*Official* Marantz 2015 NR-1506/1606, SR-5010/6010/7010 & AV7702mkII owner's thread - Page 357 - AVS Forum | Home Theater Discussions And Reviews
 12611Likes
post #10681 of 12156 Old 03-17-2018, 10:31 PM
bekindrewind's Avatar
Quoted: 250 Post(s)
Liked: 85
AV7702mkii will it passthough, Dolby Vision, HLG, HDR10, HDR10+
happyness ;>)
bekindrewind is offline
post #10682 of 12156 Old 03-17-2018, 10:50 PM
Dan Hitchman's Avatar
Quoted: 4427 Post(s)
Liked: 2487
A Dolby Vision and HLG pass-through firmware update is coming. HDR10 is already supported. I have that model myself.
HDR10+ is an unknown at this time. It may not have the right chipset for it, but you never know until they announce a patch.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #10683 of 12156 Old 03-18-2018, 02:47 AM
pwhittle's Avatar
I have just got an NR1606 and will have it in a cabinet.
What external IR receivers will work through the rear IR in connector?
pwhittle is offline
post #10684 of 12156 Old 03-18-2018, 06:14 AM
Elihawk's Avatar
Quoted: 1879 Post(s)
Liked: 1981
Marantz slimline 1504
Had an issue with my DTV and while that was being fixed (all outside the house), my Marantz did a weird thing. When DTV tech arrived, I had a picture up, but it was an error, unable to connect...as they were working, as I said, outside...when they came in to test, DTV works on my other two TV sets- but the TV with Marantz- No video, but audio and my TV has a blue screen and says no HDMI. I know it isn't the HDMI cord, since I bypass the AV rec with that cord and got a picture. Could I have had an electronic failure that allows audio but no video to work...or did a setting get reset or something? No video from my blue ray player either and switching the HDM1 ports didn't help. Is my Marantz (only 2 years old) having a electronic failure?
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
post #10685 of 12156 Old 03-18-2018, 07:29 AM
jdsmoothie's Avatar
Quoted: 21858 Post(s)
Liked: 11850
1. Just because an HDMI cable works when connected from the source --> TV does not rule out it is defective when connected to the AVR.
2. Try doing a "soft reset" by powering off all devices, unplugging their respective power cords, and all HDMI cables for 10 minutes. Connect all and power on the TV, pause 5 seconds, AVR, pause 5 seconds, source.
jdsmoothie is online now
post #10686 of 12156 Old 03-18-2018, 12:15 PM
Elihawk's Avatar
Liked: 1981
Thanks for the help...it didn't work, but I appreciate the suggestion.
post #10687 of 12156 Old 03-19-2018, 02:02 AM
jdsmoothie's Avatar
Liked: 11850
Refer to p. 136 of the Owner's manual and rest the microprocessor. Also try using every HDMI input on the AVR.
post #10688 of 12156 Old 03-19-2018, 03:00 AM
vsorgi's Avatar
Quoted: 169 Post(s)
Liked: 98
According to someone on the AVForums podcast, their Denon 7200 got the DV upgrade in the UK last week. Isn’t that a 2015 model? Hopefully that means the Marantz update will be here sooner than summer.
Sent from my iPad using Tapatalk Pro
Marantz 7010 AVR --->7.2.4, LG OLED65E6, Oppo UDP-203, Onkyo TX-750 (2nd amp), Elac UF5 Front, DCM CX-Center, Elac UB5 Surrounds Polk A4 (Back) Energy CB-20 x 4 (ceiling) Hsu VTF2-MK4 x 2 Subs, Harmony Elite
vsorgi is offline
post #10689 of 12156 Old 03-19-2018, 03:10 AM
jdsmoothie's Avatar
Liked: 11850
The release date for the "flagship" D+M models (ie. X7200WA and AV8802A) was spring (actually released on March 6), while all lower level 2015 D+M models is later this summer.
post #10690 of 12156 Old 03-19-2018, 10:03 AM
JimLely's Avatar
Quoted: 196 Post(s)
Liked: 65
Will we be getting DTS:X Virtual?
