*Official* Marantz 2015 NR-1506/1606, SR-5010/6010/7010 & AV7702mkII owner's thread - Page 332 - AVS Forum | Home Theater Discussions And Reviews
 12658Likes
post #9931 of 12468 Old 09-16-2017, 02:23 PM
frabnkgonsalves's Avatar
Help! Just added 4 on ceiling speakers for DolbyAtmos/Auro 3D sound and I am having audio dropouts when listening to movies at reference level. Will adding a multichannel amplifier solve this issue? And what amp and how many channels of amplification necessary to unburden my Marantz SR7010? Thanks.
vn800art likes this.
frabnkgonsalves is offline
post #9932 of 12468 Old 09-16-2017, 04:35 PM
Quoted: 156 Post(s)
Liked: 83
Hello! You need a 5.1 Amp. driving the four heights plus if you will want the Center Top or Vog channel ( signal from Sr7010 Sw2 preout to Center channel input in the new 5.1 amp.).
Better and more relief would be given to the Sr7010 using an external Stereo Amp for your fronts.
But ... we do not even know what loudspeakers you have! Are they 4/6 Ohms maybe?
Regards
Alessandro
Inviato dal mio ASUS_Z00AD utilizzando Tapatalk
frabnkgonsalves likes this.
Marantz Sr7011, Galactron Mk10b, Pioneer VsxLx50, Behringer NU3000dsp. Klipsch Cornwall, Wharfedale 9.1, Klipsch CP-6, 4xJblCS1214 in 2 double boxes, V.B.S.S. with Dayton PA460-8. Sony UbpX800, Lg Up970, Nvidia Shield ATV 2015, FireTv 4K, 2 Onkyio Dolby Surround ES600 pro, 2 Anleon MX200 Minimixer, Hisense 55M5500. 110 inches rolling screen, excelvan cl720d.
vn800art is online now
post #9933 of 12468 Old 09-16-2017, 06:07 PM
Regards
Alessandro
Sorry. I have Vandersteen 3, VCC center channel and VSM-1 on wall surrounds. My Atmos/Auro 3D speakers are Definitive Technology ProMonitor 1000 mounted on ceiling. I use 2 Hsu subwoofers as well. I was thinking of a 5 channel amp to drive the Vandersteens and let the SR7010 drive the ceiling speakers. All recommendations are welcome. Thanks.
post #9934 of 12468 Old 09-17-2017, 10:39 AM
jdsmoothie's Avatar
Quoted: 23689 Post(s)
Liked: 13041
The ProMonitor 1000 speakers are fairly efficient while your Vandersteen are not so your best bet is likely to purchase a more powerful 2CH or 3CH amp (eg. 250W+) to power at least the FL/FR (if not the FL/C/FR) speakers.
jdsmoothie is offline
post #9935 of 12468 Old 09-17-2017, 08:09 PM
darthray's Avatar
Quoted: 2545 Post(s)
Liked: 4166
Any descent 5 channels would do
Very affordable for the value;
https://www.outlawaudio.com/products/5000.html
A power amp give really value to power, when AVR can cheat by saying any number of Watts per channels, but how many channels driven at the same time is very questionable
If I were You, I would use that new amp to power the front 3 first.
Second, surrounds they very likely need much less power.
Then use your AVR for ceiling duty to power the ceiling ones, even less power from the amp section of the AVR.
Ray
darthray is online now
post #9936 of 12468 Old 09-18-2017, 09:22 AM
Selden Ball's Avatar
Quoted: 4819 Post(s)
Liked: 2864
Intermittent dropouts normally are not caused by amplifier limitations.
Over-stressing the receiver's amps by playing at high sound levels with 4 Ohm speakers usually causes the receiver to trip off completely, going into "protection mode". When this happens, the "standby" light will flash red quickly with several blinks per second. If the receiver trips off due to overheating, the LED will blink slowly with several seconds per blink.
Intermittent dropouts often are caused by poor or intermittent cable connections. When playing loudly, vibrations can cause loose cables, both HDMI and speaker cables, to wiggle loose and make intermittent connections.
If you get intermittent audio and/or video dropouts at all sound levels, that's usually caused by deficient HDMI cables. "Certified Premium" HDMI cables are required, capable of transporting 18 GigaBits/second.
