Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 166 - AVS Forum | Home Theater Discussions And Reviews
 13225Likes
post #4951 of 8329 Old 03-12-2018, 08:33 PM
GoBig19's Avatar
I have a Mac, but used the iPhone app (with the iPhone internal mic) and it worked very well. rolldog, you might want to give the app a shot if you have an iPhone.
GoBig19 is offline
post #4952 of 8329 Old 03-13-2018, 04:33 AM
mbroadus's Avatar
Quoted: 1090 Post(s)
Liked: 432
Originally Posted by rolldog View Post
OK, thanks. By the way, regarding the other post, I too am using Blue Jeans HDMI cables, which are Premium Certified and can handle 18Gbps. His Monoprice cables only have 10Gbps of bandwidth, which isn't Premium Certified.
I honestly don't think my problem is the cables since I old Marantz receiver will pass 1080p60 but the Anthem MRX720 will not. The 720 has no problems passing 1080p on my appletv or ps4pro but maybe the 1080p60 is the culprit, who knows! Just seems really odd. I do have a mix of cables, some 10GB and some 18GB, but I guess this is a process of elimination until I find the culprit. Glad to see Blue Jeans is on Amazon so I can have them before the weekend. I just don't want to get a year down the road and have a new 4K TV and the 720 not be able to pass higher resolution 4K video. At least Anthem has a 3 year warranty. Other than that and learning new terminology, the AVR sounds fantastic, my wife even mentioned that she could hear subtle detail that she would have never heard on the Marantz.
Still no reply from Anthem technical support.
Problems could be:
1) New Cable box (XG1v4);
2) Cables;
3) Handshake issue; or
4) AVR.
Are the Blue Jeans FE cables fairly flexible?
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-205, Bluesound Node 2i, Focal Aria 936/CC900
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
mbroadus is offline
post #4953 of 8329 Old 03-13-2018, 05:37 AM
Bill-99's Avatar
Quoted: 861 Post(s)
Liked: 536
1080p60 seems like it could push the bandwidth requirements. Does anyone know how to calculate this? Some posts give general guidance for high speed cables but it would be nice to see the math and assumptions behind that recommendation.
"Fairly flexible" is perhaps a bit subjective. All of my HDMI cables are BJC Belden Series-FE but I don't put any hard angles on any of them -- at most, a big "U" shape -- preferring instead not to stress the cable or connection point. Sounds like you might have some cabinet or space constraints that create challenges. Can you confirm? If so, it would be interesting to see what others are doing to manage this.
mbroadus likes this.
Just one more upgrade and things will be perfect.
Bill-99 is online now
post #4954 of 8329 Old 03-13-2018, 06:03 AM
mbroadus's Avatar
Liked: 432
Agree regarding bandwidth. No hard angles but I do have to snake the cables around some corners in my BDI Ola cabinet. I have a few HDMI right angle adapters. Speaking of hard angles, anyone know if the right angle HDMI adapters degrade the signal quality?
Bill-99 likes this.
mbroadus is offline
post #4955 of 8329 Old 03-13-2018, 07:03 AM
rolldog's Avatar
Quoted: 602 Post(s)
Liked: 204
Originally Posted by Jonas2 View Post
I'm not a networking expert so don't know that I will be able to help you (experts, feel free to step in! ). I suppose with that error, it is possible something else is using that TCP port (I doubt it), but you can try changing it as Anthem recommends to 1025 or 49150 (page 30).
Are you connected directly to your router via ethernet, or are you connected wireless?
I have my Anthem hardwired into my network, while I'm using my Microsoft Surface Book 2 on WiFi. I checked the port settings on my router, and I don't have any else using this port. One thing the ARC software mentions when it starts up is to make sure that nothing else uses the receiver's IP control. Everything in my house is IP controlled since everything is running on a Control4 system. I wonder if this might be causing the issue? I could unplug any devices hooked up to the Anthem when I run ARC and see if this fixes the problem.
