar issue with my x6200w and Benq ht2050. Turns out I had to switch the video output to monitor 2(pj) as opposed to dual.
My Sony x900e was causing issues with it on dual output.
Not even sure if you have a tv in the mix too but it's worth a mention.
galonzo likes this.
subacabra is online now
post #14829 of 17559 Old 11-23-2017, 08:08 PM
Brien's Avatar
Quoted: 116 Post(s)
Liked: 29
Hey everyone,
Re-ran MultiEQ XT32 after getting new hardwood floors (previously carpet) and now everything sounds overly bright/compressed, like a drive-thru window nearly.
Any ideas on why and how to fix?
Brien is offline
post #14830 of 17559 Old 11-23-2017, 08:33 PM
asere's Avatar
Quoted: 1912 Post(s)
Liked: 589
Originally Posted by Brien View Post
Hey everyone,
Re-ran MultiEQ XT32 after getting new hardwood floors (previously carpet) and now everything sounds overly bright, like a drive-thru window nearly.
Reflection.
I had the same issue after going from carpet to tile.
A nice size throw rug and maybe panels takes care of that.
I did both and all good now. My room used to echo.
Sent from my SM-G935P using Tapatalk
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #14831 of 17559 Old 11-23-2017, 08:37 PM
Brien's Avatar
Quoted: 116 Post(s)
Liked: 29
Originally Posted by asere View Post
Reflection.
Sounded better with old EQ on the hardwood floors though so don’t think that is it. Have a rug as well.
Some sort of compression/EQ thing is my gut feeling... I doubt all 3 front speakers blew.
Brien is offline
post #14832 of 17559 Old 11-23-2017, 08:40 PM
subacabra's Avatar
Liked: 4746
You didn't turn dynamic volume on by mistake did you? That would definitely add compression and sound like crap at moderate to high volume.
galonzo likes this.
post #14833 of 17559 Old 11-23-2017, 09:27 PM
084runnerltd's Avatar
Quoted: 76 Post(s)
Liked: 43
Been lurking a while, finally time to post....
I just upgraded from a Denon x2000 to a Denon 4300h. I also added to Atmos Klipsch 140SA.
Since the ?upgrade? to the new receiver everything is so quiet....? It has no where near the volume that the X2000 had...
Any ideas?
084runnerltd is offline
post #14834 of 17559 Old 11-24-2017, 02:01 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12032
Any ideas?
Oops! Wrong thread. Please repost in the 2016 Denon AVR Owner's thread ---> https://www.avsforum.com/forum/90-rec...hread-faq.html
post #14835 of 17559 Old 11-24-2017, 10:51 AM
Brien's Avatar
Quoted: 116 Post(s)
Liked: 29
That helped! Sounds much better now, but on 2ch (mostly TV ARC) the center channel still sounds like a drive thru window.
subacabra likes this.
Brien is offline
post #14836 of 17559 Old 11-24-2017, 12:57 PM
kokishin's Avatar
Quoted: 1237 Post(s)
Liked: 1247
Unless you have an upmixer selected (e.g., Dolby Surround, DTS Neural:X), you should not get any audio from the center channel for 2ch sources.
galonzo likes this.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon Fire TV Stick, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is offline
post #14837 of 17559 Old 11-24-2017, 01:25 PM
Brien's Avatar
Quoted: 116 Post(s)
Liked: 29
Brain fart, I meant just TV ARC in general.
Brien is offline
post #14838 of 17559 Old 11-25-2017, 05:12 PM
Brien's Avatar
Quoted: 116 Post(s)
Liked: 29
Brain fart... but the center channel sounds "hot" (like a drive-thru window speaker) on nearly all sources. It's set to +3.5db in levels, could this be it? Maybe I need to re-run Audyssey again?
Brien is offline
post #14839 of 17559 Old 11-26-2017, 06:05 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2846
How is the center speaker aligned? Is it tipped up (or down) so it points directly toward the Main Listening position? If the calibration microphone was off-axis that might explain some of what you're hearing. Another possibility is that the speaker's tweeter isn't working correctly (or at all).
If you haven't already done so, please take the time to look through the Audyssey 101/FAQ. It will help you to get a good calibration. The instructions in the receivers' owners manuals are pathetically inadequate.
Selden
Selden Ball is offline
post #14840 of 17559 Old 11-26-2017, 01:29 PM
Xeneize12's Avatar
Quoted: 258 Post(s)
Liked: 73
Need some advice on how to properly configure my Denon AVRX6200W
I'm waiting for my new purchase the Sony AE1 and the Oppo 203, I also have the following device connected to the 6200W:
-Xbox One X
-PS4 Pro
-Nvidia Shield
-Apple 4K TV
I'm running a 7.2.4 (Atmos), so I'll be disabling the TV audio
So far the way I plan to hook this up is: (from device to receiver)
From HDMI 2 ARC on TV -->Arc HDMI In
FIOS Cable --> Cable/Sat
Oppo 203 --> BluRay
Xbox One X --> Game
PS4 Pro --> Aux
Nvidia Shield --> Media Player
Apple 4K TV --> DVD
My questions:
1) Do I need an Audio Cable from my TV to my 6200 if I'm using the ARC?
