The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 101740Likes
post #181 of 17682 Old 07-05-2015, 08:25 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22760 Post(s)
Liked: 12412
Originally Posted by antness View Post
Sept. for the X6200W too?
No firm date yet, but likely yes as that is when the X5200W was released last year.
jdsmoothie is offline
post #182 of 17682 Old 07-05-2015, 11:33 AM
Liked: 1
Originally Posted by sijk View Post
You could look the price history of the X4100W: geizhals.eu/?phist=1133024. Most likely the initial price of X4200W will also decrease quite soon, if you are willing to wait.
Thanks. Great site! Found the X4100W at 809€ there, so I bought it. I'll upgrade in a few years if I need to.
gtubert is offline
post #183 of 17682 Old 07-06-2015, 07:14 AM
KlingonScum's Avatar
Hmmm...
Front page of this thread shows the MSRP on the 910w is $579, while the 1200X is $599. "Street" will probably be lower, but that's only $20 more for the 1200x to get the extra year of warranty and Audessey XT32 (but losing 15w/channel). That seems like a no brainer; 80 watts is plenty for my setup, I'm far more interested in the better bass equalization than raw top end punch since I'm rarely if ever at the top end.
--KS
KlingonScum is offline
post #184 of 17682 Old 07-06-2015, 07:53 AM
sikclown's Avatar
Quoted: 1681 Post(s)
Liked: 832
Originally Posted by KlingonScum View Post
Hmmm...
Well technically the s910w is comparable to the x2200w whereas the x1200w is the step up of the s710w. Denon has a pretty cool comparison section at the bottom of their product pages so you can see what you would actually lose a little (besides the warranty) by going from the s910w to the x1200w, most notably you drop down to only 5 HDMI inputs + 1 in front vs 7/1 on the s910w.
http://usa.denon.com/us/product/home...rsht/avrx1200w
LG OLED 65C7P, Denon AVR-X7200WA, Apple 4K, Oppo UDP-203, PS4, Xbox One X
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
LG OLED 55C8PUA, Denon x4400h, Apple TV 4K, Panasonic DP-UB820,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #185 of 17682 Old 07-06-2015, 07:58 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12412
Hmmm...
The S910W features Audyssey MultEQ while the X1200W features Audyssey MultEQ XT, and while XT has better "speaker" EQ than does MultEQ, both have the same level of bass equalization and any difference in power will be negligible.
post #186 of 17682 Old 07-06-2015, 08:05 AM
KidHorn's Avatar
Quoted: 1862 Post(s)
Liked: 1287
Do you know the dimensions and usd msrp of the 6200?
I saw 2299 euros on a German site. Hope it's less in USD.
I have a 4311 that barely fits and was wondering if it's about the same size.
KidHorn is offline
post #187 of 17682 Old 07-06-2015, 08:14 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12412
Dimensions are unknown as yet, but likely no different than the X5200W which has the same width as the X4311CI and about the same height but about 1" shorter in depth.
post #188 of 17682 Old 07-06-2015, 08:16 AM
KidHorn's Avatar
Liked: 1287
I really hope you're right.
It's the height that would be a problem for me. A 7200 wouldn't fit without some sawing.
KidHorn is offline
post #189 of 17682 Old 07-06-2015, 08:19 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12412
The X7200WA is about 1" taller in height.
post #190 of 17682 Old 07-06-2015, 09:59 AM
batpig's Avatar
Quoted: 4896 Post(s)
Liked: 5267
If the fit is THAT tight I would be concerned about ventilation / overheating
batpig is offline
post #191 of 17682 Old 07-06-2015, 11:03 PM
kisypher's Avatar
Quoted: 50 Post(s)
Liked: 32
Lots of great info here. Just ordered me an AVR-X2200W, never owned a Denon before so I'm looking forward to testing it out.
leinadhok likes this.
kisypher is offline
post #192 of 17682 Old 07-07-2015, 04:00 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12412
Originally Posted by MarkMul1 View Post
JD
Did you guys get your 2200's?
Yup, arrived yesterday and available now for order.
post #193 of 17682 Old 07-07-2015, 05:34 AM
dlorenzo's Avatar
Is there a difference in Audyssey between the x4100w and the x4200w? Not sure if Audyssey gets upgraded over time or remains the same...
dlorenzo is offline
post #194 of 17682 Old 07-07-2015, 06:08 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12412
No, rather it is the same and has not been updated in the last 5 years.
post #195 of 17682 Old 07-07-2015, 07:48 AM
Quoted: 723 Post(s)
Liked: 238
Hmmm...