JVC RS4500K, Paladin DCR, Lumagen Radiance Pro, LG OLED W7, OLED E7, OLED C6, Sony A1E, Samsung QLED Q9F, QLED Q7F, Vizio P75c1, Marantz AV8805, Emotiva XPA-7 Gen 3, Integra DRC-R1, Anthem MRX 720, Oppo 203, Sunfire TGA-7401, Outlaw 5000, Triad Silver 7.1.4 Atmos setup, SVS PB16 Ultra, PSA 3601,SVS PB-13 Ultra, 31 Sonance VP88R, 6x6 Control4 4K HDR AV matrix, Control4 8 Zone AMP, Control4 EA-5, Control4 EA-1, QNAP TVS-882 & TS-451+
rolldog is offline
post #4956 of 8329 Old 03-13-2018, 09:06 AM
Jonas2's Avatar
Quoted: 2835 Post(s)
Liked: 1806
Certainly give it a shot by disconnecting everything else, process of elimination. Have you tried it on wifi exclusively? Disconnect it from the router and see if it will work wirelessly at least. Can't help you with the Control4 aspect, above my paygrade, though I do see on Anthem's support site something about drivers for the AVM60 and Control4. Dunno what that is.....looks to be categorized as Remote Codes, so likely not gonna help your issue if I were to guess. This all might be worth a call to Anthem.....
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #4957 of 8329 Old 03-13-2018, 10:52 AM
mofo666's Avatar
Quoted: 12 Post(s)
Noticed that the android app is finally working again for my 1120.
Go to Google play and type Anthem MRX 2 and it should come up.
You can control the unit from your phone now. (it's about time!).
With the recent firmware update and improved app everything seems to be working really well for me... I"m happy.
mofo666 is offline
post #4958 of 8329 Old 03-13-2018, 12:23 PM
mbroadus's Avatar
Liked: 432
After doing a hard reset of the MRX-720, can I reload my ARC calibrations or do I have to recalibrate? Thanks
mbroadus is offline
post #4959 of 8329 Old 03-13-2018, 01:06 PM
BGLeduc's Avatar
Quoted: 2652 Post(s)
Liked: 2521
You can reload.
mbroadus and terrspin11 like this.
BGLeduc is online now
post #4960 of 8329 Old 03-13-2018, 06:46 PM
mbroadus's Avatar
Liked: 432
Setting up the new 720 and the receiver will not pass 1080p60 video from the cable box to my Panasonic 60VT60, audio is fine. Will only pass audio and 1080i video. Works fine passing AppleTV 1080p, PS4Pro and Blu-ray. Also, I connected my previous receiver (Marantz) and it works fine on 1080p60. Pic of settings below. Suggestions?
So, I’ve done a little detective work. I took the HDMI cable that was connected from the 720 > Panasonic plasma and connected it directly from the cable box > Panasonic plasma and switched the resolution in the cable box from 1080i to 1080p60 and it has a great picture, not a single flicker.
I then did a system reset (select and main power buttons at the same time) and reconnected the 720 to the plasma and the same problem persists, 720 will not pass through 1080p60, only 1080i.
I can rule out the TV and cable box. So...is this an AVR, handshake or HDMI cable issue?
I’m so frustrated!!
mbroadus is offline
post #4961 of 8329 Old 03-13-2018, 07:07 PM
mbroadus's Avatar
Liked: 432
mbroadus is offline
post #4962 of 8329 Old 03-14-2018, 03:13 AM
markmon1's Avatar
Quoted: 5244 Post(s)
Liked: 3411
Originally Posted by MOberhardt View Post
Thanks. The manual is surprisingly unclear on what any of these are, and the options. I take it if you choose "DTS neural X" as the multi channel option, and you give it a Dolby 5.1 or 7.1 it will use neural X to upmix it, or would it only upmix if DTS? Not to mention there is also a separate "DTS Neural X mode" setting in the Input settings that has no mention in the manual other than the menu screenshot.
DTS Neural X is the DTS upmixer.
Dolby Surround is the Dolby upmixer.
Personally, I use "dolby surround" across the board for movie mode set in the input.
DTS and Dolby provide code libraries in the processor. The upmixer will upscale the content (whatever it is) to either atmos (Dolby surround) or DTS-X (dts neural x). If the content is 2 channel, it will upscale it to full atmos and does a pretty impressive job. You can walk around and hear things like only voices coming from the center etc.
The upscaler will pass through and not upscale dts-x or atmos when in say "dolby surround" mode and receiving say dts-x. So you can set something like dolby surround and just forget it.