2) Should Instead connect the XBox or PS4 directly to the TV and leverage the ARC or audio cable for the external sound? (to avoid Input Lag, not sure how much of an issue this is)
3) Should I be disabling any processing from the 6200W and allowing any of the devices handle the upscaling? (I would assume the 6200W has as good or better upscaling/processing than the TV and the Oppo 203, but I could be wrong)
Anything else I should be thinking off/doing to optimize the connections/settings to take full advantage of every device?
Thanks for the help.
| Sony XBR65AE1 | Denon X6200W | 7.2.4 | Oppo 203 | Nvidia Shield | Harmony Elite |
| Emotiva mini-X a-100 | Ascend CMT-340 | Emotiva ERD-1 | SVS SB2000 + Martin Logan Abyss |
| PS4 Pro | Xbox One X |
|Sony XBR65X950B | Samsung UN49KS8000 |
Xeneize12 is offline
post #14841 of 17559 Old 11-26-2017, 03:15 PM
kokishin's Avatar
Liked: 1247
I checked all my speaker levels which were set by Audyssey. They are all negative. Audyssey set my center channel to -7.0dB.
kokishin is offline
post #14842 of 17559 Old 11-26-2017, 04:25 PM
byeloe's Avatar
Quoted: 20 Post(s)
My x4200 will not connect to Sirius. keeep getting the "no connection" error. Internet radio works so I know the network is good.
I have done all of the resets, including a factory hard reset. Still getting the same error.
galonzo likes this.
byeloe is offline
post #14843 of 17559 Old 11-27-2017, 06:20 AM
Quoted: 48 Post(s)
I was having the same issue with my x6200W this weekend. I haven't had time to mess with it but last I tried it was still unable to connect to Sirius. I have my AVR hard wired via ethernet so it's not a connection issue. Not sure if this is a result of the latest firmware or not...
galonzo likes this.
warnija is offline
post #14844 of 17559 Old 11-27-2017, 06:50 AM
Bill-99's Avatar
Quoted: 831 Post(s)
Liked: 517
Some feedback, at a conceptual level. I don't have experience with all of the products on your list.
"1) Do I need an Audio Cable from my TV to my 6200 if I'm using the ARC? "
You should be fine running HDMI from the TV to the AVR. Be sure your HDMI cable is "certified high speed" or "premium certified high speed", which means they'll be able to handle 4K content. (Really inexpensive at Monoprice)
"3) Should I be disabling any processing from the 6200W and allowing any of the devices handle the upscaling? (I would assume the 6200W has as good or better upscaling/processing than the TV and the Oppo 203, but I could be wrong)"
Sony upscaling, by all accounts I've read, is quite good. But this is something you can try and decide for yourself. I compared the Oppo 203 upscaling to what my Samsung KS800D could do. The results were indistinguishable so I let the TV do the work.
"Anything else I should be thinking off/doing to optimize the connections/settings to take full advantage of every device?"
If you have the option to go all HDMI, it can simplify things and produce great results. This might also be a good time to replace any HDMI cables that are not certified high speed. That's a small investment now to avoid ugly debugging downstream.
Just one more upgrade and things will be perfect.
Bill-99 is offline
post #14845 of 17559 Old 11-27-2017, 07:34 AM
galonzo's Avatar
Liked: 1702
@byeloe and @warnija , I am seeing the same thing here, hard-wired and internet radio works great.
galonzo is offline
post #14846 of 17559 Old 11-27-2017, 07:40 AM
asere's Avatar
Liked: 589
Is the x4200 going to eventually receive the new DTS Virtual:X firmware?
asere is offline
post #14847 of 17559 Old 11-27-2017, 08:31 AM
Liked: 2846
My understanding is that it's a communication problem between all D&M devices and SiriusXM. Supposedly they're working on it.
galonzo likes this.
Selden
post #14848 of 17559 Old 11-27-2017, 08:58 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12032
No, rather only the 2017 and newer models.
galonzo likes this.
post #14849 of 17559 Old 11-28-2017, 01:34 PM
asere's Avatar
Liked: 589
Thanks. It won't surprise me if its garbage like most virtual dsp's. In most cases it's like an echo.
asere is offline
post #14850 of 17559 Old 11-29-2017, 03:56 PM
T100's Avatar
Quoted: 62 Post(s)
Liked: 37
No pandora for me, X4200
T100 is offline
4:4:4 , alexa , arc , audyseey , Audyssey , avr , AVR-X2200W , bluetooth , chroma , connect , Denon , denon 2200w , denon x1200w , lfe , s710w , s910w , spotify , x-1200w , x1200w , x2200w , x3200w , x4200 , x4200w , x6200w , Yamaha