Selden
Selden Ball is offline
post #9937 of 12468 Old 09-18-2017, 11:28 AM
mdanderson's Avatar
Quoted: 114 Post(s)
Liked: 112
Correct. Max 7CH processing so either Surround Back or 2 Atmos.
I have a follow up question if you don't mind. If I play a regular(non atmos) Bluray movie in 7.1, will I be hearing back surround info coming from the Atmos speakers? I obviously would not want that. This would be when I have the amp assignment of the SR5010 set to back surround. Thanks again for the help.
Paradigm Studio 20v5-fronts
Paradigm Studio CC-490v5-center
Paradigm Studio 10v5- side surrounds,Monitor surround 3v7-bck surr
Oppo UDP-205/LG 65C6 OLED
Outlaw 976 prepro/ Emotiva BasX A-700amp/PSA 15S sub
mdanderson is offline
post #9938 of 12468 Old 09-18-2017, 12:19 PM
jdsmoothie's Avatar
Liked: 13041
Yes. It doesn't matter where the speakers are physically located.
mdanderson likes this.
post #9939 of 12468 Old 09-18-2017, 01:09 PM
mdanderson's Avatar
Quoted: 114 Post(s)
Liked: 112
Thanks for the input. I think I will wait until I can afford a more advanced prepro/receiver before I try Atmos.
post #9940 of 12468 Old 09-18-2017, 03:43 PM
Quoted: 42 Post(s)
Liked: 6
Hey-
I am trying to hook up a legacy Sony CD player from the early 90s (CDP-CE315) to my Marantz NR1606-powered system. It worked fine at my mom's house just last month, but now is not producing any sound. Am using analog cables (W/R), and they are plugged into the only option on the back of the CD player, and run into the CD 3 input on the back of the Marantz. The CD player is powered on, and I turned to the CD input on the Marantz, etc. Even tried a different set of cables.
Am I missing something here? Do I need to assign the inputs or something? If so, what setting is necessary?
Thanks for your help.
Sony XBR75x940D
Marantz NR1606
Sony UBP X800
Xbox One
kbbfooz is offline
post #9941 of 12468 Old 09-18-2017, 03:48 PM
jdsmoothie's Avatar
Liked: 13041
Originally Posted by kbbfooz View Post
Hey-
The CD source on the NR1606 defaults to "analog" so there shouldn't be any setting to change. Ensure the volume of the CD player is raised high enough. Also try the other two analog audio inputs as well.
post #9942 of 12468 Old 09-19-2017, 06:54 AM
soonerkevin's Avatar
I’m hoping someone out there can test for DD+ over arc for the Marantz SR6010 receiver. This is the model that I own. However, I can’t run the test as I’m using a 2012 Panasonic Plasma currently. I’m going to upgrade to a 2018 LG OLED next year and if DD+ works over arc then I won’t have to upgrade my receiver.
soonerkevin is offline
post #9943 of 12468 Old 09-19-2017, 06:57 AM
petetherock's Avatar
Quoted: 1757 Post(s)
Liked: 936
Has the DV update been released yet?
tjcinnamon likes this.
petetherock is offline
post #9944 of 12468 Old 09-19-2017, 06:59 AM
jdsmoothie's Avatar
Liked: 13041
No reason it shouldn't.
post #9945 of 12468 Old 09-19-2017, 07:00 AM
jdsmoothie's Avatar
Liked: 13041
Not to the Marantz models, no, rather only to the lower level 2016 Denon models at this point. Likely won't see it on the 2015 D+M models for a month or two.
petetherock likes this.
post #9946 of 12468 Old 09-19-2017, 07:32 AM
JaremyP's Avatar
Quoted: 775 Post(s)
Liked: 435
Bummer. I want to be seeing Dolby Vision on the new Apple TV this weekend...
Video: JVC NX7, Stewart Cima Neve 135"
Audio: Marantz AV7704, Emotiva XPA-11 Gen 3
Speakers: Focal Electra 1038 Be x 2, Electra CC 1008 Be, Aria 906 x 8, REL S5 SHO x 2
Sources: Apple TV 4k, Kaleidescape Strato, Xbox One X, Nintendo Switch
Xbox Live: TrackZ
JaremyP is offline
post #9947 of 12468 Old 09-19-2017, 03:04 PM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
SR6010: Switch to Standby not working with TOSLINK only...?