JimLely is online now
post #10691 of 12156 Old 03-19-2018, 10:06 AM
jdsmoothie's Avatar
Liked: 11850
No, rather only the 2017 and newer models.
post #10692 of 12156 Old 03-19-2018, 10:08 AM
Liked: 2487
Anything "virtual" outside of VR headsets is pretty much snake oil. You need actual, physical speakers in the right locations to create an effective immersive soundtrack.
mrtickleuk likes this.
post #10693 of 12156 Old 03-19-2018, 11:35 AM
JimLely's Avatar
Quoted: 196 Post(s)
Liked: 65
Thanks JD.
Dan Kumin has reviewed the Denon X3400H (which is equipped with DTS:X Virtual) in S&V for the April issue. Dan, who is a veteran reviewer, seemed imoressed with DTS:X Virtual but said that it is only available if the input is non-Dolby due to licensing restrictions. I chatted with someone at Crutchfield who said it was always available. Since you are the resident M/D maven, what is your understanding?
post #10694 of 12156 Old 03-19-2018, 11:52 AM
mrtickleuk's Avatar
Quoted: 4354 Post(s)
Liked: 6601
I wish everyone who'd ever bought a soundbar understood this. And the inventor of the soundbar too, for that matter! Sick of people seeing my setup and saying "Why don't you just get a soundbar"? The word "just" in that sentence really grates
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #10695 of 12156 Old 03-19-2018, 12:10 PM
JimLely's Avatar
Quoted: 196 Post(s)
Liked: 65
I agree with you. (Although the example of the phantom center channel in a stereo arrangement seems an exception.) However for some people height speakers are an impossibility. Since DTS:X Virtual is scalable, for those individuals who desire some semblance of an "Atmos effect" but can't place height speakers, this may be the only alternative.
post #10696 of 12156 Old 03-20-2018, 05:07 AM
jdsmoothie's Avatar
Liked: 11850
Thanks JD.
Not just my understanding, but rather what is stated in the Owner's manual and confirmed myself. DTS Virtual:X is only available with DTS and PCM audio and then only with a 5.1 or less configured setup.
post #10697 of 12156 Old 03-20-2018, 05:10 AM
jdsmoothie's Avatar
Liked: 11850
Certainly having actual physical height speakers is ideal; however, Atmos soundbars and simulated height surround modes are generally more immersive than not using them at all.
post #10698 of 12156 Old 03-20-2018, 08:45 AM
JimLely's Avatar
Quoted: 196 Post(s)
Liked: 65
Thanks, J.D.,
The restriction seems a deal-killer to me.
post #10699 of 12156 Old 03-31-2018, 10:54 AM
fsrenduro's Avatar
Quoted: 45 Post(s)
Apple TV HDR won't pass thru 7702mkii anymore
Tried searching this forum but couldn't get anything specific. My Apple TV 4k had been set for 4K HDR 60hz for a while. I guess one of the recent Apple updates now prompted it to ask me if I wanted to "try HDR" when I turned it on.
My Apple TV is routed through my 7702mkii and it is set to upscale everything to 4k/60. After several attempts to have Apple TV use its own 4k HDR output I get a black screen and after 20 seconds it reverts back to SDR every time.
If I plug the Apple TV, with the same HDMI cable, directly into my Vizio P75 the Apple TV prompts me to "try Dolby Vision" and it works perfectly. I get that the Marantz can't yet pass Dolby Vision but why did it used to allow me to use the Apple TV's HDR setting and now it won't?
don't insult my intelligents
fsrenduro is offline
post #10700 of 12156 Old 03-31-2018, 11:51 AM
mstrelau's Avatar
Do you have the latest firmware on the Vizio (4.0.23.2 - pushed out over the last three weeks or so). There is a lot of discussion over on the Vizio P-series thread where people are complaining about the AVP pass through being broken in this firmware. It works for everyone when directly connected but fails HDR when going though the Marantz, Denon, and Yamaha AVR/AVPs. It may or may not explain your issue.
