*Official* Marantz 2015 NR-1506/1606, SR-5010/6010/7010 & AV7702mkII owner's thread - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 12658Likes
post #241 of 12466 Old 08-04-2015, 01:00 PM
HEELSFINL4's Avatar
Quoted: 53 Post(s)
Nr 1606 sound modes
Thanks again for the quick response. My front left and front right speakers are on stands. They may not have been directly angled towards where I usually sit. I made a mistake in my last post. The front left and right are definitive 2000 speaker. My surrounds are definitive 1000.
I will run audyssey again. Should the first spot I test be in the middle of the 6 spots or where I sit most often(kind of directly on line with the front right and directly below the surround right). Also, as far as the subwoofer goes, do I just keep at the volume I had it at, or do I move it to a specific spot before testing. There is control on the back of the subwoofer( not sure what it's for), and a control on the side of the subwoofer for volume I believe. Thanks again
HEELSFINL4 is offline
post #242 of 12466 Old 08-04-2015, 01:08 PM
jdsmoothie's Avatar
Quoted: 23659 Post(s)
Liked: 13022
1. Both. The main listening position (ie. mic #1 ) is where YOU sit most often and should be the center of your remaining mic positions. After the first mic position, all remaining mic positions should be no more than 1-2' from that ##1 mic position. Also to clarify, the DT Pro Center 2000 is a "center" speaker which you are apparently using for all three FL/C/FR speakers?
2. The sub volume knob should be placed about 9 or 10 o'clock. As long as the sub volume level is set to something other than -12db, you're fine. The sub volume knob should not be touched again unless you must lower it more to get below -12db. What model sub are you using?
jdsmoothie is online now
post #243 of 12466 Old 08-04-2015, 01:44 PM
HEELSFINL4's Avatar
Quoted: 53 Post(s)
Nr 1606 sound modes
Ok....I am going to get this right with regard to the speakers. The center is a definitive Pro center 2000. The left and right front speakers are definitive pro monitor 1000. The surrounds are pro monitor 800 and the sub is definitive pro sub 1000. Sorry about that.
I think my subwoofer volum setting is between 9 and 10, and when I ran audyssey before it gave me a setting of -7db. I will run audyssey again. My listening position is to the right as I explained, so I don't really have any place I can move the mic to to the right. I can move it to the left a little, and up and back a little.
Spoken voices are a little hard to understand at times and it sounds to me like there's a little too much bass. When I originally ran audyssey the left and right front settings were -2.5db and the center was -6.5 db. Thanks again for all this help
post #244 of 12466 Old 08-04-2015, 02:30 PM
jdsmoothie's Avatar
Liked: 13022
The sub volume is fine where it's at so no reason to change it. As you are seated to the right on the couch, suggest you angle the center speaker up towards your head height and to the right a little towards where you sit prior to running Audyssey again. If you cannot move the mic to the right, meaning you are seated against a wall, ensure the mic is no closer than 2' from the wall in which case you may have to move the mic positions to the left of your position a little. If you have Dynamic EQ enabled for the source that is "hard to understand" you can set the Reference Level Offset setting to -10db which will help improve the quality of the dialog from the center speaker.
post #245 of 12466 Old 08-04-2015, 02:41 PM
HEELSFINL4's Avatar
Quoted: 53 Post(s)
Nr 1606 sound modes
Thanks for the suggestions. For the dynamic eq setting, where do I find the 'reference level offset'? I will rerun audyssey when I get home later tonight with those speaker suggestions you mentioned.
post #246 of 12466 Old 08-04-2015, 04:06 PM
jdsmoothie's Avatar
Liked: 13022
Owner's manual, p. 165.
post #247 of 12466 Old 08-04-2015, 05:22 PM
HEELSFINL4's Avatar
Quoted: 53 Post(s)
nr 1606 sound modes
JD...I ran Audyssey again a few minutes ago with the suggestions you mentioned. The front l/r crossover was still 150 and the center was 110. The surrounds were 80. The levels were very similar to the prior measurements. When i did a speaker balance test with a sound meter though, all my measurements were in the mid to upper 60's and nowhere near the 75db reference mark. Do I simply turn the volume (when I measured it was at 75) up to reach the 75 or do I adjust each speaker? I would have to up each speaker quite a bit to get it to 75? Thanks
post #248 of 12466 Old 08-04-2015, 05:27 PM
jdsmoothie's Avatar
Liked: 13022
You must raise the master volume up to 80/0db if you want to measure the Test Tone level with a SPL meter. There's still something wrong though as those FL/FR speakers should normally be set to < 100Hz. Try using the setup mic from your Onkyo 609 (as it is compatible) and see if you get similar results.
