*Official* Marantz 2015 NR-1506/1606, SR-5010/6010/7010 & AV7702mkII owner's thread - Page 269 - AVS Forum | Home Theater Discussions And Reviews
 12658Likes
post #8041 of 12466 Old 01-16-2017, 04:06 PM
Quoted: 25 Post(s)
Liked: 3
In fact, I'm sure this setup is supported. The .2 height channels are separate from the main 7 channels.
Seeko is offline
post #8042 of 12466 Old 01-16-2017, 04:39 PM
EdQ
EdQ's Avatar
Quoted: 23 Post(s)
Liked: 68
The setup is supported, but your AVR only has 7 amps. So it can only drive 7 speakers at a time.
You need an external 2 channel amp to do 7.x.2
Samsung 75" UHDTV | Marantz 7010 - Heights | Emotiva XPA-7 Gen3 | (2) AIRCOM T8 | HTPC with Blu-Ray
Front - Polk RTi12 | Center - Polk CSi5 | Surrounds - Polk RTi6 | Atmos - Polk S15 | Klipsch R-115SW | 7.2.4
EdQ is offline
post #8043 of 12466 Old 01-16-2017, 06:44 PM
MeanMachine's Avatar
Quoted: 446 Post(s)
Liked: 58
Is 50W too light for most ? I like the slim line but it looks skinny on power and I correct?
MeanMachine is offline
post #8044 of 12466 Old 01-16-2017, 07:02 PM
dmb12679's Avatar
Quoted: 598 Post(s)
Liked: 298
Depends on speakers, room size, and listening levels
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
HK990 -- HD990 -- Klipsch RF-7ii's
dmb12679 is offline
post #8045 of 12466 Old 01-17-2017, 12:37 AM - Thread Starter
steveting99's Avatar
Quoted: 1850 Post(s)
Liked: 652
Originally Posted by gullygill View Post
6010 for $699 or 6011 for $899
What's the difference between the 2 and which one would you purchase?
Post number 5 of the 2016 Marantz thread has the comparison between the SR6010 and SR6011.
gullygill likes this.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #8046 of 12466 Old 01-17-2017, 12:51 AM
jdsmoothie's Avatar
Quoted: 23653 Post(s)
Liked: 13020
For 8-ohm, 87db+ speakers, 50W is plenty of power for med sized rooms especially when not requiring movie reference volume levels (the use case for the vast majority of owners).
jdsmoothie is online now
post #8047 of 12466 Old 01-17-2017, 05:32 AM
Quoted: 70 Post(s)
What about 6 ohm?
Im gonna be running 2 r55ti and a r56ci center in my setup.All 3 are 6 ohm.Can the 50 watt slimline models run these good o should i stick to getting a 6010 or 6011?
gullygill is offline
post #8048 of 12466 Old 01-17-2017, 06:29 AM
Quoted: 25 Post(s)
Liked: 3
Everything is powered by the avr, by the way
There's your problem. The SR6010 is only a 7CH AVR so in order to do a 7.2.2 setup, you must add an external 2CH amp to power either the FL/FR speakers or the Height L/R speakers, the least expensive option being to power the two height speakers using either an old AVR you have laying around or an AudioSource AMP100VS purchased on Amazon.
I stand corrected. You guys were right. I have to get a 2 channel. I'm not sure how I recall them all working at one point.
Seeko is offline
post #8049 of 12466 Old 01-17-2017, 06:32 AM
jdsmoothie's Avatar
Liked: 13020
What about 6 ohm?
It should yes, but again depends on how loud you like to listen. Note however, that upgrading to the SR6010/SR6011 also upgrades from Audyssey MultEQ --> MultEQ XT32, so much better audio quality as well from using the HDAM pre-amps on the "SR" series.
post #8050 of 12466 Old 01-17-2017, 07:40 AM
stash64's Avatar
Quoted: 653 Post(s)
Liked: 245
Parasound makes an awesome compact amp at 45W per channel that could be used to drive your extra speakers. In fact, it might make more sense to use it for your two front speakers and let the AVR drive the "effects" speakers. Even though it is rated lower, it's a true and accurate rating and will have a much better power reserve than the AVR. You could get two and set them up in bridged mode for the fronts.
Here it is on Audio Advisor:
http://www.audioadvisor.com/prodinfo...umber=PAZAMPV3
Sean
stash64 is offline
post #8051 of 12466 Old 01-17-2017, 09:05 AM
IMWhizzle's Avatar
Quoted: 1064 Post(s)
Liked: 351
Not true. I own the 6010 and I've chosen this model for XT32. Both have this and HDAM circuitry.
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C and dual R-115W's
Marantz 7011 AVR
LG OLED C9
Apple TV 4K
PlayStation Pro
IMWhizzle is offline
post #8052 of 12466 Old 01-17-2017, 09:24 AM
Liked: 3
SR7010: is it possible to save/switch between multiple speaker/Audyssey calibration profiles? Something analogous to how you can set up separate ISF Bright/Dark Room profiles on TVs for when you're viewing during the day vs at night (or using various levels of light control)?
Strange question, I know, but I'm setting up my system in a multi-purpose room that will regularly be reconfigured between a normal family room setup (couch and a couple of chairs, open at one end to another room, etc) and a dedicated home theater setup (bringing in an additional couch on a riser, hanging blackout curtains to isolate sound/light from the other room, etc), so the acoustics will be quite different in each mode. Ideally, I'd like to run Audyssey in each configuration and save them as separate profiles to switch between depending on my needs that particular day, but I can't find anything about it in the manual and I can't poke around in the Marantz menu system because it isn't set up yet. Is something like this possible to do? Thanks!