This raises a question, for me: when Audyssey lists on their website 128x filter resolution for the subwoofer and only 16x for satellites on XT, do they really mean 128x LF vs. 16x MF/HF? (For instance if mains are run as large or it's a subwoofer-less system)
dkfan9 is offline
post #196 of 17682 Old 07-07-2015, 08:01 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12412
Nope, They mean audio sent to the subwoofer specifically. Although with no subwoofer in the setup, the LFE is sent to the FL/FR speakers, they are still EQ'd using the speaker numbers. This is especially important for those not using a dedicated sub but rather just using speakers with built-in subwoofers (eg. Def Tech) as the mfr suggests running them as LARGE. The better configuration is SMALL/80Hz with a subwoofer pre-out running to each Front speaker and Subwoofer can then be set to YES and the much better subwoofer EQ applied.
JBaumgart, Niro and chi_guy50 like this.
post #197 of 17682 Old 07-07-2015, 02:32 PM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
I am / was waiting for the x4200w this Fall, but I must admit that for the price, I'm really thinking of the S700W at $250. If so, just stick with it for several years and possibly go straight to an 8K unit...
I understand that talking price is somewhat taboo here, but can one provide an approximate, expected price for the x4200w that we might see this September? Over $1k I suppose? Thanks much.
EDIT / ADD: Just saw pricing on the current AVR-X4100W... No answer needed. Just got the S700W and will milk 1080 for several years...
TonyB1966 is offline
post #198 of 17682 Old 07-08-2015, 07:06 PM
HotAhr's Avatar
Quoted: 81 Post(s)
Liked: 52
I just received the AVR-X2200W Denon receiver from AVScience. It is all hooked up and sounds great. Hopefully, I'll be able to do a bit of a review in the next day or so.
Marauder, Hyabusha and kisypher like this.
Television: Samsung UN65JS9000
A/V Receiver: Denon AVR-X4300H (Ordered Dec. 9, 2016)
Subwoofer: HSU VTF Subwoofer
Speakers: Definitive Tech StudioMonitor 65, ProCenter 2000, ProMonitor 800, Heos 1 HS2
Digital Video Recorder: Directv 4K DVR
Set Top Box: Apple TV
HotAhr is offline
post #199 of 17682 Old 07-08-2015, 11:48 PM
Marauder's Avatar
Quoted: 62 Post(s)
Looking forward to hearing your impressions! I saw you originally had a Pioneer VSX-90--how does the X2200 compare? My system is similar to yours (Def Tech), do you think the X1200 would be sufficient in power? Any thoughts on Audyssey XT vs MCACC?
Marauder is offline
post #200 of 17682 Old 07-09-2015, 06:55 AM
HotAhr's Avatar
Quoted: 81 Post(s)
Liked: 52
The short answer to your question on power is, No.
And in regard to Audyssey vs. MCACC, IMO Audyssey does a much more thorough job in calibrating speaker layout. It seemed that Pioneer got the job done but the overall impact was loose after I had listened to it for a while. And the more I ran the speaker set up, the more I realized the Pioneer had reached it's limit, so setting it up again wasn't gaining anything. In fact the more I listened to the Pioneer, the less I enjoyed it, until I sold it. It started out well, but in the end it just didn't have the punch that I was hoping it had. The Denon on the other hand seems to provide a full rich impactful sound that appears as though it will be sustained long term and significant. Audyssey IMO flat out does a better job of integrating the mix of what is offered it sound wise, as opposed to MCACC. Again, that is just my opinion. But there is a noticeable difference in the outcome to my ear. I won't be trying another Pioneer Receiver. That is how disappointed I was in the outcome provided by the setup through MCACC.
Marauder and kisypher like this.
HotAhr is offline
post #201 of 17682 Old 07-09-2015, 07:37 AM
Quoted: 938 Post(s)
Liked: 424
Very good to hear. Keep us posted.
I too am going from a VSX-90 to a 2200. I am swapping it with BB so I have a 3-4 days to go before i get it.