post #249 of 12466 Old 08-04-2015, 06:24 PM - Thread Starter
steveting99's Avatar
Quoted: 1850 Post(s)
Liked: 652
Originally Posted by marijn View Post
Thank you. The problem is the available space at the back side of the receiver. Without antennas it should work and I have some space left for the cables.
The height is 170 mm so that should work. I will buy a fan for some extra cooling. Can I place this fan on the left side of the receiver? Will that be sufficient?
Hi marijn,
9mm of head space between the top of the receiver and the cabinet is a bit tight and will not provide sufficient space for heat dissipation. Heat rises from the top of the receiver and this needs to removed otherwise the temperature builds up and the receiver will go into thermal protection mode. It will shutdown at the time when one is watching a movie with large dynamics in the sound track. So you will need to have active cooling on all the time with your tight space.
Not sure if the feet of the receiver can be removed to provide an additional 0.5" (13mm) in head space.
You might want to consider the slimline model such as the NR-1606.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #250 of 12466 Old 08-05-2015, 02:33 AM
jdsmoothie's Avatar
Liked: 13022
Originally Posted by steveting99 View Post
Hi marijn,
It's never recommended to remove the feet of the AVR as there are ventilation holes on the bottom of the AVR as well which would be otherwise blocked if the feet are removed.
post #251 of 12466 Old 08-05-2015, 02:35 AM
jdsmoothie's Avatar
Liked: 13022
As Steve notes, 9mm (0.35") clearance above the AVR is woefully insufficient for ventilation. Suggest you try to relocate the AVR to another location if possible which will provide at least 50-75mm (2-3") clearance.
post #252 of 12466 Old 08-05-2015, 03:01 AM
Liked: 3
Hi marijn,
I understand that, but in my situation it is not possible to place the AVR in another location, or buy a slimline model because I use the pre-outs.
I want to buy these fans (here) and place them on each side of the AVR. Will that be sufficient?
marijn is offline
post #253 of 12466 Old 08-05-2015, 04:22 AM
jdsmoothie's Avatar
Liked: 13022
The slim-line models have Fl/FR pre-outs. However, if you have no other option, I'd start saving up for another AVR when this one dies an early death.
post #254 of 12466 Old 08-05-2015, 04:36 AM
Liked: 3
So even with fans you think the AVR's lifecycle will last shorter than normally?
marijn is offline
post #255 of 12466 Old 08-05-2015, 04:43 AM
jdsmoothie's Avatar
Liked: 13022
Most likely yes, but of course can't say with absolute certainty.
post #256 of 12466 Old 08-05-2015, 06:00 PM
jruser's Avatar
Quoted: 81 Post(s)
Liked: 33
I see the sr6010 now has an msrp listed at the beginning of the thread. Any idea of the Dac? If we dont find out I'll probably get the Yamaha a1050.
I took the sr5010 off the short list because of the lack of dsd over HDMI.
jruser is offline
post #257 of 12466 Old 08-05-2015, 06:17 PM
petetherock's Avatar
Quoted: 1757 Post(s)
Liked: 935
Was told that the 7010 / 7702 will hit our shores in Jan 2016!
You guys always get things ahead of everyone else ...
petetherock is offline
post #258 of 12466 Old 08-06-2015, 12:52 AM
jdsmoothie's Avatar
Liked: 13022
Same 24bit DAC as on the SR6009 which AFAIK is the TI Burr Brown 1690.
