*Official* Marantz 2015 NR-1506/1606, SR-5010/6010/7010 & AV7702mkII owner's thread - Page 410 - AVS Forum | Home Theater Discussions And Reviews
 12635Likes
post #12271 of 12311 Old 10-02-2019, 10:10 PM
rfb6435's Avatar
Quoted: 207 Post(s)
Liked: 94
Could be internal, i.e. failed device in the amp section.
Usually the amplifiers fail when someone is connecting speakers to the amp section (usually when they short the terminals) or something like that.
Less likely when nothing is connected...
-Rich
Quad Marantz AVR 9.2.(4+2) Atmos/DTS:X using Dual sr7010's + Dual scAtmos nr1403's
Marantz MM8003 150W/ch Amplifier Driving (L/C/R/SL/SR/SBL/SBR)
HTD Speakers L3 Tower L/R, L3 Center, Dual 12" L3 Subs, L2 Tower SL/SR, L2 Bkshlf SBL/SBR, Flat Panel WL/WR, Angled 6.5" In Ceiling FH/RH, 8" In Ceiling TM
Epson 5040UB Faux-K/3D with 106" Multi-Format Screen.
rfb6435 is offline
post #12272 of 12311 Old 10-02-2019, 10:36 PM
noah katz's Avatar
Quoted: 2115 Post(s)
Liked: 766
Who's to say that the terminals weren't shoreted (loose wire strand etc)when it was connected?
And devices do fail spontaneously; ergo MTBF.
mrtickleuk likes this.
Noah
noah katz is online now
post #12273 of 12311 Old 10-07-2019, 02:35 PM
JonDeutsch's Avatar
Quoted: 99 Post(s)
Liked: 45
Turns out it was blown AMP transistors. Odd given that I've literally NEVER used the amp!
JonDeutsch is offline
post #12274 of 12311 Old 10-07-2019, 04:08 PM
noah katz's Avatar
Liked: 766
Great, so were you able to disconnect the PS wires and eliminate the protection fault?
If so, you've come out ahead with less power consumption and cooler operation.
Noah
post #12275 of 12311 Old 10-08-2019, 12:29 PM
JonDeutsch's Avatar
Quoted: 99 Post(s)
Liked: 45
Actually... before y'all got back to me, I quickly pulled the trigger and sent it off to Best Buy to get repaired. So I was unable to self-diagnose and repair. Now I'm off line for 3+ weeks for acting hastily (with the idea of expediting!).
post #12276 of 12311 Old 10-08-2019, 12:46 PM
noah katz's Avatar
Liked: 766
Can you just ask them to disconnect PS and not repair?
I bet a lot of that 3 wk is waiting for parts.
Noah
post #12277 of 12311 Old 10-11-2019, 07:55 AM
ckronengold's Avatar
Quoted: 284 Post(s)
Liked: 120
One more time with 7010 internet / online
Hoping there might be some rhyme or reason for my issues, otherwise I'm going to start researching new receivers.
When choosing the "Internet Radio" input on the remote, my 7010 is unresponsive. And about half the time, when I use the dial on the receiver, it completely skips over that input.
On the occasions when it does "open the menu" for that input, its just frozen and I can't navigate down the sources (NAS, DLNA server, etc) either with the remote or the 4-way nav on the receiver (behind the flip down panel).
When I reset the network settings, it resolves. But only stays for a day or two before it locks up again.
I'm starting to believe that I've had an issue with the network playback for a long time, and kept thinking it wasn't something to send the unit in for repair. I'm regretting that decision now.
Any thoughts or suggestions?
Video: Epson 5050 / nVidia Shield / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
post #12278 of 12311 Old 10-11-2019, 11:38 AM
jdsmoothie's Avatar
Quoted: 22753 Post(s)
Liked: 12398
Try doing a "Network Reset" followed by a "microprocessor reset".
If still no joy, and you purchased it "new", it would come with a 3 year warranty. If purchased with a credit card, the card issuer may add an additional 1-2 years beyond the Marantz 3 year warranty so check with your credit card issuer.
jdsmoothie is offline
post #12279 of 12311 Old 10-13-2019, 12:42 PM
ddigler's Avatar
Quoted: 1107 Post(s)
Liked: 493
Do different audio formats (ie Atmos, DTS HD, etc) have their own, specific options on the SR 7010?
I’m asking because I am certain I had ‘dynamic sound’ turned off. Booted up a UHD Blu-ray disc. Clicked info and verified Atmos was being received correctly which it was. At that point entered the audio options and noticed that dynamic sounds was turned on. I turned it off and it seemed hold.