MarkMul1 is offline
post #202 of 17682 Old 07-09-2015, 01:42 PM
Bassment's Avatar
Quoted: 960 Post(s)
Liked: 389
The units that require a "2ch amp" to get their full 5.2.4 or 7.2.4 atmos, can you amp the L/R mains and then have the remaining 7 or 9 channels ran off the receiver, or do you have to amp a specific output?
Bassment is offline
post #203 of 17682 Old 07-09-2015, 01:54 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12412
Yes, although only possible on last year's X5200W and X7200WA, the new X4200W introduces more possible amp assign settings to expand from 7CH--> 9CH to include the FL/FR speakers which is also true for the X6200W as well.
post #204 of 17682 Old 07-09-2015, 11:28 PM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
How does Denon handle HMDI connections when unplugged, and if it makes any difference, particularly the S700W? I'll have reason to be away from home about 6+ the weeks several times the remainder of the year, and I imagine the rest of family won't have reason to fire-up the AVR...
post #205 of 17682 Old 07-09-2015, 11:48 PM
HotAhr's Avatar
Quoted: 81 Post(s)
Liked: 52
Denon's like most other brand name receivers have a feature called HDMI passthrough. This feature allows the audio & video content from a source like a cable box for example to pass through the receiver with the receiver's power off. This allows for the audio & video content to be watched on a television without turning on the Denon receiver or any other A/V receiver for that matter, if the HDMI passthrough feature is provided. The one thing about it is, the receiver must be plugged into the electrical wall outlet or power strip. I'm not sure if the S700W has HDMI pass through. I've not looked at their features. You'd have to look.
TonyB1966 likes this.
HotAhr is offline
post #206 of 17682 Old 07-09-2015, 11:55 PM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
Devon's like most other brand name receivers have a feature called HDMI passthrough. This feature allows the audio & video content from a source like a cable box for example to pass through the receiver with the receiver's power off. This allows for the audio & video content to be watched on a television without turning on the Denon receiver or any other A/V receiver for that matter, if the HDMI passthrough feature is provided. The one thing about it is, the receiver must be plugged into the electrical wall outlet or power strip. I'm not sue if the S700W has HDMI pass through. I've not looked at their features. You'd have to look.
Thanks for the fast reply and info HotAhr. The S700W does have passthrough alright, but the references I've found are for standby mode, which of course means that the unit is receiving power. Curious what I can expect with it off, unplugged. I just got it today actually, but haven't opened it yet, and I won't have time until this weekend...
post #207 of 17682 Old 07-10-2015, 12:09 AM
Skylinestar's Avatar
Quoted: 1311 Post(s)
Liked: 268
Yes. You can amp the FL/FR mains.
I thought that was not possible for the X4100 in 5.2.4 setup (ext amp assigned to top rear only). Is it now possible in the newer X#200 series?
Skylinestar is offline
post #208 of 17682 Old 07-10-2015, 12:17 AM
HotAhr's Avatar
Quoted: 81 Post(s)
Liked: 52
A receiver can't do anything if it is unplugged. How is it supposed to?
HotAhr is offline
post #209 of 17682 Old 07-10-2015, 12:27 AM
TonyB1966's Avatar
Quoted: 187 Post(s)
Liked: 25
I realize that it can't perform any switching between various inputs of course (with no power), but if one simply has one HDMI input, and one output, I was curious if it would pass the signal...
post #210 of 17682 Old 07-10-2015, 01:46 AM
steveting99's Avatar
Quoted: 1849 Post(s)
Liked: 651
The receiver needs to have some power so that the internal circuitry will connect with the right HDMI input and HDMI output.
Also, longer term power outage risks losing all user settings. Pulling the plug on the receiver for about 10 minutes is a soft reset. Pulling the plug on the receiver to 6+ weeks is a different matter.
If you intend to pull the plug on the receiver for that long of a period, be sure to carry out the SAVE/LOAD configuration as outlined by jdsmoothie. You may have to do a factory reset and reLOADing a good configuration will be easier than going through the setup again. Also remember directly connect the HDMI cable/sat box to the TV as the receiver does not allow pass through when the power plug is pulled.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
4:4:4 , alexa , arc , audyseey , Audyssey , avr , AVR-2310CI , avr-s710w , AVR-X2200W , bluetooth , chroma , connect , Denon , denon 2200w , denon x1200w , lfe , s710w , s910w , spotify , x-1200w , x1200w , x2200w , x3200w , x4200 , x4200w , x6200w , Yamaha
