*Official* Marantz 2015 NR-1506/1606, SR-5010/6010/7010 & AV7702mkII owner's thread - Page 166 - AVS Forum | Home Theater Discussions And Reviews
 12615Likes
post #4951 of 12181 Old 05-31-2016, 03:25 PM
jdsmoothie's Avatar
Quoted: 22015 Post(s)
Liked: 11939
Originally Posted by Ash Sharma View Post
JD - Point four int he instructions says tap the "*' icon to connect tot he unit...
I don't see the '*' icon??
Please help.
The icon should be displaying on the Spotify Connect app. If not, you might want to try deleting and reloading the Spotify app.
jdsmoothie is offline
post #4952 of 12181 Old 05-31-2016, 07:02 PM
Ash Sharma's Avatar
Quoted: 980 Post(s)
Liked: 680
Thanks .... works like a charm.
Ash Sharma is online now
post #4953 of 12181 Old 06-01-2016, 05:25 AM
Liked: 0
Marantz n4 1506 shutting off under high volume:
Hi, I purchased a refurbished nr 1506 and have been very happy with it, but have had one major problem that has gotten to be very annoying: When played at higher volumes the receiver repeatedly powers off.
I am using it in a stereo setup with a pair of Wharfedale Diamond 220's and, based on my retailers advice to fix this problem, I supplemented them with a Klipsch R-10SW. Currently, I have the crossover set at 80hz, but this thing continues to shutdown with heavy bass. For reference: Rock usually shuts it down with volume in the 75 range and action scenes in movies + music with heavy bass will shut it down when its over 70. Obviously, I'm very new to this, but I'd like to know if this is 'normal' or I need to push the retailer for a replacement.
Thanks for any help!
StevenH766 is offline
post #4954 of 12181 Old 06-01-2016, 05:25 AM
Liked: 0
Marantz nr 1506 shutting off under high volume:
post #4955 of 12181 Old 06-01-2016, 05:28 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5934
I think something is wrong with the AVR. Those speakers are not that much of a power hog IMO.
XBR65A9G / XBR65A8F
Oppo UDP-203 / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #4956 of 12181 Old 06-01-2016, 06:52 AM
Dan Hitchman's Avatar
Quoted: 4467 Post(s)
Liked: 2519
Sounds like it needs replacing.
Though, for the absolute best results when playing at reference levels you should use a robust separate power amp (if your receiver has pre-amp outs - the 1506 has them for the front L/R and subwoofer EDIT). The built-in amps in lower level receivers, especially, are pretty puny.
Dan Hitchman is online now
post #4957 of 12181 Old 06-01-2016, 07:32 AM
jdsmoothie's Avatar
Liked: 11939
These are fairly inefficient speakers so shutting down at the higher volume levels would not be unusual. You would be better served adding a more robust external amp connected to the FL/FR pre-outs.
Madmax67 likes this.
post #4958 of 12181 Old 06-01-2016, 09:40 AM
enricoclaudio's Avatar
Quoted: 3656 Post(s)
Liked: 4385
I was looking for the NR1606 and I can see it's on sale for $499 almost everywhere. Then I realized that the new NR1607 is already out for $699. This is for my bedroom setup, a 2.1 system with B&W 686 S2 speakers and Rythmik Audio LVX12 subwoofer. On this system I do 80% TV/Movies and 20% music. I'm replacing a Denon DM39-S Mini System. Am I missing something going with the NR1606 instead of the NR1607?
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #4959 of 12181 Old 06-01-2016, 09:49 AM
christoofar's Avatar
Quoted: 301 Post(s)
Liked: 207
difference between 1606 & 1607 = Dual band wifi and video calibration appear to be only differences.
Heart in SoCal - Soul from the Motor City
Sony x65-900F+ShieldTV+ Kodi Leia=>SR6010=>Integra DTA-70.1=>Chane A1.4 x 3 + DCM OW-1s x 2 + 1 x RSL Speedwoofer10 S+ 1 x Sunfire HRS12
christoofar is offline
post #4960 of 12181 Old 06-01-2016, 11:36 AM
Luke M's Avatar
Quoted: 389 Post(s)
Liked: 133
http://manuals.marantz.com/NR1506/NA...SYtgugzsae.php
After shutdown, if the power LED flashes red every 2 seconds, then it was a thermal shutdown. In that case it's probably normal, especially if it's not well ventilated.
