Which banana plugs to use with Denon X4000 ? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 11 Old 06-15-2015, 02:42 AM - Thread Starter
ahmadka's Avatar
Quoted: 23 Post(s)
Hi everyone ... Can someone please tell me what type of banana plugs to use for connecting speaker cables to a Denon X4000 ? I have several different types of banana plugs from Monoprice but I don't know which one is compatible with the said AVR. X4000 seems to only support bare wire connections for speakers, but several threads on AVS state that it DOES support banana plug connections too. Can someone help me out ? Which banana plug type should I be using, or is there some 'hack' involved ?
ahmadka is offline
post #2 of 11 Old 06-15-2015, 02:54 AM
jdsmoothie's Avatar
Quoted: 22042 Post(s)
Liked: 11956
Either the "open" or "closed" banana plugs linked below will fit just fine.
http://www.monoprice.com/Product?c_i...seq=1&format=2
Also note there is a dedicated thread for the 2013 Denon AVR models linked below for more helpful information on your X4000 ....
https://www.avsforum.com/forum/90-rec...l#post23134210
jdsmoothie is offline
post #3 of 11 Old 06-15-2015, 03:18 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4791
Did you try and insert a banana plug and it was blocked by a little plastic plug? If so, pull out the little plug, something pointy like an awl worked on some gear I had that came plugged up like that...
lovinthehd is offline
post #4 of 11 Old 06-15-2015, 06:00 AM - Thread Starter
ahmadka's Avatar
Quoted: 23 Post(s)
I have those, but I don't see any way of fitting them into X4000's connection side :/
I know about that trick, but I don't see anything similar on an X4000 ..
ahmadka is offline
post #5 of 11 Old 06-15-2015, 06:04 AM
eljaycanuck's Avatar
Quoted: 1865 Post(s)
Liked: 2615
Originally Posted by ahmadka
... Can someone please tell me what type of banana plugs to use for connecting speaker cables to a Denon X4000 ? I have several different types of banana plugs from Monoprice but I don't know which one is compatible with the said AVR. ...
I have an AVR-X4000 and I've had no problem inserting banana plugs into the ends of the speaker-level terminals.
You have several types of plugs on hand - have you actually tried plugging any of them in? If 'yes', please describe what problem you're having with inserting the plugs.
lovinthehd likes this.
eljaycanuck is offline
post #6 of 11 Old 06-15-2015, 06:15 AM
tezster's Avatar
Quoted: 643 Post(s)
Liked: 541
Just to be clear, bare wires are inserted through the side of the speaker terminal, and banana plugs plug in from the back (like an RCA cable). I just switched from bare wire to banana plugs (Sewell Deadbolts) a few weeks ago on my X4000, and it only took me a few minutes to re-connect them.
tezster is offline
post #7 of 11 Old 06-15-2015, 09:10 AM
sjm817's Avatar
Quoted: 749 Post(s)
Liked: 298
+1 on the Deadbolts. Nice small, easy to assemble. I use them with an X2100W
sjm817 is offline
post #8 of 11 Old 07-02-2015, 03:49 PM
Liked: 0
Sewell banana plugs
slippin82 is offline
post #9 of 11 Old 07-02-2015, 04:01 PM
toddman36's Avatar
Quoted: 507 Post(s)
Liked: 182
Sewell deadbolts work great and are Cheap! I bought 2 packs of 12 prs each for 55.90 on Amazon!
toddman36 is offline
post #10 of 11 Old 07-02-2015, 06:33 PM
Quoted: 909 Post(s)
Liked: 645
Went with the Sewell Silver backs for $28 on Amazon
http://www.amazon.com/gp/product/B00...ilpage_o01_s00
kluken is offline
post #11 of 11 Old 07-03-2015, 02:46 AM
ThePrisoner's Avatar
Quoted: 345 Post(s)
Liked: 250
My mains & center speaker have locking bananas from Blue Jeans Cable and they work great. Rest of speakers have cheap Rocket Fish banana plugs which do work well.
ThePrisoner is offline