I have the automatic shutdown or "Switch to Standby mode" enabled after two hours.
This has been working fine when the connection was using either multichannel RCA or HDMI, however, when using optical TOSLINK, my SR6010 stays on forever. Source is an HTPC which is usually encoding audio to AC3 using Dolby Digital Live. (Although it would be bitstreaming the original audio in whatever format, so it might switch to EAC3 for Dolby Digital Plus / TrueHD when playing a movie, or maybe 2-channel PCM if I play an audio file.)
Any thoughts on what to try or tweak?
Primary (2.1): Thiel CS 1.2 / Velodyne F1000 sub / Adcom GFA-555 Mk2 / Rotel 970BX / Sony CDP-CA9 ES
Secondary (5.1): Paradigm Mini-Monitor v.3 / CC270 v.3 center / ADP-170 v.2 surrounds /
SVS SB1000 sub / Marantz SR-6010 / AppleTV + Win7 PC / BenQ BL3200PT
cswiger is offline
post #9948 of 12468 Old 09-19-2017, 03:18 PM
jdsmoothie's Avatar
Liked: 13041
You apparently set the "Auto Standby" for Zone 2, as the main zone only goes up to 60 minutes.
post #9949 of 12468 Old 09-19-2017, 04:00 PM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
I'm fairly sure I'm talking about the Main Zone and not Zone 2, but am less sure about whether I'd set it to one hour versus two.
Here are my settings:
...so auto-standby enabled after 1 hour for Main Zone, and after 2 hours for Zone 2.
Last edited by cswiger; 09-19-2017 at 05:30 PM. Reason: #edit: updated to add image of settings
cswiger is offline
post #9950 of 12468 Old 09-20-2017, 02:37 AM
jdsmoothie's Avatar
Liked: 13041
AFAIK, there is no signal input limitation when using this setting. Try doing a "soft reset" by powering off and unplugging the AVR power cable for 10 minutes.
post #9951 of 12468 Old 09-20-2017, 02:29 PM
Quoted: 42 Post(s)
Liked: 6
There is no volume setting on the CD player, and the other two analog audio inputs are also not working. I believe they are for Blu-Ray (2) and Cab/Sat (1); changing the selected input still results in no sound.
What now? Thanks.
Sony XBR75x940D
Marantz NR1606
Sony UBP X800
Xbox One
kbbfooz is offline
post #9952 of 12468 Old 09-20-2017, 05:08 PM
jdsmoothie's Avatar
Liked: 13041
What now? Thanks.
Test it at your Mom's house again to ensure it still works.
post #9953 of 12468 Old 09-20-2017, 06:28 PM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
Thanks for the reply.
I tried doing the soft reset, but it didn't seem to make a difference; the issue is still reproducible.
With this setup, the AVR enters standby as expected:
Code:
Audio
  Sound Mode    7.1CH IN
  Input Signal    Analog
  Format    //.0
ZONE: MAIN ZONE
  Select Source DVD
  Name    DVD
  Sound Mode    7.1CH IN
  Input Mode    EXTERNAL IN
  ECO Mode    Auto
  HDMI    2
However, with the following setup, the AVR stays on forever:
Code:
Audio
  Sound Mode    Dolby Digital
  Input Signal    Dolby Digital
  Sample Rate    48 kHz
  Format    3/2/.1
ZONE: MAIN ZONE
  Select Source    Blu-ray
  Name    Blu-ray
  Input Mode    Auto
  Decode Mode    Auto
  ECO Mode    Auto
  HDMI    3
  Digital    OPT1
Note that I'm just routing audio to the AVR, so the HDMI port doesn't matter for these two cases.
Also, the HTPC will go to sleep itself after an hour, so I assume the optical TOSLINK connection shuts down then-- at the very least, there is no chance that it's sending a low-volume digitized hiss or something like that which might make the AVR still think it was getting an active signal to play.
Normally, I don't rely on the auto-standby, but I do forget once it a while so I'd still like it to work.
Ah, well, I'll try to experiment some more with it.
cswiger is offline
post #9954 of 12468 Old 09-21-2017, 04:13 AM
jdsmoothie's Avatar
Liked: 13041
Apparently not. Simple test ... just pull the optical cable.
post #9955 of 12468 Old 09-21-2017, 03:17 PM
tjcinnamon's Avatar
Quoted: 2025 Post(s)
Liked: 597
Thanks for the heads up! I look forward to it!