post #259 of 12466 Old 08-06-2015, 11:21 AM
nakedeye's Avatar
Quoted: 67 Post(s)
Liked: 24
I'm going form my old Onkyo 805 and I have a few questions. I currently have a 7.1 setup. Seeing as 95% of the stuff I will be playing is 7.1, I would like to find a receiver that does standard 7.1 but also will flip to Atmos 5.1.2 (or DTS X) when I play a track that supports it. I would then have the 7 regular and 2 height speakers up front. I understand the 2 surround back will be shut down on the 5.1.2 Amtos configuration and that is perfectly fine as long as when I play back any other surround track it goes 7.1 again and uses the surround back speakers. I have no problem using another amp (maybe even the 805) to power up things via the pre outs of a 5010 or 6010. Is there ANY recover out there that will do this? I would love to grab a 5010 and have it all set up tomorrow if I could!!!
nakedeye is offline
post #260 of 12466 Old 08-06-2015, 11:28 AM
jdsmoothie's Avatar
Liked: 13022
As the SR5010 only has 7 speaker posts, you'll have to step up to the SR6010 (Sep) for 11 speaker posts to include a dedicated set of Height 1 posts.
post #261 of 12466 Old 08-06-2015, 03:18 PM
nakedeye's Avatar
Quoted: 67 Post(s)
Liked: 24
Yeah I know that it can only handle 7 speakers at a time. I was hoping that I could drive the existing 7 speakers off the recover and then use the precut off the 5010 to a stereo amp to drive the Atmos/DTS X. Does the 5010 allow for the pre outs to be assigned differently than the amp posts? If I can assign the pre out surround back as Atmos heighth speakers and use the surround back posts off the amp when Atmos is not flagged, I will be all set on the 5010.
Don't get me wrong...I would love a 6010... They just aren't out yet!!!
nakedeye is offline
post #262 of 12466 Old 08-06-2015, 03:38 PM - Thread Starter
Liked: 652
jdsmoothie,
Would you know the DAC's used for the following 2015 Marantz receiver model numbers?
NR-1506
NR-1606
SR-5010
Will up-date the 1st page of this thread accordingly.
post #263 of 12466 Old 08-06-2015, 05:55 PM
jdsmoothie's Avatar
Liked: 13022
Not possible on D&M models.
post #264 of 12466 Old 08-06-2015, 05:56 PM
jdsmoothie's Avatar
Liked: 13022
jdsmoothie,
NR-1506
NR-1606
SR-5010
Likely the same 1690.
post #265 of 12466 Old 08-06-2015, 06:03 PM - Thread Starter
Liked: 652
^jd,
Thanks. Will up-date the posts accordingly.
post #266 of 12466 Old 08-06-2015, 06:14 PM
Liked: 935
Steve:
Any news of when the amps will hit HKG ?
post #267 of 12466 Old 08-06-2015, 06:22 PM - Thread Starter
Liked: 652
Originally Posted by petetherock View Post
Steve:
Will get in touch with the local dealer over the weekend and provide some feedback. I believe the NR-1506, NR-1606 and SR-5010 are available. Not so sure of the remaining units.
post #268 of 12466 Old 08-06-2015, 06:24 PM
Liked: 935
I usually visit Grancastle building for my hifi kicks.
If you know of other places, perhaps you can let me know?
We like to keep our options open in the land where everything costs a lot more...
http://www.dtvforum.info/index.php/t...-eg-singapore/
post #269 of 12466 Old 08-06-2015, 06:33 PM - Thread Starter
Liked: 652
Please note that the warranty is only valid locally here in Hong Kong so if there's any problems, you'll have to ship it back at your cost. If you're willing to take the risk the line voltage here in HK is the same at that of Oz (220VAC) so there's no step-up transformer required. I would say the pricing in HK is quite reasonable compared to Oz, but not as good as one can get from jdsmoothie in the states!
If you're interested in a particular Marantz model, I can ask them for a quote and if they're willing to ship across to land of Oz.
This is going a bit OT and will follow up with you via PM.
petetherock likes this.
post #270 of 12466 Old 08-06-2015, 11:13 PM
jruser's Avatar
Quoted: 81 Post(s)
Liked: 33
Did anyone happen to save the sr6010 manual while it was online? Wondering what the differences are between it and the x3200w. That $400 price difference between the two seems steep compared to the x2200w/sr5010.
jruser is offline
7010 , av7702mkii , hdmi marantz nr1506 , Marantz , marantz 7702 256gb ssd , marantz sr5010 , no sound , nr1506 , NR1606 , SR5010 , sr6010 , sr7010 , subwoofer
