Owner's Thread for Anthem 60, 720 and 1120 Receivers - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 13683Likes
post #5041 of 9315 Old 03-24-2018, 03:06 PM
madrac's Avatar
Quoted: 133 Post(s)
Liked: 96
Originally Posted by mbroadus View Post
Great info...thanks! Are you using ARC for 2CH analog too or is that even a possibility?
Yes, you can use ARC for 2CH. It can be turned on or off in the input set up.
I am currently using it with my Turntable input.
madrac is offline
post #5042 of 9315 Old 03-24-2018, 06:33 PM
The Dark Knut's Avatar
Quoted: 17 Post(s)
HELP Firmware Update Problem
Need some guidance if anyone else ran into this while trying to update the firmware. I have the MRX 1120 and everything was updating correctly and then when it got to the MCU update it stops at 49% and then a File Error .fw comes up on the panel. I have deleted the file on the USB and reinstalled and it automatically starts at MCU update and errors after 49% every time. I have to unplug the unit because it stays on now and is unresponsive with the File Error .fw displayed.
I tried a hard reset and the unit boots right up looking for the USB update. There is no way around this. Anyone else run into this or know a workaround or solution?
Repetition penetrates even the dullest of minds.
The Dark Knut is offline
post #5043 of 9315 Old 03-24-2018, 07:57 PM
mbroadus's Avatar
Quoted: 1232 Post(s)
Liked: 514
Are you using Anthem Logic Music?
Panasonic P60VT60 Calibrated by Chad B
Anthem MRX-720, Oppo UDP-203, Bluesound Node 2i
Focal Aria 936/CC900, SVS SB-3000
MacBook Pro, AppleTV 3 & 4K, Sony PS4 Pro
Zero Surge 8R15W-I
mbroadus is offline
post #5044 of 9315 Old 03-25-2018, 09:46 AM
Jonas2's Avatar
Quoted: 3075 Post(s)
Liked: 2055
Have you tried re-downloading the file onto a different USB drive? That'd be the first thing I'd try.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #5045 of 9315 Old 03-25-2018, 12:32 PM
Quoted: 17 Post(s)
Which brand or model do you recommend or has worked for you? The last one I bought and tried was Sandisk Cruzfit.
post #5046 of 9315 Old 03-25-2018, 12:40 PM
Tristan944's Avatar
Quoted: 77 Post(s)
Hi guys, new to the thread. I have the MRX 1120. Do either of the USB ports support external hard drive media files, like playing movies or music on an external hard drive?
My Blu-ray player supports this function but freezes a lot and I'm looking for a different media player.
Sound: Anthem MRX-1120. Triad Silver speakers with Atmos and SVS PB-2000 subwoofers in 5.2.2. Sony UBP-X800. Roku Ultra. Amazon Fire TV. Micca Speck G2. ViewTV AT-263.
Picture: Epson 6040UB. Seymour Enlightor 4K 140 inch screen. Audioquest Forest HDMI.
Automation: Control4
Space: Dedicated theater room. Two Jerome's Challenger sofas.
Tristan944 is offline
post #5047 of 9315 Old 03-25-2018, 12:41 PM
Bill-99's Avatar
Quoted: 1024 Post(s)
Liked: 659
Re: firmware updates... not a fan of this interface.
Anthem seems to have a love / hate thing for USB sticks. Some people have bad luck with USB 3.0 memory sticks in general, others seem to skate by. Some seem to have good luck with USB 2.0 memory sticks but not all. It feels haphazard. If this unit is that fussy, why didn't Anthem include one that should work in the box? I mean, seriously, the cost of a memory stick is a rounding error on this transaction! But enough of my whining.
I've had good luck with an ADATA S102/16GB USB 3.0 formatted as FAT32. So far.