Vizio P75-C1
Marantz AV7702mkii
Xbox One X
Apple TV4
Velodyn SMS-1
PS/3 (fat)
mstrelau is offline
post #10701 of 12156 Old 03-31-2018, 12:03 PM
fsrenduro's Avatar
Quoted: 45 Post(s)
I do have 40.0.23.2. I'll go over to that thread and see if I can find anything. Thanks
post #10702 of 12156 Old 04-02-2018, 06:59 AM
JonDeutsch's Avatar
Quoted: 95 Post(s)
Liked: 45
New Problem accessing SR-6010 via app
Hi,
Somehwere along the line, my SR6010 stopped being discoverable via any of the Android Marantz apps I have on my phone. The very same unit used to work just fine. Did one of the firmware upgrades make it not compatible? I like using the app so that I can see the audio mode the unit is in at any given time.
Any insights or advice?
Thx!
JonDeutsch is offline
post #10703 of 12156 Old 04-02-2018, 01:38 PM
jdsmoothie's Avatar
Liked: 11850
Originally Posted by JonDeutsch View Post
Hi,
Thx!
Try doing a "soft reset" and if no joy, a "network reset" as noted in post 5 of this thread.
post #10704 of 12156 Old 04-02-2018, 02:07 PM
JonDeutsch's Avatar
Quoted: 95 Post(s)
Liked: 45
Thanks. When you say "soft reset" do you mean just turning it off and on?
post #10705 of 12156 Old 04-02-2018, 03:26 PM
jdsmoothie's Avatar
Liked: 11850
What does it say in post 5?
post #10706 of 12156 Old 04-02-2018, 03:55 PM
JonDeutsch's Avatar
Quoted: 95 Post(s)
Liked: 45
OK, wiseguy. FYI - I interpreted your suggestion as learning how to do a 'network reset" as referencing post #5 , not the soft reset.
Anyhoo, I did the network reset and it didn't resolve my issues. Which I'm not surprised by, honestly, because I can access the web interface of my SR6010 just fine. Meaning, the actual network connectivity isn't the issue.
Given this, can anyone else access their newer-firmware SR6010 via the Marantz Android apps anymore? Or is it really just me? Thx!
Jon
post #10707 of 12156 Old 04-02-2018, 06:51 PM
Quoted: 42 Post(s)
Jon
I have IOS, after a while the marantz ios app started crashing instantly on selecting the app. A search revealed that marantz had a new app out that was coompatable with there new receivers, and backwards compatible with most of the recent reciever as well. Apparently they decided to kill the old app, instead of updating it, and without letting users in on the switch. Anyhow, the new app works great. Check the android store to see if the same applies android.
DubPlate is offline
post #10708 of 12156 Old 04-02-2018, 07:24 PM
JonDeutsch's Avatar
Quoted: 95 Post(s)
Liked: 45
I actually have both Marantz Android apps installed. Neither app can even "find" my SR6010 on the network, even though it is quite there. Even typing in its IP address doesn't work.
post #10709 of 12156 Old 04-02-2018, 07:58 PM
Quoted: 42 Post(s)
Can you stream any of the preloaded stations? Is the unit freezing when attempting playback over your network?
If you are experiencing the above issues, the only thing that worked for me, unfortunately, was consecutive total/factory rests. That is, networks resets did not work. Fortunately, I had a backup on my computer from which to restore.
The problem was intermittent with the unit from the beginning, then got dramatically worse after a particular update. However, it’s been several months of everyday day use since the factory reset, with no issues.
Also, you may want reboot your router, or update the firmware. And that upnp is enabled.
DubPlate is offline
post #10710 of 12156 Old 04-02-2018, 08:05 PM
JonDeutsch's Avatar
Quoted: 95 Post(s)
Liked: 45
Hi. Everything is working from a networking POV - Internet Radio works just fine. No freezing. UPNP is enabled. This is a very odd problem. Maybe it is router-related? But is there any specific port forwarding required? I didn't think that was required. Thx.
7010 , av7702mkii , hdmi marantz nr1506 , Marantz , marantz 7702 256gb ssd , marantz sr5010 , no sound , nr1506 , NR1606 , SR5010 , sr6010 , sr7010 , subwoofer