Luke M is offline
post #4961 of 12181 Old 06-01-2016, 06:07 PM
Liked: 0
Thanks for the guidance. The receiver is blinking much more rapidly so it must be a 'turn down the volume' issue, but this is at levels that are just starting to get near where I'd want to listen to a movie. I will continue trouble shooting.
post #4962 of 12181 Old 06-01-2016, 08:15 PM - Thread Starter
steveting99's Avatar
Quoted: 1847 Post(s)
Liked: 651
How far away is the Main Listening Position (MLP) from the speakers? If you did the Audyssey auto-calibration, check the distances as they are pretty accurate.
Note that the sensitivity of the Wharfedale Diamond 220 bookshelves are only 86dB/W/m, so you'd want to be sitting close to them.
The other issue is the minimum impedance of 4.1 ohms (around 224Hz). These are hard to drive speakers and if you want to crank the volume up on the NR-1506, the amp section is going to struggle and probably shutdown into thermal protection. Believe this is what you're experiencing now.
Edit: As suggested by jdsmoothie, might want to consider an external amp such as the Behringer A500 which is rated to drive 4 ohm loads.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #4963 of 12181 Old 06-02-2016, 04:27 AM
Liked: 0
Just installed my 7010, anyone know how to get the volume louder? I literally hear nothing till I hit a volume level of 50-60 which seems a bit ridiculous to me
techieanalyst is offline
post #4964 of 12181 Old 06-02-2016, 04:31 AM
GusGus748s's Avatar
Quoted: 429 Post(s)
Liked: 706
That's a good question. I noticed that I had to use more volume to make the 6010 sound the same as my X4000.
I ended up returning the 6010. The X4200 should be here any day now.
GusGus748s is offline
post #4965 of 12181 Old 06-02-2016, 04:34 AM
jdsmoothie's Avatar
Liked: 11939
D+M AVRs use a logarithmic volume scale such that average volume (after running Audyssey and when not using Dynamic Volume) will be about 50-70.
post #4966 of 12181 Old 06-02-2016, 06:11 AM
Quoted: 742 Post(s)
Liked: 556
That value of 50 - 70 is spot on with what I find my setting to be on the 7010.
Initially I thought the amp must be underpowered but my dealer explained things and now I just sit back and enjoy.
alexbarbel is online now
post #4967 of 12181 Old 06-02-2016, 06:24 AM
Liked: 4385
It's always a better idea to set the volume scale on dB (-79dB to 18dB) so in that way you will know how far or close you are from reference levels (0dB)
post #4968 of 12181 Old 06-02-2016, 06:25 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5934
Thats all I use, so I know 0.0 is reference. We generally watch Directv around -8 to -10, and Blu-ray 0.0 to -2.0.
XBR65A9G / XBR65A8F
post #4969 of 12181 Old 06-02-2016, 06:36 AM
Quoted: 742 Post(s)
Liked: 556
Hi,
I think I may be missing something here because I just switched from the linear scale, which was reading at 60 and was plenty loud, to the decibel scale which showed a reading of -20.
i couldn't get close to 0, it would blow the windows out of the house !
What is the advantage of the decibel scale ? Does it tell you more than the linear scale or is it just a preference ?
Regards, Alex.
post #4970 of 12181 Old 06-02-2016, 06:41 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5934
Originally Posted by alexbarbel View Post
Hi,
Regards, Alex.
Just easier for me to know 0.0 is reference level for me, than whatever the other scale is. My room here has always been around reference level for blu-ray. Im about 10.5 ft from the speakers and the room is over 5000 cuft.
XBR65A9G / XBR65A8F
post #4971 of 12181 Old 06-02-2016, 06:47 AM
Quoted: 742 Post(s)
Liked: 556
O.K.,
That makes sense and when I move in to my new dedicated room (soon) it may be the way to go for me. At the moment, in this much smaller space it doesn't really help because I can't get anywhere near the reference value of 0.
Thanks for the explanation. I never knew why some preferred the decibel scale.
post #4972 of 12181 Old 06-02-2016, 06:53 AM
Luke M's Avatar
Quoted: 389 Post(s)
Liked: 133
It's exactly the same information, just displayed with negative numbers or not (0dB=80).
Luke M is offline
post #4973 of 12181 Old 06-02-2016, 07:10 AM
jdsmoothie's Avatar
Liked: 11939
Sure, if you have a dedicated home theater; however, for most owners where the AVR is in the family room, the "absolute" scale (0-99) is much easier to comprehend for wives and kids ... increasing numbers means volume gets louder and decreasing numbers means volume gets quieter.