5.1.4 System: Anthem AVM 60 | Anthem Statement A5 | ATI AT526NC | Revel F208, C208, M106, C763L | Velodyne FSR-12 | Samsung UN65KS800DF | Oppo UDP-203 | Roku Premiere+ | DIY HTPC | Logitech Harmony Companion | Amazon Echo Dot
Bill-99 is offline
post #5048 of 9315 Old 03-25-2018, 12:47 PM
Bill-99's Avatar
Liked: 659
I don't think so. The manual says the one on the front is for firmware updates, and the one on the back is for factory service.
Bill-99 is offline
post #5049 of 9315 Old 03-25-2018, 01:08 PM
Quoted: 17 Post(s)
Bill-99 so true! I can't begin to express how frustrating this is and to have to trial and error different USB sticks to hopefully find one that works is beyond upsetting for something at this price point. And to top it off I had it all dialed in and will have probably lost all my settings.
I'll look for ADATA S102 USB and give it a shot. Thanks!
post #5050 of 9315 Old 03-25-2018, 01:47 PM
Tristan944's Avatar
Quoted: 77 Post(s)
Can the firmware be updated over Ethernet or wifi?
Was there a new firmware released recently?
post #5051 of 9315 Old 03-25-2018, 02:14 PM
Jonas2's Avatar
Liked: 2055
I would think that'd work! FWIW, I've used a variety, but mostly "junk" ones that I can't identify or super-cheap no-names. Never had an issue, go figure. They've never been larger than 4GB, though that should not be important, and USB 2.0.
Na, I hear you! I'd wish the thing could be done by wifi, but earlier in this thread (or the AVM60 thread?), there were some good points as to why not, and that most wouldn't find it a deal-breaker. I think Anthem should invest the extra $5.00 it might take to do this via wi-fi, but wi-fi in general just does not strike me as Anthem's area of expertise. Yes, cynical by nature I am.
Newest firmware dated late Jan., 2018.
USB only for updates.
Bill-99 likes this.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #5052 of 9315 Old 03-25-2018, 02:33 PM
BGLeduc's Avatar
Quoted: 2736 Post(s)
Liked: 2650
No.
Yes.
BGLeduc is offline
post #5053 of 9315 Old 03-25-2018, 02:41 PM
mbroadus's Avatar
Liked: 514
Currently watching Mr. Robot series on Amazon Prime via AppleTV 3 outputting 2.0 PCM and it sounds fantastic. I thought 2.0 PCM was stereo but its uncompressed digital audio with lots of mid and bass response. Read it was closer to TrueHD audio and better than DD and DTS.
Zero Surge 8R15W-I
mbroadus is offline
post #5054 of 9315 Old 03-25-2018, 02:51 PM
Tristan944's Avatar
Quoted: 77 Post(s)
No.
Yes.
What improvements were released?
Will it erase any current settings?
post #5055 of 9315 Old 03-25-2018, 04:48 PM
Quoted: 17 Post(s)
[QUOTE=Jonas2;55919298]I would think that'd work! FWIW, I've used a variety, but mostly "junk" ones that I can't identify or super-cheap no-names. Never had an issue, go figure. They've never been larger than 4GB, though that should not be important, and USB 2.0.
Just bought and tried another USB stick 3.0 reformatted fat32 and did a fresh download and extraction and still errors out at 49% MCU update. Holding down SELECT and MAIN POWER does nothing. Unplugged and cycled power button does nothing. I think this firmware update has completely bricked my Anthem MRX 1120
Anyone have experience with Anthems support and turnaround time?
post #5056 of 9315 Old 03-25-2018, 05:35 PM
Jonas2's Avatar
Liked: 2055
[quote=The Dark Knut;55920030]
Their support is excellent. Call them, don't email. My experience has been that they are pretty quick on email, but you get a live tech. in short order on the phone, and no need to worry about a delayed email back and forth.
The Dark Knut likes this.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #5057 of 9315 Old 03-25-2018, 06:14 PM
Roger Dressler's Avatar
Quoted: 3278 Post(s)
Liked: 2045
Does the AppleTV device identify the audio codec? Does it sometimes report AAC? Can you switch the audio output in the ATV from PCM to Bitstream? Not sure why you only get 2.0. The series was mixed in 5.1.