Where you run into problems is if your source upscales first. For example, if you have a PC or xbox and installed the atmos app, then the source will send atmos to the receiver and since it receives atmos it will do no upscaling. Another example, you have your pc set to 7.1 sound and play back a mkv with AAC 2.0. Because AAC is not recognized by the receiver it will not be bitstreamed so the PC will decode it. Because it's 2 channel audio, the PC will populate the left and right front channels with the 2 channels from the AAC 2.0 sound track. Then the 7.1 output from the PC will get sent to your receiver with only front left and front right channels populated. The receiver will *not* upscale this because rather than receiving 2.0 audio, it's receiving 7.1 audio but with only 2 channels populated. The correct solution here is to set the PC in this case to 2.0 speaker setup then play back the sound track. Then the receiver receives 2.0 and does the full upscale.
Due to the above, you want to set your source where possible to 2 channel stereo and bitstream every known format. The ones that can't be bitstreamed get sent in 2 channel mode this way and get upscaled by the dolby surround upscaler.
mbroadus and MOberhardt like this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #4963 of 8329 Old 03-14-2018, 05:24 AM
briandx's Avatar
Quoted: 282 Post(s)
Liked: 108
I see in your signature you have the Paradigm Prestige 85F's. How long have you had them and what are your impressions? I've have mine about 2 weeks now.
Projector/Screen: Sony VPL-VW285ES; Da-Lite Cosmopolitan Electrol (92")
TV: LG OLED 65B6P
Amplification: Anthem MRX-1120; Aesthetix Mimas; Rogue Triton II
Sources: Pioneer UPD-LX500; Simaudio 260DT; Music Hall mmf-9.3; Goldring Eroica LX
Speakers: Wilson Yvette (L/R); Paradigm In-Walls (6); Hsu Research VTF-1 MK3 (2)
briandx is offline
post #4964 of 8329 Old 03-14-2018, 05:30 AM
jmacari's Avatar
Quoted: 290 Post(s)
Liked: 627
Thanks for this.....downloaded to my Tab....the remote works like a charm!
Anthem MRX-720,Outlaw 7500 5ch amp, B&K ST 202 amp
Oppo BDP-103, Sony XBR-65X930D, Rotel RP-855, Phillips BDP-7501
Paradigm Studio 100 Fronts, Martin Logan Motion LX16 rears,Martin Logan Motion 2's
Paradigm Studio cc-590 Center, Martin Logan Dynamo subwoofer, DefTech Supercube 4000
Roku Ultra, DIRECTV 4K Genie HR-54 DVR, C61K-700, OPPO Sonica DAC, Amazon Fire TV
jmacari is offline
post #4965 of 8329 Old 03-14-2018, 05:33 AM
briandx's Avatar
Quoted: 282 Post(s)
Liked: 108
OK this is really weird. I have had a "bootleg" copy of this app for my Samsung phone for three months (Anthem sent me a copy). Well that version has been working just fine, but I was waiting for the "official" version to come out. I loaded the official version and it works, however there is something missing: My bootleg version has two addition settings screens that you can access my swiping to the right. These include pretty much every control you could want. I don't see this in the new version. Just a single page.
Anthem: Is this an issue?
Newbie789 likes this.
TV: LG OLED 65B6P
briandx is offline
post #4966 of 8329 Old 03-14-2018, 06:15 AM
mofo666's Avatar
Quoted: 12 Post(s)
Can you be more specific about the missing controls? From what I can see I can do everything the app used to be able to do and what the remote does. What I like about the app is that is displays the bitrate of the sound when you use it for tv.
mofo666 is offline
post #4967 of 8329 Old 03-14-2018, 06:44 AM
Jonas2's Avatar
Liked: 1806
Love 'em! Especially the 55C center. I think they sound great in my space, and the look works for me and the missus. Although not a perfect speaker, they offer tremendous performance for the price point in my opinion.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #4968 of 8329 Old 03-14-2018, 07:22 AM
briandx's Avatar
Quoted: 282 Post(s)
Liked: 108
Can you be more specific about the missing controls? From what I can see I can do everything the app used to be able to do and what the remote does. What I like about the app is that is displays the bit-rate of the sound when you use it for tv.
OK this is weird and may be only an issue on my phone as I had a bootleg copy to start with.
When I first installed the official app it of course showed up on my home page, and was named "Anthem MRX 2". When I opened it only the first page was accessible (Input / Volume / Zones).
So now when I look at my home page the app is called "Anthem MRX" (The "2" has dropped) and it has the same three pages my bootleg version has.
Well never mind I guess... As long as the official version has three separate screen I am good to go.
TV: LG OLED 65B6P
briandx is offline
post #4969 of 8329 Old 03-14-2018, 01:16 PM
MOberhardt's Avatar
Quoted: 917 Post(s)
Liked: 587
Where do you get the working remote? I got sent one from anthem but it wouldn't load on my tablet (not sure what Android version the beta supports, or if they sent me a dud apk).