No doubt dude! I have been on a whirlwind ride with this ATV news. So much mis-information and too much excitement on my part.
NAD 758 v3 with Dirac 7.6.4 + Rotel 976 + Panamax M5300-PM + B6 OLED 65
Speakers: Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
Subs1: 2x LRK Build Thread + 2x Rotel 981 (bridged); retired: VRK Build thread
Subs2: 2x Rythmik LVX12; 2x Dayton HF 12's Ultra-NearField + Crown XLS 2002
MiniDSP HD & Non; DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #9956 of 12468 Old 09-21-2017, 03:54 PM
Quoted: 42 Post(s)
Liked: 6
Ha! That's a long haul; brought it 1000+ miles this summer. How about another plan, maybe?
Sony XBR75x940D
Marantz NR1606
Sony UBP X800
Xbox One
kbbfooz is offline
post #9957 of 12468 Old 09-21-2017, 05:03 PM
Ricky's Avatar
Quoted: 87 Post(s)
I just went 4k with the Vizio P65 and an Xbox One S, and seem to have a Marantz 4k passthrough/processing issue.
The Vizio's HDMI5 is meant to be a PC Gamer input with very low input lag and can process 1080p/60 no problem. I don't think Vizio does any processing on the incoming signal.
HDMI's 1-4 are normal, full 4k with HDR.
My 7702mkII is hooked up to the Vizio via 2 connections:
1) Marantz Monitor 1/ARC to HDMI5
2) Monitor 2 to HDMI4
When I'm playing the Xbox, either 4k bluray or streaming netflix, to HDMI4....I get the dreaded "No Signal - HDMI 4" error! No video coming through.
I switch to HDMI5 and I get the video and full audio (ie, Atmos or DTS-X). Then if I switch back to HDMI4, I get everything works fine. The Vizio even shows "2160 HD" on top of the screen.
Please help!
ps: I've connected the Xbox straight to HDMI4 (no cables connected to Marantz) and have no problem getting video. And audio (TV's speakers).
Ricky is offline
post #9958 of 12468 Old 09-21-2017, 05:30 PM
Ricky's Avatar
Quoted: 87 Post(s)
Please help!
Forgot to mention:
For Video/HDMI Setup, I chose:
Auto Lip Sync = ON
Video Output = Auto (Dual)
HDMI Control = OFF
- ARC = OFF
- HDMI Passthrough = On
For Output Settings:
Video Mode = Auto
Video Conversion = On (to get volume on OSD...sometimes it doesn't work)
i/p Scaler =Off
Ricky is offline
post #9959 of 12468 Old 09-21-2017, 05:39 PM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
This was a good suggestion.
With the optical cable pulled, the AVR will enter standby as expected. Well, that must mean the optical cable is sending something which keeps the AVR on that is coming from the HTPC. Gives me a starting point to look into, at least.
cswiger is offline
post #9960 of 12468 Old 09-21-2017, 07:00 PM
darthray's Avatar
Liked: 4166
Finally got my AV7702mkII back from the Repair Center.
Unfortunately the buzzing noise is still there on the RCA Output. The Marantz Customer Service told me to send it back. I told them before doing so, I would like to try a XLR connector with cable that change into an RCA connector, since I suspected a bad RCA board because all XLR connections are perfect (my main 7 channels amp is XLR, and the one for ceiling duty is not).
After trying those cheating adapter cords, the hole system is finally silent and no more buzzing noise
Just some info for someone that will run into a similar situation, the post will be long gone, but some members might remember this fix.
Now to my question.
I am not sure what they did at the repair center, but after doing my calibration. Every time I turn On the AVP, the upgrade available show-up, I thought it would be for the DTS:X, but no it's for the Euro 3D. So maybe the DTS:X was done at the repair center.
Is there a way to decline the Euro 3D upgrade, so it no longer show up as upgrade available since, I do not need-it.
Ray
7010 , av7702mkii , hdmi marantz nr1506 , Marantz , marantz 7702 256gb ssd , marantz sr5010 , no sound , nr1506 , NR1606 , SR5010 , sr6010 , sr7010 , subwoofer