2.0 is also known as stereo. Any audio codec, once decoded, outputs PCM.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #5058 of 9315 Old 03-25-2018, 06:54 PM
mbroadus's Avatar
Liked: 514
From what I understand, Amazon video does not support 5.1 audio on iOS devices. Apple TV firsts decodes the stream, and then outputs raw PCM to HDTV via HDMI.
Zero Surge 8R15W-I
mbroadus is offline
post #5059 of 9315 Old 03-25-2018, 07:04 PM
Liked: 2045
Isn't the iOS device just used to navigate/select the title, then establish streaming through the AppleTV? If so, no reason the 5.1 should not make it to your Anthem.
That's how it works for me -- I use an Android phone to select Netflix shows that stream via Chromecast into the Anthem HDMI as 5.1 DD+. The phone never touches the content at all.
Anyway, I suspect we are wearing out our welcome on this Amazon topic in an Anthem thread.
post #5060 of 9315 Old 03-26-2018, 01:03 AM
markmon1's Avatar
Quoted: 6275 Post(s)
Liked: 4371
Not sure where you read this, but it's pretty much all wrong.
Anthem shows 2.0 PCM when the input is 2 channel decoded audio. The source of that 2 channel audio could be anything from high quality wav to low quality aac. You don't know. Also stereo and 2 channel are synonyms.
2 channel audio can sound pretty good and the anthem does a great job upscaling it to 5.1, 7.1 or atmos.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is online now
post #5061 of 9315 Old 03-26-2018, 04:38 AM
mbroadus's Avatar
Liked: 514
True...Amazon PrimeVideo is the only app on my AppleTV that does not output 5.1 DD or DTS, only PCM audio. From what I've read on Apple Insider, "Amazon updated the Amazon Prime Video app for 5.1 sound in 4K programming. Amazon claims that the audio improvements for HD and SD streamed content are coming soon."
Anyway, the Anthem MRX-720 does a great job upscaling 2.0 PCM audio, it sounds fantastic!
Zero Surge 8R15W-I
mbroadus is offline
post #5062 of 9315 Old 03-26-2018, 06:39 AM
Quoted: 29 Post(s)
Very happy new owner of the Anthem MRX 720 here... upgraded over the weekend from a Denon X4300 and very pleased with the upgrade in sound quality, processing, and the ARC is far superior to Audyssey as well.
I was hoping someone here could give me a quick and easy answer to this question:
I am running a Dragonfly Red DAC into the analog input 1 of the Anthem to listen to lossless music. I've set the input to no processing, so it's just transmitting the untouched analog audio from the DAC.
However this also bypasses the digital crossover and does not allow me to use my sub for unprocessed analog audio, which I kind of need.
My sub is an SVS SB-2000, which has left (LFE) and right RCA inputs and a HPF at the sub.
What I'm thinking is... Is it possible to run the unprocessed (full range) analog out from the Anthem main pre-outs into my power amp, and run an unprocessed analog out signal from the right channel of Zone 2 at the same time... run the Zone 2 out into the unused RCA on the SVS sub, and manually set the crossover there?
For this profile there would be no digital audio out into the left channel of the SVS so no worries of crosstalk from competing signals. I will have to manually adjust the crossover at the sub every time I listen to the DAC, but this is not an issue. A full range signal will also be sent from the main pre-outs into my amp, so there will be some duplication of bass in the front speakers - not sure how much of an issue this will be but I assume manually adjusting the output at the sub could compensate.
Is this the best way to achieve this, and if so, what settings in the Anthem should I be aware of to make this happen?
Or is there a better way to send an unprocessed analog signal out of the Anthem and still make use of a subwoofer?
JFHSQT is offline
post #5063 of 9315 Old 03-26-2018, 07:56 AM
Licensed2bill's Avatar
Originally Posted by briandx View Post
I did the exact same thing with my 1120 / UDP-205 combo. I settled on Coax out from the 205 and into the 1120. I created a separate input on the 1120 which uses the analog inputs, bypasses digital processing, enables the two front speakers and subs only, and bypasses ARC. I ran a series of tests and this was the combo I settled on.
