*Official* Marantz 2015 NR-1506/1606, SR-5010/6010/7010 & AV7702mkII owner's thread - Page 344 - AVS Forum | Home Theater Discussions And Reviews
 12616Likes
post #10291 of 12185 Old 11-23-2017, 11:10 AM
Fackamato's Avatar
Quoted: 122 Post(s)
Liked: 48
Is there a way to find more details about the audio and video signals? It just says 4k, or 1080p, but nothing about Hz, it depth etc.
And for sound it just says PCM or Dolby Digital. Nothing about bit rate, channels, sampling rate etc.
Fackamato is offline
post #10292 of 12185 Old 11-23-2017, 01:58 PM
mrtickleuk's Avatar
Quoted: 4429 Post(s)
Liked: 6708
There is some, limited, information available. i can only give you the Denon menu names in the hope that Marantz is similar enough for you to find it:
Setup -> General -> Information -> Audio
Setup -> General -> Information -> Video -> HDMI Signal Info
Fackamato likes this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #10293 of 12185 Old 11-23-2017, 02:34 PM
Fackamato's Avatar
Quoted: 122 Post(s)
Liked: 48
That's a bit better, thanks.
post #10294 of 12185 Old 11-23-2017, 02:45 PM
legionow112's Avatar
Quoted: 22 Post(s)
Liked: 7
Hi,
my setup: PC (Nvidia GTX 1050) -> high quality HMDI cable -> to Marantz SR 7010 (latest firmware) -> high quality HDMI cable to LG OLED C7.
In NVIDIA Control Panel I have set: 4k at 60Hz, YCbCr422, 10bpc.
But Marantz info does not show correct (10bit) "pixel depth" in info window? Why?
legionow112 is offline
post #10295 of 12185 Old 11-23-2017, 04:42 PM
mrtickleuk's Avatar
Liked: 6708
Originally Posted by legionow112 View Post
Hi,
Because it's buggy and they don't care.
Just like Denon don't care that in HDR mode, when you have rec.2020 colours, you completely lose the chroma sub-sampling information and they won't even admit this is a bug
TrueDis likes this.
_______________
post #10296 of 12185 Old 11-24-2017, 10:43 AM
batirri's Avatar
Liked: 0
IR Remote Extender
After a long search in market, internet and blogs, I decided buying Nextronics IR Remote Extender with no correct function proof. Luckily, this Nextronics remote extender (USD$14.99) works perfect with my 7702MKii
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Marantz AV7702mkII/MM7055 | B&W CM10 | JBL LSR305 | Sony Android 49x700d | Samsung BlueRay bd-j4500r| | Sirius XM Stratus 6 | Cisco SB 8P SW | MacBook Air 2014.
batirri is offline
post #10297 of 12185 Old 11-24-2017, 01:54 PM
bronty's Avatar
Liked: 36
I am considering lowering my ceiling and adding 4 x KEF Ci50R In Ceiling Speaker to use in conjunction with my NR1606 to enable dolby atmos.Would these speakers be be ok to use with my NR1606,I already have a 5:1 with key 350I.
Marantz NR1606,
oppo 203
Kef E305,
Philips 55PUT6400
FS 104 Signature Speaker Stands
bronty is offline
post #10298 of 12185 Old 11-24-2017, 02:59 PM
Craig Morris's Avatar
NR1506 doing another new firmware update today. Of course, no information available as to what was added. Marantz said our Dolby Vision and HLG firmware isn't due until next year... so no clue what this was.
Craig Morris is offline
post #10299 of 12185 Old 11-25-2017, 05:58 AM
jdsmoothie's Avatar
Quoted: 22046 Post(s)
Liked: 11958
The NR1606 is only a 7CH model, so therefore it can only be configured to operate 2 in ceiling speakers for an Atmos 5.1.2 setup. You would need to upgrade to a Marantz 6000 or 7000 series model to enable an Atmos 5.1.4 setup.
As an alternative until such time that you do upgrade, you could wire each pair of in-ceiling speakers in parallel to have the same audio going to each pair of front/rear in-ceiling speakers.
bronty likes this.
jdsmoothie is offline
post #10300 of 12185 Old 11-25-2017, 08:09 AM
Liked: 0
Unhappy SR5010 - No Audio
Just a day or two after a firmware update my Marantz SR5010 stopped outputting audio. Has anyone else experienced this in the last couple days?
I can't get audio from any source; even to headphones from the AM/FM tuner. I use the DeRemote app, and I can still see the audio type that is being processed (Atmos, DTS-HD, etc...) but no sound comes out. I've turned it up to +5 and I don't even hear a hiss. The pre-outs were in use to an external AMP, so I've tried using the onboard amp as well. I don't have another receiver I can plug-in just yet, a new Marantz is on the way.
It is out of warranty, any ideas how much this would cost to get fixed?
eric10 is offline
post #10301 of 12185 Old 11-25-2017, 08:14 AM
jdsmoothie's Avatar
Liked: 11958
The first step to take when faced with an issue is to do a "soft reset" which involves simply powering the AVR to Standby and unplugging the power cord and HDMI cables for 10 minutes.
If still no joy, do a microprocessor reset as discussed on p. 251 in your Owner's manual or post 4 of this thread.
eric10 likes this.
post #10302 of 12185 Old 11-25-2017, 08:30 AM
Liked: 0
JDSMOOTIE thank you for your reply. Did what you suggested. went through setup and when I get to the part that asks if I can hear sound from the front left speaker i don't and I also cant use the remote anymore. up/down doesn't respond. I should also add that this was the same behavior when I played test tones. In the test tones menu when the first (front left) speaker was selected i heard nothing and I could not select a different channel to play tones from.
eric10 is offline
post #10303 of 12185 Old 11-25-2017, 08:32 AM
Liked: 0
I left the receiver powered off over night when it happened, and did the microprocessor reset the next morning. I should have included it in my initial post.
eric10 is offline
post #10304 of 12185 Old 11-25-2017, 12:25 PM
jdsmoothie's Avatar
Liked: 11958
Do at least 4-5 microprocessor resets in a row .. one after another. If still no joy, then perhaps amp failure.