Ted99 and Madmax67 like this.
post #4974 of 12181 Old 06-02-2016, 08:23 AM
Quoted: 184 Post(s)
Liked: 27
Sorry if this was asked before. Is it necessary to run audyssey again if the mode is changed from front height to top front, with no changes in speaker position?
Sent from my XT1562 using Tapatalk
HT 5.2.4 - Marantz SR6011 -> Elac B6.2 + Elac C5.2 + Elac B6 (surround) + JBL Control 1 (TM) + JBL B15 (RH) + Two SVS PB1000
Samsung Bluray Player
murlidher is offline
post #4975 of 12181 Old 06-02-2016, 08:49 AM
jdsmoothie's Avatar
Liked: 11939
Yup. The AVR doesn't know there has been no change in position or even that you're using the same speakers.
post #4976 of 12181 Old 06-02-2016, 10:14 AM
TKNice's Avatar
Quoted: 161 Post(s)
Liked: 118
Hey Jd.. Is there a way to see the incoming bitrate on the front display?
Video: JVC RS540 w/Anamorphic Lens & 122" 2.35:1 CIH
Audio: Marantz SR7010 / XPA-3 / UPA-7 Sources: Nvidia Shield / Xbox One
7. Ascend Acoustics Sierra-2 (L R C), Ascend Acoustics HTM-200SE (side & rear)
2. Subs: SVS PC-2000 & eD A3-300 12" / Sensory: Aura Pro Bass Shakers
4 HTM-200SE for Atmos/DTS:X
Theater Pics / Desktop
TKNice is offline
post #4977 of 12181 Old 06-02-2016, 11:02 AM
jdsmoothie's Avatar
Liked: 11939
AFAIK, no.
post #4978 of 12181 Old 06-02-2016, 11:21 AM
TKNice's Avatar
Quoted: 161 Post(s)
Liked: 118
AFAIK, no.
Hmm, that's unfortunate. I've found the one thing my old unit could do that the 7010 can't.
I don't see it on the info screen either, so I'm assuming bitrate info is not available anywhere? The only place I've seen anything similar so far is when playing spotify or pandora on the Marantz IOS app. It shows the bitrate at the bottom where the decoding mode appears for movies.
TKNice is offline
post #4979 of 12181 Old 06-02-2016, 09:14 PM
Quoted: 742 Post(s)
Liked: 556
Hi,
I wonder if JD (or anyone ) could help me out with a frustrating problem.
When Video Conversion is set to on (which I would prefer it not to be) I get multicoloured text on documents and in some apps. Some letters are orange/red , others blue and the rest black.
When Video Conversion is set to off then the text is all as it should be but I lose the on screen display, on the TV, for volume and sound modes.
I would like to have no video conversion but retain the OSD for sound modes and volume or , failing that , have the video conversion on but have the correct text displayed.
Is there anything I can do to achieve this?
post #4980 of 12181 Old 06-03-2016, 12:57 AM
Quoted: 13 Post(s)
Liked: 5
dear all,
an advise for the following scenario if you please ....
I own an SR7010 and i have a 5.1.2 system with Dali Zensor 3 (FL/FR), zensor Vocal, Zenor 1 & pico (surrounds) - (these are 6 ohm speakers)
I am pleased with the system, and the 7010 drives it well.....but i want a better sound for music so i'm considering to upgrade my Fronts with Dali Opticon 6 and center with opticon Vokal. (Opticon series are 4 Ohm)
Do you think the 7010 can drive the 4ohm speakers in parallel with the 6ohm surrounds or will i need an external amp.
If you think the 7010 will be fine i'll give it a try....
If you think i'll need extra amplification the options (affordable and easy to find options) aren't many .....
I can get in my hands a Marantz mm7055 but officially marantz says its not designed for 4ohm speakers, so one option will be to drive the 4 surrounds from MM7055 and 7010 take care of the L-R-C 4ohm speakers .... do you think that 7010 can handle the 3 4ohm speakers ?
for the record, my listening space is about 20m2 with big openings left & right, and i dont listen music at very high volumes.
darisg is offline
7010 , av7702mkii , hdmi marantz nr1506 , Marantz , marantz 7702 256gb ssd , marantz sr5010 , no sound , nr1506 , NR1606 , SR5010 , sr6010 , sr7010 , subwoofer