Hey Briandx:
I'm in Middletown, Delaware. I tried to PM you about your setup but it says you are not accepting PMs. I would love to talk to you about your equipment. If you are willing, could you please PM me or email me at kmbaird (at) hotmail (dot) com.
Kevin
Licensed2bill is offline
post #5064 of 9315 Old 03-26-2018, 08:11 AM
BGLeduc's Avatar
Liked: 2650
Originally Posted by Licensed2bill View Post
Hey Briandx:
Kevin
Not Briandx, but I am curious how the Anthem can be sending a signal to the sub if digital conversion and processing of the analog input is disabled. From the manual:
PROCESS ANALOG AUDIO INPUT
If changed to No, digital conversion and signal processing are bypassed. Only level adjustments will be available.
BGLeduc is offline
post #5065 of 9315 Old 03-26-2018, 08:38 AM
Quoted: 45 Post(s)
I am getting 5.1 for grand tour and sneaky Pete...
Sent from my iPhone using Tapatalk Pro
Main: YouTubeTV -> Apple TV 4k -> Anthem MRX 720 (5.1.2 DTS:Neural X) <-> Sony 65A1E
Den: Apple TV -> Pioneer Kuro PDP-5010FD
DTS beats Dolby.
purduelion is offline
post #5066 of 9315 Old 03-26-2018, 08:40 AM
Quoted: 29 Post(s)
Just chiming in here but my understanding is this is not possible. If you are using the Anthem's digital crossover to send a signal out of the subwoofer pre, the analog is being re-digitized and re-converted by the Anthem DAC, which means no benefit from the Oppo DAC. This was the issue I struggled with as well.
BGLeduc likes this.
JFHSQT is offline
post #5067 of 9315 Old 03-26-2018, 09:09 AM
briandx's Avatar
Quoted: 282 Post(s)
Liked: 108
Hey Briandx:
Kevin
Hi Folks. First off, I'm not sure why my ID is not accepting PMs, as I have triple-checked my settings and PMs are not disabled as far as I can tell.
Kevin, I will email you shortly....
Projector/Screen: Sony VPL-VW285ES; Da-Lite Cosmopolitan Electrol (92")
TV: LG OLED 65B6P
Amplification: Anthem MRX-1120; Aesthetix Mimas; Rogue Triton II
Sources: Pioneer UPD-LX500; Simaudio 260DT; Music Hall mmf-9.3; Goldring Eroica LX
Speakers: Wilson Yvette (L/R); Paradigm In-Walls (6); Hsu Research VTF-1 MK3 (2)
briandx is offline
post #5068 of 9315 Old 03-26-2018, 09:11 AM
briandx's Avatar
Quoted: 282 Post(s)
Liked: 108
You are probably correct here.
I have only owned my new Paradigm L/R full range speakers for a couple of weeks, and the bass I am feeling is probably coming from those speakers and not my two subs. My old L/R speakers were in-wall and had very little bass response.
TV: LG OLED 65B6P
briandx is offline
post #5069 of 9315 Old 03-26-2018, 09:17 AM
lunnar's Avatar
Quoted: 59 Post(s)
Liked: 42
Originally Posted by markmon1 View Post
Yea if it was 100% pure pass through then the EDID from the display is what would show up not the one from the Anthem. I think those HUD settings don't make any difference.
I that is what I was expecting, and sure enough, this week I had 2 lock up. so I am back to Extended display. I wonder if I could use an HDMI splitter...
-Lunnar
"Tempo is everything, perfection unattainable..."
lunnar is offline
post #5070 of 9315 Old 03-26-2018, 10:28 AM
mbroadus's Avatar
Liked: 514
Are you watching in 4K?
Zero Surge 8R15W-I
mbroadus is offline
24bit/192kHz , 24bit/96khz , Anthem , anthem mrx720 , anthem triad in-wall subwoofer , atmos , firetv , hi res audio , mrx 1120 mrx 720 mrx 520 , MRX720 , [email protected] , Xbox