FlyingShawn is offline
post #8053 of 12466 Old 01-17-2017, 09:34 AM
Quoted: 446 Post(s)
Liked: 58
Is the NR 1607 or 1606 a smarter buy than an older 6010 or 7 because of its 4K features?
post #8054 of 12466 Old 01-17-2017, 10:08 AM
jdsmoothie's Avatar
Liked: 13020
Take a look at the OPs question again in which my response referenced.
post #8055 of 12466 Old 01-17-2017, 10:09 AM
jdsmoothie's Avatar
Liked: 13020
Depends on your feature/input/output requirements.
post #8056 of 12466 Old 01-17-2017, 10:12 AM
jdsmoothie's Avatar
Liked: 13020
Yes, but doing so requires first SAVing a different Audyssey EQ to a PC file and then LOADing the one you want which takes about 10 minutes each time.
post #8057 of 12466 Old 01-17-2017, 10:44 AM
IMWhizzle's Avatar
Liked: 351
I'm sorry. I overlooked it. My bad!
Marantz 7011 AVR
LG OLED C9
Apple TV 4K
PlayStation Pro
post #8058 of 12466 Old 01-17-2017, 11:27 AM
domain's Avatar
Quoted: 83 Post(s)
Liked: 37
Apparently not Dolby Vision (at this time), although neither can 2016 models.
Maybe I missed something, but when did this come about? Is there even an external device capable of doing this right now? My understanding is the current external (non TV apps) are not currently able to do Dolby Vision at all:
https://help.netflix.com/en/node/42384
Non-TV devices currently only support HDR.
domain is offline
post #8059 of 12466 Old 01-17-2017, 12:02 PM
EdQ
EdQ's Avatar
Quoted: 23 Post(s)
Liked: 68
How do you do that?
Sent from my Note Edge
EdQ is offline
post #8060 of 12466 Old 01-17-2017, 12:52 PM
jdsmoothie's Avatar
Liked: 13020
Chromecast Ultra.
This from the Vudu support staff ...
The VUDU Chromecast app supports Dolby Vision.
But whether is is passed from the Chomecast, through specific receivers or into a specific model TV is up to the manufacturers of those devices to properly support. Unfortunately there can be various compatibility issues related to 4K (@60Hz etc), Dolby Vision, and HDCP 2.2 that can prevent it.
Of the TVs that we have tried it has been pretty inconsistent, unfortunately. We have been reporting issues found to manufacturers, but encourage you to do the same.
post #8061 of 12466 Old 01-17-2017, 12:54 PM
jdsmoothie's Avatar
Liked: 13020
Originally Posted by EdQ View Post
How do you do that?
Refer to p. 186 in your Owner's manual for the SAVE/LOAD procedure.
I also provide the procedure in the post below when using Chrome on a 2014 Denon AVR, but procedure should be similar.
https://www.avsforum.com/forum/90-rec...l#post23775592
post #8062 of 12466 Old 01-17-2017, 01:12 PM
Liked: 3
Fantastic news, thanks! 10 minutes isn't ideal, but it'll take more time than that to reconfigure the rest of the room anyway and from the manual it sounds like the switch-over is done from a browser rather than having to muck about in the Marantz's menus with the remote.
post #8063 of 12466 Old 01-17-2017, 01:38 PM
domain's Avatar
Quoted: 83 Post(s)
Liked: 37
Chromecast Ultra.
Hmm interesting, I was reading a thread over on Google's forums where they indicate the Chromecast Ultra cannot do Dolby Vision even plugged directly into the TV, at least for LG models.
https://productforums.google.com/for...st/oL4yOR01_00
Unfortunately Google has a reputation for over-promising, leaving their products in continuous beta, and then a few years later after they get bored dropping the product altogether.
Schwa likes this.
domain is offline
post #8064 of 12466 Old 01-17-2017, 01:54 PM
EdQ
EdQ's Avatar
Quoted: 23 Post(s)
Liked: 68
Thanks for this. I have been reading so much, I missed this section.
EdQ is offline
post #8065 of 12466 Old 01-17-2017, 06:04 PM
EdQ
EdQ's Avatar
Quoted: 23 Post(s)
Liked: 68
Was able to save a file. But AVR stills says saving on the display. Been over 20 minutes.
EdQ is offline
post #8066 of 12466 Old 01-17-2017, 09:19 PM
Sittler27's Avatar
Quoted: 1360 Post(s)
Liked: 122
Can this AVR passthrough 4K60? I can't get a menu screen through it to my JVC X750 projector, but the 25' Cabernet HDMI cable to the projector gets it fine when connected directly to the Shield.
Sittler27 is offline
post #8067 of 12466 Old 01-18-2017, 12:02 AM
Quoted: 25 Post(s)
Liked: 3
Any good recommendations for 2 channel amps? I'm pushing SVS Prime's all around with front towers. 7.2.2 system.
Seeko is offline
post #8068 of 12466 Old 01-18-2017, 12:40 AM
jdsmoothie's Avatar
Liked: 13020
Least expensive option: Repurpose an old AVR not being used or purchase AudioSource Amp100VS (Amazon) to power the two height speakers
More expensive option: Use an Outlaw or Emotiva amp to power the FL/FR speakers
post #8069 of 12466 Old 01-18-2017, 12:42 AM
jdsmoothie's Avatar
Liked: 13020
Yes, all models in this thread can pass through 4k/60.
post #8070 of 12466 Old 01-18-2017, 12:44 AM
jdsmoothie's Avatar
Liked: 13020
Close the process and try again. If still no joy, try using a different browser.
7010 , av7702mkii , hdmi marantz nr1506 , Marantz , marantz 7702 256gb ssd , marantz sr5010 , no sound , nr1506 , NR1606 , SR5010 , sr6010 , sr7010 , subwoofer