If purchased new, the SR5010 comes with a 3 year mfr warranty so would still be covered, otherwise if purchased as a refurb then only a 1 year warranty so out of warranty. However, if purchased with a credit card, check with the card issuer as many cards will now add an extra 1-2 years on to the mfr's warranty.
post #10305 of 12185 Old 11-25-2017, 09:55 PM
palm101's Avatar
How can I tell on a SR6010 that it is receiving HDMI2.0a HDR signal?
palm101 is offline
post #10306 of 12185 Old 11-26-2017, 08:21 AM
cswiger's Avatar
Quoted: 335 Post(s)
Liked: 190
You can look at General -> Information on the OSD or the web page. There will be a Video section with information about the resolution, color space, and pixel depth.
(Normally one would check the display to confirm it is receiving an HDR10 signal through the AVR....)
Primary (2.1): Thiel CS 1.2 / Velodyne F1000 sub / Adcom GFA-555 Mk2 / Rotel 970BX / Sony CDP-CA9 ES
Secondary (5.1): Paradigm Mini-Monitor v.3 / CC270 v.3 center / ADP-170 v.2 surrounds /
SVS SB1000 sub / Marantz SR-6010 / AppleTV + Win7 PC / BenQ BL3200PT
cswiger is offline
post #10307 of 12185 Old 11-26-2017, 11:47 AM
jdsmoothie's Avatar
Liked: 11958
Check the TV.
mrtickleuk likes this.
post #10308 of 12185 Old 11-26-2017, 03:15 PM
palm101's Avatar
Thank you
palm101 is offline
post #10309 of 12185 Old 11-26-2017, 06:52 PM
Iwanthd's Avatar
Quoted: 50 Post(s)
Liked: 24
My 7010 is attempting to update after I selected update during standby. It keeps failing and keeps trying. How do I stop the madness so I can use my system again?
Iwanthd is offline
post #10310 of 12185 Old 11-27-2017, 05:10 AM
jdsmoothie's Avatar
Liked: 11958
Unplug the power cord.
post #10311 of 12185 Old 11-28-2017, 06:46 PM
KOTULCN's Avatar
Quoted: 241 Post(s)
Liked: 44
Thinking about picking up a NR-1506 a guy I know is selling for a decent price to replace my non-4K capable HK AVR 1700. I just want to make sure it will work with HDCP 2.2. Is this receiver a good choice?
KOTULCN is offline
post #10312 of 12185 Old 11-29-2017, 12:18 AM
jdsmoothie's Avatar
Liked: 11958
Yes, the 2015 models in this thread are HDCP 2.2. Keep in mind that the NR1506 is a 50W AVR.
post #10313 of 12185 Old 11-29-2017, 01:49 AM
KOTULCN's Avatar
Quoted: 241 Post(s)
Liked: 44
It’s high current though, correct? I wonder that even with lower wattage it should drive my Polk RM 6600 setup better than one of those cheap Sony units?
KOTULCN is offline
post #10314 of 12185 Old 11-29-2017, 02:15 AM
jdsmoothie's Avatar
Liked: 11958
At moderate volume level it should get the job done, but as they are 4-ohm speakers, may shut down in protection mode at higher volume levels. Luckily the NR1506 features FL/FR pre-outs so you can connect your HK 1700 to power the FL/FR speakers.
post #10315 of 12185 Old 11-30-2017, 08:47 AM
Pottypotsworth's Avatar
Quoted: 181 Post(s)
Liked: 38
So what exactly did the new firmware on the SR5010 bring? I forgot to look at the notes before I hit update just now.
Pottypotsworth is offline
post #10316 of 12185 Old 11-30-2017, 02:21 PM
mrtickleuk's Avatar
Liked: 6708
First page of this thread.
_______________
post #10317 of 12185 Old 11-30-2017, 03:01 PM
jdsmoothie's Avatar
Liked: 11958
Uh yeh ... bit behind on the updates in post 11 as have not gotten a response from Marantz.
post #10318 of 12185 Old 12-03-2017, 09:52 AM
noysboy's Avatar
Anyone using a Chromecast Ultra 4K and a AV7702mkII?
I have a new Chomecast Ultra 4K and when I choose the input on the AV7702mkII, it passes audio, but no video.
If I connect the Chomecast directly to my projector, JVC DLA-X750R, everything is fine, but putting it through the AV7702mkII will not work. I have tried every HDMI input with the same result. Using other sources in the same inputs works fine.
Ive searched this thread and avs and havent found anything yet...
noysboy is offline
post #10319 of 12185 Old 12-03-2017, 10:21 AM
Dan Hitchman's Avatar
Quoted: 4476 Post(s)
Liked: 2531
Are all the video processing and GUI overlays turned off on the Marantz? The video processor can cause issues. The DV update this coming summer may help because it is supposed to allow you to disable its outdated processor altogether causing a pure pass-through.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is online now
post #10320 of 12185 Old 12-03-2017, 10:29 AM
noysboy's Avatar
Yes, video processing and overlay are both off.
noysboy is offline
7010 , av7702mkii , hdmi marantz nr1506 , Marantz , marantz 7702 256gb ssd , marantz sr5010 , no sound , nr1506 , NR1606 , SR5010 , sr6010 , sr7010 , subwoofer