Are there times where, depending on source audio type being received such as Atmos or DTSMA, that the default audio options will be superseded by options specific to certain audio types being received?
ddigler is offline
post #12280 of 12311 Old 10-13-2019, 01:53 PM
jdsmoothie's Avatar
Liked: 12398
What specific setting are you referring to when you say "dynamic sound"? Dynamic Volume? Dynamic EQ?
post #12281 of 12311 Old 10-13-2019, 02:57 PM
ddigler's Avatar
Liked: 493
Set up menu, audio, surround parameter, loudness management. It seems to be holding now but initially when I fed ATMOS signal to the AVR ‘loudness management’ was turned on. I want it off, turned it off and it is holding. Point being, I have it turned off by default but when feeding Atmos it seems to at least initially want to enable itself.
Furthermore, I have Audy set to ‘flat’ by default. For some reason when I feed an Atmos signal to the AVR, it defaults to reference. Thoughts?
ddigler is offline
post #12282 of 12311 Old 10-13-2019, 11:42 PM
Dan Hitchman's Avatar
Quoted: 4690 Post(s)
Liked: 2731
I don't know if this would help or not, but in a 4k or regular Blu-ray player's audio setup menu, you do want to turn Dynamic Range Control to Off. Leaving at On or Auto (depending on the player) may be tripping the dynamic compression control on the receivers to the ON position, which you don't want under normal circumstances.
ddigler likes this.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #12283 of 12311 Old 10-14-2019, 06:13 AM
ddigler's Avatar
Liked: 493
Never would have considered this. Thanks for the advice. I’ll have to look into that.
My SR 7010 has been so consistent about holding settings over the years I was just surprised to see it change on its own like that. I clearly have Audy equalization set to flat. Every time I play a 4K UHD movie with Atmos sound it automatically flips to reference?
ddigler is offline
post #12284 of 12311 Old 10-14-2019, 08:50 AM
JonDeutsch's Avatar
Quoted: 99 Post(s)
Liked: 45
You are absolutely correct. I actually hadn't thought of doing this until you mentioned it. However, since I sanctioned the ordering of the parts, I'm now on the hook to pay for them whether installed or not. So... I wait.
post #12285 of 12311 Old 10-16-2019, 11:22 AM
ralphdk's Avatar
Exclamation SR 6010 FRONT WIDE and TOP MIDDLE at the same time 9.1 amp assign mode
Dear 6010 owners!
Can you run the FLOOR: 5ch + FRONT WIDE and HEIGHT: 2ch ( for example TOP MIDDLE ) at the time on the SR 6010 using ATMOS, DTSX , Neural X ??
Also will the HEIGHT or FRONT WIDE CHANNEL be PRE-OUT or can this be selected ?
The manual is not quite clear on this...
Thank you
ralphdk is offline
post #12286 of 12311 Old 10-16-2019, 12:23 PM
jdsmoothie's Avatar
Liked: 12398
Originally Posted by ralphdk View Post
Dear 6010 owners!
Thank you
1. Yup.
2. Either can be selected as noted on p. 221 Owner's manual.
post #12287 of 12311 Old 10-28-2019, 11:21 PM
noah katz's Avatar
Liked: 766
I can't get HDR from my Panasonic UB900 to JVC X570R projector.
I had 7702 Video Conversion set to Off, which I presumed would be passthrough mode.
With Bumble Bee UHD disc, 900 was getting HDR/BT.2020, but JVC was getting SDR/BT.709.
When I bypassed the 7702 by connecting the 900p directly to the JVC, it gets HDR/BT.2020.
I reconnected the 7702 and turned Video Conversion to On and resolution to 4k, but still no HDR.
I didn't try 4k (60/50) because my 35' HDMI cable can't handle it; I have the 900 and my ATV 4k set to output 24 Hz.
Any suggestions?
[edit] Never mind - I googled and followed the suggestion to move the 900 to the HDMI input closest to the Monitor output.
In this case it was from Bluray to CD, which is 4 positions closer - success!
Noah
post #12288 of 12311 Old 10-29-2019, 01:54 AM
jdsmoothie's Avatar
Liked: 12398
Any suggestions?
A good reminder for all.
post #12289 of 12311 Old 10-29-2019, 09:13 PM
redsandvb's Avatar
Quoted: 70 Post(s)
Liked: 51
...Never mind - I googled and followed the suggestion to move the 900 to the HDMI input closest to the Monitor output.
I was wondering, after which model years (SRxx12, xx13, etc) is this no longer an issue? Or is this still a problem, even on newer models?
redsandvb is offline
post #12290 of 12311 Old 10-30-2019, 12:31 AM
jdsmoothie's Avatar
Liked: 12398
It's always only been a problem with some sources.
post #12291 of 12311 Old 10-30-2019, 02:52 AM
legionow112's Avatar
Quoted: 25 Post(s)
Liked: 8
Hi,
I have just updated the application (Marantz 2016 AVR remote app) to the latest version 3.3.0 in the Apple App Store and each time after pressing Power on or Power off in the upper right corner, the application is crashing.