MOberhardt is offline
post #4970 of 8329 Old 03-14-2018, 06:05 PM
mbroadus's Avatar
Liked: 432
You mean the remote app, I downloaded mine from the App Store. I downloaded both of them and deleted the one that didn’t work.
mbroadus is offline
post #4971 of 8329 Old 03-14-2018, 06:18 PM
MOberhardt's Avatar
Quoted: 917 Post(s)
Liked: 587
Ah, you are talking the Apple version. They haven't updated the android one on the google store since 2014...
post #4972 of 8329 Old 03-14-2018, 07:04 PM
mbroadus's Avatar
Liked: 432
Yes...wow, that’s unfortunate!
mbroadus is offline
post #4973 of 8329 Old 03-14-2018, 08:40 PM
jmacari's Avatar
Quoted: 290 Post(s)
Liked: 627
Yes they have. I downloaded it for my Samsung Galaxy Tab yesterday from Google Play (search for Anthem-downloaded latest version); Works great, all 3 pages for the App; as I said in my post #4964 .....
jmacari is offline
post #4974 of 8329 Old 03-14-2018, 08:45 PM
MOberhardt's Avatar
Quoted: 917 Post(s)
Liked: 587
Ah right I see there are two separate ones listed now - The Anthem MRX Remote by Anthem Electronics, and the new one by Paradigm Electronics.
post #4975 of 8329 Old 03-16-2018, 06:07 AM
Liked: 0
For me neither of the two android apps work. The old one just endlessly tries to connect, the new one permanently gives me "device disconnected" errors.
wow_deathbringer is offline
post #4976 of 8329 Old 03-16-2018, 08:11 AM
Jonas2's Avatar
Liked: 1806
Yeah, just downloaded the iPhone app last night, was surprised to see how FAST it found the AVM, compared to other apps I have looking for their corresponding devices. It's pretty cool actually. Does what I expect of it, though my preference is for the actual remote since I've got line of sight right to the AVM. Might use the app more at night...
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #4977 of 8329 Old 03-16-2018, 08:19 AM
BGLeduc's Avatar
Liked: 2521
I normally would not need an App based remote, but have found a good use for it.
I have my Sony X800 connected using both HDMI outputs. HDMI1 is for video only and goes directly to my display, and HDMI2 is audio only going to the Anthem. Long story as to why I am bothering with that, but suffice to say it relates to display input tweaking for SDR converted 4K/HDR content on my non-4K Panny Plasma.
Since I can't see the Anthem GUI on the display over that input, the remote app lets me tweak things on the fly without having to change inputs on the TV, which is seriously bad show when watching a film with the family unit. I can tweak like crazy and no one need know.
MOberhardt and Jonas2 like this.
post #4978 of 8329 Old 03-16-2018, 10:12 AM
Bill-99's Avatar
Quoted: 861 Post(s)
Liked: 536
That is one cool looking right angle adapter. I don't need one with my gear today but it's nice to know such products exist.
post #4979 of 8329 Old 03-16-2018, 10:48 AM
Bill-99's Avatar
Quoted: 861 Post(s)
Liked: 536
I’m so frustrated!!
HDMI cables are such a pita. Can't wait for the move to HDMI 2.1!
You mentioned having a mix of 10GB and 18GB cables. Have you tried using only the 18GB cables on the entire path that's giving you issues?
BTW it might prevent some headaches by upgrading all of your cables to certified high speed as Anthem calls out pretty much as a requirement on page 10 of the manual. While the old cables seem to work well with other gear, Anthem gear seems fussier about this. It doesn't have to be expensive, either. Monoprice sells a 3' certified premium high speed cable for about $4. I've been using Blue Jeans Cable Belden Series-FE which is also certified high speed and it works well. (No, this is not an ad.)
All of that said, replacing cables isn't guaranteed to fix your issue, but it would eliminate a potential source of problems.
How long are your HDMI runs?
post #4980 of 8329 Old 03-16-2018, 11:32 AM
Erod's Avatar
Quoted: 1274 Post(s)
Liked: 789
You may not need to buy 2.1 cables when it's time anyway: https://www.techhive.com/article/325...cy-cables.html
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: RBH SV-661R and SV-661CR fronts, Jamo 626k4 side/rear surrounds, DefTech DI6.5R heights
Erod is offline
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