Marantz SR 7010.
legionow112 is offline
post #12292 of 12311 Old 10-30-2019, 04:54 AM
jdsmoothie's Avatar
Liked: 12398
Originally Posted by legionow112 View Post
Hi,
Marantz SR 7010.
A couple of troubleshooting steps to try:
(a) Delete the remote app and reload
(b) Do a "soft reset" of the AVR by powering it off and unplugging the power cable for 10 minutes
post #12293 of 12311 Old 10-30-2019, 12:07 PM
Quoted: 25 Post(s)
Liked: 8
I reinstalled the application and did a soft reset. No change. I think this is a remote application bug. Code snippet describing the iOS error:
fb7f883b16f0","adam_id":982083188,"build_version": "4223","bundleID":"com.dm-holdings.Mz2014AVR","share_with_app_devs":false,"i s_first_party":false,"bug_type":"109","os_version" :"iPhone OS 13.2 (17B84)","incident_id":"8C7EDCAA-8D53-4868-899B-1F7A7B634C43","name":"Mz2014AVR"}
Incident Identifier: 8C7EDCAA-8D53-4868-899B-1F7A7B634C43
CrashReporter Key: 4ee0afac2767be29ede675861a2f681f73ec3a86
Hardware Model: iPad11,4
Process: Mz2014AVR [1626]
Path: /private/var/containers/Bundle/Application/E888A30F-3775-46DF-9F4D-61BA34BE5474/Mz2014AVR.app/Mz2014AVR
Identifier: com.dm-holdings.Mz2014AVR
Version: 4223 (3.3.0)
AppStoreTools: 11A1002b
AppVariant: 1:iPad11,4:13
Code Type: ARM-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: com.dm-holdings.Mz2014AVR [1157]
Date/Time: 2019-10-30 09:30:03.9888 +0100
Launch Time: 2019-10-30 09:29:59.2886 +0100
OS Version: iPhone OS 13.2 (17B84)
Release Type: User
Baseband Version: 2.02.12
Report Version: 104
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Triggered by Thread: 0
post #12294 of 12311 Old 10-30-2019, 12:58 PM
noah katz's Avatar
Liked: 766
Cables are a factor too, right?
I have an old 35' HDMI cable that only works at 4k/24 Hz; if I got the Ruipro fiber optic cable, might that enable all of my inputs to work?
If I understand correctly, the source can see through the entire HDMI signal chain to the end to ascertain what signal can be passed, so [far away input + Ruipro] might be a more robust overall path than [nearby input + old cable] - right?
Noah
post #12295 of 12311 Old 10-30-2019, 04:22 PM
jdsmoothie's Avatar
Liked: 12398
Correct on both counts.
noah katz likes this.
post #12296 of 12311 Old 10-30-2019, 06:41 PM
redsandvb's Avatar
Quoted: 70 Post(s)
Liked: 51
Sure, but is this still a problem on newer models?
Knowing nothing about the engineering/construction of these things, seems like something that could/would be fixed?
Thanks again
post #12297 of 12311 Old 10-31-2019, 01:31 AM
jdsmoothie's Avatar
Liked: 12398
Thanks again
No clue as HDMI is fickle, although perhaps better with release of HDMI 2.1.
post #12298 of 12311 Old 10-31-2019, 07:04 PM
redsandvb's Avatar
Quoted: 70 Post(s)
Liked: 51
Got it, Thanks again.
post #12299 of 12311 Old 11-04-2019, 03:54 AM
Quoted: 25 Post(s)
Liked: 8
Hi, do any of you use the Marantz app for iOS 13.2 (Marantz AVR Remote 2016 in the latest version)? After the last app update, my application unexpectedly shuts down when I try to turn on SR 7010 from stand by mode or use e.g. the cursor).
TrueDis likes this.
post #12300 of 12311 Old 11-06-2019, 01:54 PM
BobDyl's Avatar
Quoted: 124 Post(s)
Liked: 107
I do. It's definitely been a bit buggy of late. I have had to delete and reinstall the app, while also doing the *network reset* (see first page of posts on this thread) on the 7010. It works well for a couple days but then bugs out again. However, I know Marantz is still updating the app and were aware of several new iOS issues as of a couple weeks ago, so I'm hoping they will do another update.
BobDyl is online now
7010 , av7702mkii , hdmi marantz nr1506 , Marantz , marantz 7702 256gb ssd , marantz sr5010 , no sound , nr1506 , NR1606 , SR5010 , sr6010 , sr7010 , subwoofer
